Pioneer vsx-822-k no subwoofer sound - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By stewpid2
  • 1 Post By bizwiz41
post #1 of 24 Old 01-18-2013, 08:34 AM - Thread Starter
willduggins's Avatar
Hey Everyone,
First post here so I wasn't sure whether or not to post here or in the Subwoofer forum. Either way hopefully someone can help me with my problem. I have a Pioneer vsx-822-k receiver powering two Paradigm Millinia 300 front speakers and a Polk PSW505 woofer. I want to stick with a 2.1 setup. The Paradigm fronts are working perfectly but the subwoofer is giving me issues. I have a subwoofer cable running from the "Pre-out Sub" output on the receiver to the LFE input on the sub. When I utilize the pioneer MCACC microphone assisted setup both the speakers and the sub can be heard. So basically this tells me the sub is getting a signal from the receiver and is hooked up properly (maybe??). Anyway, any other source such as music from my PS3, PS3 games, PS3 blu-ray, and even an ipod hook up from a headphone jack to rca cable do not give me any sound from the subwoofer.
I've also tried the manual setup which let me set the front speakers to small, subwoofer to "yes", and then set the cross over to 80 hz. Still no luck. Thanks for the help!
Will
willduggins is offline
post #2 of 24 Old 01-18-2013, 09:22 AM
baniels's Avatar
Quoted: 219 Post(s)
Liked: 350
Check your listening mode. Your receiver may be defaulting to a "Direct" or "Pure" mode. In that case, it will apply no processing, including crossing the signal over to the sub. Now, if you were to play a 5.1 signal in this mode, it would send the LFE to the sub, since that is what was intended, but still no low-pass info from the other channels would go to the sub.
With a stereo 2.0 source, look for a "Stereo" listening mode, which should lowpass some content to the sub.
baniels is offline
post #3 of 24 Old 01-18-2013, 09:48 AM - Thread Starter
Thanks for the response baniels. I've changed the listening modes from stereo to all of the various "surround" modes. Still nothing from the sub. Could it be related to the LFE hookup? Is there a different/better way of hooking up the sub other than using the Pre-out sub outlet on the receiver?
post #4 of 24 Old 01-18-2013, 10:44 AM
baniels's Avatar
Quoted: 219 Post(s)
Liked: 350
Hmm. No, that sounds right. The working setup/test tones confirm proper connections.
Fine tooth the manual for listening mode specifics. Keep an eye out for the word Pure and how to disable that mode.
Also try a surround source and see if you get sub output.
baniels is offline
post #5 of 24 Old 01-18-2013, 11:21 AM
fbov's Avatar
Quoted: 262 Post(s)
Liked: 151
Have you tried the radio? This would eliminate any sort of connections as the source.
Speaking of... how are you connecting devices, analog or digitall? Have you mapped inputs correctly?
Baniels is hitting the likely suspects, beyond the basic settings you mention (small, yes and 80Hz).
Are you sure there's LF content in the program?
Have you been through all the menu options (in addition to the manual) looking for Pure or Direct or any options that lack "0.1" content?
Try TV; sports are all surround and many prime time shows have a lot of bass (Castle, The Mentalist to name a couple).
Have fun,
Frank
fbov is offline
post #6 of 24 Old 01-18-2013, 02:33 PM - Thread Starter
All,
Thanks for the responses. I've finally figured it out. The issue lies with the Pioneer vsx-822-k receiver. In the setup menu the speakers have to be set to small, the subwoofer to yes, and the crossover to 100 hz or greater. Using the MCACC didn't work for me. It kept omitting the sub from the outputs for some reason. I had to do a full manual setup. Seems to be working now. Thanks again for the responses.
Will
post #7 of 24 Old 01-18-2013, 04:10 PM
baniels's Avatar
Quoted: 219 Post(s)
Liked: 350
Must cross at 100hz or higher? That can't be right.
baniels is offline
post #8 of 24 Old 03-18-2013, 03:54 PM
jaymcd0626's Avatar
can you share what you ended up setting your speakers and sub at. I have the VSX-822 as well. I get low to no sub, voices are quieter than music and background, and I have to turn my volume pretty high to get sound.
Jay
jaymcd0626 is offline
post #9 of 24 Old 03-27-2013, 11:57 AM
stewpid2's Avatar
We have the same issue and this is what I did...
1. Turn on the receiver and tv
2. Press the bottom receiver button on your remote control. (not the top button that's for power)
3. Press tv on your remote control then press the home button. The home button is located on left side of your remote control on the middle. It's a small button.
4. The home menu appears on your tv.
5. Select #2 ( manual SP Setup) by pressing the tune button then press enter.
6. Select (A) Speaker Setting press enter on remote control then set your front speakers to SMALL
7. Using the tune button select subwoofer then set to YES. Press return and it'll go back to Manual SP Setup.
8. Using the tune button again select (B) X.Over enter select then set frequency to 80 or 100Hz your choice. Press return.
