Towers with built in subs - do they require a X.2 receiver? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-07-2013, 12:27 PM - Thread Starter
Spencer740's Avatar
Hey everybody,
I have been reading around these forums for a while now and finally got around to making my first post. Cheers to everyone for all of the helpful information so far. I have just recently upgraded my 15yr old home theater speakers and have a few questions about some of the setup. I grabbed a great deal on a new receiver and slightly used speaker system, so here's what I'm working with:
Denon AVR-1613
Definitive Technology BP8060ST fronts
Definitive Technology CS8080HD center
Definitive Technology SR8080BP surrounds
and a lingering baby Mirage nanosub - working out a deal for the Deftech Supercube I (or would be open to suggestions in the <$400 range)
I have a few questions about how I'm supposed to connect everything here, so I'll just start by listing off my main questions:
1. I bought the Denon receiver before deciding on this speaker setup - Can the AVR1613 handle these speakers or am I doing them a disservice by not getting a more powerful receiver?
2. Seeing as the BP8060 fronts have integrated 300W subs, do I need a receiver that is either 7.2 or 9.2 to run the LFE connections, or do the standard High Level (red/black) inputs work well enough?
I'm sure I'll have another question or two as I get everything fully connected, but thought I'd start here. Thanks for any and all input here. I hope this is in the correct section, feel free to move it to the appropriate location if not.
Cheers,
Spence
Spencer740 is offline
post #2 of 6 Old 01-07-2013, 12:50 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Originally Posted by Spencer740 View Post
Hey everybody,
Denon AVR-1613
This is a 75 wpc AVR. One of the most powerful AVRs I know about is 150 wpc which is only 3 dB more. It takes 10 dB (10x more power) to create the perception of being twice as loud, but AFAIK there are no 750 wpc AVRs .
The BP8060 section that requires power from your AVR has 92 dB/W sensitivity which is a little above average.
Any other questions need to be settled by actual power measurements in your listennig room because they depend on its acoustics and your preferences for loud sound.
It seems like you have enough power in the AVR.
Your BP 8060 speakers have a RCA jack LFE input that in your case should be hooked up to the LFE output of your receiver. I would recommend telling your AVR that the BP8060s are small, and initially try crossing them over at 80 Hz.
Your receiver has Audyssey Multieq that you need to work with.
arnyk is offline
post #3 of 6 Old 01-07-2013, 01:11 PM - Thread Starter
Spencer740's Avatar
Thanks for the great response/advice! Though I guess I'm still confused with the LFE input/output. Here is a link to the connections on my receiver http://usa.denon.com/Assets/images/products/AVR-1613/EL_de_avr1613_e3_bk_re_bg001_lo.jpg Seeing as each tower has an LFE input, how do I get them both connected? Is there a splitter or something for that Subwoofer connection, or do I need a receiver that has 2 sub connections?
post #4 of 6 Old 01-07-2013, 03:14 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
LFE = "Subwoofer" on the back of your receiver.
It is very easy to connect 2 subwoofer inputs to one output with 2 or 3 RCA cables and one of these:
http://www.bhphotovideo.com/c/product/408215-REG/Hosa_Technology_YRA_104_RCA_Male_to_2.html
or with 3 cables:
http://www.cablesonline.com/1fpronercafe1.html
arnyk is offline
post #5 of 6 Old 01-08-2013, 08:47 AM - Thread Starter
Spencer740's Avatar
Will there be an issue with power handling if you split the connection? And what if I upgrade my freestanding sub - can you split one connection 3 ways without losing power to any of the subs?
post #6 of 6 Old 01-08-2013, 08:58 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
No, this is a line level (RCA) connection and the power involved is always minimal. A typical RCA jack output on the back of a receiver can drive at least two RCA jack inputs no sweat.
3 or 4 subs shouldn't be a problem. 10 or 100 might be cruising for trouble.
arnyk is offline
