Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 724 - AVS Forum | Home Theater Discussions And Reviews
 1759Likes
post #21691 of 21717 Old 02-23-2017, 07:28 AM
Hammonje's Avatar
Quoted: 88 Post(s)
Liked: 29
An issue I ran into was having my Sony TV connected to the AVR. My comnputer kept switching between recognizing the AVR and TV. Caused my laptop serious fits, so I had to unplug the TV HDMI. Made switching between YPAO modes quite difficult.
Man Cave HT: Yamaha RX-A3060 | Chane A5RX-C | Chane A2.4 | Chane A1.4 | HSU VTF-3 MK5 HP
Hammonje is offline
post #21692 of 21717 Old 02-23-2017, 08:10 AM
rynomyte's Avatar
Quoted: 48 Post(s)
Liked: 74
Originally Posted by Alan P View Post
I'd say your graph looks fantastic, and especially so since you are just starting out. Many on this forum would probably kill to be able to start with a frequency response like yours.
That dip at 80hz is very, very narrow. It is almost certainly not audible during actual content.
That being said, it would still drive me crazy.
Can you move your CC forward or backward a few inches (I mean physically move the speaker) to see if it makes any difference?
Thanks Alan! I'm starting to really get the hang of how to measure but the interpreting and fully understanding the graphs is where I am at now.
Yes, I'm rather anal so getting it flat as possible is my goal...That's why I went dual!
Right now, the front of my CC is just past the edge of the shelf it's on but I can play around with it's position. I have about an inch I can pull it out and several backwards but I think I want to avoid moving it back. I will try both though.
IIRC, you bought dual subs, right? If so, are they placed so that they are equidistant to the MLP? If they are not, yes, adjusting phase on one of the subs (the closer sub) should produce some good results. If they are equidistant to the MLP, then adjusting phase shouldn't do much, but it doesn't hurt to experiment and measure.
BTW, XT does have subwoofer EQ...just not as detailed as XT32.
I did go dual...the near one is about 2 feet closer. I will experiment and see what I can come up with.
Originally Posted by LastButNotLeast View Post
This is a great technique using REWs generator and SPL meter:
At What Point Do I "Play" With The 0/180 Phase Switch On Dayton 1500 SUB?
Michael
Thank you Michael! I will definitely give this a try!
I may not get to measure again until the weekend but I will certainly report back with a new graph as soon as I have one. Thanks for the help guys!
Marantz SR5009
Klipsch RF82II - RC62II - RS52II - AW-650 outside
PSA Dual V1801's
LG 55LW5600
HTPC Home Built for Kodi & Gaming
rynomyte is offline
post #21693 of 21717 Old 02-23-2017, 08:36 AM
Hammonje's Avatar
Quoted: 88 Post(s)
Liked: 29
Markus,
Bands capable of adjustment:
Speakers
62.5 Hz -- 157.5 Hz -- 396.9 Hz -- 1Khz -- 2.52 Khz -- 6.35 Khz -- 16 Khz
Subwoofer
15.6 Hz -- 19.7 Hz -- 24.8 Hz -- 31.3 Hz -- 62.5 Hz -- 125 Hz -- 250 Hz
Q factor: 0.5 - 10.8
Gain: -20 db to +6 dB
Hammonje is offline
post #21694 of 21717 Old 02-23-2017, 08:41 AM
markus767's Avatar
Quoted: 3665 Post(s)
Liked: 1314
Originally Posted by Hammonje View Post
Is there any information that shows the speaker assignments? I am running 5.1, but the software shows 1.1 thru 1.8. I thought it was the subwoofer, but hell at this point I'm just stoked to produce a graph.
1 ...8 = L R C LFE LS RS LBS RBS
Should be in Jerry's guide, no?
Hammonje likes this.
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #21695 of 21717 Old 02-23-2017, 08:49 AM
markus767's Avatar
Liked: 1314
Markus,
Speakers
Subwoofer
Thanks. Now do the 3 measurements outlined in post 21674. For now measure through channel 4 (LFE). In your AVR set the LFE low pass filter to off or the highest value possible. Don't forget to use an acoustic timing reference.
Markus
post #21696 of 21717 Old 02-23-2017, 08:57 AM
Hammonje's Avatar
Quoted: 88 Post(s)
Liked: 29
Thanks. Will do tonight and report results.
Hammonje is offline
post #21697 of 21717 Old 02-23-2017, 09:43 AM
LastButNotLeast's Avatar
Quoted: 1506 Post(s)
Liked: 1106
Originally Posted by unretarded View Post
I used my laptop from the front room that runs the TV and sound equipment and it has equalizer APO installed on it and running
If you're using ASIO, E-APO is bypassed. If you want to see what E-APO is doing, you have to run REW under JAVA (then you use E-APO to turn the speakers on and off).
Michael
unretarded likes this.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
For most of the time, the here and now is neither now nor here. Graham Swift
LastButNotLeast is offline
post #21698 of 21717 Old 02-23-2017, 01:51 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6667 Post(s)
Liked: 3671
I happen to have my laptop connected up right now, so I generated some tones, and my outputs are different from what you listed:
HDMI5=LBS, 6=RBS, 7=LS, 8=RS.
