Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 685 - AVS Forum | Home Theater Discussions And Reviews
 2033Likes
post #20521 of 22697 Old 09-26-2016, 04:37 PM
krichter1's Avatar
Quoted: 1926 Post(s)
Liked: 2197
Originally Posted by LastButNotLeast View Post
I would try a higher crossover (at least 50, probably 80Hz). Don't feel badly that your fronts aren't being "used;" they'll probably be able to perform much better and with more headroom without trying to do the job of the subwoofer.
Then you can add more subs.
Michael
You mean you think I'll have more problems having the Klipsch at 30hz & the SVS at 50hz (fwiw - I'm using the the sharp 24db slope setting on both), and would be better off keeping them both at the same X-over point (HP & LP points)?
Thx for the feedback.
Kevin
You only live once, but if you live it right, once is enough.
==> Our 4K/3D Immersive Theater
krichter1 is offline
post #20522 of 22697 Old 09-26-2016, 05:07 PM
artur9's Avatar
Quoted: 611 Post(s)
Liked: 215
Originally Posted by AustinJerry View Post
Why are your mains crossed over so high? Are they extraordinarily small? So how will the TBI's be wired up? Do they need to be co-located with the mains, or can they be placed anywhere.
I have never heard of this approach before. What problem are you trying to solve?
I'm surprised you hadn't heard of this technique. There's a bunch of stuff on the Internet (pros and cons. I just want to try it). But I think this article will answer a lot of questions.
My speakers are smallish but I find the higher I cross them the clearer everything sounds. I currently cross them at 100Hz so I want to try higher but then I have the localization problem.
My preamp has a digital in and has 4 outputs L/R and configurable L/R. The configurable L/R can be full signal or a low-passed signal in either mono or stereo. The latter would be low-passed L and low-passed R (actually, more configurable than that but for this purpose that's what matters). So I would do that and feed each signal into its own TBI. As an aside, the crossover in the preamp can go extraordinarily high (like 9999Hz) and supports a variety of types BW,LR, and orders (1st,2nd,4th,8th).
The preamp can do delay as well so the subs can either be co-located or placed anywhere, I think. I'd have them co-lo to make my life simpler and that's all my room supports anyway.
I am not sure that there's an actual problem I'm trying to solve. I've just heard that "stereo bass" can really open up 2ch soundstage and detail.
My preamp is a Lyngdorf and I'm inspired by the Lyngdorf speaker system (review).
Again, please don't judge. It's just a configuration I want to try out. I've read about how so-called stereo bass makes no sense but I'm having a mad scientist moment with this, if I ever to try it.
artur9 is offline
post #20523 of 22697 Old 09-26-2016, 05:08 PM
artur9's Avatar
Quoted: 611 Post(s)
Liked: 215
I read somewhere, and I think Markus advocates, keeping your chosen crossover the same for all speakers. It simplifies a bunch of stuff.
krichter1 likes this.
artur9 is offline
post #20524 of 22697 Old 09-26-2016, 05:53 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 7104 Post(s)
Liked: 3948
Very interesting. I look forward to reading the info in the link you provided, after this evening's debate. I would never judge, especially when someone is trying something different and interesting. good luck!
ahblaza likes this.
AustinJerry is online now
post #20525 of 22697 Old 09-26-2016, 06:02 PM
LastButNotLeast's Avatar
Quoted: 1660 Post(s)
Liked: 1270
You're talking about artur's speakers, not the debate's speakers, right?
Michael
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
LastButNotLeast is offline
post #20526 of 22697 Old 09-26-2016, 06:03 PM
Liked: 1270
Yes, better off the same and perhaps better off at 80 than at 50. Easy enough to try.
Michael
post #20527 of 22697 Old 09-26-2016, 07:02 PM
krichter1's Avatar
Liked: 2197
Michael
Yeah, I hear ya and all things being equal I could prob do it that way but just trying to keep my Pro Audyssey calibration in-tact and take the low-end burden off my existing subs (which ChadB did and sounds excellent and I'd hate to start over or waste the $450 already paid if I don't have to). I figured I could simply use the miniDSP to cut off the lower end which the Klipsch's now struggle with (Atmos & DTS:X), and blend in the SVS 2000 cylinder to handle the rest down to 16-18hz. I have them both time aligned and I'm close but it's been a bit more challenging than I I thought (and interestingly I don't really see a huge bubble between 30-50hz which the two subs share even when using the sharp slopes).
Thx
Kevin
post #20528 of 22697 Old 09-26-2016, 09:25 PM
Marc Alexander's Avatar
Quoted: 1661 Post(s)
Liked: 1340
Thx
You should be able to raise crossover points without changing the Audyssey calibration.
