Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 625 - AVS Forum | Home Theater Discussions And Reviews
 1740Likes
Old 05-16-2016, 05:27 PM
Soupy1970's Avatar
Quoted: 264 Post(s)
Liked: 269
I ran my first test run. I think it was just the front left Lol. I'm confused on how to set the "Limits". I'm also not sure where to go from here? Do I run all speakers individually, then run subs?
Denon X6200W - Klipsch KLF-10 Fronts - Klipsch KLF-C7 Center - Klipsch KLF-C7 X 2 Surrounds - Klipsch RB-61 II Back surround -OSD ACE850 ceiling x 4 Atmos - Dual HSU VTF-3 MK4 Subs - 4 Dayton Audio BST-1 Bass Shakers with SA230 Amp - BenQ W1070 projector - 106" Antra fixed Screen
Soupy1970 is offline
Old 05-16-2016, 05:30 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6621 Post(s)
Liked: 3654
Have you reviewed the guide?
AustinJerry is offline
Old 05-16-2016, 05:34 PM
Liked: 3654
Originally Posted by David Varner View Post
I am having an issue with my readings being very inconsistent and my headroom changing drastically between measurements. I notice right after I do SPL meter calibration and then take a reading everything seems OK and then the next reading the headroom goes up to like 32db when it was at 23db for the reading right after SPL calibration. I have a feeling it has something to do with the ASIO drivers. I am also experiencing the popping and clicking.(when I change outputs it goes away) ASIO is set to always resample 44.1-48 in ASIO control panel. I'm using UMM-6 and HDMI.
Basically my only resolution ATM is to SPL calibrate before every measurement. Any help would be greatly appreciated here is a graph the measurements that are "kind of flat" are right after SPL calibration and the measurements that dip below 300hz are the second measurement without SPL calibrating the mic right before.
The fact that you can SPL calibrate suggests that you are not using a sensitivity parameter, which should be automatically setting the level for the mic. If REW was loading the sensitivity parameter, you would get a message stating "calibration for this mic is not required". Why are you not using a sensitivity parameter?
Old 05-16-2016, 05:45 PM
Soupy1970's Avatar
Quoted: 264 Post(s)
Liked: 269
Your guide is how I reached the point I am at now. A lot of it went over my head but it was straight forward enough for me to invest the $100 in the Mic and give it a try. Thanks a bunch for that!. I'm going to re-read it until it all sinks in eventually.
Old 05-16-2016, 06:34 PM
Quoted: 168 Post(s)
Liked: 76
I am using "narrow_band_response_90_degree.frd" that came on the USB from Cross Spectrum. The sensitivity parameter is in that file correct? The UMM-6 I thought has to SPL calibrated no matter what. That is why I also bought a SPL meter.
David Varner is offline
Old 05-16-2016, 06:38 PM
Quoted: 168 Post(s)
Liked: 76
also see that there is another directory on the USB that says REW let me try the file in there. it is a .txt file not an .frd file.
That helped a lot but now I am having the opposite issue. With my first measurement I am getting A big dip below 300hz and every measurement after that seems normal. Hmmmm better than before I just have to ignore the first measurement. Is this normal?
Old 05-16-2016, 09:00 PM
Liked: 3654
The files from CSL do NOT have a sensitivity factor in them. You must download the file from the vendor web site. The REW guide linked in my sig has an entire section on this topic--please read it.
Old 05-16-2016, 09:29 PM
Soupy1970's Avatar
Quoted: 264 Post(s)
Liked: 269
FYI, my UMIK-1 from CSL that just arrived had the sensitivity factor in the files already. I actually went to load the sensitivity per Guide, but it was not needed.
Old 05-16-2016, 09:33 PM
Liked: 3654
It is very easy to open the file in a text editor to verify whether it contains the sensitivity factor. If it is there, fine, if not, the guide explains where to get it and how to load it.
Soupy1970 likes this.
Old 05-16-2016, 09:48 PM
Liked: 3654
When Soupy reported that his CSL calibration files included the sensitivity factor, I became curious and sent a note to Herb Singleton. Herb's response:
"We started including the *factory* sensitivity numbers for UMM-6 and UMIK-1 mics back around January/February because we were getting so many questions about people dealing with REW errors when using our calibration files. We don’t support or endorse those values, but they are there."
This is a nice enhancement to a good product--all the more reason to consider CSL as a place to buy your mic's. I'll update the Guide with this new information.
Soupy1970, andyc56 and bmcn like this.
Old 05-17-2016, 12:58 AM
Soupy1970's Avatar
Quoted: 264 Post(s)
Liked: 269
Ok, per page 95 of the guide, I did 12 sweeps. Can someone please take a look at the saved files and tell me if I'm on the right track. The first file 1 thru 6 is the full range sweeps with 1/6 smoothing. 7 thru 12 are the 300Hz sweeps with no smoothing. I did make a mistake on sweeps 11 & 12 and picked the Center plus subs in preference rather than let the AVR's bass management do it's thing. Thanks!
https://www.dropbox.com/s/0qqifmwiuh...%206.mdat?dl=0
https://www.dropbox.com/s/54syjqpt6b...2012.mdat?dl=0
Old 05-17-2016, 10:07 AM
EndersShadow's Avatar
Quoted: 449 Post(s)
Liked: 816
If I'm reading it right its on page 57 - 59 of the guide. Thanks for that, I needed to do the same myself for my mic before a big GTG in Chicago this weekend lol....
