Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 604 - AVS Forum | Home Theater Discussions And Reviews
 1912Likes
post #18091 of 22279 Old 03-22-2016, 08:13 AM
torii's Avatar
Quoted: 878 Post(s)
Liked: 459
Originally Posted by donktard View Post
You are not making much sense here. Lets go step by step.
1. Yes you can manipulate curves in REW but you need some sort of DSP to implement them in your system, for example Dirac, miniDSP, inuke
2. AVRs are relatively limited. For example, your marantz with XT32 Audyssey will ask you to take measurements and then it will make two curves...Reference and Flat. The only difference between those two is that Reference has rolloff at high frequencies and is more suitable for typical reverberant room. So you basically have a choice of equalization: reference, flat and OFF. I assume all other stereo/surround modes get affected by choice of these (except direct).
AVR EQ also can't fix nulls, thats why human intervention is necessary (regarding sub positions for example).
3. What do you mean by one setup or another setup? Is it a different listening mode like stereo or direct? Stereo mode incorporates both your subwoofers and fronts, so your response if you positioned them right should be much better then Direct. But if you measure in Direct mode, your subwoofer and Audyssey EQ/distances/levels get turned off and you will often see some nasty nulls in your bass region.
4. What is your measurement procedure? I am pretty sure you are also inconsistent here. You should measure one speaker at the time (+ subs). You also shouldnt move microphone when comparing different measurements because there is a lots of variation even if you move mic just few inches.
I never moved the mic, i never got out of a chair, I just changed settings using the remote for the avr and hit measure on the laptop. But I am human, so maybe Im doing something wrong. my point was changing the settings in the avr caused a change in my low points so I was excited to see it possibly was a null but setup error. ie...cheap fix.
I messed up, the graphs were from 2 different days/trials so maybe the heights/exact mic locations were different....guess I know why I was never a research scientist
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5 Subs: Velodyne HGS 12, VA 1512, Rythmik FV15HP
torii is online now
post #18092 of 22279 Old 03-22-2016, 08:17 AM
LastButNotLeast's Avatar
Quoted: 1585 Post(s)
Liked: 1192
Originally Posted by markus767 View Post
Anything with XT32 is fine. Cheapest option is probably a used Onkyo 818.
If it's just for the subs, how about just adding this:
https://reverb.com/item/1612855-behr..._wkaAjc68P8HAQ
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
For most of the time, the here and now is neither now nor here. Graham Swift
LastButNotLeast is offline
post #18093 of 22279 Old 03-22-2016, 08:35 AM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6950 Post(s)
Liked: 3872
Originally Posted by 1201 View Post
Thanks for that link. ive read that many times. Iirc, only 8 subjects were tested and they did not state their age, gender or the listening level, which all affect perceived flatness to a great extent.
A 60 year old man listening at 60 db will more than likely not appreciate a downward sloping house curve
I posted the link just in case you had not seen it. I am likely to be older than you are, so I know what it is to not be able to hear the very highest frequencies. In my case, my main speakers already exhibit a gentle roll-off above 15KHz, which is not uncommon. Using Dirac Live's custom target editor, I try and match the speaker's normal response curve, rather than trying to boost the high end. The nice thing about custom target curves, especially if you have a product that matches the flexibility of Dirac Live, is that you can create a response target that matches your preference. And preference is just that--different for different people.
AustinJerry is online now
post #18094 of 22279 Old 03-22-2016, 08:37 AM
Quoted: 871 Post(s)
Liked: 280
Originally Posted by Alan P View Post
You are thinking of the house curve the wrong way...it is not lowering the high frequencies, it is boosting the low frequencies.
The high frequencies would seem to be playing at the exact same level as before the house curve, it is the low frequencies that get the needed boost.
But, to each their own.
hehe. I see what you did there
THANK YOU!!! for your selfless contribution to the audio world
Anders Torger for Brutefir
Thomas Drugeon for Rephase
John Mulcahy for room eq wizard
Denis Sbragion for DRC room correction
Juha Hartikainen for Winisd
1201 is online now
post #18095 of 22279 Old 03-22-2016, 08:43 AM
Quoted: 871 Post(s)
Liked: 280
Originally Posted by LastButNotLeast View Post
Perhaps, but I DO appreciate a 3dB boost above 12K.
Part of my "house curve."
Michael
I think we are saying the same thing. the normal house curve is 0 at the low bass, gently sloping down in the high frequencies sometimes by as much as 20 db.
im saying that many people , me included, will not find this balanced.
I listen at lower volumes so my highs are boosted a bit, per the fletcher munson equal loudness curve
absolutely. Im just saying that I also thought it was fact the listeners prefer a gently sloping house curve, and I chased that for a long time.
but I have changed my opinion and I feel that many factors go into the preferred curve, and for many, it is not close to what the article by Todd suggests, or the bruel and Kjaer curve etc.
