Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 691 - AVS Forum | Home Theater Discussions And Reviews
 2224Likes
post #20701 of 23451 Old 11-11-2016, 05:21 PM
LastButNotLeast's Avatar
Quoted: 1776 Post(s)
Liked: 1396
Originally Posted by Foggy1 View Post
does this get easier when I grow up?
Yes.
Stay with it, and go through the Guide carefully.
We all started at the beginning. Just don't keep making the same mistakes over and over.
Our tolerance is pretty good for different mistakes, though.
Michael
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
Don't guess, measure: Getting Started With REW: A Step-by-Step Guide
LastButNotLeast is offline
post #20702 of 23451 Old 11-11-2016, 07:04 PM
artur9's Avatar
Quoted: 665 Post(s)
Liked: 237
Originally Posted by LastButNotLeast View Post
Yes.
True enough. Every time we think we've seen it all...
Practice practice practice. I can do a quick set of measurements that tell me something new in about 15minutes and 10 of that is trying to jack into the back of the preamp without scratching it. ;-) One of these days I'll liberate a laptop with HDMI...
artur9 is online now
post #20703 of 23451 Old 11-11-2016, 09:56 PM
Liked: 1396
Or just leave the cable plugged into the preamp.
Michael
ahblaza likes this.
post #20704 of 23451 Old 11-12-2016, 08:12 AM
Foggy1's Avatar
Quoted: 89 Post(s)
Liked: 45
Good morning gentlemen,
Time for my daily dose of humility. These graphs are left and right + sub with a 80hz crossover, dirac not engaged. Curious how to extract the data for building the sub crossover filters? do I run the filters as bass limited for the towers, full range, none etc.? I can drop box the .mdat if provided an address?
Thanks again
Name:	right 15 to 20k.jpg
ID:	1765705   Click image for larger version
Name:	rght 15-300.jpg
ID:	1765713   Click image for larger version
Name:	lft 15 to 20k.jpg
ID:	1765729   Click image for larger version
Name:	lft 15-300.jpg
Foggy1 is offline
post #20705 of 23451 Old 11-12-2016, 12:04 PM
MBrown2020's Avatar
Quoted: 68 Post(s)
First Measurements
I just started using REW and took my first measurements today while th dog was at grooming. Thank you Jerry for your awesome guide
Here is my mdat file via dropbox: https://www.dropbox.com/s/ee4t88xm4t...80hz.mdat?dl=0
These were all taken with audyssey on and subs on. Everything is small with 80hz crossover. Dual SVS PB2000 subs on 1/4 front wall, (6)B&W685s2 fronts, sides, surrounds, and HTM61s2 center with AV8802a.
I noticed a dip around 80hz, could the sub tweak guide help me with that. Otherwise anything stand out as a problem. Also it is combination living room/ Theater, so treatments might be a no-go
Thanks for your help!
MBrown2020 is offline
post #20706 of 23451 Old 11-12-2016, 04:21 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 7442 Post(s)
Liked: 4148
Congratulations on your first set of measurements. You have followed the guidelines quite well.
HST, each of your front speakers is exhibiting a rather severe issue centered at 80Hz, as you already noted (and as shown below).. The highest priority should be to identify and resolve this issue. While the sub distance tweak may help alleviate the issue, there are several steps you could take.
1. Temporarily change the speakers to large and measure each speaker's response without the subs.
2. Return the speakers to small, output the test tone to the center speaker, and temporarily unplug the speaker. This will measure the subs only (15-300Hz).
These measurements will give a better idea of whether the dip is in the mains or the subs response. Once we have that data, steps to address the dip could be:
- Find a better position for the subs (assuming you have some freedom of placement).
- Make sure the two subs are properly aligned with each other (probably not an issue if they are equidistant from the MLP, and if you use Audyssey XT32).
- Make sure the combined sub signal is properly aligned with the mains (the sub distance tweak).
Can you provide the dimensions of your listening room?
AustinJerry is online now
post #20707 of 23451 Old 11-12-2016, 04:33 PM
Liked: 4148
Thanks again
The frequency response below 300Hz is way too uneven. What do you mean by "sub crossover filters"? Are you talking about using REW's EQ functionality to try and smooth the bass response? Based on the measurement you posted earlier, there are serious issues with the sub response and expecting REW's EQ to fix it would be completely unrealistic.
