Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 652 - AVS Forum | Home Theater Discussions And Reviews
 2095Likes
post #19531 of 22901 Old 08-06-2016, 05:04 PM
Quoted: 703 Post(s)
Liked: 370
Originally Posted by AustinJerry View Post
The objective of the exercise was to measure the center channel. To do that, the same mono signal must be sent to both the left and right channels. So I am not sure what your suggestion means.
And using all channel stereo and unplugging the other speakers might be an option, but I am not looking for a solution that requires unplugging a lot of speakers. And finally, I am using a 100Hz crossover.
Why would it need to be sent to both channels? What do you think will happen if you send signal only to left channel? My guess is that frequency response measured on center channel will be 3dB lower then if you send signal to both speakers. The only thing I am not sure is will signal be 3dB lower across whole spectrum or only below crossover point.
I actually tried the same today with dreaded multi ch stereo. Frequency response of center channel was same when I sent to only left/right and when i sent to both. The only difference was that SPL when I sent to both channels was higher across whole frequency range.
Revel Ultima Salon 2, Revel M106, Revel C208, Yamaha P5000S, Denon X5200, Panasonic 65" VT50, SVS PC13-Ultra
Kef LS50, Parasound New Classic, Focusrite 2i2
donktard is offline
post #19532 of 22901 Old 08-06-2016, 05:09 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 7150 Post(s)
Liked: 3988
If you send a signal to the left speaker, then the sound comes out of the left speaker, not the center channel. The purpose of sending the signal to both the left and the right speakers at the same time is that Pro Logic, and now Dolby Surround, algorithms ate designed to reproduce sound in the center channel if both left and right channels have the same signal. That is what a center channel does. Not sure why this is difficult for you to understand.
AustinJerry is offline
post #19533 of 22901 Old 08-06-2016, 05:14 PM
Quoted: 703 Post(s)
Liked: 370
Got it now. Just a bit of a flaw in my logic.
Madmax67 likes this.
donktard is offline
post #19534 of 22901 Old 08-07-2016, 12:27 AM
indus1's Avatar
Quoted: 175 Post(s)
Originally Posted by 3ll3d00d View Post
you need to keep the reference channel constant otherwise it's not a reference & you want the full set for each channel (main channel alone, sub alone, combined)
Hi there
I've taken the following measurements
1) Left, right and centre channel only with sub switched off. I have used the centre channel as TR. When measuring the centre channel I've taken two measurements, one with the centre as TR and another with left channel as TR.
I'm not sure there is any sense or use to this approach but thought it was better to have too much data than not enough...yet again lol
2) Left, right and centre channels in combination with sub. Once again the centre is TR for L and R and then two measurements for centre channel with two different TRs.
3) Sub signal only from Left, Right and Centre. Same deal with timing refs.
https://www.dropbox.com/s/2h09f6flox...8-16.mdat?dl=0
Thanks for your help
ID:	1588601   Click image for larger version
ID:	1588609   Click image for larger version
ID:	1588617   Click image for larger version
ID:	1588625   Click image for larger version
ID:	1588641   Click image for larger version
ID:	1588657   Click image for larger version
ID:	1588665   Click image for larger version
ID:	1588673   Click image for larger version
ID:	1588689   Click image for larger version
indus1 is offline
post #19535 of 22901 Old 08-07-2016, 03:36 AM
JohnPM's Avatar
Quoted: 80 Post(s)
Liked: 51
Originally Posted by artur9 View Post
An unrelated question: Is there anyway to get REW to do the sweep measurement using an external WAV file? Occasionally I am curious as to what effect the entire chain has on sound. In that case it would be useful to measure a sweep using a file originating on my music server.
A measurement sweep can be saved to WAV from the signal generator. If you save a sweep with an acoustic timing reference signal, set the timing reference mode in the Analysis preferences to Acoustic timing reference and use 'Wait for timing reference' on the measurement dialog you can hit 'Start measuring' then play the WAV file to make the measurement. Just make sure the sweep settings in the measurement dialog are exactly the same as those used when the sweep was saved to WAV or the result will be meaningless.
LastButNotLeast likes this.
JohnPM is online now
post #19536 of 22901 Old 08-07-2016, 05:12 AM
Liked: 3988
The sub measurement, whether taken when outputting the test signal to the left, right, or center speaker, will always be the same. This assumes the same crossover for each of the mains, of course. Don't know why you would think it would be different.
Something is going on with the center channel with that rather large dip. The left and right look reasonable.
post #19537 of 22901 Old 08-07-2016, 05:23 AM
Lesmor's Avatar
Quoted: 368 Post(s)
Liked: 144
The sub graph on its own looks ok apart from rolling off far to early at the 80Hz XO
Once you add a main speaker all bets are off.
I assume these are all with Dirac on ?
If it was me I would be taking all my sweeps with EQ off until I had things the best I could and then run Dirac.
