Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 49 - AVS Forum | Home Theater Discussions And Reviews
 2285Likes
post #1441 of 23602 Old 02-18-2013, 04:15 PM
amirm's Avatar
Quoted: 1334 Post(s)
Liked: 741
Originally Posted by AustinJerry View Post
Audyssey off:
That shows the typical high pass filter on laptop mic. If you turn that into a calibration file for REW, it will then show up as a flat straight line. Once there then the Audyssey correction will show properly rather than falling that confusing curve which does not exist in real life:
amirm is offline
post #1442 of 23602 Old 02-18-2013, 04:32 PM
kbarnes701's Avatar
Quoted: 6824 Post(s)
Liked: 5262
Originally Posted by kbarnes701 View Post
Quote: Originally Posted by AustinJerry View Post
Taking Pre-Out measurements with REW
Jerry - great work - thanks. Should this form a chapter in the Guide (in the 'more advanced' section)?
If you think so, then yes.  Cut and paste is quite easy.
It  would be a pity for it to be submerged in the thread as time passes I think. You could make a section for more advanced use and include it in there, along with anything else that might crop up over time. Just a thought.
kbarnes701 is offline
post #1443 of 23602 Old 02-18-2013, 04:37 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 7724 Post(s)
Liked: 4326
Rev 2.4 of the REW Guide has been posted.
Changes in this revision:
  • Removed REW Soundcard Calibration section (left a placeholder) because it is no longer required
  • Made minor revisions to the ETC section
  • Added section describing the Pre-out measurement procedure
The guide can be downloaded at the link in my signature.
AustinJerry is online now
post #1444 of 23602 Old 02-18-2013, 04:44 PM
Liked: 4326
Audyssey off:
So that's what that is, Amir.  I didn't have that problem using the EMM-6 with it's calibration file:
Unfortunately, I'm not sure I know how to generate a microphone calibration file from a measurement curve.  Care to provide some direction?
post #1445 of 23602 Old 02-18-2013, 04:55 PM
amirm's Avatar
Liked: 741
Sure. Instead of measuring the pre-amp as you do normally, use the "Calibrate..." button in the Preferences pane. Keep hitting Next as it instructs you and REW will do the rest. Once there, measure again as you did and this time it should be ruler flat without EQ.
amirm is offline
post #1446 of 23602 Old 02-18-2013, 04:57 PM
Liked: 4326
Perfect, I'll try that tomorrow.  If successful, I'll update the procedure.  Thanks.
post #1447 of 23602 Old 02-18-2013, 06:09 PM
janos666's Avatar
Quoted: 23 Post(s)
Is there a reason you recommend setting up the Windows audio controls with 100% microphone volume? Wouldn't +/-0db be a better choice? (Hint: right click on the slider lets you switch to decibel scale.)
100% means +/-0db for playback devices but it's +6db for input devices. Strange enough, it also applies to SPDIF inputs, not only microphones. I am not sure if it's really a volume boost with clipping or not.
"DIY certified hobby-calibrator" (based on ChadB's "warning signs" list
janos666 is offline
post #1448 of 23602 Old 02-18-2013, 07:18 PM
Pres2play's Avatar
Quoted: 678 Post(s)
Liked: 325
Hi, Jerry (and team). REW virgin here. I'm half-way through this thread and hoped I'd be finished before my UMM-6 Mic arrived, but it's here now and I have a few question which may have been answered recently, so please bare with me.
1. When I do the REW microphone calibration with my RS SPL meter, I get a warning about "input sensitivety." How/where do I adjust this?
2. I'm going HDMI from my laptop to my Oppo BDP-105 which, AFAIK, only has Absolute Volume, not Relative. How important is it to use relative with REW? I'll post this in the Oppo thread, of course, in the meantime.
BTW, I'm so excited you guys started this thread. I've always wanted to toy with REW but was too put off by the setup requirements. When someone mentioned the USB mic and recommended this thread, I immediately started to read from post 1. Then when I saw your guide and learned of the HDMI hookup I knew I had to get involved. Can't wait to finally do some cals!
Pres2play is online now
post #1449 of 23602 Old 02-18-2013, 07:28 PM
Liked: 4326
I am unfamiliar with the "input sensitivity" warning.  Can you post a screen print so we can look at it?
Why is the Oppo in the loop?  The HDMI cable from the laptop should be connected to the AVR.  Please explain what you are trying to do.
post #1450 of 23602 Old 02-18-2013, 07:52 PM
Mike Garrett's Avatar
Quoted: 7084 Post(s)
Liked: 4788
Mike, several questions and comments:
- Why do you need to see the laptop screen on the projector?  How does that help with REW?
