Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 529 - AVS Forum | Home Theater Discussions And Reviews
 2273Likes
post #15841 of 23551 Old 08-26-2015, 06:42 AM
markus767's Avatar
Quoted: 4188 Post(s)
Liked: 1577
Originally Posted by Audionut11 View Post
use spectrogram instead, since it's less likely to show false results.
They show exactly the same. It's just a different visual perspective. The devil is in the window settings.
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #15842 of 23551 Old 08-26-2015, 06:52 AM
PlasmaPZ80U's Avatar
Quoted: 2289 Post(s)
Liked: 705
Originally Posted by PlasmaPZ80U View Post
However, this brings up a question about using the measurements to optimize speaker placement or sub placement or for the sw distance tweak. For those measurements, (especially in the 15Hz to 300Hz region) do I want to use psychoacoustic smoothing or no smoothing at all?
If it's below 300hz, no smoothing. But if the response has large swings in magnitude, you may be better served by applying some smoothing. Depends on how adapt you are at reading the useful information from a magnitude response I guess. Applying more smoothing takes out some of the mental work.
Personally, I wouldn't use psycho anything smoothing for these things. Either 1/48, 1/24, 1/12, 1/whatever.
Psychoacoustics is one of those things that we are far from fully understanding imo. Once everything has been dialed in, then you can apply some psy smoothing for ****s and giggles.
Okay, I'll either use no smoothing or minimal fixed smoothing when doing the sw distance tweak.
PlasmaPZ80U is online now
post #15843 of 23551 Old 08-26-2015, 06:56 AM
Audionut11's Avatar
Quoted: 162 Post(s)
Liked: 65
So really, what you're saying is that posting graphs is pointless, and only mdats should be considered. I mean, when was the last time someone new to the thread actually followed the effort Jerry put into the guide!!!
Audionut11 is offline
post #15844 of 23551 Old 08-26-2015, 06:58 AM
LastButNotLeast's Avatar
Quoted: 1792 Post(s)
Liked: 1403
Rarely, which is why they need to be encouraged to read Jerry's fabulous guide.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
Don't guess, measure: Getting Started With REW: A Step-by-Step Guide
LastButNotLeast is offline
post #15845 of 23551 Old 08-26-2015, 07:03 AM
Audionut11's Avatar
Quoted: 162 Post(s)
Liked: 65
The forum software should just be modified to recognize a REW screenshot, and throw an error requiring an accompanying mdat.
post #15846 of 23551 Old 08-26-2015, 07:08 AM
markus767's Avatar
Liked: 1577
No, that's not really what I'm saying. Posting graphs isn't pointless (the REW default is actually quite useful for spotting modal problems) but you need to understand what exactly they are showing. The graph posted above clearly isn't a meaningful representation of the actual room decay. I encourage everyone to experiment with impulse response windowing and things should become clearer.
It's true that people don't seem to read Jerry's guide but it's also not linked in the first post of this thread...
Markus
post #15847 of 23551 Old 08-26-2015, 07:19 AM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 7558 Post(s)
Liked: 4223
In my experience, it is hard to control bass resonance at 115dB. I know you bassheads like to rattle the windows, but I am more interested in tight, controlled bass response when listening to music at reasonable levels. That is why a waterfall at more reasonable levels using similar REW settings is more revealing to me.
robbiesd likes this.
AustinJerry is online now
post #15848 of 23551 Old 08-26-2015, 07:20 AM
Audionut11's Avatar
Quoted: 162 Post(s)
Liked: 65
Experiment with impulse response windowing and you'll know what I was really saying.
An area where I have been lacking. I have some understanding of windowing the higher frequencies, but not much else. What tell-tale sign leads you to believe there is an issue with how the graph in question is presented, besides issues with the scale?
And the question begs, how many people in this thread are capable of determining said issue? Wouldn't it make far more sense, for people new to REW to simply post an mdat? I was being facetious BTW, but as always, you've pushed the discussion towards expanding ones knowledge.
https://en.wikipedia.org/wiki/Transient_%28acoustics%29
post #15849 of 23551 Old 08-26-2015, 07:21 AM
Liked: 4223
Unfortunately, the thread starter has been MIA for a very long time. It is possible that a request to a moderator could result in adding the link, if that is what everyone recommends.
shpitz, Audionut11 and Saril like this.
post #15850 of 23551 Old 08-26-2015, 07:22 AM
markus767's Avatar
Liked: 1577
I certainly do
Markus
post #15851 of 23551 Old 08-26-2015, 07:26 AM
Liked: 4223
If someone were kind enough to summarize the best way to interpret the waterfall, I would be more than willing to update the Guide. And in anticipation to your response, Markus, that proper interpretation methods have been discussed a million times, I don't feel comfortable with digging out the various discussions, determining which are "the right way to interpret the waterfall", and then summarizing them. If you were to do that, we could put this to rest once and for all.
