Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 747 - AVS Forum | Home Theater Discussions And Reviews
 2100Likes
Old 04-24-2017, 07:51 AM
LastButNotLeast's Avatar
Quoted: 1689 Post(s)
Liked: 1303
So let's see some graphs!
BTW, what are you going to use to eq the subs?
Michael
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
Don't guess, measure: Getting Started With REW: A Step-by-Step Guide
LastButNotLeast is offline
Old 04-24-2017, 09:45 AM
EndersShadow's Avatar
Quoted: 568 Post(s)
Liked: 895
I'm trying to import the REW .txt file into my MiniDSP balanced 2x4. Each time I try I get this message: Your biquad in your input file is not correctly formatted.
I'm using the 2waySubAdv plug in.
Any thoughts?
My Setup | FS: Nothing right now
Quote: There exists, for everyone, a sentence - a series of words - that has the power to destroy you. Another sentence exists, another series of words, that could heal you. If you're lucky you will get the 2nd, but you can be certain of getting the 1st. - Philip K. Dick
EndersShadow is online now
Old 04-24-2017, 10:21 AM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 7158 Post(s)
Liked: 3993
Any thoughts?
As long as you select the 2x4 in the REW EQ tool prior to saving the .TXT file, it should work just fine. I do this frequently. Otherwise, I have no insight as to what might be happening.
AustinJerry is online now
Old 04-24-2017, 10:50 AM
Quoted: 568 Post(s)
Liked: 895
Here is the REW screen where I'm exporting the values to a file:
Here is what the text file with the EQ values looks like....
Filter Settings file
Room EQ V5.19
Dated: Apr 24, 2017 1:31:02 PM
Notes:
Equaliser: MiniDSP
XT32 actually off
Filter 1: ON PK Fc 66.5 Hz Gain -7.0 dB Q 3.09
Filter 2: ON PK Fc 50.8 Hz Gain -11.1 dB Q 2.78
Filter 3: ON PK Fc 36.1 Hz Gain -14.3 dB Q 3.26
Filter 4: ON PK Fc 23.4 Hz Gain -6.3 dB Q 9.93
Filter 5: ON PK Fc 17.9 Hz Gain 6.0 dB Q 2.92
Filter 6: ON PK Fc 16.4 Hz Gain -4.1 dB Q 2.00
Here is the error message:
Old 04-24-2017, 10:55 AM
gwsat's Avatar
Quoted: 2939 Post(s)
Liked: 3293
Michael
Don't receive my new subs until later this week so getting graphs that mean anything is going to have to wait. Because I now have REW setup with my receiver so that my subs will play the REW test tones, I will be ready to start EQing them after they are installed.
My Yamaha RX-A3060 has EQ subwoofer adjustments available for 4 bands for each sub. After I run a sweep in REW and identify the peaks and valleys in my room curve, I will manually adjust the subs’ EQ with the 3060. After that, I’ll run more sweeps and make more adjustments until the curve flattens out satisfactorily.
I haven’t given up on getting to the bottom of setting up REW for Mac OS to show discrete channels, one for each of my speakers. I’m not there yet but plan to keep trying to find a way to do it. I assume I wouldn’t need a MiniDSP 2X4 to do this. Is this right?
HT setup: Sony 75XBR X940D UHD HDR TV; Kaleidescape Strato Movie Server 6 TB; Yamaha RX-A3060 AV receiver; Sonamp 2-1 2channel 100W power amp; Crestron Control System; 2 Rythmik FV18 subwoofers, 6 Hsu HB-1 Bookshelf speakers, 1 Hsu HC-1 Center speaker, 4 Focal ICW8 in-ceiling Atmos speakers; Oppo UDP-203 4K HDR BD player; Mac Mini HTPC. TiVO Bolt 1TB DVR; TiVo Premiere Elite 2 TB DVR; Roku Premiere+
gwsat is online now
Old 04-24-2017, 11:33 AM
AV_mike's Avatar
Quoted: 96 Post(s)
Liked: 91
Room EQ V5.19
Notes:
Equaliser: MiniDSP
XT32 actually off
In the REW EQ screen you need to select "save filter coefficients to file" NOT "export filter settings as text". The resulting text file is very different.
Regards, Mike.
Marc Alexander likes this.
AV_mike is offline
Old 04-24-2017, 11:38 AM
Quoted: 568 Post(s)
Liked: 895
Regards, Mike.
Boom goes the dynamite!
Thank you kind sir!
Old 04-24-2017, 12:47 PM
JohnPM's Avatar
Quoted: 80 Post(s)
Liked: 51
Originally Posted by gwsat View Post
The good news, though, is that REW will send its test signals to all of my speakers.