Why would we differ?
AustinJerry is online now
post #21699 of 21717 Old 02-23-2017, 02:21 PM
3ll3d00d's Avatar
Quoted: 1571 Post(s)
Liked: 557
I believe the more commonly used format is L C R LFE LSR RSR LSS RSS
i.e. rear surrounds are channels 5 & 6
however both mappings exist
sample post with too much detail - http://forum.doom9.org/showthread.ph...85#post1443085
3ll3d00d is online now
post #21700 of 21717 Old 02-23-2017, 07:41 PM
Hammonje's Avatar
Quoted: 88 Post(s)
Liked: 29
Markus, here are the requested measurements. All were taken with time reference. 512K.
No YPAO, YPAO volume off. No other enhancers engaged.
SW
LR Main (1/6 octave smoothing)
LRC (1/6 octave smoothing)
Hammonje is offline
post #21701 of 21717 Old 02-23-2017, 07:43 PM
Hammonje's Avatar
Quoted: 88 Post(s)
Liked: 29
YPAO Natural.
SW
Hammonje is offline
post #21702 of 21717 Old 02-23-2017, 10:15 PM
citsur86's Avatar
Quoted: 955 Post(s)
Liked: 287
Originally Posted by AustinJerry View Post
Well, try this and see how it sounds, and measures. What you are proposing is called "double bass", and is generally not recommended because it can produce bloated, boomy bass. But maybe you will like it...
Finally got a chance to give this a shot tonight (double bass) by setting the Fronts to Large and Sub to PLUS on the VSX-44. The FR actually doesn't look much better at all.
I cut the graph off at 200Hz because the Frequency Response is the exact same to 20,000Hz past that between the two.
Since there isn't too much difference in FR, I will give it a shot and see how I like it for a while. However, during these sweeps I decided to turn my sub 90 degrees CC so that its now facing in a different direction and with some MiniDSP 2x4HD and PEQ filter help, my LFE FR looks the best I think it ever has in my room.
The only thing I still cannot figure out is why a full 5-20,000Hz sweep with CH1, CH2, or CH3 doesn't seem to crossover nicely. Also has a huge bump from 7000Hz to 13,000Hz - something to do with the room maybe? Anyway for me to work on this?
Notice the jumpiness between 100-1,000Hz.
Here is the CC Sweep with less smoothing:
Name:	FL+FR With and Without Double Bass.png
ID:	1990049   Click image for larger version
ID:	1990057   Click image for larger version
Name:	FL-FR-CC Sweeps.png
ID:	1990065   Click image for larger version
Name:	CC 1-24 Smoothing.png
My Current "Living Room" Home Theater!
Plasma 50" TV: Samsung PN50C8000 — DLP Projector: Optoma GT1080
Projector Screen: Elite VMAX2 Electric — Receiver:Pioneer Elite VSX-44 — Fronts: B&W 684 S1
Center: B&W CM Center S2 — Surrounds: B&W 685 S1 — Subwoofer: Rythmik FV15HP
Rear Surrounds: Polk Audio T15 — Front Heights: Polk Audio T15
citsur86 is online now
post #21703 of 21717 Old 02-24-2017, 12:37 AM
markus767's Avatar
Liked: 1314
Looks like you've measured all speakers but not just the sub at 3 different mic locations?
Markus
post #21704 of 21717 Old 02-24-2017, 07:15 AM
Hammonje's Avatar
Quoted: 88 Post(s)
Liked: 29
OK. I'll do that this afternoon. Getting off a bit early today. Thanks.
Hammonje is offline
post #21705 of 21717 Old 02-24-2017, 11:31 AM
Hammonje's Avatar
Quoted: 88 Post(s)
Liked: 29
Markus. I moved the SW from the corner to just left of my console in order to attempt a flatter target.
SW Mic Center
SW Mic Left
SW Mic Right
SW Average 3 positions
Hammonje is offline
post #21706 of 21717 Old 02-24-2017, 01:29 PM
markus767's Avatar
Liked: 1314
SW Mic Center
Can you please upload the .mdat to Dropbox or similar?
Markus
post #21707 of 21717 Old 02-24-2017, 02:48 PM
Hammonje's Avatar
Quoted: 88 Post(s)
Liked: 29
I can place it in my Google Drive and share it.
Here is a link to the .mdat file on my Google Drive:
https://drive.google.com/file/d/0B0X...ew?usp=sharing
Hammonje is offline
post #21708 of 21717 Old Yesterday, 01:28 AM
markus767's Avatar
Liked: 1314
Thanks. Looks like there's not much variance and just one non-minimum phase region around 85Hz.
So besides that area the whole response can be equalized. Unfortunately the fixed center frequency EQ of your AVR doesn't allow the necessary fine control to make it as flat as it could be. Especially the ringing at 27Hz is still there after EQ.
Attached you'll find your Yamaha's sub EQ filter set (yamaha-sub-filters.req) that you can load into "EQ filters" (use the "Generic" equalizer). Then click "Optimize gains & Qs".