My Setup | FS: Nothing right now
Quote: There exists, for everyone, a sentence - a series of words - that has the power to destroy you. Another sentence exists, another series of words, that could heal you. If you're lucky you will get the 2nd, but you can be certain of getting the 1st. - Philip K. Dick
EndersShadow is online now
Old 05-17-2016, 10:27 AM
Quoted: 168 Post(s)
Liked: 76
I read the set-up guide thoroughly and thank you very much for putting the time and effort into that it got me this far.
I checked my calibration file the sens factor is included. But I am still having issues where it seems like the test tones that REW is putting out are not putting out the lower frequencies.(I can hear it as well) Every 2nd or 3rd measurement I am getting a huge fall-off below 200hz. I don't see how I can achieve accurate measurements with this happening.
Old 05-17-2016, 10:33 AM
Liked: 3654
I checked my calibration file the sens factor is included. But I am still having issues where it seems like the test tones that REW is putting out are not putting out the lower frequencies.(I can hear it as well) Every 2nd or 3rd measurement I am getting a huge dip below 200-300hz. I don't see how I can achieve accurate measurements with this happening.
REW is not the root cause, or all of us would be seeing this behavior.
Old 05-17-2016, 10:50 AM
Quoted: 168 Post(s)
Liked: 76
OK just making sure I will try some other things and will report back. Atlest, I know to look else where.
Old 05-17-2016, 12:38 PM
LastButNotLeast's Avatar
Quoted: 1492 Post(s)
Liked: 1092
So are they accurate, or do they just suppress the error message?
Michael
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
For most of the time, the here and now is neither now nor here. Graham Swift
LastButNotLeast is offline
Old 05-17-2016, 01:54 PM
Liked: 3654
Michael
Not sure what your question means, but let me take a stab at it. Since Herb has the mic's serial number, he is logging onto the vendor's web site, entering the serial number, and downloading the vendor's calibration file, which includes the sensitivity parameter. He is then transferring the parameter to the custom calibration files he develops, which are then included with the mics we purchase from CSL. So, since CSL is using the same file we would use if we were downloading it ourselves, I think it is safe to assume that both ways produce identical results.
Does that answer the question?
Old 05-17-2016, 07:13 PM
Soupy1970's Avatar
Quoted: 264 Post(s)
Liked: 269
Anyone? Please. I'm a little over my head on what I'm doing here. Getting to the measurements following the guide was easy, but now I'm lost. Thanks
Old 05-18-2016, 09:06 AM
Alan P's Avatar
Quoted: 4698 Post(s)
Liked: 3329
OK, I'm not as knowledgeable as some of the guys here, but I took a look at the MDATs you posted...here are my first impressions:
On the full range sweeps, it looks like Audyssey is doing a fairly decent job of flattening the response on your mains/CC besides one large null at 50hz that seems to show up on your left speaker only.
The Subs 1+2 measurements are weird...it seems your response got worse after Audyssey. And look at the waterfall/spectrogram for that measurement (!), something definitely went wrong during that sweep.
The Left+Right+Subs (actually should be L+Subs or R+Subs ) and Center+Subs measurements also look worse post-Audyssey....Audyssey seems to be creating a large dip in the response between 60-85hz.
A couple questions:
What speakers do you have?
What version of Audyssey are you using?
How many mic positions did you use?
Are you using a tripod or mic boom for the Audyssey mic?
What measurement microphone are you using?
Where are your crossovers set?
Alan P is online now
Old 05-18-2016, 09:17 AM
Soupy1970's Avatar
Quoted: 264 Post(s)
Liked: 269
A couple questions:
Are you using a tripod of mic boom for the Audyssey mic?
My setup is in my signature. I have the Denon X6200 with Audyssey XT32. For Audyssey I run the full 8 positions using a Mic boom positioned against the back rest of seat. For the REW sweeps I had to sit the Mic between the back rest. (I'll include pics of room with MIC in position). Crossover is 80. The left wall is plaster, and the rest is drywall. Maybe that is effecting left speaker. I run my Subs nearfield as end tables.
Room is 13' 3" W X 20' L X 7' 3" H
ID:	1445538   Click image for larger version
ID:	1445546   Click image for larger version
ID:	1445554   Click image for larger version
Old 05-18-2016, 09:25 AM
Soupy1970's Avatar
Quoted: 264 Post(s)
Liked: 269
^ When I run Audyssey the first position is in the middle but a little higher then the mic for REW is sitting. The 2nd and 3rd run the Audyssey mic on boom is resting against the top of Backrest. I keep the same height for all 8 sweeps.
