Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 458 - AVS | Home Theater Discussions And Reviews
 351Likes
post #13711 of 13731 Old 02-27-2015, 04:09 PM
Alan P's Avatar
Quoted: 1526 Post(s)
Liked: 765
Yeah, I'm aware....just never got around to it.
AVR: Denon 4520ci, FL/R: Klipschorn, CC: Klipsch RC-64ii, SUR: Polk LS/FX x4, FH: Klipsch RB-51ii x2, SUB: PSA T-18 x2, DISP: Mitsubishi WD-73740, BluRay: PS3 & BDP-S5100, Remote: URC MX-700
Getting Started with REW
Audyssey 101
Audyssey FAQ
Alan P is online now
post #13712 of 13731 Old 02-27-2015, 04:15 PM
jim19611961's Avatar
Quoted: 227 Post(s)
Liked: 96
Originally Posted by Rod2486 View Post
Have you seen the graphs I have posted in the last few days on this thread? Is this something I would want to smooth with a manual EQ?
Perhaps. or close the doors.
My Room
My Music
Rega - Apollo, Rega - DAC, Goldpoint Passive, (2) Classe CA-100 bridged power amps (350w)
Jenzen Next
jim19611961 is online now
post #13713 of 13731 Old 02-27-2015, 05:10 PM
Rod2486's Avatar
Quoted: 58 Post(s)
Well, what I am getting at is would it sound better in the system with the hump smoothed out to match the rest of the frequency response. Being that it is so low it may never be noticed, or it may be beneficial since I am mostly HT? I just have not seen anybody elses graphs with this issue. Not sure what to do about it
I wish I could close some doors but being its in the living room that cant happen. Only open hallway to kitchen in there.
Rod2486 is online now
post #13714 of 13731 Old 02-27-2015, 05:53 PM
AustinJerry's Avatar
Quoted: 1952 Post(s)
Liked: 1108
The hump at 10Hz is unusual. If not caused by some sort of mechanical vibration in your home, then maybe it is a defective mic. I am unaware of many subs that would be causing that hump. Can you actually hear that something is amiss? Maybe you should ask your question to MiniDSP support. No one here seems to have an answer for you here.
AustinJerry is online now
post #13715 of 13731 Old 02-27-2015, 07:00 PM
Rod2486's Avatar
Quoted: 58 Post(s)
Yeah you would think the mic is at fault. But lookl at these I did in my bedroom which I can close the door and seal it off. The hump goes away. Open the door and it comes back. Weird haha
Red line is doors open
Black line doors closed
These are unsmoothed measurements
Name:	bedroom sweeps.jpg
post #13716 of 13731 Old 02-27-2015, 07:25 PM
Liked: 1108
Maybe a mechanical noise somewhere? If you can't hear it, I wouldn't worry.
post #13717 of 13731 Old 02-27-2015, 07:36 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 72
Almost looks like your door is acting like a port for your room tuned to that frequency. Though it's kind of ugly what it's doing to the rest of the FR...
Soulburner is online now
post #13718 of 13731 Old 02-27-2015, 09:36 PM
ahblaza's Avatar
Quoted: 463 Post(s)
Liked: 426
Guys, I can't see how to open the UMIK-1 up, what am I missing? Sorry for the question, just very curious.
ahblaza is online now
post #13719 of 13731 Old 02-27-2015, 09:48 PM
Liked: 1108
Look at the end of the U!IK-1, where the USB cable plugs in. The whole end of the mic simply un-screws. There are two small holes along the edge of the removable end. If you use a small pointed device like a paper clip or push pin, you can use these holes to help rotate the end out far enough so that you can finish removing the end with your fingers.
Once the end us unscrewed, gently pull the end away from the case. The PCB is attached to the end. Several wires extend from the other end of the PCB up into the mic barrel. Be very careful not to pull too hard and damage the wires.
ahblaza likes this.
post #13720 of 13731 Old Yesterday, 10:52 AM
ahblaza's Avatar
Quoted: 463 Post(s)
Liked: 426
Thanks Jerry, I thought the little indents had something to do with it but I wanted to make sure before I did something stupid. I have the miniDSP mic so I should be looking for a 12 dB gain setting, factory default? TIA
post #13721 of 13731 Old Yesterday, 11:36 AM
Liked: 1108
Mine was 12dB, yes.
ahblaza likes this.
post #13722 of 13731 Old Yesterday, 02:13 PM
markus767's Avatar
Quoted: 1415 Post(s)
Liked: 538
Newer ones are 18dB. Don't change the settings if you don't have a calibrator. If you're unsure contact miniDSP support with your mic's serial number.
ahblaza likes this.