It should look more like this:
What sub do you have? Only one sub? You need to address the low end before doing anything else. It would be nice if we could see the same measurements with room EQ turned on to see how successful room EQ is.
post #20708 of 23451 Old 11-12-2016, 04:45 PM
MBrown2020's Avatar
Quoted: 68 Post(s)
What's HST?
Thank you for your response, Jerry
I will do the measurements you requested tom and post mdat.
I have a crude drawing of the listening space. It's an open floor plan and will create challenges i know.
post #20709 of 23451 Old 11-12-2016, 06:43 PM
Foggy1's Avatar
Quoted: 89 Post(s)
Liked: 45
Yes to the bass with room eq, will run a set with dirac engaged when I get the xmc-1 back up. Seems to have bricked. The speakers and sub are Tekton Enzo's.
Foggy1 is offline
post #20710 of 23451 Old 11-12-2016, 06:50 PM
Liked: 4148
One sub is obviously not cutting it. Read this:
AustinJerry's Set-Up
post #20711 of 23451 Old 11-12-2016, 07:14 PM
Foggy1's Avatar
Quoted: 89 Post(s)
Liked: 45
Guess it's time to start saving sheckles for another sub, would you recommend buying a sub to match my current one? Will give Eric at Tekton a call and ask his thoughts. Thank you for your time and patience!
Foggy1 is offline
post #20712 of 23451 Old 11-12-2016, 07:17 PM
Liked: 4148
I am not familiar with Tekton subs. There are certainly quite a few more well-known sub brands out there. HST, identical subs are easier to configure.
post #20713 of 23451 Old 11-13-2016, 08:46 AM
artur9's Avatar
Quoted: 665 Post(s)
Liked: 237
So, timing reference question.
My old laptop has both a mic in and a headphone jack and some USB ports. The headphone jack is used as output by REW. One of the USB ports is used by REW/UMIK as mic.
Would it be possible to use a USB DAC and the mic in to make a timing reference physical loopback? I do have these bits&bobs laying about but no cash for a better laptop.
post #20714 of 23451 Old 11-13-2016, 08:48 AM
artur9's Avatar
Quoted: 665 Post(s)
Liked: 237
That Tekton speaker patent is interesting.
post #20715 of 23451 Old 11-13-2016, 09:31 AM
3ll3d00d's Avatar
Quoted: 1650 Post(s)
Liked: 621
do you mean to use the USB mic as the measurement mic? if so, you can't do a physical loopback using a USB mic.
3ll3d00d is offline
post #20716 of 23451 Old 11-13-2016, 09:44 AM
artur9's Avatar
Quoted: 665 Post(s)
Liked: 237
No, no. Use the laptop's built in mic input (not the built-in mic) for the physical loopback. And use the RCA outputs from the USB DAC.
  • Measurement output signal from headphone jack.
  • Measurement input signal from USB mic.
  • Timing reference output to USB DAC.
  • Timing reference input from USB DAC outputs to mic input jack.
I suppose it would not change the above picture if I looped the headphone jack to the mic input jack and used the USB DAC for the measurement output signal.
post #20717 of 23451 Old 11-13-2016, 09:59 AM
MBrown2020's Avatar
Quoted: 68 Post(s)
Jerry, here is the new measurements you had requested
https://www.dropbox.com/s/kp45tun525...only.mdat?dl=0
post #20718 of 23451 Old 11-13-2016, 10:15 AM
3ll3d00d's Avatar
Liked: 621
You need to use the same ad/da, or rather ad/da which are synced to the same clock, when doing a physical loopback. This means a single clock source for the output and the two inputs.