No offence but if that's the best Dirac can do for Mains + Sub I'll stick with Audyssey for the time being
Lesmor is online now
post #19538 of 22901 Old 08-07-2016, 06:14 AM
3ll3d00d's Avatar
Quoted: 1636 Post(s)
Liked: 601
Hi there
the dip in your centre channel response can be filled in, to some extent at least, with the sub but you need to fix its basic response first
this compares it to a 80Hz high pass filter of the sort your AVR applies, you can see there is a 5dB hump above the target around 70Hz and that comes out in your combined measurement. If you pull this down and adjust the timing of the sub a touch then you'll get a more even response through the crossover. You probably have to compromise along the way, I doubt you will be able to get all three bang on.
3ll3d00d is online now
post #19539 of 22901 Old 08-07-2016, 08:29 AM
Liked: 3988
I don't think that is a fair criticism of Dirac. Unless you were to see an Audyssey calibration of Indus1's setup to see how well it handles what seem to be a difficult situation, I don't know how you can make any conclusions.
post #19540 of 22901 Old 08-07-2016, 09:22 AM
citsur86's Avatar
Quoted: 1203 Post(s)
Liked: 457
Will be attempting to setup miniDSP 2x4 HD filters and EQ today. Wish me luck!
citsur86 is online now
post #19541 of 22901 Old 08-07-2016, 09:25 AM
indus1's Avatar
Quoted: 175 Post(s)
Matt asked me to provide the data. It is not for me to question why...
indus1 is offline
post #19542 of 22901 Old 08-07-2016, 09:29 AM
indus1's Avatar
Quoted: 175 Post(s)
Hi
Could you kindly give me some more instruction as to how I go about achieving this?
How do I pull down the hump? By adjusting the dirac curve?
How do I adjust the timing of the sub?
indus1 is offline
post #19543 of 22901 Old 08-07-2016, 09:36 AM
3ll3d00d's Avatar
Liked: 601
the reason is.... don't assume (that they will be the same), measure and know for certain
indus1 likes this.
post #19544 of 22901 Old 08-07-2016, 09:38 AM
3ll3d00d's Avatar
Liked: 601
You probably have 2 main options given your current equipment
1) get the bass management module and do bass management in the 88a
2) tweak the dirac curve to guide dirac into producing the curve you want
which one do you want to do?
depends on the answer to the above q (if bm in 88a then I believe it has delay setting, if not then fiddling with distances in the avr)
post #19545 of 22901 Old 08-07-2016, 09:42 AM
sdurani's Avatar
Quoted: 4778 Post(s)
Liked: 3190
De-lurking for a quickie:
Obviously there is some difference. Why? I don't know. Perhaps someone else will have a theory.
Older surround processing, like PLII, had single band steering: everything that was identical in the L/R channels (across the entire frequency range) was steered to the centre output. As such, the matrix extracted centre output had basically the same frequency response of the mono test signal being fed to the L/R channels.
By comparison, DSU (and Neural:X) uses multi-band steering, which slices the contents of each channel into several frequency bands. Having to move only parts of the channel allows for faster logic steering, which helps sound more like discrete multi-channel rather than matrix surround processing. With certain frequency bands being steered more heavily than others towards the centre output, the extracted centre can no longer be guaranteed to have the same frequency response as the L/R channels.
Sanjay
sdurani is online now
post #19546 of 22901 Old 08-07-2016, 09:52 AM
indus1's Avatar
Quoted: 175 Post(s)
If I get the bass management module we'll still be trying to sort this out on Christmas day
By the time I've got it and figured out how to set it up and use it months will pass and the problem is spoiling my enjoyment of my cinema room right now.
So I'd like to try adjusting the dirac curve first. If you could give me a little more idea about what I am trying to achieve in this regard it would be really helpful.
Is there something else that's simple to use and that could help me set the delay?
Thanks again
indus1 is offline
post #19547 of 22901 Old 08-07-2016, 10:07 AM
PlasmaPZ80U's Avatar
Quoted: 2048 Post(s)
Liked: 587
Share your before and after graphs and filters used if you want feedback.
If you use the same basic settings I did when I created the filters based on your .mdats, you should get good results.
Just be sure to hit set target level before generating filters and avoid any boost, individual or overall. And try to avoid filters with Qs past 20 or so.
Good luck.
PlasmaPZ80U is online now
post #19548 of 22901 Old 08-07-2016, 10:42 AM
Liked: 3988
He is feeding the same REW test signal to the left, right, and center channels. Bass re-direction sends the signal to the same sub. Again, assuming the crossovers are the same, under what conditions would you expect any difference in the three measurements? And if you look at the measurements, they indeed appear to be identical.
post #19549 of 22901 Old 08-07-2016, 11:01 AM
Liked: 3988
Matt, can you clarify what you mean? His center+sub clearly shows that the sub isn't doing any "filling in".
