Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 456 - AVS | Home Theater Discussions And Reviews
 344Likes
post #13651 of 13672 Old Yesterday, 02:23 PM
mattdub1's Avatar
Quoted: 49 Post(s)
Originally Posted by Alan P View Post
Try turning down the mic "volume" in Windows - right click the speaker icon in the system tray / Recording Devices / UMIK-1.
thanks Alan...isn't this against what the guide says though? the guide said to set the volume at 100. Is there a certain volume you would recommend?
mattdub1 is online now
post #13652 of 13672 Old Yesterday, 02:28 PM
3ll3d00d's Avatar
Quoted: 491 Post(s)
Liked: 126
It does sound a bit odd yes. I suggest you go to check levels in the preferences screen and send a signal then change the level as Alan suggested and see what happens to the input level.
Double check you don't have some other audio manager app that is applying a boost too. I chatted with someone last week who had that problem. Retail computers are notorious for being chocka with bloatware after all.
3ll3d00d is online now
post #13653 of 13672 Old Yesterday, 02:52 PM
AustinJerry's Avatar
Quoted: 1904 Post(s)
Liked: 1104
Originally Posted by 3ll3d00d View Post
Massively clipped UMIK-1 provides details on how to gain the gain, and SENS factor, of the mic itself. However, at stock settings, you should still be able to measure ~95-100dB without issues so that suggests a setting in your computer is the problem. You might want to open the mic to check the sensitivity but first I would look into your computer. How is the audio device configured in windows?
Matt, thanks for posting this link. I believe I saw the post back when it first started, but forgot about it. I think I'll mention it in the guide.
AustinJerry is online now
post #13654 of 13672 Old Yesterday, 02:53 PM
Liked: 1104
I don't think this is the right advice, Alan, sorry. It is just masking the problem. As the Guide recommends, the mic gain in Windows should be set to unity. This ensures everyone is on a level playing field.
post #13655 of 13672 Old Yesterday, 02:55 PM
3ll3d00d's Avatar
Quoted: 491 Post(s)
Liked: 126
From a debugging perspective, it provides information though. Namely whether the computer settings on the input device react as you would expect.
I thought REW dealt with changes to the input level anyway, for the umik, so that it didn't matter? ie it also reads that value and adjusts accordingly.
post #13656 of 13672 Old Yesterday, 02:58 PM
mattdub1's Avatar
Quoted: 49 Post(s)
Any ideas jerry as to why my mic is clipping when taking measurements at 85db? Is there more info I should provide or other settings I should check? Thx
post #13657 of 13672 Old Yesterday, 03:03 PM
Liked: 1104
OK, I just ran my own tests, with these results:
With AVR MV at -13, playing the Speaker Level pink noise test tone from the REW Generator at -12dBFS, the REW SPL meter registers 90dB, and the level indicator below the meter reads -16dBFS input signal level. Note that the AVR was in Stereo mode, and I was outputting the test signal to both left and right speakers simultaneously. And also note that my sensitivity parameter is 6.352. With these settings, I can measure up to a 103dB signal without clipping.
I also opened up my UMIK-1, and the dip switches are set to On-Off-Off, or 100, which is -12dB, according to the table on the mic's PCB. Matt, I recommend you open the UMIK-1 just to make sure your dip switch settings are the same. If your settings are the same, I am not sure what to recommend next. BTW, I have seen reference else where that some computers have a "Microphone gain setting" in the Windows Recording Device properties. You might want to check if you have such a setting and, if yes, make sure it is set to off. The Guide doesn't refer to a gain setting because I have never seen one on any of my computers.
post #13658 of 13672 Old Yesterday, 03:05 PM
Liked: 1104
It may indeed adjust accordingly, but I stand by my advice--remove uncertainty by using the recommended settings.
post #13659 of 13672 Old Yesterday, 04:19 PM
Alan P's Avatar
Quoted: 1517 Post(s)
Liked: 761
Sorry if I gave wrong advice, it was just the advice I was given (not here, in the ULF thread). I couldn't measure over ~118db with the mic at 100, I turned it down to 80 and now I can measure to ~135db (and yes, I realize most folks have no need to measure that high but I was doing max output/compression sweeps on my T-18s).
Are you saying the measurements I've taken with the mic set to 80 are invalid somehow? If so, that sux.
AVR: Denon 4520ci, FL/R: Klipschorn, CC: Klipsch RC-64ii, SUR: Polk LS/FX x4, FH: Klipsch RB-51ii x2, SUB: PSA T-18 x2, DISP: Mitsubishi WD-73740, BluRay: PS3 & BDP-S5100, Remote: URC MX-700
Getting Started with REW
Audyssey 101
Audyssey FAQ
Alan P is online now
post #13660 of 13672 Old Yesterday, 04:32 PM
3ll3d00d's Avatar
Quoted: 491 Post(s)
Liked: 126
Originally Posted by jim19611961 View Post
I agree lower bass GD/Phase/FR anomalies are unachievable for most. But taking Jerry's graph, I think those >200hz are.