- When you say "no Audyssey and no EQ", what EQ are you using in addition to Audyssey?
- Why cut off the response curves for the front three speakers at 1kHz?  If the graphs showed response all the way down to 20Hz, we could see how well the splice between the mains and the subs looks.
- Are you going to post graphs that show the response with Audyssey and EQ engaged?  Any discussion on where there may be issues needs to be made after looking at how well Audyssey and EQ are helping things.
I'm still not sure why you can't get ASIO working.  I'm not sure it has anything to do with the cable length issue.
If I can get the input to show audio, then I will not have to change the AVR input to make a change as in changing the crossover frequency or channel level. Remember, I can't just look at my AVR and see this, since it is located on the floor below my HT. I also have another reason for getting this to work. Want to be able to bring a gaming device into the HT and hook it up. Remotely located equipment does not work well with gaming systems. The controllers do not work well when the Xbox is placed by the rack and there is not any (that I know of) way to improve the controllers range, so this dictates the gaming device has to be in the HT room. If my equipment was closer, then it would be less of an issue. Right now the best solution is HDMI from the device to a second HDMI input on the projector and optical from gaming device to AVR.
I have XT32 with Sub EQ and I have a pair of MIC2200's. The MIC2200's were for adding some boost down low.
Here is a full range graph of left speaker and subs, no Audyssey, no EQ
Yes I will post XT32 graphs, once I take them. Probably will not have time until the weekend.
mjgarrett100@gmail.com
Mike Garrett is online now
post #1451 of 23602 Old 02-18-2013, 08:04 PM
Pres2play's Avatar
Quoted: 678 Post(s)
Liked: 325
I'll post a screen shot if can remember how. But at the end of the warning, the "mic/meter" window said I had 170 dB head room which can't be right.
I'm not using a receiver; the Oppo is a Blu-ray player AND prepro. It's connected directly to the power amps via 5.1 analog.
post #1452 of 23602 Old 02-18-2013, 08:45 PM
Liked: 4326
Yes, something is clearly wrong if you get 170db headroom.  If the test tone is registering 80dB on your SPL, the output loop is working properly.  It sounds like to me that the signal from the microphone is too low.  Did you adjust the mic input in Windows Audio to be 100%?  When the test tone is playing, you should see a signal registering on the REW SPL meter.  Are you seeing a signal?
Ah, an analog purist!  Nothing wrong with that.  I'll bet your system sounds great.  Unfortunately, even though I have an Oppo myself, I have no experience using it as a prepro.
post #1453 of 23602 Old 02-18-2013, 10:05 PM
Pres2play's Avatar
Quoted: 678 Post(s)
Liked: 325
Here's the screen shot. I checked Sound>Recordings>UMM-6>Properties>Level, but level reads:100. What am I missing?
The Oppo is fantastic in analog mode but there are problems with the room and I think it might be severe. I'll post some graphs soon, if I can get this little problem with the mic figured out.
post #1454 of 23602 Old 02-19-2013, 02:42 AM
kbarnes701's Avatar
Liked: 5262
Jerry, your enthusiasm and your energies in this regard are boundless. I am sure I speak for everyone when I say 'thank you' for all the effort you put in.
post #1455 of 23602 Old 02-19-2013, 02:50 AM
kbarnes701's Avatar
Liked: 5262
Absolute and Relative volumes are just two ways of looking at the same thing. It won’t make any difference to REW - so long as you can get the appropriate level (eg 80dB) you are good to go, regardless of whether this would be -14dB on a relative MVC or 56 or whatever on an absolute scale.
post #1456 of 23602 Old 02-19-2013, 02:52 AM
kbarnes701's Avatar
Liked: 5262
Originally Posted by jkasanic View Post
HSAOT, you did remind me about the sub distance tweak either here or in the Audyssey thread.  I haven't done anything with it yet for the aforementioned reasons.  If the timing of all of this doesn't improve then I'm thinking of doing another round of measurements trying to improve the current location as I'm tired of watching movies with substandard sound quality! mad.gif
It is well worth doing the sub distance tweak - it is easy to do and doesn't take all that long but it can make a tremendous difference. See Jerry's graphs in that little Guide I complied for an example of the difference it can make.
post #1457 of 23602 Old 02-19-2013, 06:23 AM
Liked: 4326
On the REW SPL that you show in the screen shot, while the test tone is playing, you should be able to drag the "SPL Reading Calibration" window out of the way and look at the level meter being displayed, as in the screen shot below.  The microphone signal should be clearly registering somewhere on the scale, which is from -100dB to 0dB, and the bar should be in the green range.  What do you see?