1201 is online now
post #18096 of 22279 Old 03-22-2016, 09:00 AM
Quoted: 702 Post(s)
Liked: 367
I think its mostly personal preference. I am a metalhead so I need to boost highs otherwise electric guitars artificial and natural harmonics wouldn't make my ears bleed. I also need dynamic range of 1db.
donktard is offline
post #18097 of 22279 Old 03-22-2016, 09:21 AM
Liked: 3872
I, on the other hand, have this problem...
post #18098 of 22279 Old 03-22-2016, 10:04 AM
SherazNJ's Avatar
Quoted: 1210 Post(s)
Liked: 144
Issue with Mains phase not getting along with subs.
After spending a lot of time and following guidance from @markus767 and @AustinJerry who pointed out the issue with my subs response, I am finally able to get a good response across all the seats. Now I get flat response without any dip/null up to 90 and then it slowly goes down. This is exactly what I had been looking for all along.
After testing all the position with subs only, I was very happy with the results of subs. So I decided to run room correction. I use Dirac. It applies correction to each channel individually. After calibration was complete, I ran a sweep to see how well it did. Not good. There is a MAJOR dip at cross-over. This clearly shows the phase issue with Main and Subs. So, I started adding delay to sub channel to see if it gets any better. It did but no where close to what it should look like. It still gets 6-7db of dip and that's after adding 10 feet of distance to subs.
Question: What can I do to prevent it? Also, how can I test this issue without running whole Dirac measurement in REW. In other words, how can I test in REW the combined response of sub+main with delay included? I think after calibration, Dirac adds the delays to main/subs and after the delays are added, it is causing them to get out of phase.
SherazNJ is offline
post #18099 of 22279 Old 03-22-2016, 10:13 AM
3ll3d00d's Avatar
Quoted: 1592 Post(s)
Liked: 578
it depends what is causing it. You need measurements with a timing reference to drill into this behaviour properly, otherwise it's trial and error.
3ll3d00d is offline
post #18100 of 22279 Old 03-22-2016, 10:19 AM
markus767's Avatar
Quoted: 3797 Post(s)
Liked: 1352
Can you post separate measurements with acoustic timing enabled of L, C, R and SW? After Dirac and with bass management filters enabled.
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #18101 of 22279 Old 03-22-2016, 10:28 AM
Liked: 3872
Matt, sorry to pick on you, but a number of you continue to say that the timing reference will provide new insight into this type of trouble-shooting. This is supposed to be a learning thread. What we need is for someone to step up and provide a detailed example on how to apply the timing reference to a real-world situation, like SherazNJ's.
Anyone willing to take one for the team?
Alan P, SherazNJ and MrGrey like this.
post #18102 of 22279 Old 03-22-2016, 10:34 AM
Liked: 1192
I'm admittedly the amateur in this esteemed group, but wouldn't changing the phase of the subs help?
Michael
post #18103 of 22279 Old 03-22-2016, 10:34 AM
3ll3d00d's Avatar
Liked: 578
I must have posted this link about 5 times now so I've done my bit
https://www.avforums.com/threads/diy...#post-20662039
this is a data driven thread so it needs the user, who has a problem, to step up and provide the appropriate measurements for there to be any further discussion. I haven't seen anyone do that yet hence no progress
3ll3d00d is offline
post #18104 of 22279 Old 03-22-2016, 11:21 AM
SherazNJ's Avatar
Liked: 144
I think Jeremy covered what I was going to say.
Let me see if I get it right. You want acoustic timing of L,C,R,SW before/After Calibration?
Right on Jerry. We need the REW guide updated with acoustic timing info.
SherazNJ is offline
post #18105 of 22279 Old 03-22-2016, 11:23 AM
SherazNJ's Avatar
Liked: 144
Michael
changing phase on sub or adding delay on avr does the same thing. I changed delay in avr and still wasn't good results.
SherazNJ is offline
post #18106 of 22279 Old 03-22-2016, 11:28 AM
3ll3d00d's Avatar
Liked: 578
sounds like a plan
3ll3d00d is offline
post #18107 of 22279 Old 03-22-2016, 11:29 AM
Liked: 3872
OK, I promise to read it closely this time, thanks.
post #18108 of 22279 Old 03-22-2016, 11:30 AM
Liked: 1192
The wavelength at 50 Hz is over 20 feet. Did you change the distance at least that much?
(technically, half that to change the phase, but wavelength is even longer at lower frequencies, so you'd need a BIG change in distance to reverse phase).
[or, of course, I'm wrong. ]
Michael
post #18109 of 22279 Old 03-22-2016, 12:11 PM
SherazNJ's Avatar
Liked: 144
Michael
Here is a twist to this whole phase issue. I have Gamma 218 Subs from RA. The sub contains two 18" drivers facing side ways. When I had sub placed Horizontally (drivers facing side walls)hugging back wall, I didn't have to add even a foot. But in that case, I don't get the best results for subs. When I change subs from Horizontal to Vertical (drivers facting front and back walls) and move them around 9" away from back wall, I get very good sub response but Major phase issues.
