Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 460 - AVS Forum | Home Theater Discussions And Reviews
 2285Likes
post #13771 of 23602 Old 03-03-2015, 11:52 AM
mtg90's Avatar
Quoted: 496 Post(s)
Liked: 974
Originally Posted by LastButNotLeast View Post
I've run separate L, C and R sweeps for my Fusion 8 Alchemies. As expected, their response is fairly similar. However, when I run them all together (I know, not one of the suggested sweeps, so I'll accept "Don't do that" as a valid reply), I get some additive, as expected, and some not. Not an ideal room by any means, but I would think the summed response would be more similar to the individual sweeps.
Or not?
Now I thought at some point I saw you had said you reversed the polarity of the entire center channel, is this true? If not ignore as I may have been mistaken.
mtg90 is online now
post #13772 of 23602 Old 03-03-2015, 11:54 AM
cfraser's Avatar
Quoted: 128 Post(s)
Liked: 73
Originally Posted by AustinJerry View Post
Keep in mind that what I posted was the pre-out measurements. If I had posted a measurement of the pre-outs with Audyssey off, you would have seen a smooth line, because pre-out measurements have no room effects. So I claim that the measurement I posted answers your question exactly WRT how much correction Audyssey XT32 applies above 300Hz. The only better answer would be to actually measure YOUR in-room response with XT32 on and off, something I cannot do.
BTW, if you want to control correction above a specific frequency, then you should consider Dirac Live as implemented in the very affordable MiniDSP DDRC-88A. Read through the 88A to familiarize yourself with this product if you have not already done so.
Thanks Jerry! Actually, I just came back to this computer to apologize, I just figured out downstairs what you meant by posting preamp output measurements...
Edit: yes, I have been following the 88A thread. I am on the fence, about that and just what I want. Was/am considering the 7702/8802, but then thought: no room for more amps in my HT room if I want to try Atmos (I do have several spare Bryston amps I could use for ceiling speakers), so maybe I need a better AVR for use as a pre-pro + 2-4 of its amps instead...that would fit OK. Do I want Atmos speakers/amps then, or do I just want to use its apparently better decoder? If I do need more channels (I find it deceiving that many Atmos proponents say it doesn't use "channels" since it's object-based!), do I want to Dirac them? etc. etc. It doesn't help that this is a bad year for audio tech, reminds me of 2010 in some ways and the half-assed audio crappage they released that model year (MY 2011 was much better): too many unresolved A/V (4K/HDMI/HDCP) things that are to be resolved shortly, there really is nothing much important that's new right now, that's why they did the Atmos this "year" (late 2014-15), else they'd have nothing to sell).
cfraser is offline
post #13773 of 23602 Old 03-03-2015, 12:07 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 7719 Post(s)
Liked: 4319
Edit: yes, I have been following the 88A thread. I am on the fence, about that and just what I want. Was/am considering the 7702/8802, but then thought: no room for more amps in my HT room if I want to try Atmos (I have several spare Bryston amps), so maybe I need a better AVR for use as a pre-pro + 2-4 of its amps instead...that would fit OK. Do I want Atmos speakers/amps then, or do I just want to use its apparently better decoder? If I do need more channels (I find it deceiving that many Atmos proponents say it doesn't use "channels" since it's object-based!), do I want to Dirac them? etc. etc. It doesn't help that this is a bad year for audio tech, reminds me of 2010 in some ways and the half-assed audio crappage they released that model year (MY 2011 was much better): too many unre4solved A/V things that are to be resolved shortly, there really is nothing much important that's new right now, that's why they did the Atmos this year, else they'd have nothing to sell).
So many decisions to make. Good luck!
AustinJerry is offline
post #13774 of 23602 Old 03-03-2015, 12:14 PM
LastButNotLeast's Avatar
Quoted: 1804 Post(s)
Liked: 1416
AFAIK, the polarity of everything is okay now. My next step, which I'm not eager to take, is to measure the response of each driver individually. According to Jeff, "I selected the Eminence Beta-8 woofer due to its high sensitivity and very linear response and was surprised at the exceptional midrange quality of this driver." I'm getting anything but a "very linear response," and I'm not about to rule out the possibility that I've done something wrong. Though the thought of rebuilding the damn things appeals to me about as much as poking an eye out.
I was hoping someone looking at the graphs would see something with a relatively easy solution. But I knew the odds of that!
