Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 644 - AVS Forum | Home Theater Discussions And Reviews
 1362Likes
post #19291 of 19307 Old Today, 03:26 AM
Lesmor's Avatar
Quoted: 307 Post(s)
Liked: 111
Originally Posted by indus1 View Post
Thanks Matt
On your first slide you have an option 'choose ref output' in the drop down. I don't have that option appear. HD audio ouput 1 appears as the first option rather than 'choose ref output'
Perhaps I have inadvertently turned something on somewhere that prevents the 'choose ref output' option from appearing?
I think I'm using the latest version of REW but won't be able to check until I get home.
Hi Indus
You can ignore any reference to HD audio 1 & 2 as AFAIK that refers to your laptop speakers.
The settings are different if you don't physically have the UMIC-1 and HDMI cables connected which is probably why you don't see any ref output option.
Lesmor is online now
post #19292 of 19307 Old Today, 06:14 AM
AustinJerry's Avatar
Quoted: 5061 Post(s)
Liked: 2858
Thanks Matt
OK, I just got my REW kit set up to see if I can add anything to this discussion.
- On the Preferences screen, the drop-down for Timing Reference Output does not contain a choice "None", or "Please select a device". I believe the latter only appears on a fresh install. This is true even if "No Timing Reference" is selected on the Analysis tab. I recommend selecting a valid channel from the drop-down to avoid confusion, but I don't think it makes any difference.
- On the Measurement screen, immediately below the primary Output selection is a second box with a check box next to it. Typically, this box would be empty to start with. If you select "Use Acoustic Timing Reference" on the Analysis tab, then this second box would be used to select the desired speaker for the timing reference signal (after checking the box). Otherwise, the second box would be used to send the REW measurement signal to two speakers at the same time, e.g. left+right.
- Clearly, the UMIK-1 must be selected as the input device on the Preferences Soundcard tab, otherwise the measurements will not be valid. This may well be Indus1's issue.
AustinJerry is offline
post #19293 of 19307 Old Today, 06:21 AM
PlasmaPZ80U's Avatar
Quoted: 1562 Post(s)
Liked: 468
Originally Posted by citsur86 View Post
Just ran LFE only - looks like I have a considerable dip at MLP right before Xover pt (at 80hz). I tried the distance tweek and even at a foot further, there is no difference at all in the graph.
File can be downloaded here.
Sub distance tweak is for CC+subs, not LFE
After some minor fixes to securing the amp onto my LV12R I decided to rerun some of my sweeps tonight moving the mic slightly as I went. Results are below. File can be downloaded here.
MLP vs Best alternative (happens to be SLP) Unsmoothed
Going to run same tests LFE only now at -22db. Anyone think I can do anything to improve this, other than Moving the sub for now and other than miniDSP for now?
Yeah, if you use the SLP, you don't really need a MiniDSP for now.
PlasmaPZ80U is online now
post #19294 of 19307 Old Today, 06:46 AM
citsur86's Avatar
Quoted: 309 Post(s)
Liked: 75
So your opinion is that levels are pretty good at SLP? I sat in SLP last night and turned on a few demo scenes and all I could hear was voices from the front left (since SLP is closer to FL). When I moved over to MLP, center channel had dialogue as normal. Guess I need to rerun MCACC with mic at SLP. But then my levels might change
FS: Proficient GL6 Center Channel Speaker
My Current "Living Room" Home Theater!
citsur86 is online now
post #19295 of 19307 Old Today, 07:04 AM
Liked: 468
Yeah, you would need to rerun MCACC anytime you change the mlp, speaker positions or sub position/gain.
post #19296 of 19307 Old Today, 07:13 AM
citsur86's Avatar
Quoted: 309 Post(s)
Liked: 75
If I do that, which I will, couldn't REW start telling me bass response is better at old MLP lol? Also, not that she cares, but i never realized my wife sitting on the other side of the couch was hearing dialogue from the front left speaker - that's kind of crappy. A move of 2ft or so changes where you hear sounds from so drastically? So there is only 1 spot in my living room where sound is not completely (noticeably) messed up?
post #19297 of 19307 Old Today, 07:47 AM
Liked: 2858
You are not solving the fundamental issues, just putting a bandaid on it. There are proven paths to improvement. Whether you can take advantage of them or not, only you can say. In order of effectiveness, they are:
- Adding one or more subs
- Finding the best placement for the subs you have
- Effective use of EQ
- Treatments (for certain problems, like resonance)
post #19298 of 19307 Old Today, 07:50 AM
Liked: 2858
Originally Posted by donktard View Post
I had an issue with extremely noisy impulse response when I was using one USB interface with mic to measure with REW and another USB soundcard to output sweep to a speaker.
Using same USB interface for input and output doesn't have that issue.