ID:	1991825   Click image for larger version
ID:	1991833   Click image for larger version
Markus
post #21709 of 21717 Old Yesterday, 01:49 AM
markus767's Avatar
Liked: 1314
With 5 PEQs you could get from this...
...to that...
ID:	1991857   Click image for larger version
Markus
post #21710 of 21717 Old Yesterday, 02:17 AM
turboman123's Avatar
Quoted: 29 Post(s)
Liked: 25
Yes, measure with an acoustic timing reference:
1. Set timing reference to L
2. Measure LFE
3. Measure R
4. Increase speaker distance of L and R by the same amount
5. Measure LFE
6. Measure R
If the measurements show always the same delay between sub and R then you're out of luck and you need to buy a new AVR with proper bass management.
Hallo Markus,
Finally got around to report back: The first picture shows the measurements as described by you in 1 - 3. Timing reference is Front Left FL, and measurements are FL, FR, and LFE. The SW delay is about 2.5 ms (using the start of first peak in the SW impulse).
Then distance for L and R were increased by 1meter in the AVR. Results are the same.
So in this way, I cannot correct the delay between L, R, C and SW.
Coming back to my post 21520. With my standard setup, the proper speaker distance is:
FrontLeft 2.6m, FrontRight 2.6m, FrontCenter 2.6m, SurroundLeft 1.7m, SurroundRight 2.3m.
If I increase the SurroundRight distance setting to higher than 2.6, then the impulse response shows a reduced delay between L, R, C and SW. This shows that the AVR sets a delay for a speaker depending on the difference between that speaker distance and the maximum speaker distance.
So I could have:
Use the original distance settings, and have a 2.5ms delay between L, R, C and SW,
or,
Use the trick with increased surroundright distance, which eliminates the delay between L, R, C and SW. But then there is time mismatch between surroundright and the other channels (of approximately 3.5ms).
What is best? My profile is movies. My gut feeling says that it is more important to get the front stage right, with the proper synchronizing of L, R, C and SW, at the expense of the surround channel.
This would be a short term solution. Longer term, I hope miniDSP would bring an HDMI AVRHD with Dirac and Bass Management before Dirac.
ID:	1991873   Click image for larger version
Name:	Markus L,R +1m.jpg
turboman123 is offline
post #21711 of 21717 Old Yesterday, 02:23 AM
markus767's Avatar
Liked: 1314
Originally Posted by turboman123 View Post
What is best?
Get a new AVR. Sorry but the one you have right now is simply "unfit for purpose".
Markus
post #21712 of 21717 Old Yesterday, 10:24 AM
Quoted: 29 Post(s)
Liked: 25
At the moment, I have other priorities (first get a job; then pay off student loans). In the meantime, I was hoping to get some advise and help to keep my mental curiosity in this field going and progressing.
post #21713 of 21717 Old Yesterday, 11:20 AM
artur9's Avatar
Quoted: 547 Post(s)
Liked: 190
What's your AVR? I relish a budget challenge (what can we do with what you have, how cheap can we replace it, etc).
artur9 is offline
post #21714 of 21717 Old Yesterday, 11:43 AM
Liked: 1106
I love spending other people's money (what can we do with what you have, how cheap can we replace it, etc.).
Michael
post #21715 of 21717 Old Yesterday, 07:30 PM
artur9's Avatar
Quoted: 547 Post(s)
Liked: 190
Michael
Spending money is the last resort!
bmcn likes this.
artur9 is offline
post #21716 of 21717 Old Today, 12:12 AM
WormInfested's Avatar
Quoted: 65 Post(s)
Liked: 48
I have a ported diy ultimax um18-22 sub and after a few tweaks in the inuke this is what i got. i'm thinking it looks ok but would like some feedback. the enclosure size is 20" wide 22" deep and 24" tall. everyone tells me its too small for the driver but i figured i'd test it out first before i do a mini marty in case it works and i can stick with it before moving on.
Pioneer Elite SC-05
JBL Studio S312II fronts, JBL Studio S10IIs mid and S8IIs rear.
Single JBL S38 center channel
Power Sound Audio V1800, 2 MFW-15's, DIY ported UM18-22, Prosub 800
Oppo BDP-103
BenQ W7500 & Silverticket 110" matte white 16:9
WormInfested is offline
post #21717 of 21717 Old Today, 07:42 AM
Liked: 3671
The response below 80Hz looks pretty good, but it falls off fairly quickly above 80Hz, which seems odd. Two additional measurements would be useful to look at:
1. A measurement of the sub only, with the crossover to the mains set as high as possible, typically 250Hz. This will show whether the sub response extends above 80Hz without being affected by a crossover. Measure 15-300Hz, no smoothing.
2. A measurement of sub+Center with crossover in place, typically 80Hz. This will show how well the sub and center are blending, especially around the crossover point, and whether the center fills in the response above 80Hz. Measure 15-300Hz, no smoothing.
Dayton , Dayton Audio , Room Equilizer Wizard Rew
