Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 505 - AVS Forum | Home Theater Discussions And Reviews
 1713Likes
Old 06-09-2015, 07:36 PM
LastButNotLeast's Avatar
Quoted: 1480 Post(s)
Liked: 1077
Originally Posted by ahblaza View Post
So Windows 10 is the same as 8.1 as far as mic values in decibels, 0.0dB = 52%........
Only while it's in beta.
ahblaza likes this.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
LastButNotLeast is offline
Old 06-09-2015, 10:29 PM
DaveyMac's Avatar
Quoted: 570 Post(s)
Liked: 104
Originally Posted by lovingdvd View Post
I bought my from Cross-spectrum.com. The mics were back ordered but I didn't have to wait long, and they processed my order very quickly. They were also very fast to response to some emailed questions. I went with them because they provide a more complete calibration file (wider range) than the MiniDSP one and I suppose it may be slightly more accurate as well. I posted my calibration file from MiniDSP vs CSL by way of a REW analysis a few pages back if anyone is interested.
You may also want to get a boom/mic stand. Its been very handy and worth the $25 (Amazon). If you get a stand and the UMIK-1 is too narrow to fit the thread on the stand, just take out the gold adapter insert that is in the UMIK-1 clamp and it'll fit the larger thread on the boom.
Thanks, I have a pretty nice stand with my XTZ room analyzer. I'm just going to REW so I can auto upload target curve PEQS to minidsp 2x4.
DaveyMac is offline
Old 06-10-2015, 06:20 AM
artur9's Avatar
Quoted: 545 Post(s)
Liked: 186
Originally Posted by Soulburner View Post
Also, this lets you maximize the distance between the rear wall and your ears. If your rear wall is reflective, it should be at least 10 feet from your ears… otherwise it needs treatment (more on this later)."
... From the article, I get the impression that it's really important to avoid sitting near the rear wall, ...
Floyd Toole recommends always treating the rear wall, IIRC, and that has been some of my most effective/satisfying treatments. I use absorption.
I think his current recommendations are lots of diffusion there. In your case shelves full of books might do the trick although they aren't the best diffusors. Or convince observers that your diffusors/absorbers are modern art.
artur9 is online now
Old 06-10-2015, 08:04 AM
SandstormGT's Avatar
Quoted: 203 Post(s)
Liked: 128
Originally Posted by DaveyMac View Post
Does the Amazon one have the '90 degree cal' file that I've seen being referred to as important?
Yes, both files get downloaded from the MiniDSP site. That was actually something I was confused about when setting everything up on Saturday...Should I be using the 90 degree cal file or the original one?
SandstormGT is offline
Old 06-10-2015, 09:13 AM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6504 Post(s)
Liked: 3611
The guide clearly states that the 90-degree file is used. Have you read the guide?
AustinJerry is online now
Old 06-10-2015, 10:07 AM
Quoted: 203 Post(s)
Liked: 128
I guess I was unclear about when I was confused....I didn't know which one to use because the guide doesn't state to use the 90 degree file until 7 pages after the REW program asks for it.
When I opened REW, it immediately asked me what calibration file to use, since the guide didn't state to use the 90 degree cal file at that point, I guessed at it myself and chose the 90 degree.
Obviously, later in the guide it clearly states when setting up the MIC, to use the 90 degree file.
Forgive me for not skipping around all the pages to find the information initially, I am working with a printed out copy...
I also see it is stated in page 3 of the guide to use the 90 degree file, I clearly forgot/missed this between the 30+ pages between when I had to use the information. I am going to throw the binder away and use the searchable PDF.
Soulburner and ahblaza like this.
Old 06-10-2015, 10:09 AM
jim19611961's Avatar
Quoted: 449 Post(s)
Liked: 153
Bookshelves, at best, may scatter some of the high frequencies (>4k). But this scattering is going to be uneven and unpredictable. Much below 4K, bookshelves neither scatter, diffuse or absorb (much).
Bookshelves, at worst, might be worse than a bare wall because of this uneven and unbalanced high frequency redirection.
ahblaza likes this.
