Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 586 - AVS Forum | Home Theater Discussions And Reviews
 1733Likes
Old 01-24-2016, 07:27 AM
corradizo's Avatar
Quoted: 1042 Post(s)
Liked: 696
corradizo is offline
Old 01-24-2016, 08:13 AM
PlasmaPZ80U's Avatar
Quoted: 1969 Post(s)
Liked: 562
Originally Posted by ahblaza View Post
You could probably do all Ascends or HTDs for that $850 and be very happy with either. Both will give you more extension if that's what you're concerned with, I gathered that from the issue with the XO setting.
Well, I'd rather get nicer LCRs (one pair of bookshelves and one center) and turn my current mains into surrounds than spend that $850 on 5 speakers (4 identical bookshelves and one center channel). I'm after the total package, including SQ/imaging/dispersion/midrange/treble/etc. (not just bass output/extension). I can always upgrade the surrounds to match the mains if desired at a later date.
Saril likes this.
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is online now
Old 01-24-2016, 08:33 AM
artur9's Avatar
Quoted: 547 Post(s)
Liked: 187
Originally Posted by PlasmaPZ80U View Post
Well, I'd rather get nicer LCRs (one pair of bookshelves and one center) ... I can always upgrade the surrounds to match the mains if desired at a later date.
For HT having all the speakers the same family has some benefit. When I had a mix&match with mains much better than surrounds the discontinuity of sound during pans was very obvious. I found it very off putting. But I didn't buy them all at once, either.
artur9 is online now
Old 01-24-2016, 09:00 AM
jim19611961's Avatar
Quoted: 449 Post(s)
Liked: 153
I'm not sure if that's the case... here's measures with sub trim 4db hot:
Lets make sure I know what I am seeing.
If you have a plot of the sub only. Then, with all else being equal, you then take a Sub + Main, and the FR goes down in a area, then phase/timing is the only thing it can be.
Think about it. When two sources are present in the same frequency range, they either add (in phase), subtract (out of phase), or it stays the same (somewhat out of phase).
My Room
My Music
Rega - Apollo, Rega - DAC, Goldpoint Passive, Classe CA-100, Crown XLS 1002, miniDSP
Jenzen Next
jim19611961 is offline
Old 01-24-2016, 09:03 AM
Liked: 562
Ok, but I tried the SW distance tweak and it didn't improve the dip under 80Hz. Also, if I reverse SW phase I get huge dips around 80Hz.
Liked: 562
What else should I try?
Old 01-24-2016, 09:11 AM
Quoted: 449 Post(s)
Liked: 153
The distance tweak is no more than adding delay. The higher the distance setting, the more delay. Start with no distance (o delay) and work it higher incrementally, measuring each time.
Do you have mdat's available?
My Room
My Music
Jenzen Next
Old 01-24-2016, 12:12 PM
Liked: 562
not at the moment but this is my best result:
Name:	dip between LCRs plus sub and LFE.png
ID:	1205986   Click image for larger version
Name:	mains L R.png
Old 01-24-2016, 01:04 PM
artur9's Avatar
Quoted: 547 Post(s)
Liked: 187
Looking at those, and being a newbie, IIUC, your left and right mains are interfering at different points with the sub. They are not symmetrical? If that's the case then one delay would not be able to fix the issue.
Old 01-24-2016, 04:01 PM
LastButNotLeast's Avatar
Quoted: 1490 Post(s)
Liked: 1090
Or one of the mains is out of phase?
Michael
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
LastButNotLeast is offline
Old 01-24-2016, 05:26 PM
Liked: 562
The speakers are pretty symmetrical relative to the TV/CC. However the MLP is to the right of the CC/TV by 2-3 feet.
Michael
Not according to wiring or YPAO or any test tones on a BD.
