Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 519 - AVS Forum | Home Theater Discussions And Reviews
 2285Likes
post #15541 of 23602 Old 07-31-2015, 03:47 PM
PlasmaPZ80U's Avatar
Quoted: 2315 Post(s)
Liked: 716
Originally Posted by AustinJerry View Post
Yes, assuming room correction did a good job.
good to know, I was wondering if it was really 10 dB louder for the sub with actual content
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
SVS Prime Bookshelf and Prime Center
Sony SS-CS5 Surrounds and Cambridge S20 Rear Surrounds
Rythmik LV12R
PlasmaPZ80U is online now
post #15542 of 23602 Old 07-31-2015, 04:56 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 382
The LFE track is encoded at 10dB lower than the other tracks. The AVR automatically adds the 10dB back, so there is no action required on your part, nor should you be concerned.
So the reason why REW ends up +10db for the sub LFE channel is because they aren't factoring in -10db to compensate for your AVRs +10db, which is assuming an input of -10db. Wow.
What started all this mess in the first place, I wonder?
Soulburner is offline
post #15543 of 23602 Old 07-31-2015, 05:18 PM
Stereodude's Avatar
Quoted: 3454 Post(s)
Liked: 2525
No, the reason it ends up +10dB is because you don't understand how the LFE channel works and therefore don't adjust your system to get the same SPL as the others when measuring.
Someone decided the LFE channel should be capable of 115dB whereas other channels were capable of 105dB. That means the same digital signal will yield different playback levels depending on the channel.
ahblaza likes this.
Stereodude is online now
post #15544 of 23602 Old 07-31-2015, 06:29 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 382
I don't think you understood the question. In REW, it is commonly reported in this thread that HDMI 4 gives +10db over the other channels. Jerry told us this is because the AVR makers add +10db to the LFE channel.
But if the AVR is adding 10db to LFE, and the LFE track really is, as Jerry tells us, encoded 10db lower by the movie studios, they'd cancel out. Hence the confusion.
post #15545 of 23602 Old 07-31-2015, 08:35 PM
Stereodude's Avatar
Liked: 2525
Yes, that's correct.
If the studio wants something in the LFE channel to play at the same SPL as the other channels them they would reduce the signal by 10dB compared to the other channels. However, they're certainly not going to do that for all LFE content. Ultimately, they mix for what they want during playback and encode the signal accordingly. It seems like you're over thinking this 10dB offset that gives the LFE channel an additional 10dB of output capability.
ahblaza likes this.
post #15546 of 23602 Old 08-01-2015, 12:52 AM
3ll3d00d's Avatar
Quoted: 1666 Post(s)
Liked: 646
The confusion seems to be that you think the REW signal is encoded differently according to which channel you use and respects some domain specific (film) encoding standards (hence is designed for use with AVRs only).
This isn't the case, it is just a signal generator that sends a certain scale signal and leaves any downstream processing to do whatever it wants. You therefore have to understand your signal chain if you want to understand the reported output.
ahblaza likes this.
3ll3d00d is online now
post #15547 of 23602 Old 08-01-2015, 03:59 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 382
That makes more sense.
Not quite. From what I was reading it sounded like this: all signal levels from REW are the same, but AVR is boosting LFE 10db. However I saw what Jerry said and it got me caught up on the idea that ALL movies will have their LFE -10db, and since REW isn't a movie with that offset you end up with an extra 10db over the other channels. While the math works out in the end, the reasons for it I didn't understand correctly.
post #15548 of 23602 Old 08-01-2015, 04:13 AM
IgorZep's Avatar
Quoted: 395 Post(s)
Liked: 190
It doesn't boost LFE 10dB (if it was done on the DSP we would get heavy clipping on the subwoofer). It is better think about it this way:
1) AVR *calibrates* subwoofer output so it has 10dB more loudness headroom than satellites (the voltage at the pre-outs could still be the same or even lower than satellites - it depends on the gain set at the subwoofer, so it is not 'electrical' or 'digital' boost, it is setting the gain structure of the system so the maximum loudness of the channel is 10dB higher).
2) Pass LFE as is to the subwoofer output channel (that is calibrated to sound 10dB louder for the same input signal level).
3) Attenuates redirected bass by 10dB so it is the same loudness at both sides of the crossover.
3ll3d00d, Soulburner and ahblaza like this.
IgorZep is offline
post #15549 of 23602 Old 08-01-2015, 03:32 PM
RayDunzl's Avatar
Quoted: 1230 Post(s)
Liked: 1431
I just thought I'd throw this in...
I'll be back later...
System links::: 1.5RQ > digits from all sources > 1177a > OpenDRC-DI with AcourateDRC > DEQ2496 > DAC2 > KCT > FPB 350mcx > reQuest + Cheezewoofer Wattless Deluxe > Sweetspot
RayDunzl is offline
post #15550 of 23602 Old 08-01-2015, 04:12 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 7722 Post(s)
Liked: 4323
That is a nasty looking waterfall, Ray. Have you considered treatments?
ahblaza likes this.
