Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 534 - AVS Forum | Home Theater Discussions And Reviews
 760Likes
post #15991 of 15998 Old Yesterday, 09:13 PM
ahblaza's Avatar
Quoted: 852 Post(s)
Liked: 771
Originally Posted by AustinJerry View Post
I don't know the purpose of the 1/3 octave cal files. Why don't you send a note CSL and ask them what they would be used for?
Thanks Jerry, I'll probably never have any use for them anyway. Sorry to be so persistent about nothing except my own curiousness....
ahblaza is offline
post #15992 of 15998 Old Today, 05:02 AM
artur9's Avatar
Quoted: 288 Post(s)
Liked: 113
Originally Posted by BrutalBodyShots View Post
What/where is the setting that I change in REW to output to the headphones?
I am not a Windows user so I cannot answer this. But I am thinking that if you don't know how to do this then there's no way to ascertain if your audio output is set up correctly.
artur9 is offline
post #15993 of 15998 Old Today, 05:15 AM
Defcon's Avatar
Quoted: 130 Post(s)
Liked: 81
Is the mic that comes with Yamaha receivers good enough for this? I'm asking because I read it was calibrated and fine to use.
Defcon is offline
post #15994 of 15998 Old Today, 05:19 AM
Stereodude's Avatar
Quoted: 1977 Post(s)
Liked: 1262
It does. I don't have a set of earbuds but the lady does, when she gets home in a few hours I'll give that a try.
Forget about that for a minute. Can you get any sound from your PC over HDMI via your receiver?
Set your HDMI output to the default sound device and go watch a Youtube video or play an MP3. If you don't hear sound I'd suggest making sure that your X2000 is actually using the HDMI input, not the RCA inputs on the front.
Stereodude is online now
post #15995 of 15998 Old Today, 05:59 AM
DonH50's Avatar
Quoted: 769 Post(s)
Liked: 546
Originally Posted by ahblaza View Post
Guys, please forgive my ignorance, I just got a CSL UMIK and download all the cal files and copied and pasted the sensitivity factor into each file. What is the use for the 1/3rd octave
Frequency response curves at 0°, 45° and 90° angles of incidence. TIA, sorry for the simple question, it's not in Jerry's guide (the only thing that isn't)...
Cheers Jeff
Most pro (and home, if anybody uses them anymore) equalizers are 1/3-octave designs and a lot of venues are, or used to be before the DSP revolution, EQ'd in 1/3-octave bands. That was/is considered sufficient resolution for most venues, and is a compromise between frequency resolution and cost (noise, power, etc.)
Ignore them for REW. Use the high-resolution 90 degree cal file.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #15996 of 15998 Old Today, 06:46 AM
BrutalBodyShots's Avatar
Quoted: 276 Post(s)
Liked: 69
I am trying to help you, but you are not answering the questions I have asked. When you attempt to output the sound using the signal generator, you say there is no sound coming from the speakers. Yet you didn't answer an important question--did REW display an error message? If yes, please take a screen shot and post it.
If no error message is displayed, REW "thinks" it is outputting a sound, but for some reason your AVR is not reproducing it. Back to the speaker level-setting tones, if they are not playing, then your AVR is not functioning properly. Next step would be to perform a microprocessor reset on the AVR. What make and model is it?
No error message in REW. Denon AVR model X2000. Was outputting test tones fine until I started messing with the mic last week.
BrutalBodyShots is offline
post #15997 of 15998 Old Today, 06:49 AM
Quoted: 276 Post(s)
Liked: 69
I will try that when I get home from work tonight. If I'm setting the AVR input to AUX and using the AUX HDMI input on the front of the AVR shouldn't that be the input that is used not the RCA's? I guess there's an off chance that the AUX input on the AVR is bad; this is the first time I've ever tried using it.
post #15998 of 15998 Old Today, 08:45 AM
LastButNotLeast's Avatar
Quoted: 804 Post(s)
Liked: 569
It looks like the AVR is set up to use that input.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
LastButNotLeast is offline
Dayton , Dayton Audio , Room Equilizer Wizard Rew