My Room
My Music
Rega - Apollo, Rega - DAC, Goldpoint Passive, Classe CA-100, Crown XLS 1002, miniDSP
Jenzen Next
jim19611961 is offline
Old 06-10-2015, 10:54 AM
artur9's Avatar
Quoted: 545 Post(s)
Liked: 186
OK, how about this (completely tongue in cheek ):
Bookshelves filled with "books". The books are actually small slabs of rockwool with acoustically transparent dust jackets.
That way one can seem as erudite as one pleases (Shakespeare? Jacqueline Susann?..)
Old 06-10-2015, 01:52 PM
ahblaza's Avatar
Quoted: 1495 Post(s)
Liked: 1596
Once you get the REW program working right and launch it you won't be asked what cal file to use and if it does happen it will automatically go to the 90 file and just click open. That's what I am accustomed to with 8.1. I don't know how this is affected with other OS's or versions of Windows, probably not at all.
ahblaza is offline
Old 06-10-2015, 02:11 PM
Quoted: 203 Post(s)
Liked: 128
You are correct, I was simply referring to the first time I opened REW, I was trying to follow line-by-line on the guide and REW had a popup immediately open upon first opening asking me what cal file to use, I didn't see anything about this at the point I was at in the guide, so I just took a stab and used the 90-degree cal file, which after making my way further through the guide, was the right decision.
Old 06-10-2015, 02:32 PM
Liked: 3611
Step 16, p. 38, specifies what cal file to use. Even if you had made the wrong selection earlier, you would have corrected yourself in Step 16, I believe.
Old 06-10-2015, 03:21 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 379
What he's saying is that there are a few points in this process where people get stumped because things don't line up quite 100% with the guide. For example the issue outlined above, and the part where it has you calibrate your mic only to find out pages later that it was not necessary with the UMIK. Perhaps some reorganizing or maybe some side notes would help.
Soulburner is offline
Old 06-10-2015, 03:54 PM
Liked: 3611
Do me a favor. Open the current guide revision and go to the section titled "Mic Calibration". Read the note immediately following the title.
"This section deals with manual microphone calibration. If your microphone has a calibration file with a “sensitivity parameter”, manual calibration is not required. Please skip to the section “USB Microphones with Sensitivity parameters: Special Considerations."
It is not like I don't see people's useful feedback and incorporate it into the guide. In return, it would be nice if you didn't bring up the same things over and over again.
Alan P and ahblaza like this.
Old 06-10-2015, 03:56 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 379
I'm glad it was updated, Jerry. Your guide has been very helpful.
Old 06-10-2015, 10:12 PM
ahblaza's Avatar
Liked: 1596
Being a first time beginner using REW I was so intimidated with this program until I spent many weeks on this thread and found Jerry's guide which I believe I would have given up without.
I tried doing one step at a time following Jerry's guide but soon found out it was more frustrating this way.
Reading through the guide first will save you a lot of time and encourage you to proceed, matter of fact I read the trouble shooting section first as I knew I would have so many questions and didn't want to ask here as I was sure they had already been addressed.
Thank you Jerry for all that you have done and continue to do, without you I wouldn't be sharing my experiences in the REW thread.
Cheers Jeff
AustinJerry likes this.
ahblaza is offline
Old 06-11-2015, 11:00 AM
Quoted: 203 Post(s)
Liked: 128
Sorry to get your blood pressure up, I will no longer post in this thread. Good day.
Old 06-11-2015, 12:30 PM
ahblaza's Avatar
Liked: 1596
Hey Sands don't take this as an assault against you, it can get frustrating being an author of a guide and constantly answering questions that have already been answered in the guide. Your posts may help someone else in this thread, and we all need help, maybe not all
So hang around, it surely will be beneficial to you, there's a vast amount of knowledge here that you can't get anywhere else.
Jeffrey
ahblaza is offline
Old 06-12-2015, 01:41 PM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 2983
Here are a couple of charts
Subs XT32 Off
Subs XT32 On
65E6P / 65EF9500 / DMP-UB900
AV7702II / Outlaw 7125
RF7II's / RC64II / Dual FV15HP's
gadgtfreek is online now
Old 06-12-2015, 01:43 PM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 2983
All Speakers Xt32 On
Old 06-12-2015, 01:45 PM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 2983
Crossover Question:
XT32 sets my mains at large and my center to small and 40. Looking at 60hz and 80hz xover, does it not look like 60hz and small would be a good choice?