I thought an example to illustrate Markus's point, or what I think his point was, re the importance of early vs late arrivals here. I kept the scale the same for comparison purposes.
excess phase of an unsmoothed measurement
excess phase of a measurement with a 100 cycle (50 left, 50 right) frequency dependent window applied
excess phase of a measurement with a 30 cycle (15 left, 15 right) frequency dependent window applied
obviously as we "close" (reduce length of) the window then we exclude more and more data which serves to quieten down the excess phase view, therefore you have to ask what size window should you choose for this purpose?
ID:	570721   Click image for larger version
ID:	570729   Click image for larger version
post #13661 of 13672 Old Yesterday, 04:35 PM
3ll3d00d's Avatar
Quoted: 491 Post(s)
Liked: 126
as far as I recall, REW is aware of this and adjusts accordingly so the levels remain accurate. You may want to search, or ask directly, on HTS to confirm that (but it would be a strange thing if REW didn't handle this properly).
post #13662 of 13672 Old Yesterday, 04:57 PM
Liked: 1104
I am not saying the measurements are invalid. For your own satisfaction, you should measure REW output with an external SPL meter to understand the relationship between the Windows sensitivity setting and REW. A little detective work will set you at ease.
So, I apologize, perhaps "wrong advice" was too strong a statement. I just think we should understand why Matt is having his issue when it should be functioning exactly like my setup.
post #13663 of 13672 Old Yesterday, 05:24 PM
mattdub1's Avatar
Quoted: 49 Post(s)
I replicated your setup and got about 88-89 db for pink noise with avr mv set to -13. I also went to stereo with front l and r playing the sound during the sweep. clipped again. next, I tried changing the mic volume from 100 down to 50 in the recording devices setting. when I test the level before running the sweep, it says "level ok" and it's -13.8db when the mic volume is at 100. if I turn the mic volume down to only 50 and hit "check level" in the measurement screen, it tells me "level ok" and it changes to -20.6. when I change the mic volume to 25 and check the level, the input goes down to -26. so the mic volume setting does seem to change the reading. I also get the same spl measurement of 88db with pink noise on the spl meter when the mic volume is at 50 or 100, but then the spl reading goes up to 89db when the mic volume is at 25 or even at 1.
Now, When I run the same sweep at the same 88db, I now have 3 db of headroom and it doesn't clip with the 50 mic volume setting. When I run the sweep again with the mic at 25 for the volume setting, I now can run the 88db sweep and have 8.8 db of headroom! This is sooo weird! Interestingly, the graphs don't seem to change much between the 100, 50 and 25 mic volume settings (attached).
Any thoughts at this point? it seems the mic volume level being turned down significantly will allow the input to not clip as easily. Is this a "band-aid" for a bigger issue? I also checked and have no way to control the microphone gain. I am running windows 7 on a dell laptop that's about 5 years old. thanks everyone for your help so far!!!
EDIT: I also tried setting the mic volume to 0 and now the spl meter reads only 74 db but my rat shack reads 87-88 still (avr mv still at -13). It looks like as long as I have the mic volume setting to at least 1, the spl meter remains accurate (agrees with the rat shack) at about 88-89 db when the avr mv is at -13. This is really weird.....
Name:	mic level differences.jpg
post #13664 of 13672 Old Yesterday, 05:56 PM
tvuong's Avatar
Quoted: 466 Post(s)
Liked: 180
I verified this with same measurement results whether mic in window is set to 100 or 10 on my cross spectrum umik-1.
tvuong is online now
post #13665 of 13672 Old Yesterday, 06:51 PM
aaranddeeman's Avatar
Quoted: 259 Post(s)
Liked: 49
Sorry for repeating, but seems like my question got lost in multiple posts and other (more interesting) posts there after.
I had posted this sometime before, but posting again with a specific question.
Please see my room sketch below.
Length : 213 inches
Width : 140 inches (Plus 24 inches within front 96 inches from the screen behind the curtain on the right hand side)
Height : 92 inches.
I was trying to use the mode calculator, but am not sure what width I should enter. As you can see the front 8 feet of the room is 164 inches wide and the remaining is 140 inches wide.
After using both width figures, and using mode calculator, it appears that my sub should be either at 9ft from front or back wall, or 5 3/4 ft to 6 3/4 ft between side walls.
Is that the correct reading?
Currently by sub is close to 9ft from front wall and I think that is one of ideal locations.
