Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 559 - AVS Forum | Home Theater Discussions And Reviews
 2285Likes
post #16741 of 23602 Old 11-02-2015, 04:08 PM
LastButNotLeast's Avatar
Quoted: 1804 Post(s)
Liked: 1416
Originally Posted by corradizo View Post
I find i have to use the dcx2496 when i run auto eq in rew, then switch to the generic eq
Why don't you just keep it "generic"?
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
Don't guess, measure: Getting Started With REW: A Step-by-Step Guide
LastButNotLeast is offline
post #16742 of 23602 Old 11-02-2015, 04:47 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 7726 Post(s)
Liked: 4326
Originally Posted by PlasmaPZ80U View Post
Does this mean the UMIK-1 should work with cal file with sensitivity parameter in Windows 10 like it does in Windows 8.1 currently? No manual spl calibration necessary?
(It's one of reasons I've been holding off on the Windows 10 upgrade.)
Any other Windows 10 specific issues resolved?
I am running ver 5.13 on a Windows 10 laptop. REW still does not recognize the UMIK-1 properly, so the sensitivity parameter is not being loaded. This means a manual mic calibration is still required. I know of no other Windows 10 issues.
AustinJerry is online now
post #16743 of 23602 Old 11-02-2015, 05:34 PM
corradizo's Avatar
Quoted: 1182 Post(s)
Liked: 891
It will usually go beyond the 8 filters the inuke supports, the Q settings can also go out of the supported inuke range and the filters will end up below 20hz which the inuke can't support. So it ends up not being so useful.
Hence my workaround: Using the dcx as the EQ so REW can do its excellent auto eq magic gets me close and then clicking on generic after the auto eq translates the dcx filters to the generic eq and allows me to dial in the frequencies and q settings to what the inuke software supports.
Side question:
Do I do a full range sweep of L+R+Subs and eq the overall response (running 200hz crossover to mains) flat to 200hz OR do I do a sweep of the lfe channel (channel 4) and eq the lfe channel that flat to 200hz?
Hope I didn't miss that in the guide.
corradizo is offline
post #16744 of 23602 Old 11-02-2015, 06:46 PM
Liked: 4326
Side question:
First of all, I don't know anything about the capabilities of the INuke. But I would think that each of your speakers, including the sub(s) have a unique response curve. I would measure each speaker separately, use the REW EQ tool to create the filter for that speaker, and load it into the INuke for that channel. Assuming, of course, that you can do that with the INuke.
I am sure someone will correct me if I am wrong, especially since I don't know what I am talking about.
ahblaza likes this.
post #16745 of 23602 Old 11-02-2015, 07:09 PM
corradizo's Avatar
Liked: 891
My avr powers my mains, the inuke 3000 dsp only powers my subs. What I'm asking is do I eq the overall bass responce (each channels bass below the crossover + lfe channel) flat or just the lfe channel (and let the other channels bass below the crossover regions stack on top of the lfe channel)?
post #16746 of 23602 Old 11-02-2015, 08:19 PM
Liked: 4326
Play a sub-only measurement sweep. You can do this by selecting HDMI4 in REW. Use this as input to the EQ tool in REW. Do NOT have the main speakers outputting the test tone at the same time.
post #16747 of 23602 Old 11-02-2015, 08:31 PM
corradizo's Avatar
Liked: 891
Got it, thanks for clearing that up for me. I had been eq'ing channel 4 all along. It was confusing me as I've read you want your system to "measure flat", but when you add the bass from the other channels to the lfe channel you end up with a "house curve" look to your L+R+Subs response. Thanks again!
post #16748 of 23602 Old 11-03-2015, 12:05 AM
markus767's Avatar
Quoted: 4253 Post(s)
Liked: 1651
Check out the 5.14 betas.
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #16749 of 23602 Old 11-03-2015, 12:42 AM
markus767's Avatar
Liked: 1651
Use Andy's fantastic software for optimization:
Optimizing subwoofers and integration with mains: multi sub optimizer
Loopback channel measurements required!
corradizo likes this.
Markus
post #16750 of 23602 Old 11-03-2015, 05:55 AM
PlasmaPZ80U's Avatar
Quoted: 2316 Post(s)
Liked: 716
Are you saying it's fixed in the latest beta? If do, I might be ready to install Windows 10.
PlasmaPZ80U is online now
post #16751 of 23602 Old 11-03-2015, 06:48 AM
Liked: 4326
The behavior has not changed under 5.14 beta8. The mic is still listed as a generic USB mic, and REW fails to load the sensitivity parameter. Markus, are you using Windows, and have you tested this out? If you are using a Mac, are you saying the mic is properly recognized? Perhaps this issue is unique to my laptop. Anyone else running Windows 10, and is the mic being recognized properly for you?
The ASIO Control Panel clearly shows the UMIK-1 as being active:
Something else is peculiar as well. When I launch REW, I normally get a pop-up if an update is available. And with ver 5.13 still installed, when I click on "Check for update", I get the message "REW is current". That is why I was unaware of ver 5.14 beta releases. I wonder why this behavior changed?
post #16752 of 23602 Old 11-03-2015, 03:10 PM
MBK
MBK's Avatar
Hi everyone,
I've been struggling through taking reliable measurements with REW on my mac using the UMIK-1. I've used J_P_A's trick of selecting the MIDI channels to get around the soundflower issues (using channel 8 as my "dead" channel as I don't have back surrounds). A few questions have come up though:
1. Do I need to worry about setting gain on the UMIK for the mac? I've gotten clipping issues that have necessitated lowering the volume of the sweeps, and the guide doesn't have info about this for the mac.
2. Some measurements people post seem to have a db rating listed along side them, but mine just say "db new". Is this something to do with calibration that I'm missing?