AustinJerry is online now
post #15551 of 23602 Old 08-01-2015, 06:21 PM
LastButNotLeast's Avatar
Quoted: 1804 Post(s)
Liked: 1416
Earmuffs.
ahblaza likes this.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
Don't guess, measure: Getting Started With REW: A Step-by-Step Guide
LastButNotLeast is offline
post #15552 of 23602 Old 08-01-2015, 07:24 PM
ahblaza's Avatar
Quoted: 1969 Post(s)
Liked: 2218
You guys are great, good place to hang out, learn and laugh a lot............
Icebergs, ear muffs and room treatments, I'm still laughing
ahblaza is online now
post #15553 of 23602 Old 08-02-2015, 07:17 AM
craig john's Avatar
Quoted: 567 Post(s)
Liked: 806
The problem is that you are confusing the LFE channel and the subwoofer output. They are 2 different things. The subwoofer output contains BOTH the LFE channel and the re-directed bass from any channels that have Bass Management applied, (i.e., set to "Small.") However, the LFE channel 10dB boost in ONLY applied to the LFE channel, and it is applied BEFORE the LFE channel is combined with the re-directed bass.
REW doesn't output anything on the LFE channel. Therefore, the signal from REW never "sees" the LFE boost. If you're setup with the left and right channels being output to the receiver, and the speakers are set to "Small" in the receiver, the subwoofer output only contains the re-directed bass from the left and right channels. There is no LFE channel... and no 10 dB LFE channel boost.
Having said that, if you calibrate with REW using the re-directed bass from the L/R channels, you'll be properly calibrated and your receiver will take care of adding the LFE channel boost. If you want to measure the LFE channel, you need to get a test disc with test tones on the LFE channel. The only one I know of is the Goldline 5.1 Audio Toolkit:
http://www.gold-line.com/51atdvd.htm
See attachment, Chapter 16.
Craig
Lombardi said it:
"Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #15554 of 23602 Old 08-02-2015, 07:37 AM
Liked: 4323
Craig
AFAIK, Craig, the output from REW HDMI4 is indeed the LFE channel. If your REW setup supports a full 7.1 HDMI interface, you could easily test this out. Send the low frequency test tone to Left+Right, turn the Left and Right amps off, and measure the signal coming from the sub channel only. Then output the same test tone to HDMI4, measure the signal, and see if it is 10dB higher. Unfortunately, my laptop only supports 2.0 HDMI, so I cannot run the test myself.
muffinmcfluffin and ahblaza like this.
post #15555 of 23602 Old 08-02-2015, 07:50 AM
Liked: 716
Mine has 7.1 support and the LFE channel is 10 dB higher.
One thing I'm worried about is losing full 7.1 HDMI support when upgrading to Windows 10.
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #15556 of 23602 Old 08-02-2015, 08:57 AM
craig john's Avatar
Quoted: 567 Post(s)
Liked: 806
Thanks for the clarification Jerry. I'll check this the next time I set up REW for measurements. I've only ever used REW in 2-channel mode to measure the L, C, R and subs.
Craig
Lombardi said it:
My System
post #15557 of 23602 Old 08-02-2015, 11:12 PM
Frank D's Avatar
Quoted: 383 Post(s)
Liked: 96
Same here hdmi 4 does measure 10 db higher from REW.
Frank D is offline
post #15558 of 23602 Old 08-03-2015, 12:06 PM
Liked: 716
Regarding the sub distance tweak, can I adjust sub trim in the AVR afterwards without needing to recheck/fine tune sub distance again?
post #15559 of 23602 Old 08-03-2015, 12:07 PM
Liked: 4323
Trim and delay are completely unrelated.
post #15560 of 23602 Old 08-03-2015, 12:39 PM
Liked: 716
Good to know, that should make things easier
post #15561 of 23602 Old 08-04-2015, 09:37 PM
CherylJosie's Avatar
Quoted: 732 Post(s)
Liked: 297
Originally Posted by jim19611961 View Post
If you share your mdats, ill take a look.
The plots for front, side, rear etc. are composite responses with two channels driven.
The plots for left, right etc. are single channel responses.
The full mono plots are all channels driven.
The full mono 1M record is long measurement. The rest are all 128K. Not sure if it matters.
I suspect you want the ETC off the center, front right, front left etc. sweeps but not the front, high wide etc. composite response with two channels driven. I took a quick look and they seem better than they were before but not sure. I still cannot read the distance off the plot (the user interface does not let me drag the cursor to view the distance). I suspect there is a simple formula in the REW guide that lets me calculate a distance from the time. I already treated the rear reflection and the side reflections are hard to treat due to room geometry but if I can identify one or two of them splattering several channels I might try.
You might also want the full mono 1M record to investigate the decay. It varies between 200ms in the treble and 300ms in the bass except for that ring at 20Hz that I was not able to EQ out no matter how I tried. There is also a little bit of resonance at 47Hz that seems related to the 12' depth of the room as well as maybe the 24' width.
