Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 544 - AVS Forum | Home Theater Discussions And Reviews
 1779Likes
post #16291 of 21760 Old 09-23-2015, 05:38 PM
BrutalBodyShots's Avatar
Quoted: 353 Post(s)
Liked: 85
Yes, my subs are equidistant from my main seat. They are both 15' from each of my ears.
I need to do a little reading on integrating my subs and my mains now, have not looked much into that yet and I'm sure it will help.
BrutalBodyShots is offline
post #16292 of 21760 Old 09-23-2015, 05:53 PM
PlasmaPZ80U's Avatar
Quoted: 1970 Post(s)
Liked: 565
Originally Posted by AustinJerry View Post
Originally Posted by PlasmaPZ80U View Post
Basically, I'm asking if the plug-in is at defaults when first downloaded and installed to my computer and if so, does synchronizing it with the 2x4 effectively load this default state into the 2x4?
Always reset to defaults as a starting point.
Ok, I'll do that.
Do I need to do that again when switching from my current sub to my new one?
PlasmaPZ80U is online now
post #16293 of 21760 Old 09-23-2015, 06:34 PM
Liked: 565
I was reading the 2x4 guide again and it says to use a y adapter for the 2 way plug-in so that both inputs on the 2x4 are used.... is this necessary for a single sub setup?
post #16294 of 21760 Old 09-23-2015, 08:46 PM
corradizo's Avatar
Quoted: 1047 Post(s)
Liked: 698
corradizo is offline
post #16295 of 21760 Old 09-23-2015, 10:31 PM
ahblaza's Avatar
Quoted: 1514 Post(s)
Liked: 1622
@Jerry , so no matter what flavor of Audyssey you have if your subs are not equidistant from MLP, to properly set up multiple subs I have to set up the delays between subs and this is best accomplished with the miniDSP 2X4 prior to running RC?
After running Audy, the delays between mains and combined subs can be done with the Sub Distance Tweak by adjusting distances (sub channel) in the AVR, correct? TIA
ahblaza is offline
post #16296 of 21760 Old 09-23-2015, 11:13 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 379
^ Not Jerry, but not necessary with XT32 + Sub EQ. With lower versions of Audyssey, yes. Or, you can use the delay on the sub if it is a true global delay and not a simple 0/180 phase control. Some subs such as Rythmik have these.
And the sub distance tweak is always good to try no matter your setup.
ahblaza likes this.
Samsung PN64H5000 (recommended settings)
Denon AVR-X4000
A little R&R: Reaction Audio CX-10 (2) | Rythmik Audio F12 (2)
And a pair of Emotiva Airmotiv 5s
Soulburner is offline
post #16297 of 21760 Old 09-24-2015, 05:00 AM
corradizo's Avatar
Liked: 698
How many subs can xt32 accommodate?
post #16298 of 21760 Old 09-24-2015, 06:16 AM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6701 Post(s)
Liked: 3693
Soulburner has provided an appropriate response.
ahblaza likes this.
AustinJerry is online now
post #16299 of 21760 Old 09-24-2015, 06:20 AM
Liked: 3693
SubEQ HT has two sub channels, and can set independent delays and trims for each channel. You can place more than one sub on each channel using Y-connectors. However, if more than one sub is connected to a single channel, the subs should be equidistant from the MLP. For example, before getting the MiniDSP 2x4, I had four subs connected, two on each channel, with each sub pair placed equidistant from the MLP.
corradizo likes this.
post #16300 of 21760 Old 09-24-2015, 09:22 PM
ahblaza's Avatar
Liked: 1622
Thanks for the reply. I do have a true delay and not 0-180 phase. Thanks again.
ahblaza is offline
post #16301 of 21760 Old 09-24-2015, 09:31 PM
ahblaza's Avatar
Liked: 1622
Jerry, I believe we discussed this a while ago as I mentioned I had two subs upfront equidistant to MLP and was getting two more behind the MLP which would also be equidistant to LP similar to your setup. You mention "before getting the miniDSP 2X4 you had this same setup, did you change anything since getting the 2X4?
ahblaza is offline
post #16302 of 21760 Old 09-25-2015, 02:10 AM
butch666's Avatar
Quoted: 32 Post(s)
Hi guys,
This weekend I am going recalibrate my quite simple 2.1 setup. (Onkyo TX-NR709, B&W DM685+ASW608 and a MiniDSP 2x4)
Previously I have always done the Audyssey calibration first and then used REW+MiniDSP to optimize the bass. But now I have read a few times in this thread that it might be better to use REW+MiniDSP to initially get the best possible response from the sub, and then run Audyssey after this. What are your guys opinions on this?
