Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 454 - AVS Forum | Home Theater Discussions And Reviews
 2095Likes
Old 02-25-2015, 06:15 PM
artur9's Avatar
Quoted: 621 Post(s)
Liked: 217
Originally Posted by jim19611961 View Post
I would be more concerned about what I am seeing at 200-300hz. +30-35ms at those frequencies looks like a problem to me. Why don't you post the whole FR range (and change the scaling)
I don't have a recent full FR. I'll try and do one in the morning.
Is this measurement just a single speaker, single speaker and subs or something else?
artur9 is offline
Old 02-25-2015, 06:26 PM
jim19611961's Avatar
Quoted: 449 Post(s)
Liked: 153
Since I was focused on the bass region, the measurement I posted is all mains and all subs.
I also think 1/48th smoothing would be better for full range analysis.
Name:	whole GD 1 48th.png
My Room
My Music
Rega - Apollo, Rega - DAC, Goldpoint Passive, Classe CA-100, Crown XLS 1002, miniDSP
Jenzen Next
jim19611961 is offline
Old 02-25-2015, 09:16 PM
Greenwood Ave's Avatar
Quoted: 184 Post(s)
Liked: 161
Originally Posted by Soulburner View Post
What does it mean if my speakers start to crackle after a couple of measurements? Crackles through the whole sweep. It did the same thing during SPL calibration. If I wait a couple minutes it's clean again. Don't tell me it's the AVR...
I had a similar sound while running one of the beta versions on my MacBook Pro. Updating to the most recent version made it go away.
Greenwood Ave is offline
Old 02-25-2015, 09:20 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 7150 Post(s)
Liked: 3988
Just to clarify, is this the sound you are hearing?
REW Sweep Distorted Sound
AustinJerry is offline
Old 02-25-2015, 09:35 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 382
Similar, but a bit more crackly and it definitely screwed up the graph. I'll play with it again tomorrow and see if I can recreate it. I now have the X4000 hooked up so I'll know if it's the AVR.
Soulburner is offline
Old 02-25-2015, 09:50 PM
Liked: 3988
If it is the same sound, it is not the AVR, which should put you at ease. It is a bug in the ASIO driver. I have reported it on the Home Theater Shack REW forum, but have never received an acknowledgement or response from JohnM.
If the distorted tone occurs, you can clear it by opening the Preferences page and toggling the Output and Timing Reference fields with different selections several times. It is a very annoying problem, and it affects many of us.
Old 02-25-2015, 11:07 PM
Rod2486's Avatar
Quoted: 119 Post(s)
Liked: 57
I showed a graph on the last page of a peak around 10hz that is constant with my graphs. In my room of 12X18X8 that opens through a small hallway to a kitchen on the front left of the room, and a small walkway to bedrooms in the right corner of the room. I dont see this room causing a peak like this and it doesnt matter where I put the mic in the room. Its always there. I believe I may have a UMIK issue.
Well I turned off my subs and ran some sweeps with just my main L/R speakers. They were run configured Large. They are Salk Songtowers with a frequency response of 42hz-20000hz. As you can see in the graphs is that even with the main speakers I still get a peak down in the 10hz area. I dont feel these speakers should have anything going on down there room dependent or not. You guys are more knowledgeable with that than me so you guys decide.
The first graph is of me testing left and right speakers separately. The second graph is of both speakers running at the same time and a average of the left and right speakers.
Name:	full range speaker - left and right.jpg
ID:	569401   Click image for larger version
Name:	Full range speaker - no sub - averages.jpg
Rod2486 is offline
Old 02-26-2015, 12:29 AM
3ll3d00d's Avatar
Quoted: 1636 Post(s)
Liked: 601
Depends how excessive the low frequency GD/Phase delay is. As previously stated, going from 60+ms GD to 30ms (40hz) was quite noticeable. But I agree that problems like this at higher frequencies definitely need attention.
did you change that without impacting frequency response?
BTW, whats that at 110hz on your graph?
2nd width mode (so varies by seating position significantly). You can see the effect more clearly on the phase graph, remember that GD is the slope of the phase response so you can see that the mode around 40Hz was causing a substantial phase rotation which is removed after correction & also that an attempt has been made to tackle the phase rotation around the 2nd width mode as it now just oscillates slightly rather than wrapping.
