Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 776 - AVS Forum | Home Theater Discussions And Reviews
 2175Likes
Old 06-26-2017, 10:59 AM
citsur86's Avatar
Quoted: 1385 Post(s)
Liked: 566
Originally Posted by grendelrt View Post
You can run tops by switching physical lines on the receiver with one of the other speakers like surrounds but I didn't put that effort in. I just wanted spl matching so I ran atmos test tones and measured in rew with umik1 against the other speakers, audyssey was spot on with front top levels and my top rears were slightly too low.
Sent from my SM-G920V using Tapatalk
I manually went in and tweaked speaker volumes following Audyssey last night based on my own hearing and preference. I tend to like the surrounds and rear surrounds louder than Audyssey sets them. I boosted the Tops gently as well. With eyes closed, speaker to speaker, it sounded about even to me when I was done.
citsur86 is offline
Old 06-26-2017, 11:52 AM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 7317 Post(s)
Liked: 4073
Originally Posted by citsur86 View Post
Yes. They were excessively high and unmoving. Each time I started REW and the SPL meter it would say (and stay static) at 115db, 160db, 130db, etc. I thought the Mic was broken so I grabbed my Macbook which also has REW installed and configured (though I never use it for taking measurements), and the Mic worked fine. So back to the Windows 10 Laptop. I found online you can troubleshoot Windows Recording Devices and the troubleshooter got to a screen where it says "Fixed - Mic Unmuted". Then everything was fine. Not sure how it got muted in the first place. Definitely spend an hour troubleshooting that last night though. Somehow it being muted cause the high db readings to appear.
Very strange. Let's make sure we remember this in case someone else experiences it. Now let's get busy again...
ahblaza likes this.
AustinJerry is online now
Old 06-26-2017, 04:36 PM
Roger Dressler's Avatar
Quoted: 1587 Post(s)
Liked: 773
Originally Posted by RockDawg View Post
I just gave this a go for the first time. I've attached my results an they look hideous.
It helps to apply some smoothing. Click >Graph at top left. Select something like 1/12.
They do not look too bad after that.
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is offline
Old 06-26-2017, 05:40 PM
Liked: 4073
I just gave this a go for the first time. I've attached my results an they look hideoous. I took measurements at each of my front 3 seats and at each seat i took measurements of the left, right and then both speakers. My dual subs were enabled for every measurement. Any and all feedback is appreciated.
https://www.dropbox.com/s/1w05ntxpsj...-2017.zip?dl=0
First of all, a tip that will make measurements easier to recognize. Rather than identify the measurement by typing in a description in the text box, identify the measurement by using the smaller box at the top (as per the attached example). Why? Because the description will then appear in the Legend, making identification easier.
As for the measurements, the large swing between 70Hz and 100Hz is an issue. What is the crossover? Did you try the sub distance tweak?
ID:	2205689   Click image for larger version
Old 06-26-2017, 06:31 PM
RockDawg's Avatar
Quoted: 83 Post(s)
Liked: 36
Crossover is 80Hz. I must have missed it... what is the sub distance tweak?
Sent from my SM-T700 using Tapatalk
RockDawg is offline
Old 06-26-2017, 08:45 PM
Liked: 4073
The sub distance tweak improves the time alignment between the subs and the mains by adjusting the sub distance parameter, re-measuring frequency response in the crossover region, and repeating until the flattest frequency response is obtained.
The definitive sub distance tweak guide can be found here: Sub Distance Tweak
Old 06-27-2017, 06:21 AM
artur9's Avatar
Quoted: 642 Post(s)
Liked: 227
That's one change I'd like to see made to REW. I would like that text field to appear in the measurement pop-up because sometimes I forget to go back and change it after the measurement.
artur9 is offline
Old Yesterday, 02:07 PM
Quoted: 266 Post(s)
Liked: 42
Using 5.3 version of REW and having one small issue. Each time I change the channel and take measurement, it doesn't generate the tone from starting frequency. Instead it starts a bit later and produced a different sound from speaker as well. But if I cancel the first measurement and take another measurement, it works fine. Basically, each time I change the input channel, I have to cancel the first measurement. Then I can take as many as I want for the same channel. I have to keep cancelling each time I change the channel I'm measuring.
Any idea why is that happening?
harrisu is offline
Old Yesterday, 02:15 PM
markus767's Avatar
Quoted: 4001 Post(s)
Liked: 1406
Version?
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
Old Yesterday, 04:53 PM
ahblaza's Avatar
Quoted: 1675 Post(s)
Liked: 1775
You need to get the latest version, you're very behind, check here http://www.roomeqwizard.com/beta.html
and click the Nirvana web site link and sign up with username and password and you could download the latest and current Beta version of REW.
I still experience what you're describing every now and then myself for some unknown strange reason even with the most up to date version as well. I can't explain why it happens but it's not only you or unique. I posted about the very same thing a year ago and never really got an answer.........
ahblaza is offline
Old Yesterday, 09:59 PM
WormInfested's Avatar
Quoted: 80 Post(s)
Liked: 58
working with three subs in my spare room now. svs pb-10nsd and two mfw 15's. mfw subs in opposite corners and the svs front left. this is my latest sweep. not sure how i got it to this point but was having phase and delay issues. all three weren't cooperating. now it looks magnificent. just need to watch maybe mad max fury road to see how it sounds. no smoothing. my mfw subs hit down to 9 or 8hz in my 10x10 room.
Pioneer Elite SC-05
JBL Studio S312II fronts, JBL Studio S10IIs mid and S8IIs rear.
Single JBL S38 center channel
Power Sound Audio V1800, 2 MFW-15's, DIY ported UM18-22
Oppo BDP-103
BenQ W7500 & Silverticket 110" matte white 16:9
WormInfested is offline
Old Today, 05:51 AM
Liked: 4073
The part you are showing looks pretty good. But we are used to seeing a measurement up to 300Hz for low frequencies so that the transition from subs to mains is displayed. Perhaps you could post a measurement of subs+mains to 300Hz for some more meaningful feedback?
Dayton , Dayton Audio , Room Equilizer Wizard Rew
