Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 727 - AVS Forum | Home Theater Discussions And Reviews
 2170Likes
post #21781 of 23244 Old 03-07-2017, 09:36 AM
markus767's Avatar
Quoted: 3992 Post(s)
Liked: 1405
Originally Posted by Marc Alexander View Post
Obviously? The mic is acting like there is just ambient noise, no matter what the noise in the room is.
Again, is the mic recognized in control panel "Sound", "Recording" tab? If yes, does the meter move according to the input (speak into the mic)?
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #21782 of 23244 Old 03-07-2017, 10:10 AM
citsur86's Avatar
Quoted: 1371 Post(s)
Liked: 557
Originally Posted by citsur86 View Post
Notice the jumpiness between 100-1,000Hz.
Here is the CC Sweep with less smoothing:
Just wondering if anyone has any adivce on how I might be able to tame this jumpines around the crossover through to 300-400hz? If it's room caused, there's not much I can do for now, but if there's other PEQ related steps I'd be willing to try.
citsur86 is online now
post #21783 of 23244 Old 03-07-2017, 10:35 AM
JohnPM's Avatar
Quoted: 83 Post(s)
Liked: 51
Originally Posted by danielrg View Post
However, if I make two or more measurements at 512K or 1M, I get large dips in some areas above 4000 Hz. It's really weird. Wasn't happening on my other computer. Using a USB UMIK-1, same one I used with my other computer.
Multiple sweeps requires exact time synchronisation between replay and recording. That can't happen when the sweep and the captured signal are from separate devices. To quote the help:
REW allows multiple sweeps to be averaged, although best results are generally obtained by using single, longer sweeps rather than multiple, shorter sweeps. Do not use multiple sweeps if the input and output are on different devices (for example, if the input is a USB mic).
I'll add an extra check in the measurement dialog to catch attempts to set multiple sweeps when using a USB mic and prevent it.
AustinJerry and ahblaza like this.
JohnPM is online now
post #21784 of 23244 Old 03-07-2017, 11:13 AM
markus767's Avatar
Liked: 1405
These are room related effects. In my book they are also highly harmful to good sound quality. At the same time they are the hardest to treat. EQ can't be used so the only option is to use acoustic treatments.
Markus
post #21785 of 23244 Old 03-07-2017, 11:20 AM
Marc Alexander's Avatar
Quoted: 2004 Post(s)
Liked: 1733
No, it moves randomly as if it is just picking up room noise even if I speak, clap, or play AVR test tones.
Marc Alexander is online now
post #21786 of 23244 Old 03-07-2017, 11:32 AM
markus767's Avatar
Liked: 1405
Can you post a screenshot?
Markus
post #21787 of 23244 Old 03-07-2017, 11:50 AM
citsur86's Avatar
Liked: 557
Figured that. I've already gotten away with doing so much more to my living room than my wife wanted that I won't push it by starting to hangup acoustic treatments. This will have to do until I get around to my basement in a year or so hopefully. Can't wait to start that build!
post #21788 of 23244 Old 03-07-2017, 12:14 PM
Liked: 1733
Did you post your L & R too? Also, a picture of their positioning? You may be able to improve just with positioning.
Is your MLP against a back wall?
post #21789 of 23244 Old 03-07-2017, 12:59 PM
citsur86's Avatar
Liked: 557
MLP is not against a back wall - it's in middle of room. The room is not a rectangle though, its basically my entire first floor which is in an L shape.
Checkout my post here which has L&R measurements
The Sub by itself has pretty good response how I have it now. When I see how it plays with the other speakers, it's not so great it seems.
post #21790 of 23244 Old 03-07-2017, 03:17 PM
Liked: 1733
Don't stress about it. I wonder how well a REQ that operates in the time domain (Audyssey, Dirac, ARC, etc... not YPAO) would help? I'll see if I can post some full range before and after graphs for my main speakers. YPAO gets choked up by my Mirage Omnipolar speakers. Audyssey XT32 makes an audible & visible difference. I have heard Dirac and ARC are even better. I wouldn't mind having an Arcam processor.
