Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 733 - AVS Forum | Home Theater Discussions And Reviews
 2149Likes
post #21961 of 23115 Old 03-19-2017, 12:20 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 7250 Post(s)
Liked: 4029
Originally Posted by trp3383 View Post
I recently picked up a umik-1 to measure my room and dual rythmik l22's. Room is around 1500cu ft. I'm trying to figure out rew, which is coming along slowly. I ran 2 sweeps with xt32 off, one with both subs set to low ht and another with them set to low music. Seems like I'm getting room gain into single digits with low music setting. Any pointers on where I should go from here? Was also wondering if grabbing a minidsp would help out? Thanks guys
Sent from my SM-G930V using Tapatalk
Couple of questions/comments:
- What do the terms "Low HT" and "Low Music" mean? These terms are foreign to me. Are these setting on the subs?
- Why measure with XT32 off? Typically we like to see XT32 on, since that is likely how you listen to the system.
- For measurements displaying the low frequencies, measure 15-300Hz, and don't use smoothing.
AustinJerry is online now
post #21962 of 23115 Old 03-19-2017, 01:15 PM
trp3383's Avatar
Quoted: 103 Post(s)
Low ht and low music are settings on the back of the subs. I took those without eq to see how the subs measured in the room before eqing. Here's the updated graph. Thanks
trp3383 is offline
post #21963 of 23115 Old 03-19-2017, 01:32 PM
markus767's Avatar
Quoted: 3947 Post(s)
Liked: 1400
Originally Posted by AustinJerry View Post
Really? According to Markus, this should have been obvious.
...to Jerry. Most users don't have a clue what all these AVR settings are for and virtually all manufacturers fail miserably in explaining them.
unretarded likes this.
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #21964 of 23115 Old 03-19-2017, 04:43 PM
Liked: 4029
Originally Posted by artur9 View Post
Is that in your updated section? That would be very helpful to note.
OK, I'll insert an explanation for the unenlightened. Tomorrow at the earliest.
Medi0gre and unretarded like this.
post #21965 of 23115 Old 03-19-2017, 05:07 PM
LastButNotLeast's Avatar
Quoted: 1703 Post(s)
Liked: 1307
The unenlightened among us will really appreciate it.
Michael
ahblaza, Medi0gre and unretarded like this.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
Don't guess, measure: Getting Started With REW: A Step-by-Step Guide
LastButNotLeast is offline
post #21966 of 23115 Old 03-19-2017, 05:56 PM
Quoted: 470 Post(s)
Liked: 340
As suggested by @AustinJerry and others, I have followed best practices and the Toole white paper that suggests best results are achieved with all subs in mono or LFE.
I have positioned the subs at 1/2 room for all 4 subs, mid point of all 4 walls, with the 2 side subs 1/4 spaced from walls.
I did a bunch of sweeps to get the best results, which is the current location and the right sub phase switch at 180, all other subs at 0.
AVR LPF/crossover set at 100hz.....
This graph is with MCACC on and off, with MCACC ON yielding the flatter response, no minidsp yet as it has not showed up. I ordered the minidsp directly from the site, not realizing they are in a land far far away.
Gold is NO MCACC.......
Name:	new sweeps in mono.jpg
Link to budget Home Theater build
http://www.avsforum.com/forum/19-ded...i-version.html
unretarded is online now
post #21967 of 23115 Old 03-19-2017, 08:05 PM
Liked: 1307
What AVR do you have? The older ones (like my SC-1223) don't do any eq for subs.
Michael
post #21968 of 23115 Old 03-19-2017, 08:24 PM
Liked: 4029
I am sure you had a reason to place all four subs at the 1/2 mark, but have you tried other placements? For my four subs, I get the flattest response by placing two at the 1/2 mark, and the other two at the 1/4 and 3/4 marks on the front wall. Looking at the freqency response you posted, you could probably do better. I would try other placements.
And why did you flip the polarity on one sub? Did the REW impulse response reveal that the polarity was reversed? Did you actually check the impulse response?
post #21969 of 23115 Old 03-19-2017, 10:01 PM
Quoted: 470 Post(s)
Liked: 340
Michael
Newer cheap pioneer elite vsx lx-301....advanced MCACC, not MCACC pro like the nice recievers, and it has a sub eq....5 channel.
post #21970 of 23115 Old 03-19-2017, 10:10 PM
Quoted: 470 Post(s)
Liked: 340
I tried a quite a few placements. I am stuck with one directly center rear firing into the MLP seating. I tried all 3 front wall, 1 center and at the 1/4 and 3/4.
Then I moved them a foot at a time up the side walls until 1/2, then moved them out to 1/4 from side walls at mid point of side walls.