Thanks for the offer and I look forward to your insights. I will be checking too in case I can figure it out how to interpret some of the info in there.
final eq.zip
CherylJosie is offline
post #15562 of 23602 Old 08-04-2015, 09:40 PM
Quoted: 732 Post(s)
Liked: 297
In the Linux world YMMV...
post #15563 of 23602 Old 08-04-2015, 09:48 PM
Liked: 4323
^ What exactly is the purpose of the full mono measurement with all channels driven? In what situation would your audio system be outputting an identical signal to all channels? I would argue that this never happens, so question what this measurement would reveal.
post #15564 of 23602 Old 08-04-2015, 10:08 PM
Quoted: 732 Post(s)
Liked: 297
Originally Posted by muffinmcfluffin View Post
Does anyone have a house curve answer I was referring to earlier? Across from 15Hz-20kHz, do you really want the whole thing to be flat? Or do you want it to slope off as you go higher? I have a feeling it's going to sound too bright if it doesn't slope off.
And how do you determine what this slope is?
https://drive.google.com/file/d/0B97...ew?hl=en&pli=1
Check the straightish green trace on slide 23 and the straightish red trace on slide 24. That is the coveted 'Harman target' that users of Dirac get an approximation of as their default (so I have read).
http://www.bksv.com/doc/17-197.pdf
Figure 5 is an older curve from an earlier time.
Notice that while Harman's curve attenuates 20KHz by ~12dB, B&K attenuates 20KHz by ~6dB. Probably best to pick something in the middle IMO given that my system with an approximation of Harman's curve in manual EQ sounds slightly muffled (or is that my hearing?).
My opinion on how to determine the slope is to set up your room treatments first to get broadband decay of somewhere between 300ms and 500ms (depending on multichannel or stereo system) and then measure all your speakers with no EQ and average their responses in REW. The speakers will tell you what your target should look like.
This approach of mine is controversial, but what I found is that in a treated room the natural rolloff of my speakers already approaches the Harman target so I am assuming that means they did something similar when developing their target.
The principle I go by is that designers make speakers have flat on-axis anechoic response and humans can perceive the general character of that flat on-axis anechoic response even after the speaker is placed in a room, but the room EQ cannot.
So what to do is to let the no-EQ microphone measurement pick up the general trend of the in-room response and then straighten the measured response with EQ until it is a straightish line, or maybe roll off the bass a little as B&K did since speakers tend to naturally do that anyway in a room past their bass extension limit and humans probably expect to hear that rolloff in a room.
muffinmcfluffin likes this.
post #15565 of 23602 Old 08-04-2015, 10:11 PM
Quoted: 732 Post(s)
Liked: 297
I was checking my room treatments to see how well they were soaking up energy so I used all channels driven to excite all the reverberations simultaneously and plotted the spectrogram above noise floor. At least, that is how I was led to believe I should check the reverb time.
Brand new at this stuff. Just got the crossovers and manual EQ set up. Now looking at the room treatments to see if they can be improved.
post #15566 of 23602 Old 08-04-2015, 10:22 PM
Liked: 4323
Treatments are designed to control bass ringing in the modal region, below 300 Hz (bass traps), or to control reflections in the spectral region, above 300 Hz (broadband traps),
To assess effectiveness of bass traps in controlling bass ringing, measure left+right+subs (or center+subs), and look at either the waterfall or the spectrogram.
To assess effectiveness of broadband traps in controlling spectral reflections, measure individual speakers and examine the ETC graph.
Soulburner and PlasmaPZ80U like this.
post #15567 of 23602 Old 08-05-2015, 05:40 AM
artur9's Avatar
Quoted: 673 Post(s)
Liked: 241
I resurrected my analog/vinyl system and found this stereo imaging test disk among my old records.
It's a bit freaky how reflections really mess with the imaging the disk's mix is trying to achieve. One example is that I have a wall about 5 feet to the right of the right speaker. Much of the time whatever is supposed to be in the right channel is floating in space about 1/2 way between the speaker and the wall. Sometimes the center image is there.
I find it very disturbing so I will need to console myself by making more treatments
Alan P likes this.
artur9 is offline
post #15568 of 23602 Old 08-05-2015, 05:52 AM
jim19611961's Avatar
Quoted: 449 Post(s)
Liked: 153
final eq.zip
I get an error opening the link.
My Room
My Music
Rega - Apollo, Rega - DAC, Goldpoint Passive, Classe CA-100, Crown XLS 1002, miniDSP
Jenzen Next
jim19611961 is offline
post #15569 of 23602 Old 08-05-2015, 08:00 AM
Alan P's Avatar
Quoted: 5136 Post(s)
Liked: 3836
Same here, invalid zip file.
Alan P is offline
post #15570 of 23602 Old 08-06-2015, 06:26 PM
Quoted: 732 Post(s)
Liked: 297
Sorry about that. here:
https://www.dropbox.com/s/w7h439mppn...%20eq.zip?dl=0
Dayton , Dayton Audio , Room Equilizer Wizard Rew