I don't know what kind of setup you have, but I don't think your tip is applicable to most of us in this thread. USB is used for the mic input, but the output is HDMI.
post #19299 of 19307 Old Today, 07:51 AM
citsur86's Avatar
Quoted: 309 Post(s)
Liked: 75
Got it and thanks for all your help. I'm completely on board with your info and trust you and other folks here who have given me the same recommendations. I guess for the moment, I am just at a place of "as good as it's gonna get" without being able to do any of the above listed items. But you know what? It sounds damn good and I'm happy with it as is for the time being. I'm thinking buying the UMIK-1 was good and bad. Good because it let me see my response and where the problem areas are. But I guess I should have thought over the purchase before I made it, seeing as how there really is almost nothing I can do about it for right now. Ignorance is bliss
post #19300 of 19307 Old Today, 08:14 AM
Alan P's Avatar
Quoted: 3743 Post(s)
Liked: 2479
You need to go much further than 1 foot. It usually takes multiple feet before you see a difference. Also, make sure you back out of the menu for the new setting to take effect.
First of all, you shouldn't have dialogue coming from the mains (you have a center, right?) most of the time. Sometimes dialogue is mixed to the other channels, but the majority of the time it should be coming from the CC only. Unless you are using a surround mode that is matrixing the dialogue into the mains (i.e. PLII Music).
Try sitting in the SLP and listening carefully for a while. Listen particularly to the bass, at varying volume levels. If you can't tell any difference, then don't worry about it and keep your MLP where it is.
Alan P is online now
post #19301 of 19307 Old Today, 08:22 AM
citsur86's Avatar
Quoted: 309 Post(s)
Liked: 75
Well strangely - that mountain at the beginning is considerably different just 2-3 feet to the left of the MLP which is the other couch seat (SLP). I think it peaks about -5db from MLP at SLP. I always use 5.1 from source (Xbox One Uncompressed) being matrixed to PLIIz Heights for TV. The dialogue I heard was only audible from FL sitting at SLP (I moved to MLP) but it was during a commercial on ABC or something. Wondering if the commercial just had crap audio. Now that I'm thinking into this so much, I am going to do some more testing when I get home like you said before switching MLP or redoing MCACC. Maybe I'll try a heavy LFE scene like the train scene on the Demo I have at MLP then at SLP at same volume and see if there is an audible difference. If not MLP will stay. It's fun to tinker, but now I see where people say you can get a little OCD with this stuff!
post #19302 of 19307 Old Today, 08:55 AM
ChrisGTL's Avatar
Quoted: 36 Post(s)
Seriously. Don't test the performance of your equipment while an advert on TV is playing - feed your system with audio that will do your money justice.
Sent from my Nexus 5 using Tapatalk
ChrisGTL is online now
post #19303 of 19307 Old Today, 09:09 AM
citsur86's Avatar
Quoted: 309 Post(s)
Liked: 75
Yeah i wasn't really testing, just sat down after all the REW sweeps at like 12:30am and turned TV on for a minute before turning it off and going to bed. I'll do more serious testing tonight with the demo discs I have.
post #19304 of 19307 Old Today, 09:49 AM
Alan P's Avatar
Liked: 2479
Yeah, PLIIz should keep the dialogue where it belongs (in the CC), but like Chris said, commercials are not the best source material.
My wife likes to lay on the couch when we watch movies. The couch is up against the right hand wall, about 3' from the MLP. While the bass is great there, the imaging kind of sucks. Yeah, the dialogue is still anchored to the screen by the CC, but the effects/music are most certainly weighted heavily to the right when sitting/laying there. She really doesn't care though, so fine by me if that's her preferred seat.
post #19305 of 19307 Old Today, 09:50 AM
Liked: 468
Commercials are often 2.0 channel (stereo). Regardless of the settings on your cable box or Xbox. Also, I wouldn't judge your setup with matrix modes active or with cable TV or the like.
You may also want to make sure that the audio settings on your cable box disable any dynamic range compression and matrix modes for stereo content. And be sure its giving you DD 5.1 for the HD channels.
The Xbox One can be set for uncompressed 7.1 or 5.1 (I find 7.1 useful even for 5.1 setups, since the 5.1 option downmixes 7.1 signals in BD movies incorrectly to the mains instead of the side surrounds) and be sure that the setting for TV surround sound is set to surround, not stereo... it is hidden in a TV menu separate from the audio settings and defaults to stereo.
Best to use the direct or straight decode option on the AVR that disables all extra processing. At least for evaluating things.
It's better to use reference scenes from a few good movies you know very well (BDs).
post #19306 of 19307 Old Today, 09:54 AM
Liked: 468
Good advice, subjectively evaluating this first before going through too much trouble is wise.
As a side note, I think Pioneer AVRs can save up to 6 separate MCACC runs/calibrations and then let you toggle between them...
post #19307 of 19307 Old Today, 09:58 AM
citsur86's Avatar
Quoted: 309 Post(s)
Liked: 75
Some Pioneer AVR's do. Not the VSX-44 - been down that road in that thread. It REALLYYY pushes the word "Elite" to it's limits.
Dayton , Dayton Audio , Room Equilizer Wizard Rew