Michael
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
Don't guess, measure: Getting Started With REW: A Step-by-Step Guide
LastButNotLeast is offline
post #13775 of 23602 Old 03-03-2015, 12:20 PM
mtg90's Avatar
Quoted: 496 Post(s)
Liked: 974
I don't see anything wrong with the individual speaker measurements. Just for kicks try reversing the input wires on the center channel and measure all three again.
mtg90 is online now
post #13776 of 23602 Old 03-03-2015, 12:23 PM
cfraser's Avatar
Quoted: 128 Post(s)
Liked: 73
Jerry: Sorry, I was typing my response above while talking on the phone, so it's a bit disjointed...
Yes, so many very very very important decisions that my life depends on. If I have to "make room" for more gear, and that would be a lot of difficult work, I want to do it in a longer-term and worthwhile way, rather than scatter-shot. I just don't have floor room to spare for any more racks, and the existing ones are already way over my head so I need step-stools to reach stuff lol (multiple systems in room).
cfraser is offline
post #13777 of 23602 Old 03-03-2015, 12:27 PM
Liked: 1416
Next week. Life is getting in the way for a few days. I'll let you know.
post #13778 of 23602 Old 03-03-2015, 03:31 PM
revans35's Avatar
New to REW and I tried to follow the guide as much as possible (on a mac w/ a USB mic). Any ideas what might be going on around 60Hz? This is a new dedicated HT space with zero treatments. Trying to get some baseline measurements before I start on a new HT build. Room is approx 19'x15'x9.5'.
ID:	581825   Click image for larger version
ID:	581841   Click image for larger version
revans35 is offline
post #13779 of 23602 Old 03-03-2015, 05:31 PM
artur9's Avatar
Quoted: 673 Post(s)
Liked: 241
Originally Posted by revans35 View Post
Any ideas what might be going on around 60Hz? ... Room is approx 19'x15'x9.5'.
Seems like a room mode. Do you have a separate sub? More than one? Have you done the sub crawl?
artur9 is offline
post #13780 of 23602 Old 03-03-2015, 05:55 PM
revans35's Avatar
This is a measurement with the Left and Right speakers, and a separate SVS SB13 Ultra sub. Right now I just have the single sub.
revans35 is offline
post #13781 of 23602 Old 03-03-2015, 06:26 PM
aaranddeeman's Avatar
Quoted: 1703 Post(s)
Liked: 619
What is the cheapest (yes cheapest.. no breaking the back) and simplest but most effective way to make a bass trap.
I know R30 is mentioned, but how do one hold it together say for a corner trap?
I googled, but most of the DIY articles are for studio application (and towards heavier use side).
For the HT, what would be our best approach?
aaranddeeman is offline
post #13782 of 23602 Old 03-03-2015, 08:09 PM
artur9's Avatar
Quoted: 673 Post(s)
Liked: 241
Literally, the cheapest is to buy a roll of R30, break the seal on the bag and drop it somewhere in the room. You may need more than one roll to achieve your goal.
I've read of people using chicken wire to make a sort of frame for the R30 and then covering it with a decent fabric.
artur9 is offline
post #13783 of 23602 Old 03-03-2015, 08:12 PM
artur9's Avatar
Quoted: 673 Post(s)
Liked: 241
Have you tried moving the sub around and measuring to see where it works best?
This is what I meant by sub crawl. Have you done that? Instead of listening, since you have a mic and REW, you can use those to find the best place for the sub.
artur9 is offline
post #13784 of 23602 Old 03-03-2015, 08:50 PM
jkasanic's Avatar
Quoted: 329 Post(s)
Liked: 123
Not chicken wire as I used the wire form to support stacking but similar to what you described:
jkasanic is offline
post #13785 of 23602 Old 03-04-2015, 05:07 AM
Liked: 619
I was wondering if I can make a cylindrical long bag and shove R30 in it and then stick that cylinder at the corner (hidden).
post #13786 of 23602 Old 03-04-2015, 05:08 AM
Liked: 619
That will consume half of my HT real estate..
post #13787 of 23602 Old 03-04-2015, 06:02 AM
Liked: 1416
But it would sound GREAT!
post #13788 of 23602 Old 03-04-2015, 07:42 AM
jkasanic's Avatar
Quoted: 329 Post(s)
Liked: 123
Tell me about it!
|Tch0rT| and Boomassiv like this.
jkasanic is offline
post #13789 of 23602 Old 03-04-2015, 07:48 AM
Alan P's Avatar
Quoted: 5136 Post(s)
Liked: 3835
That looks like 60hz hum to me...try unplugging your appliances (fridge, freezer, HVAC) one at a time and running sweeps until it disappears.