XT32 engaged, xovers for mains and center at 60hz
Xovers at 80hz
Here are the speaker set at 40hz
I reduced master volume by 10db when running the subs for the first two charts.
Old 06-12-2015, 02:39 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 379
Subs XT32 Off
Subs XT32 On
Just a tip, it would be easier to compare if you overlay them on one graph. It looks like Audyssey is doing a good job flattening your FR in areas not dominated by room nulls.
Old 06-12-2015, 02:49 PM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 2983
I almost did, but then you get people that didnt want them overlayed. Those are easy enough to compare. One thing about this thread is no one is every happy with your chart layout
But you are right, it did a good job with from 40-90 IMO.
Old 06-12-2015, 03:19 PM
Liked: 3611
You may think that everyone's immediate reaction is that they don't like the graphs as presented. But you should ask yourself the question, "How can I present the data in a way that exhibits the point I am trying to make, or highlights the differences I am asking about?"
So, for example, if you are trying to get feedback regarding what crossover to use, present the same speaker (e.g. the center channel) showing each of the crossover choices. Having all of the measurements overlaid on the same graph highlights the difference slopes and makes the answer more obvious.
Keep trying--your presentation skills will get better!
Old 06-12-2015, 04:22 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 379
When I first started posting graphs, I got blasted by an unnamed expert for having 2db resolution. I told him that I have no control over it, yet he instated that I can fix it by adjusting the limits (they were already set). The guy got so irate that he basically rage quit.
It turns out, that despite his insistence to the contrary, REW is making the decision regarding the db increments on the left based on your screen resolution. When I run the program full screen on my 27" 2560x1600 monitor it chooses 2db. When I shrink the window a bit it reverts to 5db. So to keep everyone happy I just keep the window size down.
Anyway, from what I've read your big dip from 100-300Hz is going to be pretty important, being right in the range of human speech and a lot of musical instruments. Try moving your speakers and your seat forward and back and note any changes.
The dip at 22Hz will be an issue with LFE effects in some movies. That's going to come down to sub and seat placement. Of course room layout will dictate how much flexibility you have.
gadgtfreek likes this.
Old 06-12-2015, 06:37 PM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 2983
I have a bunch more charts to post in a second, maybe everyone will be happy
I am stuck with the subs, not much to do there, BUT, I can move my mains back as much as 12". Center has no movement really. I know these dips and dives an be issues, but one perspective I have to keep is before I even fired up REW, this thing sounded great. Now I would like to fix what I can, thats within reason, but I do not intend on obsessing either. Its a fun process that I want to aid me, not dive me nuts (short drive).
There are a few things I want to address in the current charting I have done, before I start moving speakers.
Old 06-12-2015, 06:41 PM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 2983
Subs:
XT32 on Red, Off in Blue
Red is subs setup with crossovers bypassed before running XT32 (I have had problems here in the past)/Blue is plate amp xovers set to 80hz before running XT32
Thought on 80hz vs bypassed?
Old 06-12-2015, 06:45 PM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 2983
80hz vs 60hz for mains and center
FR Blue 80hz/Red 60hz
FL Blue 80hz/Red 60hz
Center Blue 80hz/Red 60hz
Old 06-12-2015, 06:55 PM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 2983
All speakers no XT32
All speakers with XT32
Center XT32 Blue/off Red
FR XT32 Blue/Off Red
FL Xt32 Blue/Off Red
Old 06-12-2015, 08:03 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 379
80hz looks better to me.
By "crossovers bypassed", do you mean the knob is turned all the way? I would always leave it that way when using bass management. I don't know if there's a clear winner from your graphs.
Old 06-12-2015, 08:09 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 379
Also, I'm curious if you use Audyssey flat and use the bass tone control, does the 100-300Hz dip come up at all?
Dayton , Dayton Audio , Room Equilizer Wizard Rew