post #15852 of 23551 Old 08-26-2015, 07:33 AM
markus767's Avatar
Liked: 1577
There is no 'issue' with the graph. The issue is how the graph got interpreted
By the way, 3ll3d00d explained how waterfall, spectrogram and decay are 'constructed':
Markus
post #15853 of 23551 Old 08-26-2015, 07:34 AM
Liked: 4223
I certainly do
Request has been submitted: http://www.avsforum.com/forum/43-for...l#post36791690
post #15854 of 23551 Old 08-26-2015, 07:41 AM
torii's Avatar
Quoted: 1477 Post(s)
Liked: 794
i am confused on what graphs to use after measurements are taken and how to interpret them? Is there a list for the 1st timer? I created a thread, but I guess thats not the right way? looking for a small 5 step program.
any thoughts? 15k replies is a bit too much to sort thru imo.
rew results need feedback 1st try
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5 Subs: Rythmik FV25HP, Rythmik FV15HP
torii is offline
post #15855 of 23551 Old 08-26-2015, 08:30 AM
Liked: 1403
I think it should be sent once as a pm to anyone who posts here.
With a quiz at the end.
Michael
Alan P likes this.
post #15856 of 23551 Old 08-26-2015, 08:39 AM
Liked: 1403
Repost from another thread because I think it will be of interest to many here:
free AES article by Floyd Toole on Room EQ
http://www.aes.org/journal/online/JAES_V63/7_8/#paper1
The Measurement and Calibration of Sound Reproducing Systems
Open Access
Author:Toole, Floyd
Affiliation:Retired, Consultant to Harman International
For decades, it has been widely accepted that a steady-state amplitude response measured with an omnidirectional microphone at the listening location in a room is an important indicator of how an audio system will sound. This paper examines both small and large venues, home theaters to cinemas, seeking a calibration methodology that could be applied throughout the audio industry. Room equalization schemes adjust the room curve to match a target believing that this ensures good and consistent sound. The implication is that by making in-situ measurements and manipulating the input signal so that the room curve matches a predetermined target shape, imperfections in (unspecified) loudspeakers and (unspecified) rooms are measured and repaired. It is an enticing marketing story.
JAES
2015 July/August - Volume 63 Number 7/8
Thanks to krabapple for the original post.
post #15857 of 23551 Old 08-26-2015, 08:52 AM
jim19611961's Avatar
Quoted: 449 Post(s)
Liked: 153
Here is the same file presented in PSY and 1/6th octave smoothing. PSY, obviously, favors boosting the higher end gradually beginning at about 1K.
Is also smooths the low end more than does 1/6th.
My Room
My Music
Rega - Apollo, Rega - DAC, Goldpoint Passive, Classe CA-100, Crown XLS 1002, miniDSP
Jenzen Next
jim19611961 is offline
post #15858 of 23551 Old 08-26-2015, 08:59 AM
Quoted: 449 Post(s)
Liked: 153
It might be worth discussing whether the controls box should be included in all posted graphs. Especially encouraged for novice and new posters to this thread.
My Room
My Music
Jenzen Next
post #15859 of 23551 Old 08-26-2015, 09:03 AM
markus767's Avatar
Liked: 1577
Originally Posted by jim19611961 View Post
Attachment 908690
Reading REW help usually helps
"Variable smoothing applies no smoothing below 100 Hz, 1/3 octave above 10 kHz and varies between 1/48 and 1/3 octave from 100 Hz to 10 kHz, reaching 1/6 octave at 1 kHz. Variable smoothing is recommended for responses that are to be equalised. Psychoacoustic smoothing uses 1/3 octave below 100Hz, 1/6 octave above 1 kHz and varies from 1/3 octave to 1/6 octave between 100 Hz and 1 kHz. It also applies more weighting to peaks to produce a plot that more closely corresponds to the perceived frequency response. ERB smoothing uses a variable smoothing bandwidth that corresponds to the ear's Equivalent Rectangular Bandwidth, which is (107.77f + 24.673) Hz, where f is in kHz. At low frequencies this gives heavy smoothing, about 1 octave at 50Hz, 1/2 octave at 100 Hz, 1/3 octave at 200 Hz then levelling out to approximately 1/6 octave above 1 kHz."
