Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 693 - AVS Forum | Home Theater Discussions And Reviews
 1621Likes
post #20761 of 20780 Old 11-27-2016, 01:21 PM
AustinJerry's Avatar
Quoted: 5903 Post(s)
Liked: 3312
Originally Posted by FargateOne View Post
Thank you Austin.
I was not sure about how to cure the uneven frequency response and you confirm that more treatment is not the best way.
About Dirac Live, I have nanoAvr-DL (you know...bass management after EQing thing...supposed to be bad!). I tried only a couple of time Dirac for my 2 front mains only (stereo, no sub, speakers set to large in the receiver) and , until now, I am not happy with the auto target curve. I know the procedure using text files to create my own target with DL but I do not know what to change to get better sound. I tried to make some changes somewhere on the curve but doing worst than no EQ at all. ( low fr coming boomy, lost details in higher fr, shift in sound stage image etc) . Without guidance it is a long process of trial and error.
On the other hand, I must say that Dirac Live works very very well for my 5.1 setup for movies: the best sound I ever had particularly since I've reduced dratically the reflections with bass traps.
BTW, thank you again for your REW step-by-step guide!
I agree that the Dirac implementation in the NanoAVR is flawed. Have you considered switching to the 88A?
If you want to develop a custom curve, you might find the guide linked in my sig useful.
AustinJerry is online now
post #20762 of 20780 Old 11-28-2016, 06:58 PM
MBrown2020's Avatar
I did some measurements moving the center channel at diff distances from wall. My range is min 15" from face of speaker to wall and max 42" from wall. Looks like 21" looked best?
mdat:https://www.dropbox.com/s/q4274wo3a7...eaks.mdat?dl=0
I also did some the sub tweak. Audyssey default was 15.5ft for both subs. I did measurements at 14.5-8.5 and 16.5-23.5. The three best ones look like 1=22.5 2=20.5 3=11.5. What do you think and did I do it right?
mdat: https://www.dropbox.com/s/1a8pjz11is...weak.mdat?dl=0
MBrown2020 is offline
post #20763 of 20780 Old 11-28-2016, 07:51 PM
Quoted: 34 Post(s)
Liked: 1
I know it is not the thread for this, but I think that the flaws in NanoAvr-DL are much less a problem in room of smal dimensions like mine (3 500 cubefeet more or less) than in larger room.
My Rotel is an integrated amp with rca inputs for 8 channels and my Cambridge CXU player can do bass management BUT I do not think that I will survive longtime if the Significative Other knew that I would want to buy 1K device after already spent 549$ for nanoAvr-DL.
Thank, I will take a look at it.
My system 5.1 :
ROTEL RSX-1562 /Fronts: B & W 804 D2 bi-amplified; surround : B&W 704 and center B&W HTM4d2/sub SVS PC 2000 /TV Samsung UN55ES8000
/BD player Cambridge CXU/ set-top (cable box) rented from cable co.
Bis Audio cables and power bar from the wall to the receiver
My room:15'4" x 11' 6" x 7'6" tv near the center of the long side wall
FargateOne is online now
post #20764 of 20780 Old 11-29-2016, 04:07 PM
Waterboy77's Avatar
Quoted: 437 Post(s)
Liked: 200
I would like to do some measurements of my room to get a base line before I fill the cavity behind the screen wall with insulation. Trying to see the impact (good, bad or indifferent) of filling
What measurements are best to reflect this?
Typically I do the usual 8 and then LCR with subs.... 11 in total
I noticed on the first page that it is best to have a waterfall measurement that incorporates the LR and subs but I am unaware of a way to select this in REW.... just the 8 individual HDMI selections????
Also why is it recommended to turn of room correction if you are tying to measure the performance of the room??
