Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 562 - AVS Forum | Home Theater Discussions And Reviews
 2003Likes
post #16831 of 22538 Old 11-05-2015, 01:07 PM
Brian Fineberg's Avatar
Quoted: 3543 Post(s)
Liked: 3515
Ok uninstalled both REW and Asio and reinstalled. It recognized hdmi. But not umik. So undid the little trick to get the umik to be recognized. By changing to Java etc.
Sure enough umik showing. But now hdmi says not connected again!!!
Also under umik advanced properties (in Windows) it's greyed out on 24bit 48000. I can't change it
This is getting very frustrating. I bought a new laptop just for the hdmi and I can't get it to work!!
Help Poe favor
Brian Fineberg is offline
post #16832 of 22538 Old 11-05-2015, 01:12 PM
JohnPM's Avatar
Quoted: 79 Post(s)
Liked: 49
The ASIO input problem is fixed in V5.14 beta 9. There isn't an easy solution to identifying the UMIK when going via ASIO4All. The inputs get the helpfully generic names "USB Audio Device 1", "USB Audio Device 2", but the same names are used for other generic USB soundcards so it is possible to have several "USB Audio Device 1" appear in the available input channels. I'll see if I can come up with anything to work around that at the weekend.
JohnPM is offline
post #16833 of 22538 Old 11-05-2015, 01:23 PM
Liked: 3515
For me it's not the input. It sees the umik fine.
But it doesn't see the hdmi connection
It's either one or the other. HDMI no umik. Or no hdmi but umik. But not both at the same time.
post #16834 of 22538 Old 11-05-2015, 04:45 PM
asere's Avatar
Quoted: 1424 Post(s)
Liked: 284
Overlays
Here are a couple overlays. The yellow is corner and red is front middle wall.
asere is offline
post #16835 of 22538 Old 11-05-2015, 04:48 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 7030 Post(s)
Liked: 3926
Overlays of what? Sub only, or sub+something else? Regardless, the measurements don't look very good at all, either one.
AustinJerry is offline
post #16836 of 22538 Old 11-05-2015, 05:00 PM
asere's Avatar
Liked: 284
The sub alone with audyssey ON.
Sent from my SM-G900P using Tapatalk
asere is offline
post #16837 of 22538 Old 11-05-2015, 05:06 PM
asere's Avatar
Liked: 284
My mistake the yellow is audyssey on in the corner. The red is audyssey off front middle wall. Only sub measurements.
asere is offline
post #16838 of 22538 Old 11-05-2015, 05:12 PM
Liked: 3926
Why do you keep showing us these measurements? They don't seem to be getting any better. What are your expectations?
post #16839 of 22538 Old 11-05-2015, 05:16 PM
asere's Avatar
Liked: 284
I understand. If I get another KK will it extend the low end?
asere is offline
post #16840 of 22538 Old 11-05-2015, 05:38 PM
corradizo's Avatar
Quoted: 1082 Post(s)
Liked: 749
What are the dimensions of your room? What is the distance from your mlp to the front of your room? Ceiling height? Let's figure out where your nulls are and places that would work for your sub. Once we identify those places, put your sub at each spot it can go in the room and measure. Label each measurement so you remember the spot and post them all together. Make sure to turn off audyssey and any other enhancements while you do this.
When we determine the best measurement, that spot will be your subs new home. Then re-run audyssey entirely, then measure again and post that graph.
That graph will be as good as it gets for you until you get another sub or three and something to eq and time align them.
corradizo is online now
post #16841 of 22538 Old 11-05-2015, 06:08 PM
asere's Avatar
Liked: 284
My room is open to the kitchen. The combination is 5000 to 5200cf. I sit about 10ft from sub and mains.
I have taken measurements in all possible sub placements and it's either corner or front middle wall.
At this point I'll have to invest at least on another sub. The KK is so expensive though. I won it but can't afford a second one at $3000. Had it been SVS or something for that money I could get maybe 3.