Old 05-18-2016, 09:34 AM
Alan P's Avatar
Liked: 3329
Thanks Jerry!
Hmmm...well, XT32 should be doing a better job than I'm seeing in your Audyssey On measurements. Could be something wrong with your Audyssey technique.
You say "Mic boom positioned against the back rest of seat", not sure what that means, but if the boom is actually touching the seat, that is a no-no. I do not see a mic boom in your pics, I see a very small tripod for your measurement mic that is resting on the seating...another no-no.
You also said "For the REW sweeps I had to sit the Mic between the back rest"...why? You should be using the mic boom and positioning the measurement mic exactly where you head would be while listening. I'm thinking maybe you don't know what a mic boom is....it looks like this.
Are you keeping all 8 positions tightly clustered or are they spread out?
Have you reviewed the Audyssey 101 and FAQ (linked in my sig)?
I notice you have leather (or "leather-like") seating. During Audyssey calibration, I would highly recommend you cover those seats with something thick like a blanket or towels. This can reduce unwanted reflections off of the leather that can screw up your calibration.
And, just because I'm curious, why are you using horizontal speakers for surrounds and why are your subs facing opposite directions?
Oh, and I'm not Jerry.
Old 05-18-2016, 09:37 AM
Alan P's Avatar
Liked: 3329
One other comment....have you tried one sub up front and one nearfield (or one in the back of the room)? You will get more of the smoothing benefit from duals if you spread them out more.
Old 05-18-2016, 09:45 AM
Liked: 3654
Observations:
- You seem to have a good grasp of how to take and present the REW measurements, so good job there.
- In measurements 1-6, Audyssey is doing a good job in smoothing out the pre-Audyssey response curves, which show some pretty big variations.
- The measurement level for the left channel is 6-7dB higher--what happened there?
- Bass ringing not too bad--a minor issue in the 40-50Hz range showing on the left channel.
- The measurement showing subs 1+2, Audyssey on, is not very good at all, showing wild 30dB swings. What version of Audyssey are you using, XT32? The bass response needs major work.
Old 05-18-2016, 09:48 AM
Soupy1970's Avatar
Quoted: 264 Post(s)
Liked: 269
Thanks Alan! I'll include a picture of Audyssey mic position. It only touches in the 2nd, and 3rd Audyssey sweep. I actually did cover the seat with blankets. If you look at the picture of the back of my room you will see there is no place for Subs. I could run one up front though. As for the surrounds, i just wanted to be timber matched. That Center is full range and sounds better than the Klipsch RB-61 bookshelf I had before. I can run Audyssey again tonight. Thanks again for help.
Old 05-18-2016, 09:55 AM
Soupy1970's Avatar
Quoted: 264 Post(s)
Liked: 269
Observations:
Thanks for chiming in. Yes XT32. I'm off to work now, but late tonight I will run Audyssey again, then run new sweeps in REW. One thing that I did during those first sweeps was change the Mic volume in Windows because on the 2nd or 3rd sweep my headroom dropped. Not sure if that did anything to mess up the readings.
Old 05-18-2016, 09:57 AM
Liked: 3654
I would not worry about the mic measurement level--it was only a minor observation. What is far more problematic is the choppy bass response. You should use REW to find better placements for the subs in an attempt to smooth out the response.
Old 05-18-2016, 10:01 AM
Soupy1970's Avatar
Quoted: 264 Post(s)
Liked: 269
What would be the best way to find the best Sub position. Should I disconnect one sub, and place the other in the seat and take measurements in all availble positions?
Old 05-18-2016, 10:27 AM
Alan P's Avatar
Liked: 3329
Jerry,
If you look at the pre-Audyssey subs only sweep you can easily tell that something went wrong with the post-Audyssey measurement...especially if you look at the spectrogram.
Why is the mic touching anything besides the boom?? Is your boom wore out or something?
Most horizontal speakers are a compromise (to fit under or over a display), I wouldn't recommend them for surrounds...but to each their own.
I took a single sub and moved it to every available position in the room (furniture sliders are your best friend during this) and took sweeps. I then placed the two subs in the two spots that measured best. Of course, there will still be more tweaking after that, but it will get you in the ballpark.
Old 05-18-2016, 10:50 AM
boifido's Avatar
Quoted: 73 Post(s)
I'm just wanting to confirm about calibrating to reference. Say I do a -20db sweep in REW, and it hypothetically showed 85db flat on the graph from 20hz-20khz. Would that be valid? (Ignoring the dolby 85db vs 83db debacle thread)
I'm worried about accuracy calibrating with pink noise as getting subs dialed in with band limited signal seems like it could be prone to error. It would be easier for me to use the graph to integrate subs with the speakers so the combined system was roughly showing 85db on a -20db sweep. If that's accurate for the low end then maybe I could try afterwards doing a bass managed full range pink noise calibration.
boifido is online now
Dayton , Dayton Audio , Room Equilizer Wizard Rew
