Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 550 - AVS Forum | Home Theater Discussions And Reviews
 2220Likes
post #16471 of 23435 Old 10-19-2015, 08:03 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 7439 Post(s)
Liked: 4140
Originally Posted by Sittler27 View Post
I have two SVS PB 12-Plus subs.
Originally Posted by artur9 View Post
You can smooth the bass out quite a bit with 2 subs (although 3 or 4 is better ).
Here is a similar analysis showing the advantages of multiple subs:
AustinJerry's Set-Up
ahblaza likes this.
AustinJerry is offline
post #16472 of 23435 Old 10-20-2015, 06:32 AM
Sittler27's Avatar
Quoted: 747 Post(s)
Liked: 63
Thanks, but I just bought the two PB12s and they are big in the room, so my wife won't go for the money spent and look of yet another sub or two. That would be like $6-7K just on subs.
Sittler27 is online now
post #16473 of 23435 Old 10-20-2015, 06:38 AM
PlasmaPZ80U's Avatar
Quoted: 2229 Post(s)
Liked: 682
Here's one sub in my room. None of these subs are rated for less than 30Hz, BTW.
Now two subs. At this point I could have used parametric EQ to get rid of that peak and things would be pretty good.
And here it is with three subs.
I use the Geddes method for the results above. Something like a MiniDSP helps with that but isn't necessary if your subs have have the proper controls.
An obligatory video (how does one keep this from embedding?!) www.youtube.com/watch?v=SCWL-zusyqw
While 3 subs looks way better, 2 subs doesn't show much improvement (relatively speaking).
(Which makes me wonder if the common advice of getting a second sub is really worth the money or effort to setup/integrate...)
Perhaps eq is more convenient and cost effective...
PlasmaPZ80U is online now
post #16474 of 23435 Old 10-20-2015, 06:51 AM
Quoted: 319 Post(s)
Liked: 54
Dumb question: just bought a Dayton UMM-6 Mic from CSL. Which way should the mic be oriented when measuring? I've seen pictures with up down and horizontal orientation.
Home Theater and Home Automation Enthusiast
MalevolentHamster is offline
post #16475 of 23435 Old 10-20-2015, 07:06 AM
Liked: 4140
For general room-response measurements, place the mic in the MLP with the tip at ear height, pointed towards the ceiling. Use the 90-degree, 1/3 octave calibration file. For "near-field" measurements (which are designed to measure a single speaker's response without the effects of the listening room), point the mic directly at the speaker's dust cap several inches away, and use the 0-degree 1/3 octave calibration file.
post #16476 of 23435 Old 10-20-2015, 07:17 AM
Quoted: 319 Post(s)
Liked: 54
post #16477 of 23435 Old 10-20-2015, 07:27 AM
Liked: 682
Looking at Jerry's sub pairs shows a similar trend. So, does this mean without 3 or 4+ subs, the benefits of multiple subs isn't typically as great as some claim?
Or are there situations where dual subs does make a huge difference in frequency response?
Also, is it better to have a raw (before eq) response with mostly peaks vs. dips since the former can be easily fixed via eq whereas the latter cannot?
And is a flat frequency response for bass really preferred over a house curve of some sort?
I'm not trying to be critical or argumentative, just trying to determine the cost to benefit ratio of 2 subs vs one, particularly with a single listener in one very specific mlp. Especially when DSP is available for eq like with the MiniDSP 2x4 unbalanced.
post #16478 of 23435 Old 10-20-2015, 07:37 AM
LastButNotLeast's Avatar
Quoted: 1773 Post(s)
Liked: 1392
You need to start with a flat response, to which you ADD a house curve.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
Don't guess, measure: Getting Started With REW: A Step-by-Step Guide
LastButNotLeast is offline
post #16479 of 23435 Old 10-20-2015, 07:44 AM
Liked: 682
In my case, I already had a downward sloping raw frequency response from 20Hz to 200Hz or so. By cutting the 2 big peaks and smoothing out the slope, I ended up with a pretty sweet house curve.