What mode is your processor set to for the HDMI input? You may need to experiment with the mode to make multi-channel selection available.
JohnPM is offline
Old 04-24-2017, 01:05 PM
Marc Alexander's Avatar
Quoted: 1775 Post(s)
Liked: 1440
Correct, you do not need a MiniDSP. You once you have a sweep you can have REW generate a generic EQ text file for you which will help get you started with how to set the Yamaha PEQ filters. At least that is how I go about it.
Even if you never get it working where you can select the LFE channel individually as long as you can send sweeps through L&R you are fine. You can just raise the crossover to see a fuller sweep of the sub's response at the MLP.
Marc Alexander is online now
Old 04-24-2017, 01:10 PM
gwsat's Avatar
Liked: 3293
Thanks, I'll check it out the next time I hookup REW via an HDMI cable.
gwsat is online now
Old 04-24-2017, 01:44 PM
markus767's Avatar
Quoted: 3903 Post(s)
Liked: 1392
Jerry -- I found that earlier today but it doesn't apply to my version of REW: I am running REW V5.19 Beta 4. Despite what the caveat says, I could find no dialog box for multichannel output in the Measure dialog. The good news, though, is that REW will send its test signals to all of my speakers. It works the same way, whether I use AirPlay or an HDMI cable to connect my MBP to my receiver. Thanks for trying to help anyway.
Don't use AirPlay. Plenty of things can go wrong that way. Use HDMI instead.
Your Mac has several audio inputs and outputs. What did you select as audio output in REW preferences?
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
Old 04-24-2017, 02:30 PM
gwsat's Avatar
Liked: 3293
Markus -- Thanks for the advice. Although I was intrigued by AirPlay and experimented with it, I shifted to HDMI and have been using it most of the time lately. I haven't had a chance to experiment anymore with REW and my receiver today but will do so later today or tomorrow. Thank you for weighing in on my problem.
When I have connected my MBP to my receiver (a Yamaha RX-A3060) with an HDMI cable, should it show up as an output choice in the Sound settings for my MBP or do I have do something in REW first?
gwsat is online now
Old 04-24-2017, 02:38 PM
markus767's Avatar
Liked: 1392
You should see your AVR (or projector/TV) in both (Audio MIDI Setup app and REW).
Markus
Old 04-24-2017, 02:48 PM
gwsat's Avatar
Liked: 3293
Markus -- OK will check it out. Where can I find the "Audio MIDI setup app?" I saw it referred to in the REW for Mac tutorial but neither understood what it was nor where to find it.
gwsat is online now
Old 04-24-2017, 03:22 PM
markus767's Avatar
Liked: 1392
Applications > Utilities
Markus
Old 04-24-2017, 03:32 PM
JohnPM's Avatar
Quoted: 80 Post(s)
Liked: 51
Originally Posted by Marc Alexander View Post
Thank you everyone! It's so much clearer now. I had previously been using impulse response overlays but I thought the delay/distance display had eliminated the need… an Easy Button.
I have made a change for the next beta so that when using the acoustic timing reference the delay figure will be taken based on the start of the impulse response instead of the peak if the peak is more than 1 ms later. That may give better results when measuring subwoofers.
ahblaza and unretarded like this.
JohnPM is offline
Old 04-24-2017, 03:34 PM
Liked: 1440
Thanks John!
Old 04-24-2017, 03:47 PM
Gorilla Killa's Avatar
Quoted: 547 Post(s)
Liked: 599
I doubt the 96Khz means much for the sub channel. The 2x4HD is limited to 2v out, while the 2x4 balanced has switchable 2v or 4v. So you need to assess the voltage output that will be required by your subs, and whether the placement of the subs in the room will require a delay greater than 7.5ms, which is the 2x4's limit. As for more plug-in's, you only need one, the Advanced 4-Way.
This is the Achilles heel of these units. I encourage anyone who has the time to shoot them a email about raising this limit, Ive sent quite a few. I get a canned answer every time. They may just roll there eyes every time they see its me
Gorilla Killa is offline
Old 04-24-2017, 04:25 PM
gwsat's Avatar
Liked: 3293
Markus -- OK, found it! Will see what I can do with it once I have made an HDMI connection to my receiver. Will report after that. The info you have given me looks like a huge breakthrough, though. Will report what happens here. Once again, thanks to you, Jerry, and the others who have provided such valuable information about the intricacies of REW.
gwsat is online now
Old 04-25-2017, 06:07 AM
gwsat's Avatar
Liked: 3293
^ ^ ^ @markus767 I followed your instructions and was able to use REW and the Audio MIDI Setup app to give me control over all of my 7.1 speakers in REW. I ran several test sweeps of my current sub with REW and am now satisfied that I have REW configured in a way that will allow me to EQ my subs when I receive them later this week.
