Subwoofer cable wall plate - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-06-2013, 03:02 PM - Thread Starter
flickhtguru's Avatar
Liked: 110
I'm buying the wall plates for the new home I'm building. I will have a 7.2 system in our 1st floor livingroom. I am getting a 7.2 - 2 gang wall plate, this plate has connections for 2 subs. My question is what type of plate do I use at the other end? (the end where the sub will actually be in the room) I need the rear of the plate to have threaded coax cable type connection and then the front needs RCA connecion.
I'm buying my wire and plates from monoprice.com. Thanx.
Shawn
flickhtguru is offline
post #2 of 6 Old 01-07-2013, 06:35 AM
Ratman's Avatar
Quoted: 1275 Post(s)
Liked: 1024
Ratman is online now
post #3 of 6 Old 01-07-2013, 07:08 AM - Thread Starter
Liked: 110
^^^ Thanx... Duh, I never thought of buying a blank plate and putting the correct connector in it. I was looking for plates already made up. I will use this link. Thanx again.
Shawn
post #4 of 6 Old 01-07-2013, 09:18 AM
commsysman's Avatar
Quoted: 963 Post(s)
Liked: 521
You could also buy a plate with a BNC connector on it; that is what I would do.
commsysman is online now
post #5 of 6 Old 01-07-2013, 03:50 PM
Ratman's Avatar
Liked: 1024
Why? Then you would need a F connector on the back, then a BNC to RCA adapter in the front.
post #6 of 6 Old 01-08-2013, 07:51 PM
Wiendog's Avatar
Here's what I bought and it should work. I couldn't find a single RCA connector for my sub so I got this:
http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10425&cs_id=1042502&p_id=2999&seq=1&format=2
Wiendog is offline