Please see the room, both mode charts and sub only FR (with Audyssey off). (Pls ignore the sub position shown in the room. The sub is now under SR)
I really appreciate your input.
ID:	571001   Click image for larger version
ID:	571009   Click image for larger version
ID:	571017   Click image for larger version
aaranddeeman is offline
post #13666 of 13672 Old Yesterday, 06:55 PM
mattdub1's Avatar
Quoted: 49 Post(s)
I now reinstalled the umik 1, rew, asio and set everything back up again according to the pdf instructions. same results. The only way I can measure at 88 db (-13 mv in avr) is if I turn the mic volume down in the windows recording devices control pane. I ran several sweeps (mic level at 5,10,15,20,25) and each time I increase the mic volume, I get less headroom when running the 88db sweep. The graphs are similar, but it seems the mic volume slightly affects the graphs by a db or two. I attached comparisons of mic volume 100 vs each of the volume settings I tried. Are these differences in the graphs enough to worry about where I should just set the volume to one of the lower levels (like 10 for example) and forget about all this?
The main reason I got rew was to figure out best placement for my sub when I get it. I'm not sure how these mic volume settings will affect the subwoofer frequencies when I get my sub in a few weeks
Name:	mic volume 100 vs 5.jpg
ID:	571121   Click image for larger version
Name:	mic volume 100 vs 10.jpg
ID:	571129   Click image for larger version
Name:	mic volume 100 vs 15.jpg
ID:	571137   Click image for larger version
Name:	mic volume 100 vs 20.jpg
ID:	571145   Click image for larger version
Name:	mic volume 100 vs 25.jpg
post #13667 of 13672 Old Today, 02:25 AM
3ll3d00d's Avatar
Quoted: 491 Post(s)
Liked: 126
if you want to be sure there is no issue then take your question to the HTS board and ask there, I'd just turn it down and forget about it myself but no harm in being belt and braces about it.
post #13668 of 13672 Old Today, 02:33 AM
3ll3d00d's Avatar
Quoted: 491 Post(s)
Liked: 126
Length : 213 inches
Height : 92 inches.
IME of a room with a few regular shaped alcoves, the sim can be broadly accurate in parts of the room but breaks down completely as you get closer to the irregular parts. For example my room is shaped like so
the circles are the seating positions. The sim, using the full width of the room, works well in the green spot but not at all in the red spots. The only way I know this is because I have measured it in various locations in the room. There is no way anyone can tell you whether or not a sim will be accurate in your sort of room, you just have to measure and go with what the measurements tell you.
post #13669 of 13672 Old Today, 02:50 AM
markus767's Avatar
Quoted: 1406 Post(s)
Liked: 534
Yep, that was my point. Thanks for showing these graphs.
Excellent question and no good answer to it. Objective listening tests could give an answer.
People often think that looking at graphs would tell them how something sounds. That isn't true. You first have to understand what measurements show and how they correlate to what we hear. Then and only then specific measurements and data presentations are helpful.
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is online now
post #13670 of 13672 Unread Today, 06:17 AM
Quoted: 259 Post(s)
Liked: 49
Attachment 571578
I agree. Actually the current position is with the measurements (and convenience). I wanted to see if I can get it better.
So I guess I need to slide that elephant around for one more time..
post #13671 of 13672 Unread Today, 08:27 AM
mattdub1's Avatar
Quoted: 49 Post(s)
so another strange question... I tried flipping the switches on the circuit board for my umik-1 and uninstalled the driver, and reinstalled it. from the factory, it was set at 18db gain. The switches for the 18db setting stock are the first pic attached. I flipped them the opposite way, which according to the chart on the board is 12db, and reinstalled the driver. When the mic shows up , it now shows 36 db. The switch settings for this are in the second attached pic. Is something wrong with my mic? When I read the "severely clipping" thread that was posted with instructions on how to change the mic gain on the circuit, someone there shows that when their switches are in the position in my second pic, they are at 12db mic gain??? The graph on the back of the board doesn't seem to correspond at all with the gain settings I get when flipping the switches. To be honest, it's hard for me to make sense of that chart, unless I am reading it wrong.
ID:	571809   Click image for larger version
post #13672 of 13672 Unread Today, 08:31 AM
Rod2486's Avatar
Quoted: 51 Post(s)
I don't know if anyone saw my post #13597 ? This is an issue that is stumping me and would like to get some input if I should send my umik back for another one.
I did measurements yesterday with the subs being the only thing on. I placed the mic basically right in front of the cone. As close as I could get to my grill. Still has this big peak in the 10hz range
Rod2486 is online now
Dayton , Dayton Audio , Room Equilizer Wizard Rew