I am starting to wonder if this sub design of having two drivers on opposite side vs having them aligned in front is causing it? Could it?
SherazNJ is offline
post #18110 of 22279 Old 03-22-2016, 01:25 PM
Alan P's Avatar
Quoted: 4886 Post(s)
Liked: 3513
No, not really...the two are quite different actually.
Changing phase only aligns the sub at one frequency, proper time-alignment (using digital delay) aligns the sub at all frequencies.
Alan P is offline
post #18111 of 22279 Old 03-22-2016, 01:30 PM
markus767's Avatar
Liked: 1352
After calibration and bass management, so 4 measurements with acoustic timing reference. You could do an additional measurement L+SW so I can check if the acoustic timing reference did work.
Markus
post #18112 of 22279 Old 03-22-2016, 01:47 PM
3ll3d00d's Avatar
Liked: 578
wut?
I don't know where you get the idea that time alignment == phase alignment
a phase dial is typically an all pass filter, i.e. a frequency dependent phase shift
a delay is a fixed time offset, i.e. a frequency dependent phase shift (as the amount of time represented by a 1 degree phase shift varies by frequency)
so there are differences in how they are implemented and the results may well be different (because they likely apply different phase shifts) but they are not different at all in principle
3ll3d00d is offline
post #18113 of 22279 Old 03-22-2016, 02:11 PM
Quoted: 702 Post(s)
Liked: 367
wut?
So, you are saying that once Audyssey time aligns subs I can still play with phase to get better results?
donktard is offline
post #18114 of 22279 Old 03-22-2016, 02:15 PM
3ll3d00d's Avatar
Liked: 578
well no, I didn't say anything about what that means for audyssey, I'm just saying how it works. Note that this also doesn't mean I'm saying you can't improve matters, that just depends on your situation.
3ll3d00d is offline
post #18115 of 22279 Old 03-22-2016, 02:18 PM
torii's Avatar
Quoted: 878 Post(s)
Liked: 459
is this a dirac or audyseey discussion?
torii is online now
post #18116 of 22279 Old 03-22-2016, 02:25 PM
SherazNJ's Avatar
Liked: 144
neither. Its a discussion of phase aligning speaker with sub. I just happen to be using dirac for calibration and in order to determine the issue, Markus among others want me to share the data.
Guys, I'll upload the file once I get home.
SherazNJ is offline
post #18117 of 22279 Old 03-22-2016, 02:26 PM
torii's Avatar
Quoted: 878 Post(s)
Liked: 459
sweet, as i am interested in this
torii is online now
post #18118 of 22279 Old 03-22-2016, 02:41 PM
Quoted: 702 Post(s)
Liked: 367
Here are couple of impulse measurements for those interested.
First picture is my typical Center channel impulse response. Then I added one ceiling 2'x4'x4" broadband absorber.
Then I added a nice wool blanket on couch.
Then 3 2'x4' absorbers on sidewall and additional ceiling absorber.
Last picture targets spike produced by floor reflection, I treated that one by putting 3 small fluffy fake fur pillows in front of center channel (they do seem to produce a big bump in frequency response from 500-700 Hz lol so i must see if that will be an issue).
I lost last measurement somehow though.
Anyway, although I have not tried out center yet, I played some music (and although there is a few more issues for fronts up to 10 ms because i didn't target them) and improved clarity is amazing. Stuff like Two Steps From Hell and typical classical music finally doesn't sound like a noisy mess.
ID:	1331074   Click image for larger version
ID:	1331082   Click image for larger version
ID:	1331090   Click image for larger version
ID:	1331106   Click image for larger version
Name:	floor issue.png
donktard is offline
post #18119 of 22279 Old 03-22-2016, 02:46 PM
Alan P's Avatar
Liked: 3513
wut?
Well, I was embarrassingly misinformed/uneducated....after doing some more research on phase/delay this afternoon, you are (of course) correct 3ll3d00d. I apologize for any confusion I may have caused to the OP.
Good news is, after doing all that reading on phase/delay, I have some ideas to try in my own system to maybe improve things a bit more.
3ll3d00d likes this.
Alan P is offline
post #18120 of 22279 Old 03-22-2016, 02:47 PM
etc6849's Avatar
Quoted: 171 Post(s)
Liked: 124
Interesting. So manually time aligning usually improves things? I use the Emotiva XMC-1 with the Emotiva version of Dirac Full. Seems to time align my subs with my main speakers.
Is it some issue with accuracy? There are a few phase issues on my plots, but I had assumed they were caused by my room.
Name:	FL freq resp.jpg
ID:	1331186   Click image for larger version
Name:	FR freq resp.jpg
Premise, a FREE home automation program. Open-source Z-Wave Premise Module found here.
etc6849 is offline
Dayton , Dayton Audio , Room Equilizer Wizard Rew
