Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 679 - AVS Forum | Home Theater Discussions And Reviews
 2287Likes
post #20341 of 23608 Old 08-31-2016, 09:42 AM
Quoted: 720 Post(s)
Liked: 380
In order to investigate the issue further I have hooked up one of my front speakers pre-outs to Focusrites input to measure a frequency response of DAC.
One set of measurements was taken using Java drivers and other one using ASIO4ALL drivers.
Red measurement is Direct mode and green one is Stereo, no smoothing obviously. In both cases you can see audyssey XT32 doing its nifty job below 1kHz. But issues start above that.
ASIO4ALL fails to correctly report above 1Khz. I have no clue what a hell is going on up there, but it pretty much coincides with shape of my normally measured graph (huge dip between 2k and 7k and bump around 10k)
Java fails much later...and huge dip at 8.5Khz pretty much coincides with my old REW measurements when I was using Java (and thinking that my tweeters are dying).
Again, I don't think UMIK users will ever have this issue, but it would be helpful to know whats causing it.
ID:	1633961   Click image for larger version
Revel Ultima Salon 2, Revel M106, Revel C208, Yamaha P5000S, Denon X5200, Panasonic 65" VT50, SVS PC13-Ultra
Kef LS50, Parasound New Classic, Focusrite 2i2
donktard is offline
post #20342 of 23608 Old 08-31-2016, 10:15 AM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 7739 Post(s)
Liked: 4332
No disrespect, Donktard, but IMO this question is best asked in the REW forum on Home Theater Shack. The focus here is on USB microphones.
AustinJerry is online now
post #20343 of 23608 Old 08-31-2016, 10:30 AM
Quoted: 720 Post(s)
Liked: 380
No problem, just pointing it out here for some rare folk who might have same issues.
donktard is offline
post #20344 of 23608 Old 08-31-2016, 07:40 PM
aaranddeeman's Avatar
Quoted: 1703 Post(s)
Liked: 619
I am looking for some advice on positioning dual (identical) subs for the best combined FR.
I have REW setup and can take measurements.
Once I get that right , I will re-run Audyssey..
aaranddeeman is offline
post #20345 of 23608 Old 08-31-2016, 07:51 PM
Liked: 4332
Try the 1/4 and 3/4 points along the front wall for a start, then take measurements.
post #20346 of 23608 Old 08-31-2016, 09:27 PM
Liked: 619
Thanks. I will try that.
post #20347 of 23608 Old 09-01-2016, 04:16 AM
artur9's Avatar
Quoted: 673 Post(s)
Liked: 241
This thread has useful information:
mtg90a's multiple subwoofers mains integration how-to
artur9 is offline
post #20348 of 23608 Old 09-01-2016, 04:52 AM
Liked: 619
post #20349 of 23608 Old 09-01-2016, 10:01 PM
Old Soul
APRisti's Avatar
Quoted: 68 Post(s)
Liked: 8
Trying out REW to be used with my Emotiva XMC-1 to improve bass in my room. Seems to have a bass null in main listening position. Subwoofers are 2 JTR passive captivators run by peavey ipr2-5000. I have a mini-dsp that i use for PEQ and xover duty.
Both subwoofers are behind AT projector screen and unfortunately i can't move subwoofers due to theater design. Walls all have acoustic panels. Sub setting is set at Mono and here's the measurement of both subwoofers together. Red line is original measurement while blue line is using the Auto-EQ setting imported to the mini-dsp.