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is online now
post #13723 of 13731 Old Yesterday, 02:26 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 72
Mine is 18db.
I would think that altering this would throw off the noise floor measurement, and that there is an interplay with the sensitivity factor, is that right?
post #13724 of 13731 Old Yesterday, 02:35 PM
markus767's Avatar
Liked: 538
That is correct. The sensitivity factor is (also) based on the hardware gain setting. Don't change it or the calibration will be off.
Soulburner and ahblaza like this.
Markus
post #13725 of 13731 Old Yesterday, 04:14 PM
mattdub1's Avatar
Quoted: 61 Post(s)
Iv read several posts, including a reply from minidsp, that says its OK to change the umik gain thru the dip switches, as long as you adjust the sensitivity factor in your calibration file according to how much you adjust the gain. For example, my umik came at 18db gain. I was running out of headroom so changed the gain via the dip switches to 12db gain setting. My original sensitivity was -1.79 I believe, so I changed it to -7.79 in the calibration file to compensate for the 6 db difference in the gain when lowering from 18 to 12. I posted several graphs a few posts back that show not much if any difference in the measurements between the 12 and 18db gain settings so the mic appears accurate after changing the gain setting. You just have to change the sensitivity factor in the cal file. The only benefit of this appears to be an increase in headroom before the mic clips.
mattdub1 is online now
post #13726 of 13731 Old Yesterday, 06:43 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 72
An interesting comparison of my current system with and without Audyssey XT32.
There is also some impressive room gain happening here with the little corner-loaded Velodyne VX-10, plus a little Dynamic EQ sprinkled on top. I realize that for posting future measurements I should have DEQ off. Overall, XT32 it did a decent job bringing up some lows and taming some peaks. I need to figure out what is killing my 400-600Hz region, but I'm not going to go to great lengths just yet. Reason is that the speakers and sub are changing within the next month so this was just getting the new AVR all ready for them in advance. When you're within the return window on speakers/subs, you don't want to have AVR problems. Once I have the new speakers and subs and after I've moved, I'll get more serious with this.
I decided to use dark colors for OFF, and bright colors for ON. These were done at -20 on my X4000 which gives a headroom of about 10db. They are 85db sensitivity speakers. All settings following AustinJerry's guide, which has been a great help. CSL UMIK-1, HDMI.
Left speaker. Dark red is Audyssey OFF, bright red is Audyssey ON
Right speaker. Dark blue is Audyssey OFF, light blue is Audyssey ON
Name:	EMP Right.png
One last thing. I can't get my AVR to display MULTICH IN. It's in Stereo, and I can change it to all kinds of other things, but not MULTICH IN. It does default to MULTICH IN for my PS3, but not my Chromecast or my PC. I doubt this will be a problem for Left, Right and Sub measurements but it deviates a bit from Jerry's guide.
*Under Construction*
To: AVR-X4000, Chane A3rx-c, Rythmik L12 (2)
Samsung PN64H5000 Recommended Settings
post #13727 of 13731 Old Today, 02:05 AM
markus767's Avatar
Liked: 538
Correct. You need to change the sens factor in the calibration file the exact same amount you've changed the hardware gain setting. This will retain level calibration.
Markus
post #13728 of 13731 Old Today, 10:21 AM
mattdub1's Avatar
Quoted: 61 Post(s)
Doesn't this contradict what you stated before? You had said not to change the gain on the umik or the sens factor otherwise the calibration would be off..
post #13729 of 13731 Old Today, 11:32 AM
markus767's Avatar
Liked: 538
No contradiction. If you adjust BOTH settings you'll be fine but if you adjust only one then calibration will be off.
Markus
post #13730 of 13731 Old Today, 01:43 PM
ahblaza's Avatar
Quoted: 463 Post(s)
Liked: 426
My Sens Factor is .6814dB for both 0 and 90 degree, does this sound right, I haven't opened my UMIK-1 up yet so what would be your estimate that my mic's gain setting is it. I know I'm missing something here. I think I need to just start taking some measurements regardless where the gain is at period. I've been following this thread the whole time. I have Jerry's guide, current version of REW and ASIO4ALL drivers installed and HDMI. I'm just so intimidated by all of this and I don't understand my reluctance to get started.
Jeff
post #13731 of 13731 Old Today, 01:54 PM
Liked: 1108
Jeff
I believe it was mentioned earlier that current UMIK-1's are shipping with an 18dB setting, which would be consistent with your sensitivity parameter. There is no reason to be concerned. It sounds like everything is configured properly. Dive in.
Dayton , Dayton Audio , Room Equilizer Wizard Rew