Any assistance appreciated
One day I will start the new theater....... one day..... THAT DAY HAS ARRIVED
"If the women don't find you handsome, they should at least find you handy." Red Green
Family Cave Theater
Automation Thoughts/ Questions
Waterboy77 is online now
post #20765 of 20780 Old 11-29-2016, 04:43 PM
Liked: 3312
To measure L+R+Subs, output the test signal to HDMI1 and HDMI2. Make sure the speakers are set to Small in the AVR, with crossover (80Hz is good). The subs receive the bass signal by virtue of bass management. Insulation behind the screen is likely to have the most effect in the low frequencies, which is what I expect your objective is.
Measuring the surrounds is not that important.
ahblaza likes this.
post #20766 of 20780 Old 11-29-2016, 05:22 PM
Waterboy77's Avatar
Quoted: 437 Post(s)
Liked: 200
Hi Jerry, attached is the measure screen, I don't see a way to select two outputs....??
Yes speakers are small and XO is 100Hz
Yes insulation for low fequencies and potential resonating... due to front wall construction
Family Cave Theater
post #20767 of 20780 Old 11-29-2016, 05:55 PM
Liked: 3312
Is that an old version of REW? The current version is v5.17 beta 9. The output screen is shown on page 63 of the REW Guide. Latest version of REW can be downloaded here: http://roomeqwizard.com/installers/.
post #20768 of 20780 Old 11-29-2016, 06:28 PM
Waterboy77's Avatar
Quoted: 437 Post(s)
Liked: 200
Yup It's 5.16 with JRE
I now see there is a newer guide also....... my things seem to change quickly
I will return when I get up to date and do some re-reading
Previous question that I am still curious about....
"Also why is it recommended to turn of room correction if you are trying to measure the performance of the room??"
Family Cave Theater
post #20769 of 20780 Old 11-29-2016, 07:01 PM
artur9's Avatar
Quoted: 508 Post(s)
Liked: 163
The idea is to improve the room's "native" response before icing the cake with room correction.
IOW, for example, try to make the sub response as flat as possible and then use Audyssey or other to flatten it even more.
Waterboy77 likes this.
artur9 is online now
post #20770 of 20780 Old 11-30-2016, 09:19 AM
LastButNotLeast's Avatar
Quoted: 1359 Post(s)
Liked: 956
Actually, it's 12, and it's here:
http://www.roomeqwizard.com/beta.html
Michael
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
LastButNotLeast is offline
post #20771 of 20780 Old 11-30-2016, 09:21 AM
Waterboy77's Avatar
Quoted: 437 Post(s)
Liked: 200
Michael
Yes when I checked for updates via REW beta 12 came up
Family Cave Theater
post #20772 of 20780 Old 11-30-2016, 09:54 AM
Liked: 3312
Michael
I always attempt to provide good information here, and appreciate LastButNotLeast keeping me honest. I neglected to see that the list of available updates, when sorted alphabetically, places updates later than beta 9 at the top of the list.
post #20773 of 20780 Old 12-01-2016, 04:31 PM
MBrown2020's Avatar
Jerry,
If you could please have a look at post #20762 when you have spare time. I wanted to see if I was doing things right.
post #20774 of 20780 Old 12-01-2016, 04:55 PM
MBrown2020's Avatar
Base dB level of measurement
How do you know the base dB level of a sweep to see how high and low the dips are?
As I understand it if my AVR is set to 0dB (Reference Level) and the measurement sweep is at -12 dB, is the base level at 93 dB (105dB - -12dB)? If AVR is at -5dB than base is 87dB (105- 12dB - 5).
post #20775 of 20780 Old 12-01-2016, 04:57 PM
Liked: 3312
Originally Posted by MBrown2020 View Post
Jerry,
Yes, later this evening.
post #20776 of 20780 Old 12-01-2016, 05:02 PM
Alan P's Avatar
Quoted: 4340 Post(s)
Liked: 3024
Not Jerry, but I took a look.
I think 15" off the wall looks just a bit better than 21". You get a bit more SPL in the 50-150hz range.