If I had used eq to get a flat response from 20Hz to 100Hz or so and then added a house curve, it would have been too much eq/processing with a worse looking and sounding result. And I didn't have the option of improving raw frequency response since placement was already the best I could do.
post #16480 of 23435 Old 10-20-2015, 07:47 AM
Liked: 682
post #16481 of 23435 Old 10-20-2015, 07:51 AM
Liked: 682
Maybe this result has more to do with luck than best practices, but there's no denying the improvement post eq... I suppose by taking advantage of the pre eq frequency response characteristics, I was able to make the most of things short of moving stuff around or buying more subs.
post #16482 of 23435 Old 10-20-2015, 07:57 AM
PretzelFisch's Avatar
Quoted: 405 Post(s)
Liked: 264
It still has a lot to do with room shape/size and position of the sub. These are measurements at one position and most times adding a second sub helps with maintaining a consistent response through out the whole room as opposed to improving response at one seating position.
Alan P, Dr. X and ahblaza like this.
PretzelFisch is offline
post #16483 of 23435 Old 10-20-2015, 08:00 AM
Liked: 4140
You are simply pointing out that there is no such thing as "right or wrong" when it comes to bass response. A long as you use best practices to achieve a response that meets your preferences, that is what matters.
ahblaza likes this.
post #16484 of 23435 Old 10-20-2015, 08:38 AM
Alan P's Avatar
Quoted: 5047 Post(s)
Liked: 3722
In my room, adding the second sub only marginally improves the FR...but it does even out the bass over a MUCH wider area.
I'm currently considering adding a third.
ahblaza likes this.
Alan P is online now
post #16485 of 23435 Old 10-20-2015, 09:15 AM
Liked: 682
All valid points, perhaps what I really mean to say is for me and some others a second sub may not provide as much benefit as one might hope for. However, with so many variables, it would be near impossible to know without trying it.
Of course, having more consistently even frequency response through a larger listening area could have merits for multiple listeners and/or multiple mlp's. That does appear to apply most if not all of the time whereas a better frequency response in the absolute sense in just one narrow mlp from 1 vs 2 subs is harder to generalize.
I suppose the main thing I should take from this is Jerry's comment about how there is no one approach that is always best and ultimately it has to do with what the user is starting with in terms of setup, gear, and budget for additional expenses and how willing they are to try different approaches and setups with varying cost to benefit ratios and varying end results.
For me, eq provides a lot of bang for the buck out of a single high quality sub and I don't need a larger listening area or multiple mlp's so multiple subs are not required.
post #16486 of 23435 Old 10-20-2015, 01:38 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 382
My bass is just as flat as Jerry's but with 2 subs. Every room is different. With only one, my graphs look awful. Though to be fair, that's just turning one of them off. I never optimized for only one sub.
This is regarding bass response at my main seat, though the whole room does see a benefit.
PlasmaPZ80U likes this.
Soulburner is offline
post #16487 of 23435 Old 10-20-2015, 02:01 PM
virtualrain's Avatar
Quoted: 845 Post(s)
Liked: 317
Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measuremen...
I wonder if there's a case to be made for buying multiple (or more) less expensive subs vs a single (or fewer) high-end sub(s).
For example, if you can spend $1500 on subs, do you buy a single sub that consumes your budget that goes ultra low with tons of power or do you buy a pair of $700 subs that will provide more even response and possibly some gain reinforcement?
SONY 75X850C | YAMAHA RX-A2050 | 5 DAYTON AUDIO APA150 | KLIPSCH RP 5.2.4
virtualrain is offline
post #16488 of 23435 Old 10-20-2015, 02:06 PM
Brian Fineberg's Avatar
Quoted: 3543 Post(s)
Liked: 3516
This has been brought up many times
Most of the time the recommendation is buy multiple less subs. Unless you can buy the one bigger more expensive sub with another down the road once you save for it
Brian Fineberg is offline
post #16489 of 23435 Old 10-20-2015, 02:06 PM
Liked: 4140
As long as the less expensive subs are of reasonable quality, there are numerous arguments that multiple subs outperform a single expensive sub.
ahblaza likes this.
post #16490 of 23435 Old 10-20-2015, 03:43 PM
Liked: 682
Well, depends on price range... if I had to choose between 4 Dayton Audio SUB-1200s ($150 each retail) or one Rythmik LV12R ($600 each retail)... I'd go for the LV12R all day.
