SUB- Distance ( Delay ) ??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-17-2013, 05:45 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
How can different Distance settimgs for the Sub be seen with REW ??
randyc1 is offline
post #2 of 3 Old 01-17-2013, 07:32 PM
xianthax's Avatar
Assuming your playing broadband noise. The largest indicator will be the integration between the sub and your main speakers. You want the lowest delay possible without causing cancelation with the main speakers. This will appear as a dip in the frequency response around the cross-over point with the main speakers. e.g. you have a crossover at 80hz, if the delay isn't in sync with the mains you will see a dip in the frequency response around 80hz. The only caveat to this is if your room has modes at your measurement position that line up with the cross over point, measure the sub alone to find these first.
xianthax is offline
post #3 of 3 Old 01-17-2013, 08:26 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
What i had tried was getting the FR of the mains alone , then i took a FR of the subs alone at 12' then one at 18' . The 2 sub sweeps where identical compared to the Mains ??
randyc1 is offline