(Once or twice before Audyssey has for some reason boosted my very low bass <20Hz, which my sub won't really do, so I've had to use the MiniDSP to neutralize this)
butch666 is offline
post #16303 of 21760 Old 09-25-2015, 04:44 AM
AV_mike's Avatar
Quoted: 92 Post(s)
Liked: 87
Originally Posted by butch666 View Post
Hi guys,
I use my MiniDSP2x4 prior to running Audyssey. I have moved the subs all over the room, even into positions that could not be used (middle of the room, etc) just to see if placement would help. With all of that done, and the raw sub response as smooth as I could get it, there were still two large room mode peaks at approx 45Hz & 55Hz - and Audyssey always saw these as the F3 point of the subs. It boosted higher frequencies to match the peaks - and did nothing below those frequencies. With the MiniDSP & REW I can use some PEQ to tame the peaks, and also a High Pass Filter at approx. 16Hz to stop the subs trying to output infra-sonics that they are really not capable of achieving (and the non-dedicated room does NOT like one bit - rattle, rattle). With the PEQ and HPF in place Audyssey 'sees' the real response of the subs in the room and simply fine tunes the whole range - no excessive boost or cut anywhere.
Regards, Mike.
ahblaza likes this.
AV_mike is offline
post #16304 of 21760 Old 09-25-2015, 05:08 AM
butch666's Avatar
Quoted: 32 Post(s)
Thanks for your input Mike.
I've made the following plan for calibrating. Do you see any obvious errors or things that I should do differently?
RESET ALL.....
01. Place Sub in corner....... Measure with REW
02. Place Sub in position 2... Measure with REW
Select location with the best response!
03. Re-measure sub in chosen location.
04. Use REW to generate MiniDSP filters.
05. Apply filters in MiniDSP (+HPF at ~20Hz).
06. Measure sub again to check if it worked.
Repeat 3-6 until best result achieved
07. Run Audyssey
With Audyssey ON
08. Set Crossover to 70 Hz. Measure FR+FL+Sub to see response
09. Set Crossover to 80 Hz. Measure FR+FL+Sub to see response
10. Set Crossover to 90 Hz. Measure FR+FL+Sub to see response
Choose crossover with best response
11. Do Sub-Distance tweak to optimize crossover
Q's:
1. Audyssey Dynamic EQ, ON or OFF when not measuring at reference?
2. When doing sub sweeps, is it sufficient to temporarily set x-over as high as possible,
and keep the front speakers connected. Or is it better to disconnect the fronts? (No HDMI on PC unfortunately)
butch666 is offline
post #16305 of 21760 Old 09-25-2015, 05:31 AM
markus767's Avatar
Quoted: 3676 Post(s)
Liked: 1322
butch666
First measure the near field response of your sub to get a general idea what to expect from it.
Then measure each sub location at several points within the listening are. Select the sub location that...
1. has lowest point to point variance
2. shows the lowest amount of non-minimum phase effects
3. delivers the highest output
Finally apply EQ and optimize the crossover region to the subs.
Alternatively place the sub very close behind your head (<1-2 ft) and run Audyssey. Done.
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #16306 of 21760 Old 09-25-2015, 05:45 AM
butch666's Avatar
Quoted: 32 Post(s)
Originally Posted by markus767 View Post
butch666
Thanks for your input Markus.
Would you mind elaborating a little on point 2. Which graph should I be looking at? And what in the graph should I be looking for?
butch666 is offline
post #16307 of 21760 Old 09-25-2015, 06:09 AM
markus767's Avatar
Liked: 1322
Here's a detailed discussion: http://www.roomeqwizard.com/help/hel...imumphase.html
Markus
post #16308 of 21760 Old 09-25-2015, 07:04 AM
butch666's Avatar
Quoted: 32 Post(s)
Thanks for the link. Think I read that a some time ago as well. It is however a very theoretical approach with little to no information on what to actually do (click) in REW.
For instance how do I do this: (quote from link)
"The minimum phase response is generated by using the measurement amplitude and calculating the corresponding minimum phase from it, using a mathematical relationship between the two that holds for minimum phase systems. By looking at the difference between the measured and minimum phase (the excess phase) and measuring the slope of that difference to find the excess group delay, we get this plot:"
Doesn't seem very obvious does it?
I therefore think the following practical approach might be easier:
1. Measure
2. Apply EQ filters
3. Measure again
4. If filter didn't work, it's most likely non-minimum phase
Of course identifying non-minimum phase effects before applying filters would be slightly faster/easier, but I just do not see how REW can help me do this.
butch666 is offline
post #16309 of 21760 Old 09-25-2015, 07:30 AM
markus767's Avatar
Liked: 1322
Funny, every time the topic means 'you need to learn something new' people use the word 'theoretical'
Click GD > Controls > Generate Minimum Phase there's your Excess Group Delay plot. A lot easier (and way less time-consuming) than trial and error.