However note that SPL was not affected, the sharp null is still there.
I think this is a good example of where the GD chart alone is misleading and that you need to consider what is actually happening in the phase & frequency response to get a fuller picture. I think you also need to consider similarity of response across channels. There's a video of the trinnov people around (part 1 is
and there are parts 2 and 3 on youtube as well) where they talk about consistency of phase response across channels along with smooth changes as opposed to an absolute phase target. Intuitively this makes sense given that your ears are using interaural phase differences to image hence discontinuities between ears are presumably undesirable.
I'll see if I have a graph for that later.
ID:	569585   Click image for larger version
3ll3d00d is offline
Old 02-26-2015, 03:58 AM
3ll3d00d's Avatar
Liked: 601
Is this just the GD tab in REW? If so, here's mine. I have a room mode at 31Hz but I do not understand why the group delay would be negative.
AIUI group delay is not an actual absolute time delay unless the delay is constant, it is instead a measure of the relative delay of different frequencies within the envelope. I think it also means it can only be calculated for a steady state signal and I'm not sure whether it directly applies to transient content.
Technically it's the negative derivative of the phase response hence it is a measure of the rate of change in the phase response & hence why looking at the phase response can be informative to see what underlies that GD graph. This means a negative group delay is possible when the phase response does weird things and that is exactly what happens when your measurement captures the direct sound and reflected content. It also means the group delay view of an in room measurement will be seriously affected by how you window that response hence then the Q is which view is the "right" view (as usual but worth pointing out).
There's an interesting thread on the subject here -> http://www.audiocircle.com/index.php?topic=24932.0 (though pictures no longer there)
3ll3d00d is offline
Old 02-26-2015, 04:43 AM
markus767's Avatar
Quoted: 3894 Post(s)
Liked: 1392
I would be more concerned about what I am seeing at 200-300hz. +30-35ms at those frequencies looks like a problem to me. Why don't you post the whole FR range (and change the scaling) like this:
Don't forget that this data probably contains all room interaction so the GD plot is misleading. Our hearing gets better at separating direct from reflected sound as frequency is rising. One would need to use a sliding window on the IR in order to get more meaningful GD readings.
3ll3d00d and IgorZep like this.
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
Old 02-26-2015, 05:23 AM
artur9's Avatar
Quoted: 621 Post(s)
Liked: 217
Here it is. Looks terrible.
artur9 is offline
Old 02-26-2015, 06:31 AM
Liked: 3988
Originally Posted by 3ll3d00d View Post
simplest way to do that in REW is generally to import an appropriate FRD file
mine is attached, blue is pre EQ, purple is post.
Attachment 568177
Here is a GD graph from my system, with Dirac Live RC. What does it tell us?
Old 02-26-2015, 07:04 AM
cuzed2's Avatar
Quoted: 198 Post(s)
Liked: 254
Jerry,
OK I'll take a shot (with the qualifier - that I need to learn about the GD feature).
However, my guess:
There are issues at 35, 40, and 78 Hz.....?
Cuzed2
CuznEddy Cinema
cuzed2 is offline
Old 02-26-2015, 07:22 AM
cuzed2's Avatar
Quoted: 198 Post(s)
Liked: 254
Jerry,
However, my guess:
Jerry,
Disregard my comments above.
With just a bit more reading >> What your graph tells me is I have a LOT to learn about GD
Cuzed2
CuznEddy Cinema
cuzed2 is offline
Old 02-26-2015, 07:23 AM
Liked: 3988
Jerry,
However, my guess:
Other than you picked three spots where the graph shows dips, "issues" doesn't say much.
Edit: Saw your update, so never mind.
Old 02-26-2015, 07:31 AM
artur9's Avatar
Quoted: 621 Post(s)
Liked: 217
I'm curious, if you compare with no Dirac, if it'll show that Dirac is adding 10ms of GD.
artur9 is offline
Old 02-26-2015, 07:33 AM
artur9's Avatar
Quoted: 621 Post(s)
Liked: 217
I wonder if it'll look better if I only do L or R or C?