Selling the KK would solve it but it's a really nice sub and besides it's $3000 for just one so winning was a blessing.
Eventually I guess.
asere is offline
post #16842 of 22538 Old 11-05-2015, 06:13 PM
corradizo's Avatar
Liked: 749
Ok, what I'm getting at is you need to determine if where your sitting is a big part of the issue. Might want to take 3 or 4 measurements per possible sub location going a few inches in every direction to get a better view of what's going on. So if you can't move your subs, maybe living your couch a little bit might help etc.
post #16843 of 22538 Old 11-05-2015, 06:23 PM
asere's Avatar
Liked: 284
I have done that. The family room is not as big as the kitchen so I can only move the MLP just a couple of places. The sub measures the same on average. With such a room a second sub is my only option.
asere is offline
post #16844 of 22538 Old 11-05-2015, 08:56 PM
ahblaza's Avatar
Quoted: 1590 Post(s)
Liked: 1716
Originally Posted by markus767 View Post
Yes that works. You don't need to remeasure though. Just click "Save" in the RTA panel and the response shows up in the main window.
Thanks Markus, especially with the save option, a lot easier....
ahblaza is offline
post #16845 of 22538 Old 11-05-2015, 09:10 PM
ahblaza's Avatar
Liked: 1716
Help Poe favor
Brian I have the same issue with the input device (UMIK) grayed out, I just change the output device (receiver) to 24 bit 48000 so they match, I don't know if this makes a difference but it works for me. It was very frustrating for me as well in the beginning, I could get the input to work but no output and then the opposite. I just kept going over and over Jerry's trouble shooting section and it worked some how and never had a problem since. Good luck..
PlasmaPZ80U likes this.
ahblaza is offline
post #16846 of 22538 Old 11-05-2015, 10:02 PM
Liked: 3926
Help Poe favor
As ahblaza says, there is noting wrong with the mic configured at 24 bit 48000. Just make sure the output device is configured the same. The important thing is that they match.
No help for the ASIO problems, sorry. We have all been through the pains of trying to get it to work properly. I have had the most success by toggling to Java, exiting and re-starting REW, toggling back to ASIO, exiting and re-starting REW, and praying.
And asking for help from Edgar Allan Poe doesn't help, normally...
post #16847 of 22538 Old 11-05-2015, 11:44 PM
markus767's Avatar
Quoted: 3850 Post(s)
Liked: 1371
Did you measure with MultEQ off and Dynamic EQ off? Please post the .mdat showing all the locations you've measured.
By the way, what AVR do you have?
Eventually I guess.
Spending that kind of money on a sub isn't necessary. Got to http://www.data-bass.com/data?page=home and you'll find DIY subs for a couple of hundred bucks that are better or as good as what you can buy in a store.
ahblaza and corradizo like this.
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #16848 of 22538 Old 11-06-2015, 06:44 AM
asere's Avatar
Liked: 284
I measured with multeq off and no deq as my Onkyo 805 has no deq on board. It's powerful but Flintstone era lol.
I deleted all the measurements for the areas that were really horrible. Even I could see that. The best placement given the room size and were it can only be placed was the front right corner or front middle wall. I placed it in the corner at least for now. That is Ken Kreisel's suggestion because he made them for corner placement.( although I don't know if I can agree completely as all rooms are different). Ken doesn't even trust REW as he says he uses sophisticated measuring equipment from what he told me. Anyways that's a different subject.
Thanks for taking interest. My sub sounds really good. I just want the tactile feeling. I know it will never be possible unless I get more subs. I'll look into the DIY.
asere is offline
post #16849 of 22538 Old 11-06-2015, 07:34 AM
markus767's Avatar
Liked: 1371
It is but that sound like BS to me. You can't make a sub for corner placement (if it's not a corner horn that relies on walls). REW is as sophisticated as the user using it.
Subs are really simple animals. The hard part is how to integrate them into a specific room.
corradizo and asere like this.