I have taken the advice you and Jerry gave me and given up on using AirPlay to connect REW to my receiver. Am pretty sure it works but wifi is wifi so I agree that going the HDMI route is by far the better course.
Thanks again to you and Jerry for your invaluable assistance.
gwsat is online now
Old 04-25-2017, 06:28 AM
Liked: 3993
Atta boy! We knew you could do it. Time to get down to some serious work!
gwsat likes this.
Old 04-25-2017, 08:26 AM
confinoj's Avatar
Quoted: 222 Post(s)
Liked: 121
About to get started with REW. I know the guide say not to place mic on sofa cushions but my goal is to see what the frequency response is at different seating positions in our living room as subjectively I'm noticing very large variations in mid bass and ultra low bass. So should mic stand just be on floor at ear height as close as possible to seating positions? Thanks.
Samsung PN59D8000 | Denon AVR-X4300H | Tivo Roamio via OTA | ATV4 | Media PC running Plex server/Plex Media Player
Front L/R Polk RTiA3 | Center Polk CSiA6 | Front Heights Polk RCi55 | Surround Polk OWM3 | Sub SVS PC12-Plus x 2
confinoj is online now
Old 04-25-2017, 09:33 AM
gwsat's Avatar
Liked: 3293
My new Rythmik FV18 subs are in town and scheduled for UPS delivery "By End Of Day." I'm looking forward to getting them setup and configured.
Before deploying REW, one of the Wise Men in the Yamaha RX-AX060 thread told me that before using REW I should run YPAO three times. First with one sub connected, the second with the other sub connected and, finally a third time with both subs connected. Then, finally, it will be time to roll out REW. Given the learning curve I have had to climb in order to become familiar enough with REW for it to be usable, the need to run YPAO three times doesn't bother me much.
gwsat is online now
Old 04-25-2017, 11:22 AM
Liked: 3993
Strange. I would think each YPAO would start out with fresh setting, without any recollection of previous runs. Sounds like the advice you received is hocus-pocus. Did you challenge his reasoning?
The typical approach to using REW to EQ the sub channel would be:\
1. Turn off YPAO.
2. Measure the combined sub signal, 15-300Hz.
3. Develop and apply the manual sub EQ based on the REW measurements.
4. Run YPAO.
5. Measure results with REW.
unretarded likes this.
Old 04-25-2017, 11:26 AM
Liked: 3993
Best to use a boom mic stand. Position the mic tip at ear level. Keep the mic 12-18" away from seat backs. Make sure there is an unobstructed line-of-sight to all speakers (i.e. the seat back should not block anything).
Old 04-25-2017, 11:56 AM
Liked: 1303
Why eq flat?
Why eq flat when the Fletcher-Munson curves (AIUI) show that our hearing is anything but "flat."
Wouldn't it be possible to load a house curve into REW to change the target curve to reflect this?
Wouldn't it sound "better"?
Michael
Old 04-25-2017, 12:38 PM
markus767's Avatar
Liked: 1392
[I...]
Michael
It doesn't matter whether the "sensitivity" of our hearing is flat or changes with frequencies. The hearing of the mixing/mastering engineer is like yours. So when his speakers we're flat yours should also be flat. What really matters with regards to equal loudness curves is the difference BETWEEN the curves when you listen at a level that is different from reference (whatever that is when talking about music mixes as only movie mixes know a standardized reference level).
Markus
Old 04-25-2017, 12:45 PM
Liked: 1303
I understand that the curves represent differences at different volumes, but the overall "shape" of the curves is similar. That's what I was looking at as a target curve.
So the "flat" we're measuring already considers that.
Many thanks!
Michael
Old 04-25-2017, 02:30 PM
Foggy1's Avatar
Quoted: 89 Post(s)
Liked: 45
Would this pertain to subs positioned behind the couch as well? Is it OK for the couch back to block subs or should the mic be raised to a height which allows a clear path?
Foggy1 is offline
Old 04-25-2017, 02:37 PM
Liked: 3993
The recommendation specifically pertains to mains speakers with directional mid and high frequency drivers. Clearly, a direct line of sight should be maintained for these speakers.
Subs, however, are entirely different. The low frequencies are not directional and simply "fill the room". So I would say for the subs, keep the mic tip at ear height even though the seat back may be blocking the sub. As always, it is a good idea to experiment to make sure this recommendation works for you.
Dayton , Dayton Audio , Room Equilizer Wizard Rew