With all subs and L+R maybe the messiness is from that and all the under-treated reflections.
artur9 is offline
Old 02-26-2015, 07:36 AM
Quoted: 449 Post(s)
Liked: 153
L+subs
Black = Before
Blue = After
GD
Phase
Name:	ba phase.png
FR
My Room
My Music
Jenzen Next
Old 02-26-2015, 07:44 AM
Quoted: 449 Post(s)
Liked: 153
Like when doing FR, running all mains and subs will look skewed unless the mic is EXACTLY the same distance from the higher frequency sources. If not, I would definitely look at L+subs, R+subs separately.
My Room
My Music
Jenzen Next
Old 02-26-2015, 07:47 AM
artur9's Avatar
Quoted: 621 Post(s)
Liked: 217
If I read it correctly the phase blog I mentioned yesterday says there's 0.1mm or such of wriggle room :-)
artur9 is offline
Old 02-26-2015, 07:48 AM
3ll3d00d's Avatar
Liked: 601
AFAIK the Dirac filter is not long enough to be able to perform non minimum phase correction at those frequencies hence any impact on GD will be via the effect of taking out minimum phase room issues. Why do you think it will add a specific amount of GD? (given that that would imply a step change in the phase response at some specific frequency)
3ll3d00d is offline
Old 02-26-2015, 07:53 AM
3ll3d00d's Avatar
Liked: 601
the thing that stands out from the FR is that it rolls off a little earlier and is that smoother through the lower (for music) bass. I would think that that would be the audible aspect over and above the reduced pace of phase rotation through the 40-60Hz range. What did you actually do to implement that change?
3ll3d00d is offline
Old 02-26-2015, 07:55 AM
3ll3d00d's Avatar
Liked: 601
I would argue not much more than you probably have a sealed sub and that you have a fairly normal, but recently controlled, room.
3ll3d00d is offline
Old 02-26-2015, 07:56 AM
Quoted: 449 Post(s)
Liked: 153
My rear (main) sub had been phase reversed, and now it is not.
My Room
My Music
Jenzen Next
Old 02-26-2015, 07:59 AM
Quoted: 449 Post(s)
Liked: 153
Jerry,
However, my guess:
I think the lower bass, or the region shown here looks fine. Its above this frequency range where I am not sure whats going on with your setup.
My Room
My Music
Jenzen Next
Old 02-26-2015, 08:30 AM
artur9's Avatar
Quoted: 621 Post(s)
Liked: 217
Because the graph rarely dips below 10ms. Seems to me that something is adding 10ms across the board.
In comparison to Jim's GD graphs which have more variance and does approach 0ms. IIRC, Jim doesn't use any EQ.
artur9 is offline
Old 02-26-2015, 08:37 AM
3ll3d00d's Avatar
Liked: 601
you're misunderstanding what GD is then, it is a measure of the relative delay of different frequencies within the envelope, i.e. within the impulse itself, i.e. it is a measure of how long those frequencies take to pass through the filter relative to other frequencies. It is not, as I said in the earlier post, absolute time unless group delay is constant.
An example to illustrate, the absolute time delay incurred by my filter is ~650ms but you don't see my GD as showing up at 00s of ms
3ll3d00d is offline
Old 02-26-2015, 08:39 AM
markus767's Avatar
Liked: 1392
It tells you there's probably an overall delay that you should remove from the IR.
Markus
Old 02-26-2015, 08:45 AM
artur9's Avatar
Quoted: 621 Post(s)
Liked: 217
If I'm following along then your GD shouldn't show 00s of ms because all the frequencies are equally delayed by your filtering.
I am assuming that 0ms of GD means that nothing is delaying that frequency relative to other frequencies.
What does it then mean if all the frequencies show a 10ms GD?
Simpler question, I think, what would cause 1 (or a handful) of frequencies to show significant GD?
artur9 is offline
Old 02-26-2015, 08:46 AM
Quoted: 449 Post(s)
Liked: 153
In an absolute or most accurate sense, yes. But I think what most of us are after, with any measurement really, is what we measure vs what that same measurement should look like. In the case of GD, in a perfect world, it would say 0ms from top to bottom. In the real world, there will some delay in the lower end. How much and at what frequency range is debatable. But from what I have studied, it should be possible to keep most of the GD pretty flat until you get to the low end. If you have 10 or 20ms bumps in the mids or upper bass, something is amuck.
My Room
My Music
Jenzen Next
Dayton , Dayton Audio , Room Equilizer Wizard Rew
