Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 774 - AVS Forum | Home Theater Discussions And Reviews
 2165Likes
post #23191 of 23216 Old 06-16-2017, 09:00 AM
gwsat's Avatar
Quoted: 3043 Post(s)
Liked: 3407
Originally Posted by PlasmaPZ80U View Post
Brian Ding of Rythmik Audio (creator of their subs) mentioned that having subs with deeper extension can make the sound stage larger in all 3 dimensions if the music recording has even a little bit of very low frequencies. That's why most of those subs play down to 12-14Hz before room gain.
Of course, the speakers and their placement is another very important aspect of it and early side wall reflections could subjectively help.
I can attest to the accuracy of what Brian Ding said. As some here may recall, I recently bought two Rythmik FV18 subwoofers. After I got them dialed in, when listening to TrueHD Atmos soundtracks I noticed a dramatic improvement in the spaciousness of what I was hearing. All of a sudden, I felt as if I was in a bigger room. The FV18’s tuning frequency is 12Hz. Needless to say, I have also been well pleased by the LFE I have heard. Haven’t listened to any two channel music yet, so don’t know how much my subs might help it.
HT setup: Sony 75XBR X940D UHD HDR TV; Kaleidescape Strato Movie Server 6 TB; Yamaha RX-A3060 AV receiver; Sonamp 2-1 2channel 100W power amp; Crestron Control System; 2 Rythmik FV18 subwoofers, 6 Hsu HB-1 Bookshelf speakers, 1 Hsu HC-1 Center speaker, 4 Focal ICW8 in-ceiling Atmos speakers; Oppo UDP-203 4K HDR BD player; Mac Mini HTPC. TiVO Bolt 1TB DVR; TiVo Premiere Elite 2 TB DVR; Roku Premiere+
gwsat is online now
post #23192 of 23216 Old 06-16-2017, 09:29 AM
PlasmaPZ80U's Avatar
Quoted: 2122 Post(s)
Liked: 636
I can attest to the accuracy of what Brian Ding said. As some here may recall, I recently bought two Rythmik FV18 subwoofers. After I got them dialed in, when listening to TrueHD Atmos soundtracks I noticed a dramatic improvement in the spaciousness of what I was hearing. All of a sudden, I felt as if I was in a bigger room. The FV18?s tuning frequency is 12Hz. Needless to say, I have also been well pleased by the LFE I have heard. Haven?t listened to any two channel music yet, so don?t know how much my subs might help it.
Mine is 19Hz tune but in my small nearfield setup with medium to large sized bookshelves I get a huge sound stage for my 1150 cubic foot room. I am literally 2m from the fronts and surrounds.
PlasmaPZ80U is online now
post #23193 of 23216 Old 06-16-2017, 09:31 AM
Liked: 636
My Rythmik LV12R has a knob labeled phase/delay and the extreme ends are labeled 0 degrees/0ms and 180 degrees/10ms.
That's an all-pass filter.
So is it identical to sw distance in AVR?
post #23194 of 23216 Old 06-16-2017, 10:32 AM
markus767's Avatar
Quoted: 3987 Post(s)
Liked: 1405
No. https://en.wikipedia.org/wiki/All-pass_filter
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #23195 of 23216 Old 06-16-2017, 03:12 PM
grendelrt's Avatar
Quoted: 141 Post(s)
Liked: 77
Hey guys I got my Umik-1 in and started playing with REW today. I am waiting on an adapter to use my boom mic stand, so today I just familiarized myself with the software. I read the excellent getting started faq and then worked through taking some measurements and had a few questions if anyone could help.
1. I bought my mic from amazon (unfortunately didnt read about CSL until after my mic shipped) and downloaded the factory 90deg file from minidsp.com. Am I correct in my reading that I don't do anything but use this file, no calibrations necessary? Also when I am taking SPL readings from individual speakers using the pink noise should I also use the 90deg file?
2. This part in the faq I was a little confuse, part a says to use the center channel, part d says to click sub cal, which then used my sub, so which should I use to get my spl reading?
a. Set REW output to output to the center channel (HDMI3).
b. Set up the mic at the MLP at ear level.
c. Open the REW SPL Meter and click the red button to start measuring SPL.
d. Open the REW signal generator, select Pink Noise, Subwoofer Cal, and set the output to
-12dBFS (this is the same level as for the measurement sweeps).
3.Do most people stick with a Length of 256k?