Any comments on the graph and what i can do to improve bass
Name:	rew subwoofer.jpg
APRisti is offline
post #20350 of 23608 Old 09-02-2016, 03:56 AM
Bass and Hi-Fi Enthusiast
citsur86's Avatar
Quoted: 1563 Post(s)
Liked: 742
It looks like your not measuring your subs lower response. What subs do you have? You should start your sweep 5db below their lower extension to at least 200hz. Also is this sweep channel 4 only?
citsur86 is online now
post #20351 of 23608 Old 09-02-2016, 04:18 AM
Old Soul
APRisti's Avatar
Quoted: 68 Post(s)
Liked: 8
Jtr captivator passive running on peavey ipr2 5000 @2ohms
How do i start the sweep 5db below their lower extension ? How do i find out their lower extension. Sorry first time tuning
http://jtrspeakers.com/home-audio/captivator/
Same as this subwoofer and box but without the amp
APRisti is offline
post #20352 of 23608 Old 09-02-2016, 04:24 AM
citsur86's Avatar
Liked: 742
Sorry I meant 5hz below their lower extension not db. Looks like they down to 16hz but 2 likely go lower. I would run the sweep from 10hz-200hz. You can set this on the screen from where you run.
post #20353 of 23608 Old 09-02-2016, 04:27 AM
Old Soul
APRisti's Avatar
Quoted: 68 Post(s)
Liked: 8
ah gotcha, will run it later and post here
Gain should not matter When running these tests right ? I set the gain when i run dirac
APRisti is offline
post #20354 of 23608 Old 09-02-2016, 04:34 AM
citsur86's Avatar
Liked: 742
Not too sure about that but @AustinJerry , whose active here, has a guide in his signature that he created and is VERY helpful. Check that out as it should help you out a lot.
post #20355 of 23608 Old 09-02-2016, 06:33 AM
Liked: 4332
Are the measurements taken with Dirac Live turned on? And to assess the true bass response, a better representation would be to measure subs+mains, usually sub+center. Output the REW measurement to HDMI3 only (center channel), with center set to "small". This will show how well the center picks up the low frequency output above the crossover point, and show the phase relationship between subs and mains. What is the crossover value?
post #20356 of 23608 Old 09-02-2016, 06:38 AM
Quoted: 440 Post(s)
Liked: 57
I'm looking at getting a UMIK-1 soon with REW, but I have a question to the pros regarding level matching speaker and subs.
I'm currently using a Galaxy CM-140 SPL meter and when using the pink noise in my AVR I set the speakers to 75 dB and the subwoofer to 72 dB (I've been told that SPL meters read bass a little low, so 72 dB is actually closer to 75 dB).
If I were to get the UMIK and use REW, would I still set the sub to 72 dB or would everything be set to 75 dB? The UMIK is more accurate than a typical SPL meter?
Stephan Mire is offline
post #20357 of 23608 Old 09-02-2016, 06:46 AM
Liked: 4332
I think you will find a calibrated mic will be more accurate than most SPL meters. If your objective is to match levels across all speakers, then I would use the same value for the subs. As a side note, some have reported that speaker levels can vary whether room correction is on or off. On D&M AVR's with Audyssey, the pink noise level-setting test tones from the AVR are output with Audyssey off. The most accurate way to level-set the speakers would be with a test disk, with room correction turned on. It depends on how accurate you want to be, of course. In my personal experience, the difference with room correction off versus on rarely exceeds 1dB.
post #20358 of 23608 Old 09-02-2016, 07:10 AM
Quoted: 440 Post(s)
Liked: 57
Thank you for the detailed reply AustinJerry.
So you personally use a test disk to set levels? Just not sure how this would affect the AVR as far as reference levels goes. Since I've always used the pink noise in the AVR to calibrate levels (0 reading 75 dB for all speakers).
I do have a Marant receiver (SR5011). What test disk would you recommend for setting levels?
post #20359 of 23608 Old 09-02-2016, 07:27 AM
Liked: 4332
I have a number of test disks with Audio test tones, with Spears&Munsil Blu-Ray ver 2 being my favorite (because of its suite of video tests as well). However, as I mentioned, the level differences I have observed have rarely been more than 1dB, which is borderline inaudible. I usually use the AVR pink noise tones for simplicity.