I am ordering bass traps (8 tri-corners) and acoustic panels from lasoundpanels.com. My Mirage utilize 1st reflections so acoustic panels only on front and back walls.
post #21791 of 23244 Old 03-07-2017, 03:23 PM
Liked: 1733
@markus767 & @Steve Hanna , thanks for trying to help.
The mic is working now. I noticed some scratches near the top of the mic that could only be TEETH MARKS! My 3.5 year old is still putting everything in his mouth. Now that the mic has dried out, it is working again. I've checked against recent measurements from Friday and Saturday and all is good now!
Steve Hanna, Foundation42 and bmcn like this.
post #21792 of 23244 Old 03-07-2017, 04:30 PM
Foundation42's Avatar
Quoted: 53 Post(s)
Liked: 56
Let us know what you think of their bass traps and panels. I have panels up for reflections but I've been looking around at what to do for bass traps. I hadn't heard of that company before, but looking at their site, their Lo-Tone traps might be interesting.
Foundation42 is online now
post #21793 of 23244 Old 03-07-2017, 09:40 PM
WormInfested's Avatar
Quoted: 79 Post(s)
Liked: 58
haven't had an opportunity yet to even things out in the main theater setup so i messed with the spare room subs instead tonight. moved both up front and level matched them at 0 on the receiver and at 75 decibels using my radio shack analog meter. sounds smoother than before but i can tell one is a sealed sub. one day i'll switch to dual sealed with the um15 package. subs measured here are the SVS PB10 NSD and Definitive Pro Sub 800. included the pre level match measurement of the prosub which seemed to fair well to an extent even though it does suck compared to an actual real sub with a wider frequency range.
Name:	dual leveled.jpg
ID:	2013297   Click image for larger version
Pioneer Elite SC-05
JBL Studio S312II fronts, JBL Studio S10IIs mid and S8IIs rear.
Single JBL S38 center channel
Power Sound Audio V1800, 2 MFW-15's, DIY ported UM18-22
Oppo BDP-103
BenQ W7500 & Silverticket 110" matte white 16:9
WormInfested is offline
post #21794 of 23244 Old 03-08-2017, 07:58 AM
Alan P's Avatar
Quoted: 4946 Post(s)
Liked: 3576
Using what to generate the pink noise? Your AVR?
You have REW, why aren't you level matching using your microphone and pink noise from REW? This would be more accurate than an SPL meter.
ahblaza likes this.
Alan P is offline
post #21795 of 23244 Old 03-08-2017, 09:21 AM
EndersShadow's Avatar
Quoted: 571 Post(s)
Liked: 901
So I finally got time to post a graph of what happened when I switched the phase on my subs and had to ask some questions to make sure I did things right.
Below is a graph of the BEFORE, AFTER and when I switched a SINGLE subs phase.
After I switched phase on both subs, should I have re-run XT32 or not? Should I switch the phase on just one and not the other, etc?
Also any thoughts on things to play around with?
My Setup | FS: Nothing right now
Quote: There exists, for everyone, a sentence - a series of words - that has the power to destroy you. Another sentence exists, another series of words, that could heal you. If you're lucky you will get the 2nd, but you can be certain of getting the 1st. - Philip K. Dick
EndersShadow is offline
post #21796 of 23244 Old 03-08-2017, 09:45 AM
markus767's Avatar
Liked: 1405
First optimize your subs for low seat to seat differences. Then run MultEQ. Play with crossover and sub delay for further optimization.
Markus
post #21797 of 23244 Old 03-08-2017, 10:29 AM
Alan P's Avatar
Liked: 3576
Please re-post the graph with the Freq. Axis toggled. This graph is set to Linear (all octaves have equal spacing) when you want it set to Logarithmic.
Alan P is offline
post #21798 of 23244 Old 03-08-2017, 11:55 AM
Quoted: 571 Post(s)
Liked: 901
Pretty much done all that. Cant move either of them much, and moving them doesnt change anything in the measurements. Played around with distances of both subs and crossover settings.
Like this?
post #21799 of 23244 Old 03-08-2017, 12:11 PM
markus767's Avatar
Liked: 1405
Can you post the .mdat showing that data?
If you don't see any changes after moving subs you're doing something wrong.