Old 01-24-2016, 05:28 PM
Liked: 562
yet the CC+sub is off by the same amount as L+R+sub
Old 01-24-2016, 09:49 PM
artur9's Avatar
Quoted: 547 Post(s)
Liked: 187
I think the symmetry relative to the MLP is the only thing that matters. The point of the equilateral triangle is the MLP so the position relative to the TV doesn't matter with regard to the sound.
OTOH, I bet it looks good.
Old 01-25-2016, 12:06 AM
Quoted: 644 Post(s)
Liked: 335
Couple of questions regarding measurements and graphs:
1. On all SPL graph should I put horizontal line at SPL level I measured? If yes, where do I read out SPL level of measurements?
2. Are decay/waterfall readings in direct corelation with peaks/nulls of frequency response graph? For example, lets say i have a nasty peak at 200 Hz, then I assume there will also be long reverberation/decay times at that frequency? But, is it possible to have a dip, for example at 1500 Hz, but at the same time have really long decay time at that frequency?
3. How can I figure on ETC graph which frequencies cause peaks that need to be tamed? I figured I can only read distances to reflection points, but that doesn't help much if I don't know which frequencies cause peaks. Someone mentioned that ETC is only useful for high frequencies, does it mean that it doesn't show low frequencies?
donktard is offline
Old 01-25-2016, 05:15 AM
corradizo's Avatar
Liked: 696
Check out post #17547 regarding regarding ETC and the frequencies needing to be treated.
Old 01-25-2016, 06:49 AM
MrGrey's Avatar
Quoted: 489 Post(s)
Liked: 510
Good morning,
Anyone want to take a quick look. do i need to eq anything?
Receiver - Sony STR-DH550
Fronts - Klipsch Reference Premiere RP-280F
Center
- Klipsch Reference Premiere RP-450C
Surrounds - Don't ask lol
Sub - Rythmik FV15HP
MrGrey is offline
Old 01-25-2016, 06:58 AM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6600 Post(s)
Liked: 3644
Originally Posted by MrGrey View Post
Good morning,
The response below 100Hz looks pretty flat, with a nice upward slope. The response above 100Hz looks typical. The dips are narrow, and probably can be controlled with room correction. How about showing a full-range measurement to 20KHz with smoothing applied, either 1/6 or variable?
Side comment: the black background makes the graph harder to read, at least on my tablet.
AustinJerry is online now
Old 01-25-2016, 07:03 AM
MrGrey's Avatar
Quoted: 489 Post(s)
Liked: 510
ok nice, ill take those measurements right now. i will also change the background to white. i added the image as an attachment instead so see if you it looks better. brb
Center
MrGrey is offline
Old 01-25-2016, 07:13 AM
Liked: 3644
Yes, I can read the legend now.
Old 01-25-2016, 07:14 AM
MrGrey's Avatar
Quoted: 489 Post(s)
Liked: 510
Attached is full-range measurement to 20KHz with var smoothing and the other with 1/6 smoothing.
Name:	var smooth.png
ID:	1208738   Click image for larger version
Center
MrGrey is offline
Old 01-25-2016, 07:21 AM
Liked: 562
Well, I have an unusual setup involving the bed as MLP and small bedroom (due to a back injury that just won't go away). However, if you see where I started in Jan 2015 (in terms of HT setup/calibration and placement/quality of speakers) when I got into this hobby, you'd be very impressed. I know I am.
Old 01-25-2016, 08:28 AM
artur9's Avatar
Quoted: 547 Post(s)
Liked: 187
I find it amazing that your sub goes all the way to 20KHz. Can you hear that?
Old 01-25-2016, 08:30 AM
artur9's Avatar
Quoted: 547 Post(s)
Liked: 187
... if you see where I started in Jan 2015 (in terms of HT setup/calibration and placement/quality of speakers) when I got into this hobby, you'd be very impressed. I know I am.
Indeed it is. Now we're just trying to get that last little bit more. Are the delays on your mains the same? Maybe you can address the dip by adjusting those delays.
Or, possibly, since this is HT, ignore the mains and just address the dip on the Center's graph. That might also improve the L/R.