Markus
post #16850 of 22538 Old 11-06-2015, 08:03 AM
LastButNotLeast's Avatar
Quoted: 1632 Post(s)
Liked: 1239
Transducers?
http://www.avsforum.com/forum/113-su...s-transducers/
I like my ButtKicker.
Michael
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
For most of the time, the here and now is neither now nor here. Graham Swift
LastButNotLeast is offline
post #16851 of 22538 Old 11-06-2015, 08:19 AM
Alan P's Avatar
Quoted: 4893 Post(s)
Liked: 3526
Have you tried extreme nearfield placement (i.e. right behind your chair/couch)? This will give you the best response and the most tactile feedback.
Remind me, which KK sub do you have??
Alan P is offline
post #16852 of 22538 Old 11-06-2015, 08:41 AM
markus767's Avatar
Liked: 1371
I agree. It doesn't get much better than this. Works with a single sub for a single listening position. Can be made to work for 2-3 seats with 2 subs.
Markus
post #16853 of 22538 Old 11-06-2015, 08:42 AM
Liked: 3515
hahaha
thanks for the response...Ive thrown in the towel with HDMI....so I returned the laptop to BB and will stick with the macbook
thanks anyhow
ahblaza likes this.
post #16854 of 22538 Old 11-06-2015, 09:07 AM
asere's Avatar
Liked: 284
I cannot place it behind the couch because it would be in the path to the kitchen. Nothing like a dedicated room
The sub I have is the DXD12012.
asere is offline
post #16855 of 22538 Old 11-06-2015, 09:22 AM
Alan P's Avatar
Liked: 3526
Well, if I paid $3K for that sub (I know you didn't,but....) and had that kind of in-room response, I would be seriously ticked.
On their site, they don't even give the response of the sub...they just say "typical in room response".
What mic are you using and are you using a tripod or mic boom when measuring?? Maybe the crappiness of your response is in your measurement method since you keep saying it sounds good.
Alan P is offline
post #16856 of 22538 Old 11-06-2015, 09:35 AM
asere's Avatar
Liked: 284
I use Umik 1. I say it sounds good as far as not boomy, it's tight and really shakes the wall where the driver faces. I just want in the chest feel but looking at my graph it won't be possible with just one sub. In my case it's the room size that has a lot to do with it.
My room is about as big as yours and if I got it right you have 3 subs and a really NICE response. I just need more subs.
asere is offline
post #16857 of 22538 Old 11-06-2015, 09:44 AM
Alan P's Avatar
Liked: 3526
I only have two subs currently, the third is on the way.
Still, with one $3K sub you should be getting a much better response than that! Your response is down 20db from 40hz to 20hz ...a sub priced at that level should extend much lower than that.
Have you tried any nearfield measurements of the sub to confirm it is working properly? Put the mic about 2" from the dustcap on the driver and take a sweep.
ahblaza likes this.
Alan P is offline
post #16858 of 22538 Old 11-06-2015, 10:01 AM
asere's Avatar
Liked: 284
I understand but won't the sub loose headroom in a room as big as mine? I will try the measurement like you mentioned as a test. Great point.
asere is offline
post #16859 of 22538 Old 11-06-2015, 10:14 AM
Alan P's Avatar
Liked: 3526
How big is your room? Mine is 5K cubic feet and I get this response with a single $3K sub (PSA T-18...not a fair fight though since the T-18 has 3 18" drivers). This is without Audyssey and CC+sub.
Alan P is offline
post #16860 of 22538 Old 11-06-2015, 10:31 AM
asere's Avatar
Liked: 284
My room is around 5K cf too. Here is a graph with vertical at 50-150 and 45-100. I was told 50-100 is the way to go. Now the room response on the purple was taken awhile back with Audyssey On and to me looks good compared to the recent one I took earlier.
asere is offline
Dayton , Dayton Audio , Room Equilizer Wizard Rew