Why? because it has strong output down to 20Hz or so, whereas the SUB-1200 doesn't sound strong under 32Hz or so and the LV12R is much punchier (300W RMS vs. 120W RMS) and more articulate/refined/musical/has direct servo
Dr. X likes this.
Current Setup REW FR measures
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha RX-A2070, SVS Prime Bookshelf Mains and Prime Center, Sony SS-CS5 Surrounds, Cambridge S20 Rear Surrounds, Rythmik LV12R; PS4 Slim, Xbox One, Xfinity X1
post #16491 of 23435 Old 10-20-2015, 03:47 PM
Liked: 4140
How about four Lv12R's vs. one Seaton Submersive?
Alan P and ahblaza like this.
post #16492 of 23435 Old 10-20-2015, 04:02 PM
Liked: 682
probably 4 LV12Rs, unless the greater extension/output under 20Hz makes a huge difference in movies
post #16493 of 23435 Old 10-20-2015, 04:08 PM
Liked: 4140
I rest my case.
ahblaza likes this.
post #16494 of 23435 Old 10-20-2015, 04:11 PM
3ll3d00d's Avatar
Quoted: 1650 Post(s)
Liked: 621
we seem to be forgetting footprint here, one reason single subs get expensive is because they cram a load of output/power into a "small" package. Of course you can throw multiples at the problem but the space required to do that is rather more expensive (in many cases) than a more powerful sub.
if we're window shopping though then why not multiples of some brutally powerful subs
ahblaza likes this.
3ll3d00d is offline
post #16495 of 23435 Old 10-20-2015, 04:17 PM
3ll3d00d's Avatar
Liked: 621
3ll3d00d is offline
post #16496 of 23435 Old 10-20-2015, 04:23 PM
Liked: 4140
I think the conversation started with the premise, if you have $X, is the money better spent on one expensive sub, or several more reasonably-priced subs.
Multiples of brutally powerful subs probably doesn't fit the premise.
ahblaza likes this.
post #16497 of 23435 Old 10-20-2015, 04:49 PM
artur9's Avatar
Quoted: 664 Post(s)
Liked: 236
For a single listener, @markus767 has the best advice. Put one sub about one foot behind your head.
Anything beyond that would seem a waste of money.
ahblaza likes this.
artur9 is offline
post #16498 of 23435 Old 10-21-2015, 05:56 AM
Dr. X's Avatar
Two subs instead of one was/is worth it for me.I've never used equalization (I don't have anything against it, though).
With proper placement, I'm able to change the peaks and nulls away from my seating position more easily than with one sub. More importantly, for me, is that I can always localize the sub in the room. Even just a little bit is distracting for me. Actually the absolute most important thing - it just sounds better to me with two subs rather than one. I have two subs set up in my two main HT rooms. It's awesome.
I also second the advice to get two good quality subs rather than two cheap ones (I've done both). If one sub sounds bad, two sounds just as crappy, but louder. I've even tried mixing subs to save money: one expensive, one cheap(er). Results were underwhelming.
Be mindful of the law of diminishing returns, though. Two really good subs can be had for reasonable money, especially if you're willing to buy second hand.
Dr. X is offline
post #16499 of 23435 Old 10-21-2015, 06:03 AM
Liked: 3516
although very informative...i dont agree (nor do many professional engineers) agree witht eh geddes video...specifically 2 subs (notice he didnt mention getting them to play nice with each other with phase etc) or his complete dismissal of room gain...
room gain is definitely prominent...and can be easily measured
ahblaza likes this.
post #16500 of 23435 Old 10-21-2015, 08:20 AM
Liked: 682
When measuring distortion, does switching between a 256K measure and a 1M measure make a significant difference in the numbers?
EDIT: checking the same measures in 256K vs. 1M showed no significant changes in numbers
What was interesting was the 1M measure was smoother than the 256K measure in frequency response... curious
Dayton , Dayton Audio , Room Equilizer Wizard Rew