post #20360 of 23608 Old 09-02-2016, 10:28 AM
Old Soul
APRisti's Avatar
Quoted: 68 Post(s)
Liked: 8
measurement is taken with dirac off
what i do is i set all the crossovers to 200 on the xmc-1 on all speakers before i measure the subwoofer ( i turn off all amplifiers except sub-amp ) then output device is XMC-1
here's what i got when i ran 10-200hz
purple line is after i use EQ and uploaded values on my mini-dspHD ( HP filter 14 , LP filter 150 )
i'm running 2 subs mono, they are beside each other behind AT screen
APRisti is offline
post #20361 of 23608 Old 09-02-2016, 10:41 AM
EndersShadow's Avatar
Quoted: 632 Post(s)
Liked: 960
For just your sub measurement it doesnt look too bad. However I'd look to add some cuts to that peak around 80hz to bring it down so its more flat overall, which then could allow you to increase the gain to get a more level response.
However without seeing how the subs interact with your mains above and below the crossover point you've set, that suggestion may or may not be applicable.
My Setup | FS: Salamander Synergy 303, Outlaw LFM-1 sub, Sanus UF22 Speaker Stands, Nintendo Wii, 5 channel Polk LSi system (all threads here)
Quote: There exists, for everyone, a sentence - a series of words - that has the power to destroy you. Another sentence exists, another series of words, that could heal you. If you're lucky you will get the 2nd, but you can be certain of getting the 1st. - Philip K. Dick
EndersShadow is online now
post #20362 of 23608 Old 09-02-2016, 11:19 AM
Liked: 4332
I believe your original post asked for feedback and advice. As I said, in order to offer advice, I would need to see a measurement with Dirac on, and showing subs+mains (preferably the center channel), extending to 300Hz, with no smoothing.
post #20363 of 23608 Old 09-02-2016, 04:59 PM
Old Soul
APRisti's Avatar
Quoted: 68 Post(s)
Liked: 8
Sorry for the delayed reply, forgot to reply i was going to post the graph later on
attached is the sub+center channel measurement graph
Crossed at 80hz with dirac on
red line is subs+center
green is center only
blue is subs only
APRisti is offline
post #20364 of 23608 Old 09-02-2016, 05:38 PM
Liked: 4332
blue is subs only
Something doesn't look right. It doesn't make sense that that huge dip in the frequency response doesn't change when you go from sub only to subs+center. Perhaps you could make the REW MDAT file available for sharing?
post #20365 of 23608 Old 09-02-2016, 05:44 PM
Old Soul
APRisti's Avatar
Quoted: 68 Post(s)
Liked: 8
attached the mdat file here
thanks
http://s000.tinyupload.com/?file_id=...70365987835583
APRisti is offline
post #20366 of 23608 Old 09-02-2016, 06:10 PM
Liked: 4332
Really? Try Dropbox.com
post #20367 of 23608 Old 09-02-2016, 06:48 PM
artur9's Avatar
Quoted: 673 Post(s)
Liked: 241
I have a test DVD that I downloaded the image from avsforum for this purpose.
Now, I spin up the disc and level set with that. It's particular helpful that it shows what the volume should be on the screen as it plays.
artur9 is offline
post #20368 of 23608 Old 09-02-2016, 07:16 PM
Old Soul
APRisti's Avatar
Quoted: 68 Post(s)
Liked: 8
sorry about that
https://dl.dropboxusercontent.com/u/...7/apristi.mdat
thanks again for your help
APRisti is offline
post #20369 of 23608 Old 09-02-2016, 07:28 PM
Liked: 4332
sorry about that
What is the difference between "Main only" and "sub+center"? I still don't understand why there is a 17dB jump between 60Hz and 70Hz. Is that the DSP you are applying? From 60Hz to 15Hz the response is reasonably flat, but that jump at 60Hz must produce some over-emphasized bass. Above 70Hz the response looks typical.
post #20370 of 23608 Old 09-02-2016, 07:32 PM
Old Soul
APRisti's Avatar
Quoted: 68 Post(s)
Liked: 8
Let me run everything again for comparison and get you new graphs and mdat by tomorrow
APRisti is offline
Dayton , Dayton Audio , Room Equilizer Wizard Rew