4. Should i use a Timing reference?
5. When running my measurements and spl I did:
a. Audyssey Reference
b. Dynamic Vol Off
c. Dynamic EQ Off
d. Buttkickers Off
Anything else I should turn off or on?
Thanks for the help, hoping to get some proper measurements this weekend.
grendelrt is online now
post #23196 of 23216 Old 06-16-2017, 03:52 PM
Quoted: 486 Post(s)
Liked: 362
I posted a vid once, no idea how to search for it, that showed a guy, I think from the rocky mountain audio festival giving a lecture on setting the front sound stage........so it felt like the person was in the room etc etc etc.
Wish I could rember what/where it was.
Link to budget Home Theater build
http://www.avsforum.com/forum/19-ded...i-version.html
unretarded is online now
post #23197 of 23216 Old 06-16-2017, 03:53 PM
gwsat's Avatar
Liked: 3407
Yeah,I'm about the same distance, ~7 feet, from my front sound stage and subs too.
gwsat is online now
post #23198 of 23216 Old 06-16-2017, 04:08 PM
Quoted: 486 Post(s)
Liked: 362
Originally Posted by artur9 View Post
That sounds like you're talking about bass extension (lower frequency) rather than the illusion of instruments behind the plane of the speakers. Or am I misunderstanding what you are suggesting?
In a sense, I hanker for what some reviewers claim to achieve: the wall behind my speakers as I face them listening disappears as if David Copperfield were present. ;-)
I am not certain such a thing ever really happens.
This guy will walk you thru it........
Only had to go about 2000 vids back in my youtube history to find it....
post #23199 of 23216 Old 06-16-2017, 10:29 PM
artur9's Avatar
Quoted: 640 Post(s)
Liked: 223
I don't know but it did remind me to rake my speakers back a bit more. It was a fun/interesting video what with all the guy's anecdotes.
unretarded likes this.
artur9 is offline
post #23200 of 23216 Old 06-18-2017, 07:05 AM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 7282 Post(s)
Liked: 4053
This guy reminds me of Jim Smith, and is just about as useful as some of Jim Smith's tips, especially how to "voice" speaker setups. I think I'll stick to Toole for my advice for now.
ahblaza, andyc56 and unretarded like this.
AustinJerry is online now
post #23201 of 23216 Old 06-18-2017, 09:26 AM
LastButNotLeast's Avatar
Quoted: 1713 Post(s)
Liked: 1318
He has a YouTube video, too.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
Don't guess, measure: Getting Started With REW: A Step-by-Step Guide
LastButNotLeast is offline
post #23202 of 23216 Old 06-18-2017, 09:45 AM
Liked: 4053
Your point?
post #23203 of 23216 Old 06-18-2017, 11:21 AM
Liked: 1318
Just for those who desire input from a (more) reliable source.
And don't have the patience to read the book.
Michael
gwsat likes this.
post #23204 of 23216 Old 06-19-2017, 05:41 AM
soulcougher73's Avatar
Quoted: 18 Post(s)
Hey all. I just got my umik-1 from CSL the other day and installed REW and ASIO per the guide. When i am trying to find my noise floor should i be Z weighted? My SPL seems a lot higher than the guide (assuming i'm understanding all this. not the most technical person when it comes to speakers/sound). I was at around 59-63 SPL with my HVAC turned off. The guide mentions the average noise floor is about 50. The other question i have is if it is indeed 60 noise floor do i then need to add at least 40 to that per the guide to get up to 100 SPL on the following step? Should my HVAC be on when i'm trying to fine my noise floor?
All this is daunting to me. So hopefully i can work through it slowly and maybe actually understand what im doing lol
soulcougher73 is offline
post #23205 of 23216 Old 06-19-2017, 06:20 AM
Liked: 4053
I am assuming you are using the proper calibration file, and that the file has the mic's sensitivity parameter. This is covered in the guide.
With the mic plugged in, open the REW RTA window, configure the measurement for 32 averages 10-20KHz, and allow the average response to be generated. The response curve should show which frequencies are contributing to the high noise floor. Low frequencies are a common cause. Post a screenshot here so we can see what you are observing.