Could this be because of the non-minimum phase area centered below 90Hz?
So what is the logic behind the recommendation to move bass management to the 88BM from the AVR? How will that address the non-minimum phase issue?
citsur86 and Madmax67 like this.
post #19550 of 22901 Old 08-07-2016, 11:12 AM
Liked: 3988
Hi there
I've taken the following measurements....
Looking at the MDAT that you provided, bass resonance looks quite good as shown by the waterfall. However, the ETC graphs show a significant number of early reflections on all three channels. Reducing these reflections would likely improve the quality of the audio. Sub response by itself looks very good. Now if we could just figure out what is causing that massive dip in the center channel...
post #19551 of 22901 Old 08-07-2016, 01:10 PM
Liked: 3988
Originally Posted by sdurani View Post
De-lurking for a quickie: Older surround processing, like PLII, had single band steering: everything that was identical in the L/R channels (across the entire frequency range) was steered to the centre output. As such, the matrix extracted centre output had basically the same frequency response of the mono test signal being fed to the L/R channels.
Thank you for this explanation, Sanjay. As I read it, I had a distinct feeling that this is not the first time I have heard you explain the differences, and I apologize if I have asked a question that you have answered in the past. Regardless, I have bookmarked your post so that I can refer to it if the question comes up again.
So this leaves us with the question--for REW users who are forced to use the Java driver, how can they accurately measure the frequency response of the center channel? As far as I can tell, the only way will be to physically move a speaker cable from the left or right channel and hook it to the center speaker. If you know of another way, please let me know. I think this is important enough to update the section of the Guide that deals with using the Java driver.
post #19552 of 22901 Old 08-07-2016, 01:51 PM
citsur86's Avatar
Liked: 457
When setting up the filters for the MiniDSP 2x4 HD, do I initially run sweeps on Channel 3 (center+subs) or 4 (just LFE)? I am trying to do PEQ on just the bass response.
post #19553 of 22901 Old 08-07-2016, 01:56 PM
3ll3d00d's Avatar
Liked: 601
if he has the same crossover for each speaker and if there is no other random oddity then there is no reason to expect them to vary
my personal preference is avoiding wild goose chases so I prefer to measure to be sure that things are working as expected. I apply this rule in triplicate when it comes to data presented over the interweb
AustinJerry likes this.
post #19554 of 22901 Old 08-07-2016, 02:00 PM
Liked: 3988
You should measure sub only (HDMI4) with room correction off. Then run the REW equalization tool, save the filters to your local drive, launch the HD plug-in, and import the filters.
Once that is all completed, take a fresh measurement of the sub only (room correction still off, of course). Compare the before and after measurements to make sure the imported REW EQ filters are producing the desired result.
And finally, you will need to re-run room correction since the sub channel response has changed. Run a post-calibration measurement of the sub channel, and one of the sub+center as well. Post all four measurements here for use to see how well the process has worked.
post #19555 of 22901 Old 08-07-2016, 02:01 PM
Liked: 3988
We are on the same page, Matt. Thanks.
post #19556 of 22901 Old 08-07-2016, 02:02 PM
3ll3d00d's Avatar
Liked: 601
my emphasis on my quote
i.e. it's not filling in atm but if he tweaks it then the effect of that dip can be ameliorated (to some extent at least). However the dip then looks much worse because of the preceding hump and that comes from the excess output in the C channel which has been added by the dirac filter (according to earlier dirac data).
it gives him additional tools via different filter types and slopes. This will make it easier for him to use the sub to combat that event.
post #19557 of 22901 Old 08-07-2016, 02:42 PM
citsur86's Avatar
Liked: 457
Got it - so the idea is for the MiniDSP 2x4 HD to do PEQ before MCACC EQ? Won't the filters being applied from the HD be incorrect if I change the room EQ after having set them (the filters) up?
Also-I should have the db set to -22 for channel 4 right?
post #19558 of 22901 Old 08-07-2016, 03:02 PM
citsur86's Avatar
Liked: 457
Just finished saving a filter - realized i dont have anything installed for the miniDSP 2x4 HD. I see there is a plugin but it is $10?
post #19559 of 22901 Old 08-07-2016, 03:12 PM
Liked: 587
You want the MiniDSP to do the (main) sub EQ... MCACC might add a bit after that, but likely nothing significant on your model, which lacks sub EQ.
MCACC might improve the CC+sub measurement, though... likely at and above the crossover frequency.
As for the dBFS level -22 shall measure LFE channel at same level as -12 for CC+sub.
post #19560 of 22901 Old 08-07-2016, 03:14 PM
Liked: 587
Did the person you bought it from already buy the plug-in? If so he can send you an install file for the plug-in.
I bought my 2x4 unbalanced from an AVS member and got the plug-in from them via the install file.
Dayton , Dayton Audio , Room Equilizer Wizard Rew