The sub distance of 20.5' looks best to me. There is a large peak at 128hz though that is present in all of the CC+subs measurements that isn't there in the CC only measurements...must be induced by the subs. Have you measured the subs alone and is that peak from their response? If so, you may be able to bring that down with sub placement.
My $.02.
Alan P is offline
post #20777 of 20780 Old 12-01-2016, 05:04 PM
Liked: 3312
Yes, should be.
Pick a measurement, click on the Spectrogram tab, and then click Generate. The measurement peak is shown on the right of the screen.
post #20778 of 20780 Old 12-01-2016, 05:19 PM
MBrown2020's Avatar
My $.02.
Thanks for giving it a look. The sub response does not have a peak at 128hz when measuring alone. The crossover for all speakers is at 80hz so I would think something with the center channel must be making it.
The 15" off the wall had more dips between 200-300 hz though, which I would think would be bad
post #20779 of 20780 Old 12-03-2016, 04:26 PM
MBrown2020's Avatar
Hello,
Took new measurements today after running audyssey pro with av8802a. I took measurements of all three front left, right, and center speakers to get the smoothest response I could get with the speaker placement constraints. I found that putting in the foam port plugs helped with the front speakers bass response lowering all the peaks from 90-200hz somewhat. I also did the sub tweak and found that the distance of subs from default 15' to 21' had pretty smooth response. The left and right response alone look not so great, but the l+r and the center I thought looked pretty good without any treatments. What do you think?
mdat: https://www.dropbox.com/s/mdljh7yrg5...inal.mdat?dl=0
ID:	1805345   Click image for larger version
post #20780 of 20780 Old Today, 07:59 AM
Quoted: 34 Post(s)
Liked: 1
I am on strike since 6 weeks and it will continue.
After doing my daily picketing hours, I have spent the rest of the first days on strike to read about room treatment.
Everybody agee here to say that after to buy good equipment and good speakers and after to place them at the best place possible, the next step for a good SS&I is treatment long before to buy a PEQ (audyssey, YPAO, minidsp).
Like many, I bought an EQ device first hoping that it will do miracles.
Thanks to this strike I have decided to try to built bass traps (to buy those during a strike would have been a cause for divorce!!). I must say that the places available are rare due to waf. But she let me go into the rabbit hole at one condition: do not move the furniture.
My room is small (see my system) . Where ceiling joins walls, I can put some traps on the front and the back walls jonction but not on the jonction with the left and right side walls. For corners, only 2 are available. For the jonction between floor and wall, I had only the place behind the fronts speakers and a little at the right side wall and at the back wall. Finally in the vertical jonction with 2 walls, only one (the back right side corner) could be treated and not entirely.
90 hours later more or less, 12 traps are in place. They are of various dimensions choosen by the place that I have not by the sound science ( if I understood well it must be a relation between the trap dimensions and the sound waves to treat). Some are 24 inches X 16 inches, others are 26 inches X 32 inches and others are 12 X 36. All made of wood for the frame, jute for the fabric and Roxul Safe'Nsound at least 3 inches thick and more where possible.
Now, the basses ( 15hz to 300hz) decay of 20db in the first 300ms and 80% decay below the noise floor after 450ms.
BUT THE DIFFERENCE IN THE SOUND IS BREATHTAKING!!!
The difference is near as great as the difference between my 5 PSB alpha series speakers and my B&W!!!!
It is difficult to believe!
Also, now, a little change of not more than 8 cm between fronts and 4 cm in the distance from the front wall make easily audible changes in SS&I. Also, changing the toeing by a few degrees is audible etc.
...and all changes are measurables!
Of course, I do not have perfect resoiknse curves but it is the best I ever had and the best I can for the moment.
Thanks to all of you experts here and a special thanks to JohnM for REW.
My system 5.1 :
Dayton , Dayton Audio , Room Equilizer Wizard Rew
