Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 642 - AVS Forum | Home Theater Discussions And Reviews
 1351Likes
post #19231 of 19246 Unread Yesterday, 05:12 PM
citsur86's Avatar
Quoted: 280 Post(s)
Liked: 70
Originally Posted by AustinJerry View Post
Low frequencies will generate standing waves in a room. The standing waves depend on the room dimensions. For example, my room has a width of 19"6". The primary resonant frequency associated with this dimension is 29Hz. A primary wave will have a peak at the left and right room boundaries, and a null exactly in the center of the room. So, if you sit in the center of the room, you will never hear 29Hz bass notes. The second resonant frequency is 58Hz. it will have nulls at the 1/4 and 3/4 points across the room width, and a peak at 58Hz. So, if you sit in the center of the room, 58Hz bass notes will sound loud and over-emphasized. The point is that your room has resonant frequencies, and depending on what they are, you will hear (and measure) peaks and nulls at the MLP.
If you were to provide a layout of your room, including length, width and height dimensions, as well as the current position of your speakers and sub(s), I can plug the dimensions into a room mode calculator to predict the response at the MLP. Once we know these details, we can make recommendations that might alleviate response issues, which you can decide to follow or not.
Take a look at the link in my signature where you can find pictures of my room. You'll see that the room my speakers and sub are in is basically the majority of my first floor which Is almost completely open concept. Would I include the kitchen / dining room in my measurements since these rooms are completely open to the living room where the sub is.
FS: Proficient GL6 Center Channel Speaker
My Current "Living Room" Home Theater!
citsur86 is offline
post #19232 of 19246 Unread Yesterday, 05:12 PM
AustinJerry's Avatar
Quoted: 5055 Post(s)
Liked: 2852
Originally Posted by citsur86 View Post
Got it! Very helpful thanks! Soooo I kind of understand there are these miniDSPs you can buy that sit between the sub and AVR which can apply corrections at the problematic areas, like my 25-35hz Mount Everest. What exact device would I need and is it complicated ton"program" it to do the EQ corrections?
EQ can pull down peaks, but is not very effective at raising dips. Before leaping forward and purchasing a device that may or may not help, let's try and understand why you are seeing the response you are measuring. Please provide the information I requested.
AustinJerry is offline
post #19233 of 19246 Unread Yesterday, 05:17 PM
Liked: 2852
That is a challenging room shape. The back of my room is open as well (pics in my sig). Another approach that will at least give you an indication of whether location of the MLP is influencing the response is to move the REW mic a foot to the left, a foot to the right, then forward and finally backwards. Take the same measurement at each spot and not whether you see significant variances.
post #19234 of 19246 Unread Yesterday, 05:20 PM
citsur86's Avatar
Quoted: 280 Post(s)
Liked: 70
Ok I'll likely do this tomorrow since I can't really run anymore sweeps tonight. Baby sleeping and all. But I can see if there are any changes a foot in any direction from MLP.
citsur86 is offline
post #19235 of 19246 Unread Yesterday, 05:31 PM
citsur86's Avatar
Quoted: 280 Post(s)
Liked: 70
Originally Posted by PlasmaPZ80U View Post
When you say speaker only, did you set the speakers to large/sub disabled to disable bass management?
Also, when doing so don't measure too loud (85-90dB average should be enough) and start the sweep not much lower than the rated low extension of your speakers to minimize the risk of bottoming out any woofers. I would say 40-50Hz for bookshelves/cc and a bit lower for small to medium towers, like 30-40Hz. Satellites probably 70-80Hz or higher.
If you measured the speakers with bass management off than if you see any similar peaks or dips to the subwoofer it is room acoustics.
Forgot to reply to this. Nope guess I did the speaker only wrong. I just went into the generate tone screen and set to speaker only and then did channels 1, 2, and 3.
Also, because the LFE channel measures 10dB higher, turning the REW signal from -12dBFS to -22dBFS for LFE will keep you from running sweeps too close to this sub's output limits especially downlow.
You currently seem to be measuring the sub around 100dB and it maxes out at 20Hz just slightly higher. So, 90dB would be easier on the sub.
I completely forgot the volume I set the receiver to mattered. Brain fart on my part. It's also why the second set of graphs went up into the 100s and why the "weird sounds" I was hearing from the subs were happening. I was watching some demo scenes between those runs and had the volume about 7db higher than the first tests. I also realize now that the higher volume at 15hz out of a sub rated to 19hz is a bad idea! I understand enough now not to do that. Hopefully I didn't do any damage to the sub.
citsur86 is offline
post #19236 of 19246 Unread Yesterday, 05:59 PM
XBR11's Avatar
Quoted: 238 Post(s)
Liked: 148
Having a problem. Or two. Can't play any sound to play through my AVR.
Recording Devices. UMIK. Properties. Listen tab. Playback through this device.
Should it be the "Default Playback Device" or the HDMI device (my default device is listed as "Sony AVAMP")? (This page 25 of the instructions)
Page 30 of the instructions. I cannot find "Open the Windows Sound Recorder app (Start/All Programs/Accessories/Sound Recorder)".
But I can find "Voice Recorder". Is it the same thing? I have Windows 10. Perhaps these instructions were from a previous version of Windows.
When I record something I am getting "We couldn't save this recording. It looks like the autosaved file was deleted before you finished recording it." So anything I try to record (to test the playback) doesn't work. What do I do?
_______________________________________________
[Hey, what does that Acronym mean?! Click here to learn.]
