2 channel placement - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 01-07-2013, 10:55 AM - Thread Starter
Hifisound's Avatar
Quoted: 100 Post(s)
I recently found a new 2 channel placement by which I feel the the speakers disappear more and a beter stereo image is created.
Here is the diagram :
Earlier I used to sit at point A and the speakers were firing straight
While experimenting a bit I toed in the speakers to point at A and moved myself to B.
This was quite good listening experience and felt the stereo image was much better than A
Is this is classic nearfield placement ? Or a similar experience can be achieved in another placement as well.
I tried this with my dynaudio contours 1.8 mkii and even my smaller Audioengines A2s (although the distances were proportionally smaller) and got similar results.
Any similar experiences from other ? any thoughts ?
Or is it theoretically a wrong placement ?
Hifisound
Hifisound is online now
post #2 of 12 Old 01-08-2013, 11:43 AM - Thread Starter
Hifisound's Avatar
Quoted: 100 Post(s)
Any thoughts ?
post #3 of 12 Old 01-08-2013, 12:06 PM
Ethan Winer's Avatar
Quoted: 264 Post(s)
Liked: 359
Originally Posted by Hifisound View Post
moved myself to B ... and felt the stereo image was much better than A
Yes, this makes sense because you get more of the direct sound from the speakers, and less of the reflected sound from the room. For even better stereo imaging and overall clarity, you should consider at least a little acoustic treatment. This will get you started:
Acoustic Basics
--Ethan
Ethan Winer is offline
post #4 of 12 Old 01-08-2013, 12:15 PM
BarracudaDelGato's Avatar
Any thoughts ?
When I started getting into hi-fi (early eighties), rolleyes.gif the recommended LP was at the vertex of an equilateral triangle - all 60° angles. Moving further away from the line connecting the speakers was considered OK, but getting closer to it was frowned upon.
I still follow that old bit of advice, but TBH I am not sure if it's still the consensus. smile.gif At your "B" LP, the angle to the speakers is 90° (quite a bit wider than 60°).
A minor point, but I think that the speaker vertices should be measured from the middle of the front panel, not from inside the cabinets.
BarracudaDelGato is offline
post #5 of 12 Old 01-08-2013, 12:35 PM - Thread Starter
Hifisound's Avatar
Quoted: 100 Post(s)
So for listening from position B, what will be bare minimum treatment required ? I guess side wall (and ceiling) absorbing panels for early reflection will not be required ?
post #6 of 12 Old 01-08-2013, 12:40 PM - Thread Starter
Hifisound's Avatar
Quoted: 100 Post(s)
What would be reason for not suggesting to move closer ?
post #7 of 12 Old 01-08-2013, 12:43 PM
Quoted: 264 Post(s)
Liked: 359
It all helps. Reflection points are important, as are bass traps. A little helps a little, a lot helps a lot. Though you don't need to cover everything!
--Ethan
post #8 of 12 Old 01-08-2013, 04:19 PM
commsysman's Avatar
Quoted: 985 Post(s)
Liked: 526
If you learn what the exact dispersion pattern of your tweeters is, you can set things up with a lot more knowledge and that will help.
Some tweeters have a very narrow dispersion pattern in the vertical plane, which makes the height of your ears relative to the tweeter very critical (correction can be made by tilting the front of the speaker upward in some cases).
Some have a limited horizontal dispersion pattern, which makes the "toe-in' of the speakers critical.
Any discussion about this subject is not going to be productive until you have more detailed information about each tweeter, and apply it properly.
commsysman is offline
post #9 of 12 Old 01-08-2013, 10:12 PM - Thread Starter
Hifisound's Avatar
Quoted: 100 Post(s)
Let me check where I can find that data for my Dynaudio Contours 1.8mkii and Audioengine A2 tweeters (Dynaudio has not responded to one such similar earlier request)
post #10 of 12 Old 01-08-2013, 10:27 PM - Thread Starter
Hifisound's Avatar
Quoted: 100 Post(s)
--Ethan
But in such a nearfield position (where direct sound is much more than reflection) what should be the priority for ? Side+ceiling or behind speaker wall ?
post #11 of 12 Old 01-08-2013, 10:45 PM
My memory is not what it used to be... If I am not mistaken, the reason given was that the image would suffer. This is ironic, as you find image improves by getting closer. Ethan's explanation makes sense though.
Another factor could be that a 60° (or narrower) angle allows to sit a little further away from the speakers. In your B example you are sitting less than 6ft from the speakers. In a smaller space this could be more of a problem.
post #12 of 12 Old 01-09-2013, 11:40 AM
Quoted: 264 Post(s)
Liked: 359
The only way to know is to measure your room:
Room Measuring Primer
Then you'll know exactly how damaging the reflections are. But no matter how close you are to your speakers, you still have many peaks and deep nulls at bass frequencies.
Also, the front wall behind your speakers is mostly irrelevant if you have normal box-type speakers that send sound forward only. More on that here:
Front Wall Absorption
--Ethan