You don't absolutely need to measure 40dB higher than the noise floor if you find that too loud. It is just a general guideline.
post #23206 of 23216 Old 06-20-2017, 04:19 AM
cyberkryten's Avatar
Quoted: 16 Post(s)
Originally Posted by cyberkryten View Post
I thought that, but even adding a delay didn't seem to cure the timing reference being a click, though I'm not sure if REW livens up the output immediately and then delays, or (more likely) just puts it at the start. Are there any other options that might help (I've noticed it on both my Yamaha CXA5000 and Arcam AV860)
I might have missed it but I didn't see any suggestions of how to increase the delay between REW starting a signal on the HDMI output and the timing reference being sent to give an AV receiver more time to 'lock on' to the input signal on the HDMI.
Are there any options which do that? I can't find anything in the menus as setting 'Start Delay' seems to delay the entire process, so just adds a few seconds before REW starts to do anything on the HDMI output.
cyberkryten is online now
post #23207 of 23216 Old 06-20-2017, 05:09 AM
JohnPM's Avatar
Quoted: 83 Post(s)
Liked: 51
There isn't any way to do that, but I've added a feature in the next beta that sends a couple of seconds of an effectively silent (-150 dBFS) sine wave before the sweep starts, that will hopefully help.
JohnPM is offline
post #23208 of 23216 Old 06-20-2017, 07:22 AM
Liked: 636
John,
For the MiniDSP, is there any difference between save filter coefficients to file and export filters as text?
post #23209 of 23216 Old 06-20-2017, 08:27 AM
Liked: 4053
John,
From the REW Help file: "The MiniDSP equaliser setting supports the same filter types and resolutions as the Generic setting, but for 6 filters. It is aimed at the MiniDSP plug-in Advanced mode, which allows filters to be specified by their biquad coefficients. The Save Filter Coefficients to File action writes the filter coefficients to a file in a format suitable for use with the MiniDSP software".
If you run the "save filter coefficients to file" and "export filters as text" (as shown below), you would see that the files are very different.
Name:	Filters as text.JPG
ID:	2196385   Click image for larger version
Name:	Save coefficients.JPG
post #23210 of 23216 Old 06-20-2017, 09:01 AM
Liked: 636
John,
Thanks, I usually use the save filter coefficients to file option. So, I guess I'm doing it correctly?
FWIW, in the MiniDSP plug-in the text for each PEQ band under advanced looks like the 2nd image you attached.
post #23211 of 23216 Old 06-20-2017, 09:59 AM
Liked: 4053
The second image is indeed the save filter coefficients file, so that should not be a surprise.
post #23212 of 23216 Old 06-20-2017, 10:30 AM
Liked: 636
^I see.
post #23213 of 23216 Old Today, 01:14 AM
Roger Dressler's Avatar
Quoted: 1576 Post(s)
Liked: 761
Should work! Can also use dither noise.
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is online now
post #23214 of 23216 Old Today, 05:00 AM
JohnPM's Avatar
Quoted: 83 Post(s)
Liked: 51
That's what gets produced in practice since the sine wave generator is dithered by default.
JohnPM is offline
post #23215 of 23216 Old Today, 10:49 AM
Quoted: 16 Post(s)
Thanks John, I'll keep an eye out for it
post #23216 of 23216 Old Today, 11:29 AM
tjcinnamon's Avatar
Quoted: 1044 Post(s)
Liked: 251
REW to test distortion
Hi All,
I'm getting some distortion in my Prestige F75's and (I THINK) one speaker seems louder than the other. I have some REW experience, a measurement mic, and multi-meter.
The Audyssey EQ graphs don't look too different and I have the fronts set at the same volume -1dB. If I lean toward the tweeter at a -20dB, I can hear a little static so it's not the cleanest signal.
This distortion generally happens during bass scenes but is not consistent. I generally listen with MV at -20dB at max. I have the crossovers set to 60Hz and theses speakers range goes down to 42Hz. I've had it happen with the cross-over at 80Hz as well.
So it could be the AVR, the speakers, or the speaker wire (banana plug).
1) Thoughts on this? How can I get this to consistently replicate
2) How can I test to see if they output coming out the same?
3) Is there a way to test for distortion?
I'm leaning speaker-wire then AVR as the culprits.
Joe
Marantz 7010 for 7.2.4
2 x Paradigm Prestige 75F's
1 x Paradigm Prestige 45C
8 x Paradigm CI Pro P65-R's
Sub 2 x Rythmik LVX12's
TV: LG 65B6
tjcinnamon is online now
Dayton , Dayton Audio , Room Equilizer Wizard Rew
