Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 645 - AVS Forum | Home Theater Discussions And Reviews
 1364Likes
post #19321 of 19328 Old Today, 06:53 AM
LastButNotLeast's Avatar
Quoted: 1117 Post(s)
Liked: 769
Originally Posted by PlasmaPZ80U View Post
Do any of them make AVRs with Dirac Live built in? Or pre-pros?
Scroll to the bottom of this page:
http://www.dirac.com/home-and-professional-audio/
Michael
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
LastButNotLeast is offline
post #19322 of 19328 Old Today, 07:16 AM
AustinJerry's Avatar
Quoted: 5064 Post(s)
Liked: 2859
Originally Posted by citsur86 View Post
Thanks. Got it. So in your case is the 2x4 is just a consolidation device not doing any EQ?
The 2x4 is not doing any EQ. The only processing it does is to set the delays for the subs. I tried using REW-generated EQ filters in the 2x4 before running Dirac. After measuring the results both with EQ and without EQ in the 2x4, I did not see any difference (i.e. the 2x4 EQ was not adding anything). In the interests of keeping things as simple as possible, I disabled the 2x4 EQ.
AustinJerry is online now
post #19323 of 19328 Old Today, 07:20 AM
Liked: 2859
Does this mean that you disable any room correction in your AVR or pre-pro and leave the trims and delays in that at defaults too? Letting the 88A do all of that?
Wondering how it works...
Yes, Audyssey is disabled in my 8802, trims and delays are all set to zero, and all speakers are set to "large" (the 88A has a more sophisticated bass management capability). All trims and delays are set by Dirac Live (in the same way that Audyssey sets trims and delays).
post #19324 of 19328 Old Today, 07:21 AM
Liked: 2859
Didn't Indus1 answer this for you already?
post #19325 of 19328 Old Today, 07:52 AM
PlasmaPZ80U's Avatar
Quoted: 1567 Post(s)
Liked: 468
Thanks for the details
PlasmaPZ80U is online now
post #19326 of 19328 Old Today, 08:07 AM
citsur86's Avatar
Quoted: 317 Post(s)
Liked: 75
Nice good to learn that something like that is available. When I click the pioneer link at the bottom of the Dirac page it takes me to a Japanese site. Wondering what AVRs have Dirac built in as well
FS: Proficient GL6 Center Channel Speaker
My Current "Living Room" Home Theater!
citsur86 is online now
post #19327 of 19328 Old Today, 09:09 AM
Liked: 2859
The advantage of an outboard solution is that you can upgrade AVR's to take advantage of new technologies, yet retain the same room correction technology.
post #19328 of 19328 Old Today, 09:30 AM
Liked: 468
Only concern I have with Dirac Live is overall cost/complexity of setup. Up til now even Audyssey XT32 was out of reach, but that Denon AVR-3300W is just close enough to the Audyssey XT AVRs I was comfortable spending money on to be worth the money. I'm currently using YPAO on a 2013 Yamaha AVR that was the lowest model in their entire range at the time. It was worth $250-$300 MSRP at the time, part of an entry level HTiB. That version of YPAO is good enough for the basics (setting trims, delay, and bass management) but it's auto PEQ has crappy sound quality despite marginal improvements in measured frequency response, particularly with treble.
The MiniDSP 2x4 unbalanced handles sub EQ more than well enough for me, but I need a better room correction solution for my 5 speaker channels.
Dirac Live would be ideal but I don't think Audyssey XT32 would disappoint, especially coming from my Yamaha HTR-3066.
Dayton , Dayton Audio , Room Equilizer Wizard Rew