9. Tune button again select (C) Channel Level press enter then press enter for test tune. Make adjustment for your L and R front speakers and your subwoofer. After you were done all the adjustment and satisfied the output simply press the return button to exit the home menu.
On my power subs I set the crossover to max, gain is halfway. This is just me you can tweak your sub the way you want.
Hope this help.
hiltinuts2 likes this.
stewpid2 is offline
post #10 of 24 Old 03-28-2013, 08:40 AM
McStyvie's Avatar
Liked: 78
Doesn't sound right...80 HZ is usually the recommended XO point, but ofc, most go from 60 - 120 or more or less depending on speakers/sub. In otherwords, there is another issue at play here.
McStyvie is offline
post #11 of 24 Old 05-08-2013, 10:04 PM
dcheez's Avatar
I have a VSX-822 and I'm trying to hook up a Harmon Kardon SB16 soundbar to it. I've connected the soundbar to the receiver via the optical cable but I get zero sound from it. The optical input says "optical assignable", but I don't know where to program it. Is the optical where the soundbar receives the audio out? I'm new to this. When I put the system to Cable I get the clear picture on my tv coming from the cable box but zero sound. The sub connects wirelessly to the soundbar so there's no wires to connect to the receiver. I'm not sure that this receiver is built for a soundbar.
dcheez is offline
post #12 of 24 Old 05-09-2013, 06:21 AM
bizwiz41's Avatar
Quoted: 14 Post(s)
I agree the crossover should be set to 80Hz, and I believe this AVR is capable of that setting. One of the issues here is that we are speaking about "Stereo" mode for music. I have a Pioneer AVR also, and have noticed this same "issue" of the subwoofer "seeming" to not output bass.
One of the variables I've noticed is that it depends upon the song/music has to actual bass content and level. Some music does play through, others do not.
Now my speaker set up is completely different; I have two Polk towers as mains, and each has a powered sub built in. How I initially remedied this was to set the fronts to "Large", and set the sub to "PLUS". Setting the sub to "PLUS" sends duplicate bass (not just LFE or below XO) to the sub. I think this is the affect you are seeking (when it comes to music listening).
Again, the real culprit is the media, some songs just do not have the lower levels, hence why you must set your XO to 100Hz. Considering that you are using a 2.1 set up, you may want to consider setting your fronts to "Large" and your sub to "PLUS", if you like/want more bass.
pbaxter likes this.
Sometimes I have to remind myself that I bought all this "stuff" to enjoy it!
bizwiz41 is offline
post #13 of 24 Old 05-09-2013, 07:31 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
I wish you all of the luck in the world because you'll need it.
As a rule AVRs are not designed to drive soundbars and soundbars are not designed to be driven from AVRs.
Let's review the relevant facts. The sound bar has an optical input. It is designed to be connected to an optical output, which can be commonly found on a TV set or a DVD/CD/Blu Ray player.
Accroding to the specs for this AVR
http://www.pioneerelectronics.com/PUSA/Home/AV-Receivers/Pioneer+Receivers/VSX-822-K
It has no digital audio outputs whatsoever.
I'm sure that this AVR is not designed for use with a soundbar, especially via a digital input. Most aren't.
Soundbars and AVRs are actually similar devices. A Soundbar is roughly equivalent to an AVR + a set of regular unpowered speakers.
Your soundbar was probably designed to plug into the optical output of your TV. Try it there!
arnyk is offline
post #14 of 24 Old 05-09-2013, 07:56 AM
bizwiz41's Avatar
Quoted: 14 Post(s)
arnyk is correct that this will not work. The Pioneer VSX-822-K will not drive a sound bar. There are no audio "digital out" connections on the VSX-822-K. The "assignable" you see on the AVR means you can assign that input to any of the component inputs on the AVR.
To use the sound bar, you will need to connect it to the "Digital Out" on your TV or cable box. You can connect two (outputting) sources to the sound bar, as long as one is analog and the other digital.
You do not mention how you have the TV and cable box connected (i.e. thru AVR via HDMI cable, or direct to TV from cable box). I'm assuming you have an HDMI running from the cable box to the AVR, and are looking to run audio through the soundbar. In this case run the audio directly to the soundbar from the TV.
I am simply curious as to why you would want both a soundbar and an AVR? Are you trying to use the soundbar as a speaker or set of speakers?
bizwiz41 is offline
post #15 of 24 Old 05-09-2013, 08:36 AM
fbov's Avatar
Quoted: 262 Post(s)
Liked: 151
Guys, let's be clear here...
You can't drive an active soundbar with an AVR, since by definition, an active speaker already contains an amplifier.
One should still be able to use the AVR for switching, assuming line outputs on the AVR audio so you can get the signal to the soundbar. Quite a waste of amplification, though...