Markus
post #15860 of 23551 Old 08-26-2015, 09:14 AM
Quoted: 449 Post(s)
Liked: 153
Yes, I agree. But many folks are more inclined to look at a graph comparison than read the REW help manual
Along similar lines, while Jerry's guide can be most useful, unfortunately, the longer and more detailed it is, the less inclined most people will be to read it.
edit: The PSY REW help definition doesnt explain the apparent high end rise I am seeing.
My Room
My Music
Jenzen Next
post #15861 of 23551 Old 08-26-2015, 09:42 AM
markus767's Avatar
Liked: 1577
The problem is that they look at graphs they don't understand (although they think they do) and as a consequence they draw the wrong conclusions.
I agree. It should cover the basics and get people started.
"It also applies more weighting to peaks to produce a plot that more closely corresponds to the perceived frequency response"
Markus
post #15862 of 23551 Old 08-26-2015, 09:55 AM
Liked: 1403
AustinJerry meets Cliff Notes?
(Do they still have them, or am I dating myself? )
Michael
post #15863 of 23551 Old 08-26-2015, 09:59 AM
Quoted: 449 Post(s)
Liked: 153
I dont think a guide can solve this. To this day, I am still revising how I interpret the graphs. It takes experience to draw proper conclusions. Paramount, IMO, to graph interpretation is separating what is relevant from what is not.
Add to this, there are certain things REW will never tell us. For instance, the direction of a reflection. This alone can cause us to chase red herrings.
My Room
My Music
Jenzen Next
post #15864 of 23551 Old 08-26-2015, 10:02 AM
Quoted: 449 Post(s)
Liked: 153
Michael
A compromise might be to separate the guide into two sections. Basic and advanced. That way, those adverse to long reads can skim the condensed/simplified version, while having the option to explore individual topics in the advanced section as needed.
LastButNotLeast likes this.
My Room
My Music
Jenzen Next
post #15865 of 23551 Old 08-26-2015, 11:47 AM
Quoted: 51 Post(s)
Liked: 9
I have a pretty simple question. It's related to miniDSP 2x4. I was planning to use it in conjunction with REW to equalize the sub. I connected the miniDSP in it's default state b/w the AVR and sub ( by clicking Restore to Default button in the plugin). I then played test tones from my receiver. The test tones from speakers obviously played fine, however the test tones/ bass level from the sub drop significantly when miniDSP is connected b/w the AVR and the sub. If I connect the sub directly to the receiver the test tones from the sub play just fine.
Has anyone seen this before or do I have to make some changes to the miniDSP from it's default state to get the correct bass levels from the sub? Without applying any filters, atleast in it's default state I would expect the bass levels to be same as the bass levels when the sub is directly connected to the receiver.
I don't know if this is the right place to pose this question, if not I'll start a new thread.
nikhilnh is offline
post #15866 of 23551 Old 08-26-2015, 12:18 PM
Liked: 4223
What's you are experiencing is a gain issue. There is a whole section in the MiniDSP Users Guide dealing with gain matching. Another place to look would be in the 2x4 setup document linked in my sig. Once you understand how to set your voltages properly, then your subs may need to have their gain settings adjusted. When you add a component like the 2x4 into the signal path, you should expect to need to make some adjustments to get it dialed in properly.
And yes, I believe this discussion belongs in the MiniDSP thread, not here.
post #15867 of 23551 Old 08-26-2015, 12:25 PM
Liked: 705
Is the MiniDSP unbalanced? If so, the sub might not be getting enough power from the MiniDSP at it's current sub gain knob position (on sub). Also, you may have to configure the MiniDSP input voltage between the two options if yours has them.
In short, the sub trim in AVR and sub gain knob on sub must be set right with an unbalanced MiniDSP to avoid clipping and to get sufficient output from the sub at reasonable listening levels. Odds are in your current configuration the sub is getting less power with the MiniDSP in the chain vs. hooked up directly to AVR.
post #15868 of 23551 Old 08-26-2015, 01:08 PM
Quoted: 51 Post(s)
Liked: 9
Thanks to both, for the suggestions. Yes, the minDSP is unbalanced. I'll have to go through the 2x4 setup doc to gain a better understanding the voltage settings.
Jerry, the DopBox link to the miniDPS 2x4 setup document in your sig is not working.
nikhilnh is offline
post #15869 of 23551 Old 08-26-2015, 01:36 PM
Alan P's Avatar
Quoted: 5083 Post(s)
Liked: 3770
Works for me.
Alan P is online now
post #15870 of 23551 Old 08-26-2015, 02:51 PM
Quoted: 51 Post(s)
Liked: 9
Originally Posted by Alan P View Post
Works for me.
It's working for me too. Might have been a network glitch.
nikhilnh is offline
Dayton , Dayton Audio , Room Equilizer Wizard Rew
