Dust covers for 6.35mm stereo jacks? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-08-2013, 04:37 AM - Thread Starter
Barbarian887's Avatar
My cd player and receiver both have phone jacks that aren't in use atm, and I want to keep any dust from getting in.
Right now I'm covering them with a tiny piece of paper anchored with electrical tape, crude and looks tacky as hell.
Can I buy some kind of dust plugs or do I need to get creative?
Barbarian887 is offline
post #2 of 4 Old 01-08-2013, 05:04 PM
commsysman's Avatar
Quoted: 963 Post(s)
Liked: 521
Actually, that 6.35mm is normally referred to as 1/4 inch...lol.
I would get some small pieces of 1/4 inch wood dowel, maybe 1 inch long, and just insert them part way in the hole when it is not in use. plastic would also work fine if you can find the right size rod and cut it to length.
You could even take an unused phone plug and cut it off very short and put it in the hole.
commsysman is offline
post #3 of 4 Old 01-08-2013, 05:49 PM
Bigus's Avatar
Quoted: 196 Post(s)
Liked: 222
Moddiy.com has nice plastic plugs for just that purpose for a buck each (not sure about shipping, comes from Hong Kong, some stuff free shipping some not). That's one place i frequently check for the odd bits for PC and audio stuff...
Probably plenty of local places carry them too, just never looked.
Bigus is online now
post #4 of 4 Old 01-09-2013, 06:33 AM
Ratman's Avatar
Quoted: 1271 Post(s)
Liked: 1022
Ratman is online now