HAve fun,
Frank
fbov is offline
post #16 of 24 Old 11-27-2013, 08:46 AM
hiltinuts2's Avatar
Hope this help.
Thank you very much for this post. This worked perfectly with my new 823k and Polk PSW10.
hiltinuts2 is offline
post #17 of 24 Old 11-02-2014, 03:29 AM
Liked: 0
Hello everyone..
I have problem with my av receiver 822k,the problem is it no sound at front right speaker during listen to radio and watch video..but,if I change listen to usb port,the speaker no problem,all speaker function..what exactly the problem is it?i got this problem 2 time already and no more warranty..can some one help me solve this problem?
aziq91 is offline
post #18 of 24 Old 06-18-2015, 06:33 AM
stryfetew's Avatar
Thank you! I was beating my head against the wall trying to figure out what was occurring.
stryfetew is offline
post #19 of 24 Old 08-20-2015, 07:59 AM
pbaxter's Avatar
Originally Posted by bizwiz41 View Post
<div class="quote-container" data-huddler-embed="/t/1452709/pioneer-vsx-822-k-no-subwoofer-sound#post_23136142" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>McStyvie</strong> <a href="/t/1452709/pioneer-vsx-822-k-no-subwoofer-sound#post_23136142"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
Doesn't sound right...80 HZ is usually the recommended XO point, but ofc, most go from 60 - 120 or more or less depending on speakers/sub. In otherwords, there is another issue at play here.</div>
</div>
<br>
I agree the crossover should be set to 80Hz, and I believe this AVR is capable of that setting. One of the issues here is that we are speaking about "Stereo" mode for music. I have a Pioneer AVR also, and have noticed this same "issue" of the subwoofer "seeming" to not output bass.<br><br>
One of the variables I've noticed is that it depends upon the song/music has to actual bass content and level. Some music does play through, others do not.<br><br>
Now my speaker set up is completely different; I have two Polk towers as mains, and each has a powered sub built in. How I initially remedied this was to set the fronts to "Large", and set the sub to "PLUS". Setting the sub to "PLUS" sends duplicate bass (not just LFE or below XO) to the sub. I think this is the affect you are seeking (when it comes to music listening).<br><br>
Thanks! Setting SUB to PLUS and XOVER to 100Hz got the subwoofer working again
pbaxter is offline
post #20 of 24 Old 07-08-2016, 08:40 PM
Liked: 0
I'm wondering if someone could figure this out. Wondering if resurecting an older forum will bring the right helpers back...
I just got a new Polk Audio DSW pro440wi 8" sub. As I was hooking it up I wasn't getting sound, so I checked through my Pioneer VSX 822 settings. As mentioned above, I went through the speaker setup. Set my front, centre, and surrounds to 'small'. However, there's no subwoofer option. Just F, C, S, and SB. Has anyone come across this? My 822 manual says there should be: F, C, S, SB, and Subwoofer.
Any tips? The new sub is up and running..remote isn't working though.
Joel
insane_snowman is offline
post #21 of 24 Old 07-09-2016, 12:43 AM
Yosh70's Avatar
Quoted: 194 Post(s)
Liked: 138
You have the sub cable inserted properly in the pre-out on the back of the receiver? Is the blue light on the sub "on"?
The manual speaker settings on the receiver should give you the option of a subwoofer, yes or no...Im not sure what you're missing.
Yosh70 is offline
post #22 of 24 Old 07-09-2016, 10:52 AM
Liked: 0
Hi Yosh70, Update..the sub is working great now (the volume may have been too low initially). The sub cable is properly installed and the blue light is on. However the initial issue remains with the receiver. Not sure if its an issue worth worrying about, since the sub is working...but the settings in the receiver are missing the option:
There's no subwoofer option under what my receiver shows:
2. Manual SP Setup > 2a. Speaker Setting >. F, C, S, and SB. My 822 manual says there should be: F, C, S, SB, and Subwoofer.
Secondary issue, that blue light you mention can only be turned off with the remote..which currently isn't working. Still looking for a different battery to see if that's the issue.
post #23 of 24 Old 07-09-2016, 04:21 PM
Yosh70's Avatar
Quoted: 194 Post(s)
Liked: 138
Weird no subwoofer option....maybe peruse the Pioneer forum or contact Pioneer support. But at least you're getting LFE content anyways.
As for the remote, its flaky at times (I have the same sub) but it does work after numerous pushes of the buttons
I have mine setup front firing and auto on (sub comes alive and blue light comes on when there is .1 signal)
Very nice sub for the money and my small room, .
Yosh70 is offline
post #24 of 24 Old 07-09-2016, 05:17 PM
Liked: 0
Thanks for the reply. A new battery did the trick! Turns out the remote was sent with a dead battery... Yeah the sub is solid in my small living room, size and power wise. I received it for $300 new..not a bad deal.
I posted the receiver question on the VSX 822 forum. Thanks for the tips.