Markus
post #16310 of 21760 Old 09-25-2015, 07:39 AM
Liked: 3693
The significant change is that all four subs are connected to a single output on my Marantz 8801 and I no longer use Audyssey SubEQ HT. The reason for implementing the 2x4 was to prepare for the implementation of Dirac LLive using the MiniDSP 88A, which has only one sub channel in my 7.1 configuration. The 2x4 allows me to set the delays outside of the AVR.
And BTW, measuring the bass response after switching from Audyssey to the 2x4, I am able to duplicate the results I was getting with Audyssey (actually improve the results, when you factor in the Dirac Live calibration).
ahblaza likes this.
post #16311 of 21760 Old 09-25-2015, 07:40 AM
butch666's Avatar
Quoted: 32 Post(s)
What's funny about calling a mathematical/theoretical explanation for theoretical?
Funny how some people have to use links and long explanations before coming up with the simple and easy answer people are looking for.
But I do thank you for the easy/simple answer we ended up with in any case ;-)
ahblaza likes this.
butch666 is offline
post #16312 of 21760 Old 09-25-2015, 07:42 AM
markus767's Avatar
Liked: 1322
Well, you first have to understand what you're looking at. If you don't you will most likely draw all the wrong conclusions from measured data. The internet is full of that.
P.S. How to get to the plot is in the link I've provided...
Markus
post #16313 of 21760 Old 09-25-2015, 07:55 AM
butch666's Avatar
Quoted: 32 Post(s)
Not trying to pick a fight here, but the easy answer to:
How do I know what is minimum and non-minimum phase?
"1. Plot the Excess Group Delay. 2. Anywhere the plot is flat is minimum phase."
You might then even add that these are the areas that can be EQ'd as a bonus!
But, again, I thank you for your input and will be using it this coming weekend.
butch666 is offline
post #16314 of 21760 Old 09-25-2015, 08:03 AM
markus767's Avatar
Liked: 1322
Looks like you've learned something! More important than me spitting out words people might or might not believe in
By the way here's a typical example of a dip that can not be equalized.
ID:	960841   Click image for larger version
andyc56 likes this.
Markus
post #16315 of 21760 Old 09-25-2015, 08:13 AM
butch666's Avatar
Quoted: 32 Post(s)
Glad that we zipped up and threw away the rulers :-)
Great graphs!
butch666 is offline
post #16316 of 21760 Old 09-26-2015, 09:57 AM
Liked: 565
Just got MiniDSP 2x4 unbalanced and after hours of issues this is the best I could do:
Do subs sound best at 80Hz and under only (crossovers)?
when I click match response to target it says 75% of the response is above the target... also, would I get better results with match range something else than 20Hz-200Hz?
(more details in link above)
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
post #16317 of 21760 Old 09-27-2015, 08:25 PM
Liked: 3693
Windows 10 update
I recently updated the guide with a section describing the differences with using REW on a Windows 10 system. The key difference I reported was that Windows 10 is not recognizing the mic by its description, and is not automatically loading the sensitivity parameter. This forces Windows 10 users to manually calibrate their mics (assuming they want correct absolute levels, of course).
Subsequently, I have discovered a second anomaly. The guide has instructions for setting the USB mic's gain level in Windows Audio. For Windows 8.1 systems, the recommended mic gain setting is 0dB. In Windows 10, a 0dB gain setting results in a "input level too low" warning when running the measurements sweeps. By increasing the gain setting to +10dB, the warnings go away, and with this setting there is still a reasonable amount of headroom for the measurements.
I have updated the guide with this new tip. On the positive side, as long as you calibrate the mic manually, and set the mic gain to +10dB, REW functions quite well under Windows 10.
post #16318 of 21760 Old 09-28-2015, 12:17 PM
Liked: 565
Does the procedure outlined the MiniDSP guide, REQ EQ tool section, auto generate Modal filters? or just PK filters?
post #16319 of 21760 Old 09-28-2015, 01:00 PM
JohnPM's Avatar
Quoted: 69 Post(s)
Liked: 44
There seems to be some variation in whether and when Win 8.1 and Win 10 recognise the UMIK, I have several examples of the mic and while some appear as generic USB devices others continue to be recognised correctly (earlier versions of Win 8.1 recognised all of them correctly however, so something has changed). miniDSP are investigating.
The low level warning is probably because REW is applying a different threshold for the test when it 'knows' the input is a USB mic, the actual input levels should be the same so the gain could be left as 0 dB and the warning ignored.
JohnPM is offline
post #16320 of 21760 Old 09-28-2015, 01:21 PM
Liked: 3693
Thank you for comfirming that something is amiss, John. As for the low level warning, I will try leaving the gain at 0 and observe the results.
Dayton , Dayton Audio , Room Equilizer Wizard Rew