Alan P is offline
post #13790 of 23602 Old 03-05-2015, 09:34 AM
SherazNJ's Avatar
Quoted: 1210 Post(s)
Liked: 144
Can someone please explain how to interpret RT30 graph? What is it showing? What should a good RT30 result look like? I'm attaching my center channel FR and RT graphs.
ID:	585057   Click image for larger version
SherazNJ is offline
post #13791 of 23602 Old 03-05-2015, 10:08 AM
Liked: 4319
Center FR looks good. Not sure the RT60 has much value. It is rarely posted here or discussed. It is a measure of reverberation in the room, and I don't know what is good or bad. I suggest you read the REW Help section, or do an internet search. For comparison, here is my T30:
Edit: Are you going to get a Dropbox account so you don't have to post those postage-stamp size images all the time?
post #13792 of 23602 Old 03-05-2015, 10:18 AM
ahblaza's Avatar
Quoted: 1967 Post(s)
Liked: 2213
Guys, sorry for such an elementary question, in the preference settings in REW I can not get the UMIK-1 to be detected, the only option in the slide down menu is HD audio 1 and 2. When I first launched REW a caption did show up that a UMIK-1 was detected but then it was gone. Sorry guys, I finally decided to try and take a measurement, all the windows configurations went well until I got to this part. I'm using a 8.1 windows laptop with HDMI.
Jeff
ahblaza is offline
post #13793 of 23602 Old 03-05-2015, 10:18 AM
3ll3d00d's Avatar
Quoted: 1666 Post(s)
Liked: 646
you don't need dropbox, just use the image url itself and insert into the post using the img tag instead of as an attachment which helps those of us behind corporate firewalls that block dropbox
3ll3d00d is online now
post #13794 of 23602 Old 03-05-2015, 10:18 AM
SherazNJ's Avatar
Liked: 144
I didn't know to attach like you did. Now I do. I"ll create a dropbox account. Thx.
Jerry can you also post your FR account with/without sub channel plz (Dirac version). Thx
SherazNJ is offline
post #13795 of 23602 Old 03-05-2015, 10:25 AM
3ll3d00d's Avatar
Liked: 646
good or bad depends on what the goal is, I'd say yours looks a shade on the dead side. If you want a reference then tou can look for things like EBU3276 calculators which tend to show target times in the 0.3-0.4s range for normal sized rooms.
post #13796 of 23602 Old 03-05-2015, 10:27 AM
ggsantafe's Avatar
Quoted: 222 Post(s)
Liked: 176
Jeff
Looks like you already got a response in the PSA thread: Official Power Sound Audio Subwoofer Thread
Have you tried Hop's suggestions? Your problem is not uncommon, and following the recommendation above often solves the issues you are encountering. As the I Ching says "perseverance furthers"
ggsantafe is offline
post #13797 of 23602 Old 03-05-2015, 11:05 AM
SherazNJ's Avatar
Liked: 144
Sorry, this just flew over my head. I don't even know what I'm looking at. What does it represent? Would be great if someone can explain in lehman terms.
SherazNJ is offline
post #13798 of 23602 Old 03-05-2015, 11:32 AM
Liked: 4319
The horizontal straight-line segments represent frequency ranges (horizontal scale). The height of the line segment corresponds to a "liveliness" measurement in your listening room (vertical scale). I believe that I have heard that a value above .5 indicates a fairly lively room. The lower the measurement, the more toward "dead" your room measures. That is about all I know.
As I said, no one seems to care about this measurement, so I wouldn't obsess about it.
post #13799 of 23602 Old 03-05-2015, 11:36 AM
3ll3d00d's Avatar
Liked: 646
it shows how long does the sound take to reduce (decay) by a given amount plotted by frequency, arguably not directly applicable to a small room but still used to give some information as to the liveness of a room.
post #13800 of 23602 Old 03-05-2015, 11:54 AM
SherazNJ's Avatar
Liked: 144
Ok then how'd we know if your room is getting more towards being dead? We have FR to see if we are getting a pretty much flat response. We have Filtered ID to see how much of reflection is going in room. If anything, I got a lot of reflection going for my center channel (even though I have first reflection covered all around
https://www.dropbox.com/s/evw110f2z8...ction.jpg?dl=0
So how do we know if a room is dread for a specific channel? I thought if you have more reflection going that its more alive than being dead.
Jerry: Haven't been able to successfully share file yet. Working on it.
SherazNJ is offline
Dayton , Dayton Audio , Room Equilizer Wizard Rew