XBR11 is offline
post #19237 of 19246 Unread Yesterday, 06:02 PM
citsur86's Avatar
Quoted: 280 Post(s)
Liked: 70
Just went through these troubles today. Set the default playback device to the hdmi or receiver that shows up when you connect the PC to the AVR and the AVR is on the input that the HDMI is plugged into. Voice recorder is sound recorder on windows 10. I don't know about the saving issue, but the more important thing is that you can playback the quick test clip of your voice you record to make sure the mic is hooked up and working. Make sure you close out of voice recorder before opening REW too since REW needs sole propriety over the mic
citsur86 is offline
post #19238 of 19246 Unread Yesterday, 06:06 PM
XBR11's Avatar
Quoted: 238 Post(s)
Liked: 148
I can't record my voice, and play it back, because it won't save.
XBR11 is offline
post #19239 of 19246 Unread Yesterday, 06:08 PM
citsur86's Avatar
Quoted: 280 Post(s)
Liked: 70
Ah I see. Try the things here: http://answers.microsoft.com/en-us/w...f137386?auth=1
citsur86 is offline
post #19240 of 19246 Unread Yesterday, 06:08 PM
PlasmaPZ80U's Avatar
Quoted: 1551 Post(s)
Liked: 465
Yes, the frequency response graph is showing that the sub is playing much louder at 25-35Hz at the MLP.
The comment about masking sound under 25-35Hz peak refers to the subwoofer output, which comes from the LFE channel and bass management. In a nutshell, having 25-35Hz play *much* louder than 15-25Hz or so will make the stuff under 25Hz barely audible (if at all) audible. That assumes the sound is not just purely under 25Hz, but also includes 25-35Hz or even higher.
Dominating the response means that what you hear from the sub will be mostly the 25-35Hz peak, since it is much louder than everything else sub-wise. It isn't necessarily referring to the speaker/sub balance but rather overall frequency response for all channels, particularly the LFE channel.
Regarding headroom, I might be wrong but my logic would be that the peak at 25Hz-35Hz isn't eating up headroom because the room acoustics are boosting that frequency range, not sub EQ. So, if you were to take ground plane measurements of the sub up close you would likely see that sub on it's own is playing quite flat but the room is what adds peaks, dips, ripples, etc. So, as I understand it, that peak doesn't eat headroom but it does mean at high SPL you will be hearing 25-35Hz very loud. Removing that peak with EQ would basically compensate for the room acoustics making 25-35Hz about as loud as everything else the sub plays.
The new MiniDSP 2x4 HD would be good choice because it has the unbalanced rca connections you need for LV12R and it has twice the max input and output voltage capability of the MiniDSP 2x4 unbalanced (which I have).
Having more capability means the MiniDSP input is less likely to clip/distort at high SPL and also means you won't have to crank sw gain too much.
It works with REW EQ tool and the MiniDSP plug-in. Quite easy to use with a little practice.
PlasmaPZ80U is offline
post #19241 of 19246 Unread Yesterday, 06:27 PM
XBR11's Avatar
Quoted: 238 Post(s)
Liked: 148
I followed its advice. It said something like my internal speakers were disabled and it re-enabled them. This is true, since I only wanted to output via HDMI, I had disabled my internal speakers.
With this "fix" I will try again tomorrow (when I have more time).
thanks for the quick help.
XBR11 is offline
post #19242 of 19246 Unread Yesterday, 06:52 PM
citsur86's Avatar
Quoted: 280 Post(s)
Liked: 70
Been reading up on it. Doesn't seem too complicated. Wondering if it's compatible with my receiver. Also wondering if $225 more (plus the $100 for the UMIK-1) will really give me enough benefit from my $600 sub or not.
citsur86 is offline
post #19243 of 19246 Unread Yesterday, 06:57 PM
citsur86's Avatar
Quoted: 280 Post(s)
Liked: 70
The reason I'm wondering if it works with my receive is that it looks like the miniDSP 2x4 HD has 2 inputs. Is that for LFE input or Line In? My sub seems to only have an LFE output.
citsur86 is offline
post #19244 of 19246 Unread Yesterday, 07:06 PM
XBR11's Avatar
Quoted: 238 Post(s)
Liked: 148
citsur86 - I have the MiniDSP nanoAVR HD. Haven't used it yet. Take a look at it.
XBR11 is offline
post #19245 of 19246 Unread Yesterday, 07:26 PM
Liked: 465
All you need is a second rca cable: first cable from AVR sub/LFE pre-out to MiniDSP input 1 and second cable from MiniDSP output 1 to LV12R LFE in (or Line In if you prefer).
The MiniDSP 2x4 unbalanced is cheaper, but you might have issues with clipping past -10MV or so. You can read Jerry's MiniDSP/multi sub guide for more info on gain structure and the like to understand the difference in input and output voltages and how it relates to sw trim and MV.
https://dl.dropboxusercontent.com/u/...0Rev%201.4.pdf
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Rythmik LV12R; PS4, Xbox One, Motorola RNG150N
post #19246 of 19246 Unread Today, 12:24 AM
3ll3d00d's Avatar
Quoted: 1193 Post(s)
Liked: 399
Something isn't right about your REW measurement technique, I am sorry to say. Not sure where to go from here. Perhaps Matt will have a suggestion.
it's certainly v strange
here's a pic of the IR for one of the main channel measurements in the data @indus1 posted, the blue line is a random measurement of my L speaker for comparison
and here it is in dBFS terms which show that the measurement remains almost (within a few dB) as loud as the initial signal a full 10-15ms later and it is persistently loud not just spikes (reflections) which you can see in my data.
@indus1 your measurement is extraordinarily noisy, this can't possibly be your room unless you sit in a glass box. The only guess I have is that it's the channel you are using for a non existent timing reference. I would remove that and try again.
ID:	1568793   Click image for larger version
3ll3d00d is online now
Dayton , Dayton Audio , Room Equilizer Wizard Rew