Old 01-25-2016, 10:17 AM
Liked: 1
Originally Posted by AV_mike View Post
RISC_Taker
Only one word of caution from me - and it's not break-in. Always allow electronics/speakers/etc to fully acclimatize to the ambient temperature within your home before powering up...
This makes perfect sense to me, thank your for the input. I think I'm lucky in that the sub is coming from about 1.5 hours away so the temp should not be wildly different from when it's delivered, but I'll resist the urge and let it sit for a couple of hours while I set up the mic and laptop. Never know how hot or cold the storage facility/delivery vehicle might be.
RT
Sharp AQUOS LC60E88UN
Pioneer VSX-1120-K Receiver 7.1
2 Klipsch RF-3IIs
4 Klipsch RS3s
1 Klipsch center RC-3II
1 Klipsch RSW-15
RISC_Taker is offline
Old 01-25-2016, 10:22 AM
Liked: 1
Perhaps you can also just replace the amp (if that's what died):
http://www.parts-express.com/cat/sub...amplifiers/332
Michael
I plan to try to repair it if for no other reason than to learn something. I have the diaphragm and speaker out, just have to get in to the box and take a better look.
Thanks very much for the link, between that and what the guys on the Klipsch sub gave me, I'm hoping I can use it in my office surround system if I can resurrect it.
RT
2 Klipsch RF-3IIs
4 Klipsch RS3s
1 Klipsch RSW-15
Old 01-25-2016, 12:46 PM
Liked: 3644
Not bad at all, MrGrey. I suspect it sounds pretty good. I don't see any obvious issues in the frequency response curves.
Next step would be to post both a waterfall (which would allow us to view bass resonance), and the ETC (which shows how well reflections are controlled). Instructions on how to generate both are in the guide. Please follow the posting guidelines.
ahblaza likes this.
Old 01-25-2016, 02:20 PM
MrGrey's Avatar
Quoted: 489 Post(s)
Liked: 510
its sound incredible. this is the first time i can say i am really enjoying my system. it just sound right. thanks allot for the help. i will read the guidelines and be doing those graphs right now.
Name:	L+SUB water.png
ID:	1209810   Click image for larger version
Name:	R+SUB water.png
ID:	1209818   Click image for larger version
Name:	CNT+SUB water.png
Center
MrGrey is offline
Old 01-25-2016, 03:34 PM
Liked: 3644
Not bad at all. A little issue right at 60Hz. Wonder if that is ground hum from the 60Hz power? I doubt that it is audible.
Now on to the tough one, the ETC.
Old 01-25-2016, 07:33 PM
hoopsrgreat's Avatar
Quoted: 47 Post(s)
Liked: 63
I'm using REW for first time and still running through setup. I'm not at home, So excuse me if I mistate something. I am using the step by step guide. It states to set REW output level to L+R+sub under preferences I think after measuring pink noise, and then increasing volume on avr up to 90db. Problem is I don't see that drop down menu for L+R plus sub. It has numbers on output, and the first one has subs and rt front, number two has only left front and subs, number three has no out put...I'm kind of sick how to get both fronts and sub outputting at this point. Remember I'm still in the setup stages.
IM trying to set the "REW Output, "L+R+ Subs." Ido not see anywhere fo rme to do that. Under REW PREFERENCES
hoopsrgreat is offline
Old 01-25-2016, 07:48 PM
Quoted: 677 Post(s)
Liked: 97
Hi Jerry
One question, where is the recommended place to buy MiniDSP UMIK-1, from MiniDSP $75 or from Cross-specturm $100? One is w/o calibrated one with calibrated. Is UMIK-1 better than dayton UMM-6? Thanks.
https://www.minidsp.com/products/aco...urement/umik-1
http://cross-spectrum.com/measuremen...ated_umik.html
Roudan is offline
Dayton , Dayton Audio , Room Equilizer Wizard Rew