I am in a almost square room.....11 foot 6 inches wide x 12 foot 9 inches deep..... Seating is approx. 1/3rd room distance...between 1/3rd and 1/4..
I just flipped the polarity on the subs in all kinds of combinations to see which gave the best response.
I did not check the impulse response since I do not have the minidsp yet .......
I thought it,the response looked pretty good......
I am not complaining that it can get better, I like that !
EDIT:
If I am reading the graph correctly I am at approx. +/- 5db , the paperwork on the subs states it is +/- 3db......or with work and a minidsp can it exceed the rated +/- 3 db ?
post #21971 of 23115 Old 03-19-2017, 10:29 PM
sdurani's Avatar
Quoted: 4809 Post(s)
Liked: 3220
I am sure you had a reason to place all four subs at the 1/2 mark...
From Welti's subwoofer placement paper:
Sanjay
sdurani is online now
post #21972 of 23115 Old 03-19-2017, 10:40 PM
Quoted: 470 Post(s)
Liked: 340
I might have to try 2 front center and 2 rear center......might get me some extra extension.
post #21973 of 23115 Old 03-20-2017, 01:09 AM
Quoted: 470 Post(s)
Liked: 340
Here is 2 center front and 2 center rear...........side by side. Crossed over at 80hz.
It is +/- 3db except for the giant room induced hole around 70hz.......
Name:	final final no mcacc.jpg
post #21974 of 23115 Old 03-20-2017, 06:31 AM
Liked: 4029
Just curious, why did you shorten the vertical scale? Typically, we recommend the scale to be configured in 5dB increments, say 50-100dB. The smaller increments make the response curve look much worse than it is. And with the scale as it is, we can't even see the bottom of that massive dip. Your last post had the vertical scale configured properly.
post #21975 of 23115 Old 03-20-2017, 06:48 AM
Liked: 1307
Sort of.
You'll do much better with the minidsp.
Michael
Name:	Screen shot 2017-03-20 at 9.46.09 AM.png
post #21976 of 23115 Old 03-20-2017, 10:38 AM
Liked: 4029
Michael
As per the request, I have updated the new section in the Guide with a description of how AVR's handle the distance settings to determine speaker delays. Please review and comment as appropriate.
post #21977 of 23115 Old 03-20-2017, 12:55 PM
Quoted: 470 Post(s)
Liked: 340
Sorry about that, I will post a correctly scaled one when I get home.
I like a finer scale on things.....
Trying to get resolution better than +/- 3db on a 5 db scale triggers my OCD....
I moved them back to the center of all 4 walls after that......still unsure where they will end up, only fixed one is the rear center.
I am open to putting the other 3 wherever they work the best.
post #21978 of 23115 Old 03-20-2017, 12:59 PM
Liked: 1307
RF impulse response is furthest RIGHT, no?
Michael
post #21979 of 23115 Old 03-20-2017, 01:11 PM
Liked: 4029
Michael
Yes, nice catch. Fixed, thanks.
post #21980 of 23115 Old 03-20-2017, 03:10 PM
artur9's Avatar
Quoted: 635 Post(s)
Liked: 222
I moved them back to the center of all 4 walls after that......still unsure where they will end up, only fixed one is the rear center..
I would do it Geddes-style. Leave that fixed one wherever it is. Then place one at the mid-point of one of the walls and adjust its phase and level to improve the response. Then repeat with the subsequent subwoofers but put them in random locations.
I was messing around last night with amps and ended up with the below.
Name:	new amp attempt.jpg
artur9 is offline
post #21981 of 23115 Old 03-20-2017, 04:17 PM
Liked: 4029
I see mention of Lyngdorf and Krell in the legend. Do you have this equipment? Are you using RoomPerfect?
And why the abrupt drop-off at 25Hz?
post #21982 of 23115 Old 03-20-2017, 04:55 PM
Quoted: 470 Post(s)
Liked: 340
NICE!
That was sort of my original plan.......sweep move, sweep move,sweep move, until the ideal locations were found........
I was thinking in a 6 inch grid pattern, sweep, check response....move 6 inches,sweep,check response, move 6 inches.....do this is a grid style thru all the available locations. Letting each sub end up where ever was best.
I enjoy all of this stuff, so hundreds of sweeps is fine by me, it is a hobby for fun.......probably spent over 10 hours yesterday sweeping and playing......changing settings,location,eq,room correction etc etc etc for all the locations.