Last edited by Marc Alexander; 09-26-2016 at 09:32 PM. Reason: Deleted irrelevant information
Marc Alexander is online now
post #20529 of 22697 Old 09-26-2016, 11:15 PM
markus767's Avatar
Quoted: 3885 Post(s)
Liked: 1388
Stereo bass in acoustically small rooms is nonsense. The room completely scrambles any directional information below 100Hz. You end up with directional effects that are NOT in the recording and unpredictable bass performance as the two stereo subs will interact in different ways depending on the directional information in the recording. Better create a monophonic bass channel and use it with multiple subs.
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #20530 of 22697 Old 09-27-2016, 05:17 PM
artur9's Avatar
Quoted: 611 Post(s)
Liked: 215
Right but what about mid bass modules that extend up to 300Hz like the Lyngdorf BW-1?
artur9 is offline
post #20531 of 22697 Old 09-27-2016, 11:13 PM
markus767's Avatar
Liked: 1388
That's a bad idea because you limit the locations where subs can be placed. With a sub playing that high it has to be placed near the satellites because of localization issues.
ahblaza likes this.
Markus
post #20532 of 22697 Old 10-03-2016, 08:32 PM
artur9's Avatar
Quoted: 611 Post(s)
Liked: 215
Sort of following Markus's advice, I decided to lower the crossover so that the mains have the opportunity to enhance the soundstage. It was too much work to rearrange everything to do the flanking sub thing.
I took the opportunity to phase match etc. Still have room EQ left to do but I hardly need it given the graphs I have. I use Krell ARES for movies and Lyngdorf RoomPerfect for music. RoomPerfect has the funny feature of telling you how much correction it does and I have not had it do more than 4-6% ever.
In any case, I really like how this came out for my 2channel setup. I am only using 3 bands of PEQ with a crossover set at 70Hz. For final approval of changes, I use a version of Ottmar Liebert's FireOpal that has a lot of reverberant bass in it. Sounds terrible if bass isn't flat and modally controlled.
Results:
P.S. This automatic embedding of youtube videos is really annoying.
Name:	latest effort.jpg
artur9 is offline
post #20533 of 22697 Old 10-05-2016, 04:50 AM
3ll3d00d's Avatar
Quoted: 1630 Post(s)
Liked: 597
I thought the lyngdorf approach (using mid bass modules and a high crossover) was an allison effect play?
3ll3d00d is offline
post #20534 of 22697 Old 10-05-2016, 05:46 AM
Liked: 3948
Darn, Matt, you made me Google!
Foundation42, 3ll3d00d and ahblaza like this.
post #20535 of 22697 Old 10-06-2016, 05:13 AM
ShoutingMan's Avatar
Quoted: 243 Post(s)
Liked: 47
I'm utterly ignorant on equalization hardware, software, techniques...
I've got a new home theater. For budget reasons, I used a Marantz 7702mkII and Marantz 5 and 7 channel amps, rather than going with a DSP-based amplifier system.
Now that it's finished, I've learned that it could use equalization beyond the simple speaker gain and bass cutoff controls the Marantz offers. I can't afford to upgrade to DSP amps or a suite of hardware graphic equalizers right now.
I have an HTPC.
Could I use the REW software as an intermediate processor, between Marantz 7703 line-out and Amps, to tune for speaker response?
I've skimmed the REW site and the first page of this thread. I see how REW measures the room. But I don't see how ihow or if it can act as an equalizer in the audio chain, especially for a 7.3.4 system.
ShoutingMan is offline
post #20536 of 22697 Old 10-06-2016, 06:00 AM
Liked: 3948
I have an HTPC.
No need to shout, man.
REW is not an equalizer. The only thing REW can do along those lines is measure your room response and, using its EQ tool, allow you to create filters that can be loaded into an outboard piece of hardware such as a MiniDSP.
You don't mention it, but are you using the Marantz' Audyssey room correction capabilities? Audyssey is far more sophisticated than a simple equalizer and is capable of significantly improving your audio. Or are you using Audyssey already and want something more?
ShoutingMan likes this.
post #20537 of 22697 Old 10-06-2016, 06:07 AM
Liked: 1270
I have an HTPC.
Use this:
https://sourceforge.net/projects/equalizerapo/
Michael
post #20538 of 22697 Old 10-06-2016, 06:10 AM
Quoted: 243 Post(s)
Liked: 47
Ha ha
Thanks for simple explanation.
I'm working with custom installer who typically sells, installs, and calibrates with DSP amps like Pro Audio Technology and a PC-driven measurement and calibration tool (like REW, I suppose). They don't usually run Audyssey and call it done.
So, my Marantz has Audyssey. They've run it, done some further adjustments and are going from there based on their professional tools and experience installing home theaters.
What I haven't done is run Audyssey listen to what it can accomplish per se. So I will consider recording all the settings my installer makes, then run Audyssey and compare its results, and decide which to keep. That will be a great weekend activity later this Winter!
