Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 684 - AVS Forum | Home Theater Discussions And Reviews
 1553Likes
post #20491 of 20499 Unread Today, 11:27 AM
AustinJerry's Avatar
Quoted: 5453 Post(s)
Liked: 3104
Originally Posted by mharris2007 View Post
Hi Jerry. I have the front left two on one channel of the minidsp, the front right on another, the rear left on its own, and the rear right on its own. I will get more measurements with the polarity and post it here. Thanks so much for your help.
Matt
Post the MDAT file for downloading as well, please.
AustinJerry is online now
post #20492 of 20499 Unread Today, 04:18 PM
rawhit's Avatar
Quoted: 17 Post(s)
Liked: 45
My 1st post in this thread. I got Cross Spectrum umik-1 and also made some acoustic panels based on DIY poster thread.
I am trying to measure the difference with acoustic panels in place vs without. Since these are thin panels (2" + 1" airgap) there is likely no difference in sub response but posting that also to understand how improve the in room response for the sub.
Any help with interpreting the data would be much appreciated. Since these are my 1st ever measurements I am not even 100% sure if I did them right (hopefully!).
Images attached.
Link to mdat files
Name:	Right speakers with room treatments.jpg
ID:	1684385   Click image for larger version
Name:	Right Speaker no room treatments.jpg
ID:	1684393   Click image for larger version
Name:	Overlay with and without treatments.jpg
ID:	1684401   Click image for larger version
Name:	Sub only with posters.jpg
rawhit is online now
post #20493 of 20499 Unread Today, 04:41 PM
Marc Alexander's Avatar
Quoted: 407 Post(s)
Liked: 268
Images attached.
Link to mdat files
That looks really good to me. I like what you've done.
I think you just need to reduce your volume level and redo the measurements (maybe -20dB). You want the waterfalls to fully decay by 300ms.
Your bass response looks a little low. You want the subwoofer level to at least match the main speakers. Many of us prefer it 3-6 (or even 9) dB hot.
Marc Alexander is offline
post #20494 of 20499 Unread Today, 05:59 PM
Liked: 3104
Images attached.
Link to mdat files
Sorry, I don't agree with Marc.
Couple of housekeeping suggestions:
- There is no need to have six separate MDAT files. You can conduct multiple REW measurements within the same file. Saving six measurements in one MDAT, rather than have six individual MDAT files is much more efficient.
- You need to describe what each measurement represents, i.e. subs+mains, subs only, etc. Otherwise, how are we going to know what the measurements are? It looks like you have provided four measurements that have subs+some other speaker, and two measurements that are sub only. Just a guess.
First, let's look at what looks like the Subs+mains:
There are huge swings in the freq response below 200Hz. Sub response falls off a cliff below 50Hz. What sub(s) do you have?
Now let's look at a good waterfall. Note the waterfall vertical scale is 60-110, which coincides with your measurement level (which maxes at 100dB). Time window is 450ms. These are the ways we present waterfall graphs, if you read the guide.
The waterfall is not terrible, but since the frequency response is so bad, it is hard to make a conclusion. Now the ETC graph:
Significant reflections higher than -20dB. Not good. Finally the sub response:
Not good at all.
You have your work cut out for you. Sorry if I have been blunt.
post #20495 of 20499 Unread Today, 06:57 PM
rawhit's Avatar
Quoted: 17 Post(s)
Liked: 45
Thanks Marc. For the next round, will lower the levels to -20db. These measurements were taken with AVR volume at 0db and no bass boost.
Not good at all.
Thanks Austin. Lot of useful comments and I definitely have a lot more reading to do. Few quick comments.
  • I will collate the measurements into single mdat file.
  • The 1st two graphs are of only the front right speaker, red one is with room treatment and green without room treatments. The subwoofer was switched off. My mains do fall off sharply at around 40-45hz as you noted.
  • Was trying only compare a single speaker with and without room treatment to see if waterfall plot shows more damped response with quicker fall off in time domain.
  • The subs are Seaton submersive HP+ master and slave crossedover at 90hz. One reason for the anomaly could be that my AVR (aging denon 4311ci) is set to have low freq mode as LFE+main so may be the AVR is trying to blend in and distribute the low freq to both sub and main .
    I will take some measurements with low freq mode as LFE only for complete hand over to sub.
  • Will also take some measurements below 100hz with sub+mains playing together to check if it helps smooth out the response.
post #20496 of 20499 Unread Today, 07:55 PM
ahblaza's Avatar
Quoted: 1323 Post(s)
Liked: 1365
Jerry I wanted to know if I'm on the right track here, I'm trying to get good in room bass response. They are all self explanatory I think. Thank you, I have mdat files in my REW folder but don't know how to post them in a single file, not to take up a lot of room here I just dropped the jpgs below. I just wanted to let you know I'm getting acquainted with Win10 instead of my obsolete 8.1...
To help understand what I was doing I originally did the SDT for music only with L+R mains but then the C+subs didn't look so good, so I tried to get the best of both worlds with optimizing with the SDT for both music and movies.
Name:	SUBS ONLY GREEN AUDY PURPLE OFF.jpg
ID:	1684721   Click image for larger version
Name:	SUBS ONLY ORIG SPOT AUDY ON.jpg
ID:	1684729   Click image for larger version
Name:	SUBS ONLY AFTER SLIGHT TURN.jpg
ID:	1684737   Click image for larger version
Name:	C+ SUBS AUDY ON WITH MUSIC SDT.jpg
ID:	1684745   Click image for larger version
Name:	R+SUBS AFTER C SDT.jpg
ID:	1684761   Click image for larger version
Name:	C+SUBS WITH L+C+R SDTs HAPPY AGAIN.jpg
ID:	1684785   Click image for larger version
Name:	SUBS ONLY AFTER BOTH C+L  STD.jpg
ahblaza is online now
post #20497 of 20499 Unread Today, 08:01 PM
ahblaza's Avatar
Liked: 1365
I will learn how to just put these in a folder to just open and view instead of all of the above. Sorry
post #20498 of 20499 Unread Today, 08:01 PM
Liked: 3104
A measurement of right speaker without the sub is quite useless for general information.
Seaton subs are very good subs. The sub response curve indicates to me that you don't have the subs dialed in properly yet. As for the setting on the 4311, there is nothing wrong with that AVR. I still have a 4311 in the bedroom, and it is a fine AVR. Your speakers should be set to "small" with a crossover ~80Hz, and the setting in the 4311 should be "LFE" and not "LFE+Main".
If you want to show a meaningful graph of bass response, measure subs+center, 15-300Hz, at 85-90dB measurement level, and leave the response curve unsmoothed.
post #20499 of 20499 Unread Today, 08:06 PM
Liked: 3104
That is a ton of measurements. Several look quite good. Clearly moving the sub resulted in a nice improvement. I don't quite understand what you were changing for the other measurements, but surely you can tell which measurement looks the best. Stick with that one. The bass looks really nice!
Edit: I just realized SDT means the sub distance tweak. For some reason, I was confusing it with STD! . I would stick with the SDT that makes the sub+center look the best.
Dayton , Dayton Audio , Room Equilizer Wizard Rew