3ll3d00d is offline
post #20719 of 23451 Old 11-13-2016, 12:27 PM
Foggy1's Avatar
Quoted: 89 Post(s)
Liked: 45
Always interesting, enjoy talking with Eric. He talked me into the Enzo's and out of the dragons, said they would be overkill in my room! Now that Jerry says the Enzo sub isn't cutting it i may have to reconsider. The adventure continues:relaxed:
Foggy1 is offline
post #20720 of 23451 Old 11-13-2016, 03:00 PM
Liked: 4148
I said the sub isn't performing well, but did not attribute the poor performance to the Enzo. I know nothing about your brand of sub. I assume that the performance is a combination of less than ideal placement, and the fact that you have only one sub. Multiple subs can make a dramatic improvement, as long as you find the right placement. If you plan on additional subs, getting another of the same kind would be the least expensive approach.
post #20721 of 23451 Old 11-13-2016, 03:25 PM
Liked: 4148
Something is going on that I can't quite figure out. First of all, the sub response is actually quite good.
However, the individual mains measurements are not great. Note that you can combine two measurements in REW using trace arithmetic. However, when I do this, I am not getting the same results as the measurements you provided earlier.
For example, the summed Right+subs is much better than the measured result from earlier. I am trying to understand the differences--anyone else have a theory?
post #20722 of 23451 Old 11-13-2016, 04:08 PM
Foggy1's Avatar
Quoted: 89 Post(s)
Liked: 45
Apologies Jerry, seem to be misinterpreting alot recently. Sub placement is in the front left corner, may be able to move it inside the left speaker but those are about my only options, all suggestions appreciated?
Foggy1 is offline
post #20723 of 23451 Old 11-13-2016, 04:18 PM
Liked: 4148
Now that you are becoming used to REW, experiment with all potential sub placements and measure the results. Remember to measure with room correction off, since correction changes when things are moved around. A second sub is still your best option for improvement.
post #20724 of 23451 Old 11-13-2016, 04:33 PM
Foggy1's Avatar
Quoted: 89 Post(s)
Liked: 45
Thanks, will be back in touch as soon as I can get my xmc-1 unbricked:neutral_face:
Foggy1 is offline
post #20725 of 23451 Old 11-13-2016, 05:22 PM
artur9's Avatar
Quoted: 665 Post(s)
Liked: 237
Are you familiar with the sub crawl procedure?
You may not be able to use some of the placements you find but knowing the best places for the sub is handy information nonetheless.
post #20726 of 23451 Old 11-13-2016, 07:19 PM
carminepesce's Avatar
Quoted: 49 Post(s)
Liked: 44
Hey guys, I'm getting ready to start taking measurements of my setup. I've printed out & gone over Jerry's awesome guide. At the risk of sounding like a complete fool, I cannot seem to find how to take just a sub measurement...Is it just a matter of disconnecting my main speakers from my amp? Please forgive me if this has been mentioned in the guide but I couldn't seem to find it.
Thanks so much guys!!!
Carmine.
carminepesce is offline
post #20727 of 23451 Old 11-13-2016, 07:24 PM
Liked: 4148
Carmine.
There are two ways:
1. Output the REW test signal to HDMI4 (the LFE channel). Note that the test signal on the LFE channel is output at a +10dB level, so lower the AVR master volume to compensate.
2. Output the signal to the center channel and temporarily disconnect the center channel wire, or turn off the amp driving that channel. The center channel should be set to "small" so that low frequencies are routed to the sub.
post #20728 of 23451 Old 11-13-2016, 07:28 PM
Quoted: 49 Post(s)
Liked: 44
There are two ways:
Thanks so much Jerry!!! Greatly appreciate all the work you've put into compiling the guide. I'll post my .mdat once I take my measurements tomorrow. Looking forward to seeing how my system is interacting with my room
AustinJerry likes this.
post #20729 of 23451 Old 11-14-2016, 05:20 AM
jkasanic's Avatar
Quoted: 329 Post(s)
Liked: 123
One small but perhaps significant suggestion to Jerry's recommendation would be to also raise the crossover setting to the highest value; otherwise, once you've set the speakers to small, bass management is engaged and your sub output will be limited by your crossover.
jkasanic is offline
post #20730 of 23451 Old 11-14-2016, 05:55 AM
Foggy1's Avatar
Quoted: 89 Post(s)
Liked: 45
I am, and I haven't tried it due to lack of available spots for the sub and its 100lb load. Think I will give it a try though and run some measurements, don't trust my ears to know good sound. Could somebody post a graph of a good looking sub?
Foggy1 is offline
Dayton , Dayton Audio , Room Equilizer Wizard Rew
