Lack of BASS while playing itunes on my new HT setup. HELP! - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 64 Old 06-11-2013, 12:31 PM
krabapple's Avatar
Quoted: 385 Post(s)
Liked: 372
Originally Posted by sealteamz6 View Post
I see. Well I already understand flac is lossless ans superior to mp3. Basically I am saying I kinda doubt I would notice a difference. But I can't know for sure until I test
Correct!
If you use a PC, you can download a free player called foobar2000, which comes with an ABX comparison tool. It''s a great way to test for audible difference between files on your own.
krabapple is online now
post #62 of 64 Old 06-11-2013, 12:33 PM
krabapple's Avatar
Quoted: 385 Post(s)
Liked: 372
Originally Posted by Ysay View Post
FLAC is not supported by iPod. You will have to use Apple lossless or other supported format to listen to your music. I prefer uncompressed format on my iPod Classic to get the best SQ out of my iPod. If you're happy with the SQ of your MP3, then you're set and all you have to do enjoy.
Apple Lossless (ALAC) would get you exactly the same SQ from your iPod, and the files would be smaller (assuming your iPod supports ALAC in the first place)
post #63 of 64 Old 06-18-2013, 01:13 PM
Point Source
beastaudio's Avatar
Quoted: 3509 Post(s)
Liked: 2831
So did you ever figure out why you are not getting any bass though? Since that is after all the name of the thread?
beastaudio is online now
post #64 of 64 Old 06-21-2013, 11:59 PM
krabapple's Avatar
Quoted: 385 Post(s)
Liked: 372
He fixed it back in post #16 when he discovered bass management.
Yamaha Rx A710bl Receiver
