Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 485 - AVS | Home Theater Discussions And Reviews
 414Likes
post #14521 of 14535 Old Yesterday, 06:27 PM
toofast68's Avatar
Quoted: 98 Post(s)
Liked: 24
Originally Posted by AustinJerry View Post
Bass resonance, which is what we are trying to measure, is caused by the low frequency contribution of subs + main speakers. If you want to impress us with your performance, measure center + subs, or left + right + subs.
Center plus subs plus LOUDER - is this decent ?
I know have some super low freq ringing....but that is way down low I think.
toofast68 is offline
post #14522 of 14535 Old Yesterday, 06:39 PM
AustinJerry's Avatar
Quoted: 2346 Post(s)
Liked: 1208
^ IMO, looks pretty decent.
BTW, you really should present your graphs with a log scale. Maybe you could correct and re-post?
AustinJerry is offline
post #14523 of 14535 Old Yesterday, 08:59 PM
toofast68's Avatar
Quoted: 98 Post(s)
Liked: 24
Can do I just have to figure out exactly what you mean....
post #14524 of 14535 Old Today, 06:13 AM
Liked: 1208
Sure. Here is a graph with a linear scale:
And here is a graph (same measurement) with a log scale (the difference is in the spacing on the horizontal scale):
You can toggle between the two modes by clicking the "Freq Axis" button in the top right corner.
Notice that the two graphs look quite different, and the graph in log format actually makes it much easier to identify issues in the lower frequencies. Going forward, you should always post using a log scale--for our purposes, the linear scale is of no value.
post #14525 of 14535 Old Today, 06:43 AM
toofast68's Avatar
Quoted: 98 Post(s)
Liked: 24
Ok, here is the log version..to my untrained eyes (but learning) it does not look quite as good. But I guess not much I can do about the super low stuff anyways....
post #14526 of 14535 Old Today, 08:09 AM
Liked: 1208
First of all, the bass resonance looks to be well under control. Addressing anything under 20Hz is very difficult. Besides, what lives down there? Nothing in music content, which is where resonance is really audible. Probably only LFE effects on movies, and I don't think you will be able to hear much of a difference. Time to move on to the Impulse Response (ETC) graph and look at specular reflections...
BTW, notice how much more revealing the log graph is. In linear mode, you may not have seen that there are slightly different issues at 30Hz vs. 20Hz.
post #14527 of 14535 Old Today, 08:29 AM
artur9's Avatar
Quoted: 199 Post(s)
Liked: 64
Isn't there a bit of rising resonance as the graph approaches 300Hz? What would cause that?
artur9 is offline
post #14528 of 14535 Old Today, 09:54 AM
jim19611961's Avatar
Quoted: 265 Post(s)
Liked: 98
These two measurements are EXACTLY the same (one taken right after the other), except one is a 128k sweep (top graph), and the other a 1M sweep (bottom graph). At 21.5hz, the 128k shows 7.6% distortion, the 1M shows 3.13%.
I have observed other differences in data vs sweep length in the low end, notably in waterfalls . Therefore, it may be recommended to do 1M sweeps when finalizing a change.
My Room
My Music
Rega - Apollo, Rega - DAC, Goldpoint Passive, (2) Classe CA-100 bridged power amps (350w)
Jenzen Next
jim19611961 is offline
post #14529 of 14535 Old Today, 10:59 AM
Liked: 1208
Originally Posted by jim19611961 View Post
Attachment 672649
Attachment 672657
Yes, but which one is correct, the one which shows the better result? Wishful thinking?
post #14530 of 14535 Old Today, 11:12 AM
Quoted: 265 Post(s)
Liked: 98
No, not wishful thinking. For each doubling of the sweep length, you gain 3db in S/N. JohnPM has said this. So 1M has a better S/N over a 128k by 9db. Its possible that neither is absolutely correct. But my bet is that the 1M is more correct.
My Room
My Music
Jenzen Next
post #14531 of 14535 Old Today, 11:35 AM
Liked: 1208
Yes, now that you mention it, I do recall that comment by John.
Perhaps we should compare the shorter and longer sweep results. If not much difference, shorter is quicker.
post #14532 of 14535 Old Today, 11:48 AM
3ll3d00d's Avatar
Quoted: 563 Post(s)
Liked: 152
in room THD measurements, IME, are pretty sensitive to low level environmental noise hence I suspect you're likely to get more robust results from using multiple sweeps.
Is that possible with a USB mic? ISTR multiple sweeps being problematic when multiple clocks are in the picture.
3ll3d00d is offline
post #14533 of 14535 Unread Today, 09:50 PM
lovingdvd's Avatar
Quoted: 677 Post(s)
Liked: 131
I assumed it was in the REW User guide, so never asked. But since I see it being talked about here, I wonder... What is the recommended setting then as far as the sweep parameteres/options that can be used?
lovingdvd is online now
post #14534 of 14535 Unread Today, 09:52 PM
lovingdvd's Avatar
Quoted: 677 Post(s)
Liked: 131
This looks excellent! Congratrs. Can you tell us a little about your room setup, where the MLP is, where the sub is placed etc? How about room treatments? I assume you must have some treatments going to have this great of a result (either that or you are sitting on top of your sub ).
post #14535 of 14535 Unread Today, 10:48 PM
mattdub1's Avatar
Quoted: 147 Post(s)
^^ I think he already posted about his room treatments a few pages back when you asked him
mattdub1 is online now
Dayton , Dayton Audio , Room Equilizer Wizard Rew
