Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 738 - AVS Forum | Home Theater Discussions And Reviews
 1871Likes
post #22111 of 22115 Old Today, 01:46 PM
mjmcmahon67's Avatar
Quoted: 141 Post(s)
Liked: 61
Hi guys -
I was making some adjustments to my miniDSP after moving one of my subwoofers and ran into some unexpected results with REW. Here's what I did:
I setup REW with a timing reference (using the center speaker) and ran a frequency sweep
I then ran sweeps with the same center speaker as a timing reference for the front and rear subwoofers, intending to use the delay differences in my miniDSP setup.
Oddly - my initial sweep went wrong somehow: showing a delay of 7.5ms for the center speaker using the center speaker as a timing reference. That obviously doesn't make any sense. Any insight as to why this happened? I re-ran the test with the sweep running from 80Hz to 300hz (eliminating the subs) and ensured my receiver was set to pass the signal directly through.
Mike
PJ - Sony VPLHW45ES / Screen - EliteScreens 120" CineGrey / BD - Sony BDP-S5100 / AVR - Yamaha RX-A3030
Speakers - B&W 683S2/ HTM61S2 / 685 Surrounds / Fluance Signature Bi-polar Rear Surrounds/ PSA S1500 & XS15se subs
mjmcmahon67 is online now
post #22112 of 22115 Old Today, 01:48 PM
markus767's Avatar
Quoted: 3767 Post(s)
Liked: 1347
Originally Posted by mjmcmahon67 View Post
Hi guys -
Mike
Post .mdat.
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #22113 of 22115 Old Today, 01:56 PM
Quoted: 141 Post(s)
Liked: 61
I'd dumped the originals, but here's another test with the same issue - speaker 1 1 (Left Front) used as timing reference, yet shows a system delay??
zip file attached
post #22114 of 22115 Old Today, 02:21 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6897 Post(s)
Liked: 3829
OK, what are we looking at here? Hint: label your measurements if you expect feedback.
Name:	Impulse Overlay.jpg
AustinJerry is online now
post #22115 of 22115 Old Today, 03:30 PM
Quoted: 141 Post(s)
Liked: 61
Sorry Jerry - I thought I'd explained it thoroughly but obviously not. The first measurement is the reference timing - in this case the Front Left speaker. The second is the subwoofer using the front left as a timing reference. I was following the instructions provided here for measuring time delay - https://www.minidsp.com/applications...ing-time-delay
Under the section "Tabulate your results", it points out that you should have a zero System Delay for the first speaker - which would make sense when you're measuring the same speaker as you use for a time reference. In my case, the system delay showed 6.92ms for a system delay on the same speaker?
I've updated the .zip file with labels to help clarify things.
Thank you,
Mike
Dayton , Dayton Audio , Room Equilizer Wizard Rew