What are the results? Inconclusive? Then go back and start with a general assessment of your room's acoustics.
Markus
post #21800 of 23244 Old 03-08-2017, 01:11 PM
Alan P's Avatar
Liked: 3576
Like this?
Yup.
I'd go with the phase reversed on both subs.
Alan P is offline
post #21801 of 23244 Old 03-08-2017, 01:36 PM
LastButNotLeast's Avatar
Quoted: 1717 Post(s)
Liked: 1321
And an xo of 80. Let's see it now with the center (or L + R, if your main interest is music).
Michael
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
Don't guess, measure: Getting Started With REW: A Step-by-Step Guide
LastButNotLeast is offline
post #21802 of 23244 Old 03-08-2017, 02:48 PM
Quoted: 571 Post(s)
Liked: 901
Yup.
Any suggestions on if the stuff above 80 Hz is an issue?
Michael
Will try to get these tonight if possible.
PS that is with an XO of 80.
post #21803 of 23244 Old 03-08-2017, 03:10 PM
markus767's Avatar
Liked: 1405
Some (most?) people just hear what they want to hear...
Markus
post #21804 of 23244 Old 03-08-2017, 03:55 PM
Quoted: 571 Post(s)
Liked: 901
post #21805 of 23244 Old 03-08-2017, 03:58 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 7301 Post(s)
Liked: 4065
I must not be understanding the measurements. If you have two subs, and are measuring the subs only, then reversing the polarity on both subs will produce the exact same measurement. Please help me understand what is being measured.
ahblaza likes this.
AustinJerry is online now
post #21806 of 23244 Old 03-08-2017, 04:45 PM
Quoted: 571 Post(s)
Liked: 901
The massive dip right above 80hz in the original measurement (subs same phase as mains) that is MUCH better in the subs with phase inverted from mains measurement.
post #21807 of 23244 Old 03-08-2017, 05:08 PM
Liked: 4065
I asked for clarification for what the measurements represent. Are the measurements with subs+mains, or subs only?
post #21808 of 23244 Old 03-08-2017, 05:26 PM
Quoted: 571 Post(s)
Liked: 901
Apologies. It is left + subs. Is there a way to do a L/R + subs? In a single measurement?
Left Original
Left with a single sub with inverted phase
Left with both subs with inverted phase
post #21809 of 23244 Old 03-09-2017, 12:59 AM
markus767's Avatar
Liked: 1405
You've ignored my questions/suggestions. By the way, did you read Jerry's guide? https://dl.dropboxusercontent.com/u/...%20Version.pdf
Markus
post #21810 of 23244 Old 03-09-2017, 06:12 AM
Quoted: 571 Post(s)
Liked: 901
Your question about .mdata was added after I saw your original post, just like you adjusted this post to add the part about Jerry's guide after I had already reviewed the responses to this thread earlier this morning.
I have downloaded and reviewed Jerry's guide as well as MTG90's thread about optimizing multiple subwoofers. Jerrys guide is how I was able to get measurements at all.
Your question about proof that I've optimized is farther back in this thread but I will repost here. Overall I have over 75+ measurements of the mains + sub and rather than bore everyone with the bad ones, or incrementally good ones I posted mainly where I ended up at the end of each nights tweaking.
This is the first night of attempting to integrate my 2 subs with my mains. The graph is NOT logarithmic and I forget which of the 75 measurements these two represent so I wont be able to go back in and redo it as logarithmic for a perfect A/B of what I have now.
Additionally I dont have a lot of flexibility to move things around at all, so basically at this point my options are I can move my mains maybe a foot farther out from each other and thats about it. And I've measured what happens when I move the mains out or toe them in and it is not any better than what I have now.
Slowly getting there... still not sure how to address the crossover issues between my subs and the mains. I tried crossing the mains over at 80, 100hz with the LFE @ 150 even and still nothing.
Tweaked with the distances of the subs and got a better response but still not perfect.
Whats hard to see is that the tweaked Left and Right response are VERY close to each other, as opposed to the originals where they were totally out of whack.
But here you go.
Left
Right
Subs
Dayton , Dayton Audio , Room Equilizer Wizard Rew