3. When I've set my volume to get ~85db reading in the SPL meter my measurements show a drop off trend of about 10db by the time the sweep hits 400Hz. This trend seems odd, wondering if it's something to do with the sub running hot?
Any insights would be appreciated. I'm not satisfied with the measurements I took this last week, I think I need to try again to get a better read with different crossovers.
wse and J_P_A like this.
MBK is offline
post #16753 of 23602 Old 11-03-2015, 04:19 PM
asere's Avatar
Quoted: 1587 Post(s)
Liked: 338
Subwoofer Graphs
Which one is better for sub only? This is with Audyssey off
Name:	corner wall by sofa.jpg
ID:	1037193   Click image for larger version
Name:	middle wall front room.jpg
asere is offline
post #16754 of 23602 Old 11-03-2015, 04:38 PM
Liked: 4326
Sorry, neither is very good. I would consider additional subs.
post #16755 of 23602 Old 11-03-2015, 04:40 PM
asere's Avatar
Liked: 338
I know but I need to settle for now on placement. Which one would you go for considering the circumstances?
Sent from my SM-G900P using Tapatalk
asere is offline
post #16756 of 23602 Old 11-03-2015, 05:02 PM
asere's Avatar
Liked: 338
Jerry, here is another one I found back in august with sub placed front wall. This one is with Audyssey on. Today's measurements with the pics I posted earlier the sub was on the sofa while I placed the mic in different areas. I don't know but I think this one looks better.
Name:	sub middle front wall driver facing wall.jpg
asere is offline
post #16757 of 23602 Old 11-03-2015, 05:15 PM
Liked: 4326
If my only option were to choose one of the three measurements you posted, I would choose the last one.
asere likes this.
post #16758 of 23602 Old 11-03-2015, 05:16 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 382
That graph is considerably better. How did it sound compared to now? You should have noticed the difference right away.
Soulburner is offline
post #16759 of 23602 Old 11-03-2015, 05:48 PM
asere's Avatar
Liked: 338
Middle front wall sounds really good but I'm going with corner placement and see. I'll re measure after I run audyssey.
asere is offline
post #16760 of 23602 Old 11-03-2015, 06:27 PM
Liked: 4326
Sorry, I guess I wasn't paying close attention. Are you saying the first two measurements were taken with the sub in the MLP and the mic in a spot where the sub would be placed? Why didn't you say that in the first place? No wonder the two measurements looked so bad. That approach will not work. You are wasting our time.
ahblaza likes this.
post #16761 of 23602 Old 11-03-2015, 06:29 PM
asere's Avatar
Liked: 338
That's right. I'm sorry another poster said earlier it would be ok to place the sub on couch at ear level at MLP and travel with the mic.
asere is offline
post #16762 of 23602 Old 11-03-2015, 07:11 PM
Brian Fineberg's Avatar
Quoted: 3543 Post(s)
Liked: 3517
Ok new computer (only used REW with Mac before without hdmi)
When selecting Asio under output it says "1: Not connected 1"
Everything else is fine. But obviously I can't output a test one or seep
HDMI out is setup properly. I can play anything over the speakers from YouTube etc. but when using REW it says not connected
Any help? I appreciate it as always
Brian Fineberg is offline
post #16763 of 23602 Old 11-03-2015, 07:21 PM
Liked: 4326
Is this a Windows computer? What version of Windows?
Open the ASIO control panel. You should see the HDMI output device. Hover the mouse over the HDMI device. Does it say "Active, polling" or does it say "Idle"?
Sometimes after the initial installation of ASIO, the computer needs to be rebooted to get it to work properly. Have you done that?
ahblaza likes this.
post #16764 of 23602 Old 11-03-2015, 07:26 PM
Liked: 3517
Yes I rebooted
In the control panel it doesn't even show up (under audio oupit it shows as denonavr)
This is Windows 8. Brand new HP stream
post #16765 of 23602 Old 11-03-2015, 07:53 PM
asere's Avatar
Liked: 338
Guys I have read this before I think but I can't find it now.
When in REW using the generator with pink noise for the sub test and using the REW SPL. What level do you set the master volume to? I have been moving it to read 75-80db. Is this correct?
asere is offline
post #16766 of 23602 Old 11-03-2015, 08:02 PM
Liked: 4326
Yes I rebooted
That doesn't sound right. Are there any output devices listed in the ASIO control panel? And what appears on the Output Device drop-down list on the Preferences screen?
ASIO4All is notoriously stubborn, and there doesn't seem to be a proven problem resolution technique. Uninstalling/re-installing might work and may be worth a try. I wish I had better advice, Brian.
post #16767 of 23602 Old 11-03-2015, 08:04 PM
Liked: 4326
Your question is not clear. You can set the MV to whatever level you like, depending on what you are trying to do. What exactly are you doing?
post #16768 of 23602 Old 11-03-2015, 08:24 PM
asere's Avatar
Liked: 338
I am trying to see at what level the sub volume starts to drop. Example if I set the level to read 75db eventually it will be in the 50' s and lower. If I set the level at 100db it will drop too of course. I guess what I'm asking is what is the best way to test the sub capability at high spl?
asere is offline
post #16769 of 23602 Old 11-03-2015, 08:25 PM
Liked: 716
Where do I download the latest beta from? Don't see it on the main REW download site. Just upgraded to Windows 10.
post #16770 of 23602 Old 11-03-2015, 08:28 PM
Liked: 4326
If you are outputting a steady REW test tone, the sub level should stay constant, not drop. Why would the sub level start to drop? Perhaps I am not understanding correctly.
Dayton , Dayton Audio , Room Equilizer Wizard Rew