Sweeping single subs, multiple subs etc etc etc.
post #21983 of 23115 Old 03-20-2017, 05:56 PM
artur9's Avatar
Quoted: 635 Post(s)
Liked: 222
Yes and yes. I have the Krell Foundation for HT and a Lyngdorf DPA-1 for 2 channel. Although the measurement was with Lyngdorf-only and RoomPerfect bypassed. RoomPerfect says it applies 4% correction, whatever that means, but I assume not much.
All my subs are small. None are rated to below 30Hz.
artur9 is offline
post #21984 of 23115 Old 03-20-2017, 05:58 PM
artur9's Avatar
Quoted: 635 Post(s)
Liked: 222
NICE!
Thanks. I am not as gleeful as you are with all the measuring but an enthusiast has to do what an enthusiast has to do.
BTW, it might be easier to place the sub in the MLP and move the mic around. Just saying....
artur9 is offline
post #21985 of 23115 Old 03-21-2017, 10:49 AM
PlasmaPZ80U's Avatar
Quoted: 2104 Post(s)
Liked: 628
So I measured my impulse response of all 5 speakers and sub, Room Correction off, bass management off, speakers 15-20,000Hz and LFE channel 15-300Hz with acoustic timing reference set to right surround speaker as it is closest to MLP. I left the speaker and sub distances at where YPAO set them, which is:
FL 7.2ft
FR 5.8ft
CC 6.2ft
SL 4.6ft
SR 4.4ft
SW 6.4ft (was 8.4ft before sw dist tweak but set at 6.4ft during these measures)
https://drive.google.com/file/d/0B2P...ew?usp=sharing (mdat file)
Issue is FL, FR, CC all are before 0ms and SL and SR are at 0ms. Why is that considering YPAO set these distances/delays and they are very close/matching tape measured distances?
Current Setup REW FR measures
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Sony SS-CS5 Surrounds, Cambridge S20 Rear Surrounds, Rythmik LV12R; PS4 Slim, Xbox One, Xfinity X1
PlasmaPZ80U is online now
post #21986 of 23115 Old 03-21-2017, 11:00 AM
Liked: 1307
Probably for the same reason I get different results using MCACC: the mic and placement are different.
Fortunately, I have 6 MCACC presets, so I can make changes and compare the results easily.
Michael
post #21987 of 23115 Old 03-21-2017, 11:11 AM
Liked: 628
Michael
Mic placement is very similar, but likely a few inches off in the XYZ space.
Anyhow, one related question I had about IR measures in general is must the non bass managed speaker sweeps start at 15Hz? My fronts are ported bookshelves and are rated -6dB at 48Hz and my surrounds are rated down to only 80Hz, unspecified dB point and are sealed sats.
Could I set the start frequency to 80Hz for all 5 speakers OR 15Hz start frequency, leaving bass management on but with sub plate amp off?
post #21988 of 23115 Old 03-21-2017, 11:48 AM
Liked: 4029
FL 7.2ft
FR 5.8ft
CC 6.2ft
SL 4.6ft
SR 4.4ft
Let's put this in perspective. The alignment difference between the FL and FR speakers is .22ft, or .2ms. That is insignificant. The alignment difference between the FL and the SR (the timing reference),is .93ft, or .83ms, also quite small. Keep in mind that the MCACC and the REW mic are different mics, and being able to place the REW mic in exactly the same spot at the MCACC mic would be extremely difficult. I think the differences you are seeing are due to mic placement variations, and I would not adjust the MCACC settings based on the REW measurements.
I was also very concerned with comparing REW impulse response measurements with the results from automated room correction. As a Dirac Live user, I am fortunate to be able to use the UMIK-1 mic for both the REW measurements and the Dirac calibration. I conducted this experiment:
1. Place the UMIK-1 in the MLP.
2. Run a one-position Dirac calibration and save the results to an 88A pre-set.
3. Using the 88A Utility program, observe the Dirac delays.
4. Without moving the mic, run the REW measurements for each channel.
5. Using the REW Impulse Response Overlay, observe speaker alignment with the Dirac delays.
The results are shown below. Without moving the mic, the alignment looks perfect, IMO. IOW, room correction does a fine job aligning speakers.
Name:	Time-alignment with Dirac.jpg
post #21989 of 23115 Old 03-21-2017, 11:51 AM
Liked: 1307
Now I just have to figure out how to keep my HEAD in exactly the same place every time.
Michael
ahblaza likes this.
post #21990 of 23115 Old 03-21-2017, 11:51 AM
Liked: 4029
Michael
As I recommended in my previous post, I would be inclined to accept the MCACC results with out change. You say you can "compare the results easily". I question whether you can hear minor delay adjustments by listening only. Maybe you have golden ears--I don't know.
ahblaza likes this.
Dayton , Dayton Audio , Room Equilizer Wizard Rew