Thanks again
post #20539 of 22697 Old 10-06-2016, 06:28 AM
Liked: 3948
Ha ha
Thanks again
Sounds like a good plan. While I am sure your professional installers have done a fine job, I can't tell from your response whether the installers have run and are using Audyssey, but IMO Audyssey will do a far better job than simply tweaking manual settings. Please report back with your impressions.
And before you do anything, consider running a network save to preserve the settings made by the installers. By doing this, you can easily restore the exact previous state in case you want to go back. The procedure is simple and quick, and having a stored configuration for your system is very important. The instructions are here: The **OFFICIAL** DENON AVR-4520CI thread
ShoutingMan and mharris2007 like this.
post #20540 of 22697 Old 10-06-2016, 06:51 AM
Quoted: 243 Post(s)
Liked: 47
They've run Audyssey. Then further manually adjusted the Marantz 7702 settings.
Thanks for the network save tip. I haven't read my manual yet. I'll get back to the Marantz thread to learn more. (Since this is a paid installation, and it's not yet completely finished, I haven't gone past "Push Power and Hit Play" yet.)
post #20541 of 22697 Old 10-06-2016, 06:53 AM
Quoted: 243 Post(s)
Liked: 47
How do you insert a PC-based EQ in between the Processor and Amps? For a 7.x.4 Atmos system? I know nothing here; I need the "PC EQ for Dummies" summary
post #20542 of 22697 Old 10-06-2016, 07:15 AM
Liked: 1270
Just follow the tutorial in the wiki.
The program is capable of eq of individual channels (up to 7.1), but I suggest you start with just overall eq to get a feel for that program and REW.
Or, you may find after running REW, that you don't need any additional eq/treatment, which would be very nice, indeed.
Michael
post #20543 of 22697 Old 10-06-2016, 07:46 AM
3ll3d00d's Avatar
Liked: 597
you'd have to route the analogue output into a PC, perform processing and then route the output into the amps. This is a non trivial task to setup.
3ll3d00d is offline
post #20544 of 22697 Old 10-06-2016, 09:57 AM
Liked: 1270
He has an HTPC. The output is FROM the PC, unless I'm misunderstanding.
Michael
post #20545 of 22697 Old 10-06-2016, 10:26 AM
3ll3d00d's Avatar
Liked: 597
Michael
There is no atmos decoder on the PC so the output must be bitstream
ahblaza likes this.
3ll3d00d is offline
post #20546 of 22697 Old 10-06-2016, 11:25 AM
Liked: 3948
Given Matt's comments that setting this up is not trivial, I still think you need to assess whether you need additional EQ or not. REW measurements will show your current state. If things are "good enough" you may want to sit back and relax. Implementing additional EQ without assessing current state would be flying blind.
And BTW, I don't understand how the installers are tweaking the settings after Audyssey has been run. Enabling the Marantz manual EQ will disable Audyssey, and that would be a step in the wrong direction.
ahblaza likes this.
post #20547 of 22697 Old 10-07-2016, 06:27 AM
Quoted: 243 Post(s)
Liked: 47
Got it, thanks. Using HTPC as Digital EQ is not easy.
(My HTPC plays blu-rays, bit streaming A/V over HDMI to Processor to decode Dolby Atmos. Processor is connected with line-out to amps powering the speakers.)
With tip on Marantz, I'll be able to backup settings and review standard Audyssey cal vs manual adjustments.
post #20548 of 22697 Old 10-07-2016, 10:40 AM
Liked: 1270
Equalizer-APO should work fine for you, then.
But, again, use REW first to see if you need to "improve" anything.
Michael
post #20549 of 22697 Old 10-07-2016, 10:57 AM
3ll3d00d's Avatar
Liked: 597
he's bitstreaming, EQ is applied to PCM i.e. decoded streams.
3ll3d00d is offline
post #20550 of 22697 Old 10-10-2016, 07:19 PM
cdejesus24's Avatar
Liked: 36
Hey guys,
I'm currently on page 35 of the Getting Started With REW guide (great guide and big thanks to whomever created it btw), and in the preferences settings of REW, I'm not getting my umik-1 mic as an option for an input device and my output devices are limited to hd audio output 1 or hd audio output 2. I'm using a denon s710w and am trying to use REW to set up my minidsp that I just connected. I'm connecting to my avr via hdmi. The mic is set as the default device and works (tested with voice recorder) and sound is coming through my home theater, so I don't know where to go from here.
Also, only one of my subs is currently working after connecting both to the mini dsp. My avr has two sub outs but as there is no audyssey sub-eq I connected the minidsp with only one rca to the avr and my subs are connected to the out 1 and out 2.
I'm re-reading the guide and searching online, but any help would be greatly appreciated.
Denon S710w > PSA MT110 LCR, Ascend CBM-170se surrounds, & dual PSA S1500
cdejesus24 is offline
Dayton , Dayton Audio , Room Equilizer Wizard Rew
