Neo:X 7.1 - Wides a bit too directional - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 01-13-2013, 10:11 PM - Thread Starter
BB1111's Avatar
Quoted: 80 Post(s)
Liked: 32
Hello,
I've been running 7.1 with my NR818 for a few months now and I feel like the wides are being too directional, I can easily make out where the sound is coming from versus having it seemless like with the surrounds.
I currently have them wall mounted at 60 degrees with the tweeters about a foot about ear level. The stereo mains are electrostatics and the wides are not, but in the same series of speaker. Also I'm wondering if wides are right for this room, the front part is only 12' wide and one wide (left) is closer than the right, the right is in the ideal position but only about 4-5 feet from the ESLs.
Another option is also using heights or rear surrounds. The heights would be 8' up and the rear surrounds would be 10 feet into the back of the room maximum.
Appreciate any advice on making them blend in better.
BB1111 is offline
post #2 of 12 Old 01-14-2013, 08:07 AM
commsysman's Avatar
Quoted: 970 Post(s)
Liked: 522
It sounds to me as if you are trying to cram 10 pounds into a 5-pound bag.
I suggest you go to a 5.1 system and optimize it.
The result may be far more satisfying.
commsysman is online now
post #3 of 12 Old 01-14-2013, 09:32 AM
sdurani's Avatar
Quoted: 4485 Post(s)
Liked: 2905
A couple of things you can do to make the Wides less distracting: lower their volume level and/or point them to the person at the opposite end of the couch (e.g., point the Left Wide to the person on the right side of the couch).
If you decide to change them to Heights, I would keep the same ±60° location but mount them as high up as possible. I prefer this to mounting them high above the Front L/R speakers because it gives a sense of sound above you rather than just a taller soundstage.
My first choice would be to use those speakers as Rears, placed behind you and spread at least 60° apart. However, in order get proper rear-vs-side separation in the surround field, you'll need to place the Side speakers directly to your sides (±90°). With 10 feet of space behind you for the Rear speakers, you're an ideal candidate for the traditional 7.1-speaker layout. There's also a lot of movies mixed for that speaker configuration.
Sanjay
sdurani is online now
post #4 of 12 Old 01-15-2013, 03:20 PM - Thread Starter
BB1111's Avatar
Quoted: 80 Post(s)
Liked: 32
Got an update here
I angled the wides a bit differently and it made a nice difference, a lot less directional now which is great.
But one other thing is that while playing between DTS:Neo X modes and DSX + Dynamic EQ I found that with Dynamic EQ a ton of my mid-bass came back while with DTS: Neo X it was missing when I was using only Re-EQ.
To get the same effect with DTS:Neo X on should I run it with just Dynamic EQ and Re-EQ off? Also what is the difference when it is running DTS:Neo X + THX Cinema?
Thanks..
BB1111 is offline
post #5 of 12 Old 01-15-2013, 03:24 PM
Kamikaze13's Avatar
Quoted: 100 Post(s)
Liked: 49
Neo x adds the 6th and 7th channel on 5.1 material.
VIDEO: JVC DLA-RS57U Projector / 122″ EluneVision Reference Studio 4K Cinemascope Screen - Oppo BDP-103 Blu-Ray Player - PlayStation 3 AVR: Anthem MRX-1120 SPEAKERS: Paradigm Monitor 11 Mains - Paradigm Monitor CC-390 Center - Paradigm Monitor ADP-390 Surrounds x 4 - Polk MC60 Atmos Ceiling x 4 SUBWOOFERS: SVS PB2000 / Velodyne DPS-12
Kamikaze13 is online now
post #6 of 12 Old 01-15-2013, 04:12 PM
sdurani's Avatar
Liked: 2905
And adds the 8th and 9th channel, and 10th and 11th channel.
Basically, Neo:X scales 2-channel or 5.1-channel material to (upto) 11 speakers.
Sanjay
post #7 of 12 Old 01-15-2013, 04:18 PM - Thread Starter
BB1111's Avatar
Quoted: 80 Post(s)
Liked: 32
DSX was playing the wides also. I was doing 7.1.
I'm asking why I had more mid-bass with DSX versus using Neo:X
BB1111 is offline
post #8 of 12 Old 01-15-2013, 05:04 PM
sdurani's Avatar
Liked: 2905
Originally Posted by BB1111 View Post
Sorry, just making a general comment about Neo:X, not specific to your set-up.
You were using loudness compensation (Dynamic EQ) with DSX. Was Dynamic EQ on when listening to Neo:X?
Sanjay
post #9 of 12 Old 01-15-2013, 05:23 PM - Thread Starter
BB1111's Avatar
Quoted: 80 Post(s)
Liked: 32
Appreciate your replys sdurani
For the last two months I was using DTS:X Cinema + THX Cinema setting with RE-Eq enabled and no Dynamic EQ.
Today after trying DSX with Dyn. EQ I realized how much of my mid-bass was missing (I normally listen at -10 or -5)... I've tried DTS:X with Dynamic EQ only and also with Dyn. EQ and Re-EQ but the highs were overly bright both times and was too fatiguing. When I use just Re-EQ with THX Cinema the highs were good but the midbass was missing.
Just confused on why this is happening. Does DSX apply it's own curve? I was using Audyssey "Movie" in all instances.
BB1111 is offline
post #10 of 12 Old 01-15-2013, 05:46 PM
sdurani's Avatar
Liked: 2905
Yes, because our human hearing varies across frequencies AND changes depending on level. As you lower the volume, we hear the low frequencies drop off faster than the rest of the range.
So receivers have loudness compensation (Audyssey Dynamic EQ, THX Loudness Plus, Dolby Volume) in order to compensate for our hearing by boosting the low frequencies more and more as you lower the volume. This selective boosting gives the impression that the bass is staying as loud as the rest of the frequencies.
The bass difference you were hearing wasn't due so much to DSX wides vs Neo:X wides but more due to having Dynamic EQ on vs having it off. If you leave Dynamic EQ on for all modes, their bass should sound similar.
Sanjay
post #11 of 12 Old 01-15-2013, 06:54 PM
Kamikaze13's Avatar
Quoted: 100 Post(s)
Liked: 49
I believe loudness plus diverts the all the bass from your mains to your sub, hence more mid bass?
post #12 of 12 Old 01-15-2013, 10:27 PM - Thread Starter
BB1111's Avatar
Quoted: 80 Post(s)
Liked: 32
After some testing I've found Dyanmic EQ to give a better overall sound, it was similar with Neo:X but I liked DSX a little bit more
BB1111 is offline
