Receiver settings when watching movies. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-16-2013, 11:46 AM - Thread Starter
cdnjeepin's Avatar
I always wondered what my settings should be when watching movies.
First off I have a Yamaha RXA720 receiver.
When I am watching movies should it be set to Yamaha's CinemaDSP say in Standard or should I be using something else?
It has Dolby Pro Logic, PLIIx Movie, PLII movie, Neo:6 Cinema
But I can also play it in Straight mode which will produce unprocessed multichannel sounds for multichannel sources.
I play movies either through Netflix, DVD's through Xbox and I stream from my NAS with the xbox too, all the movies on my NAS are either AAC or 5.1
cdnjeepin is offline
post #2 of 5 Old 01-16-2013, 11:48 AM
Kamikaze13's Avatar
Quoted: 99 Post(s)
Liked: 49
I have always used straight and then switch to neo or a different sound mode when needed.
VIDEO: JVC DLA-RS57U Projector / 122″ EluneVision Reference Studio 4K Cinemascope Screen - Oppo BDP-103 Blu-Ray Player - PlayStation 3 AVR: Anthem MRX-1120 SPEAKERS: Paradigm Monitor 11 Mains - Paradigm Monitor CC-390 Center - Paradigm Monitor ADP-390 Surrounds x 4 - Polk MC60 Atmos Ceiling x 4 SUBWOOFERS: SVS PB2000 / Velodyne DPS-12
Kamikaze13 is online now
post #3 of 5 Old 01-16-2013, 11:52 AM
rnconync's Avatar
Liked: 33
I have been trying to figure this out for a while with my Yamaha receiver...I'm not sure what setting I should ever be on to listen to the source material properly...What I have ended up doing from all the reading I have done is just setting the receiver to "STRAIGHT" for pretty much any source and leaving the PLIIx on for just about everything(since I have a 7.1 setup)...I have to manually switch the PLIIx on a lot of the time...and it seems most of the stuff comes through without a flag, but I am assuming it is because of my older HT-5760 receiver and using the newer Lossless tracks on the movies I have been watching lately...they come across as a higher quality audio than regular DVD's, but not the full uncompressed signal since my receiver can't handle it because of it's age.
As a note on my receiver I can use PLIIx on both DTS and DD signals, so I never mess with ES/EX Matrix etc. anymore....also from what I have read, most all of these other settings on my older receiver (ES/EX, matrix) are for 6.1 and creating a mono rear center (6.1) or mono dual rear surround speaker signals whereas the PLIIx from what I read creates a stereo signal for the two surround back speakers taking from each the left and right channels for each respective speaker.
Some people seem to prefer the surround enhanced mode or Movie "Spectacle" modes and all...but I tend to leave my on the settings mentioned above..
rnconync is offline
post #4 of 5 Old 01-16-2013, 11:55 AM
Kamikaze13's Avatar
Quoted: 99 Post(s)
Liked: 49
Same with my RX-V2700, it can't process the HD codecs so I leave it on straight. I can't remember if you can turn on neo with straight mode selected to get your 7 channel from 5 channel sources.
post #5 of 5 Old 01-16-2013, 12:20 PM - Thread Starter
cdnjeepin's Avatar
Well it looks like I will try the "Straight" tonight when I get home.
might have to try the Dolby TrueHD, and the DTS-HD master audio