If no sound is registering in the SPL meter, then exit REW and try the Windows Sound Recorder test described on page 25 of the Guide.  The Sound Recorder should show a level as you are talking into the mic, and when you save the file, you should be able to clearly hear your voice in the recording.
If the mic fails both of these tests, you may have a defective mic.
post #1458 of 23602 Old 02-19-2013, 07:37 AM
Selden Ball's Avatar
Quoted: 3503 Post(s)
Liked: 1770
my current surrounds are just Speakercraft AIM Wide One's and AIM Wide 8's with both sets being in-ceiling.  Any thoughts on why Audyssey may have set my surround xovers so low (don't tell me it's in the FAQ already)! eek.gif
Don't forget that Audyssey's microphone is intended to be used with grazing-incidence audio (i.e. speakers which are close to 90 degrees off axis). Unfortunately, that means that in-ceiling speakers (which are more nearly on-axis to the microphone) probably can't be calibrated as accurately as floor-standing speakers.
In other words, more than the crossover frequency might be having problems. frown.gif
This is, of course, a good reason for using REW: to find out just how bad things really are in your listening environment.
Selden
Selden Ball is offline
post #1459 of 23602 Old 02-19-2013, 08:49 AM
JChin's Avatar
Quoted: 377 Post(s)
Liked: 210
Hi Jerry, got the mic last week and downloaded cal files from the USB stick. The sheet of paper that came with the mic say to download cal file in text format from Dayton website. Do I need to download this text format as well? I didn't see it mention in the v2.4 REW Guide.
JChin is online now
post #1460 of 23602 Old 02-19-2013, 11:07 AM
Liked: 4326
Glad you received the mic.  The only calibration files you need are on the USB stick.  Make sure you use the one for a 90-degree mic orientation.
post #1461 of 23602 Old 02-19-2013, 12:06 PM
Pres2play's Avatar
Quoted: 678 Post(s)
Liked: 325
The mic doesn't work with Sound Recorder either. It's enabled in the sound control panel and level is set at 100, but no good. I called Cross Spectrum Lab and Herb (?) said he would check if there were any compatibility issues with Windows7.
Meter shows no response...
Level set to 100...
post #1462 of 23602 Old 02-19-2013, 12:11 PM
kbarnes701's Avatar
Liked: 5262
I am using the UMM-6 with Windows 7 without any problems.  Is the blue LED on the mic body lit when you have it plugged into the USB port?  Have you tried it on a different USB port?
post #1463 of 23602 Old 02-19-2013, 12:15 PM
Liked: 4326
Same here.  Win7 is not the issue.
post #1464 of 23602 Old 02-19-2013, 12:19 PM
Pres2play's Avatar
Quoted: 678 Post(s)
Liked: 325
The blue light is lit and I tried all three USB ports on my Asus lappy. Guess I'll have to return it tomorrow:(
post #1465 of 23602 Old 02-19-2013, 12:21 PM
Liked: 4326
Yes, unfortunately it sounds like you have a bad mic.  The only other thing you might try is plugging it into a different computer, perhaps a friend's, or one at work?  This would rule out the laptop as being the issue.
post #1466 of 23602 Old 02-19-2013, 12:32 PM
kbarnes701's Avatar
Liked: 5262
It\s odd that the mic is defective though. I can believe this with an out-of-the-box product, but Herb has calibrated this mic and it must have worked when he did that surely?  HST I can't think of anything else to suggest. If Windows and REW can both 'see it', then it ought to, well, just work.
post #1467 of 23602 Old 02-19-2013, 03:14 PM
JChin's Avatar
Quoted: 377 Post(s)
Liked: 210
Great, so point the mic up toward the ceiling when I take measurement, correct?
JChin is online now
post #1468 of 23602 Old 02-19-2013, 03:16 PM
Pres2play's Avatar
Quoted: 678 Post(s)
Liked: 325
Geez, forgot all about my desktop PC. I'll try it when I get home.
post #1469 of 23602 Old 02-19-2013, 03:17 PM
JChin's Avatar
Quoted: 377 Post(s)
Liked: 210
Hi Pres2play, after making the changes try shutting down or restart lappy. Your laptop may require the reset for the changes to take effect.
JChin is online now
post #1470 of 23602 Old 02-19-2013, 03:23 PM
Pres2play's Avatar
Quoted: 678 Post(s)
Liked: 325
Agreed. I'm hoping it's just some weird setting on the laptop. I'll know definitely when I plug into my PC tonight.
Dayton , Dayton Audio , Room Equilizer Wizard Rew
