LPCM vs.Dolby TrueHD vs. DTS-HD Master Audio - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: LPCM vs. Dolby TrueHD vs. DTS-HD Master Audio
LPCM 24 35.29%
Dolby TrueHD 14 20.59%
DTS-HD Master Audio 30 44.12%
Voters: 68. You may not vote on this poll
 3Likes
post #1 of 87 Old 01-18-2013, 12:31 PM - Thread Starter
PlayNice's Avatar
Quoted: 185 Post(s)
Liked: 174
I was just wondering, what do you hope for in you sound mixes? Are you a Dolby kinda person or does LPCM get you going, me I have a soft spot for DTS-HD Master Audio. When you purchase a new Blu-Ray and look on the back what are you hoping to see? No need to argue why you format of choice is better, just plain fun here.
Vizio 80" 3D LED M801D-A3 ISF Calibrated | Onkyo TX-NR818 w/ Polk Monitor 50 (Fronts), Onkyo SK-520 (Surronds), SKW-770 (Sub) | Win 8.1 PC i7 3930k, 2 SLI GeForce 770's, 32GB RAM | Mac Mini 2011 i5 2.3Ghz, 16 GB RAM w/ PLEX | Roku 3 | Oppo BDP-103D | Xbox One, PS4, Wii U, Xbox 360 S, PS3 Slim | Harmony Touch
PlayNice is offline
post #2 of 87 Old 01-18-2013, 12:54 PM
sdurani's Avatar
Quoted: 5123 Post(s)
Liked: 3605
Considering all three of the choices you listed result in bit-for-bit identical soundtracks, it's like asking whether you prefer to open up files that were compressed using Zip or RAR. BTW, I'm not arguing with you, just plain having fun.
Sanjay
sdurani is offline
post #3 of 87 Old 01-18-2013, 12:58 PM
marcusj0015's Avatar
THEY'RE. ALL. LOSSLESS. if your player or receiver can decode them all, it means jack ****. if they can't, your blu-ray player will just decode DTS-HD MA or TrueHD to PCM anyway.
Now if you're talking about making an MKV, I prefer using FLAC because it compresses better.
I prefer TrueHD, because it's format is cleaner and less complicated, DTS-HD MA has a lossy DTS track inside, with a diff contained in external channels, it's complicated, but the decoder has to combine the diff and the DTS to get back the lossless audio, TrueHD takes up less space and can easily be decoupled from it's AC3 extension, unlike DTS-HD MA.
marcusj0015 is offline
post #4 of 87 Old 01-18-2013, 02:03 PM - Thread Starter
PlayNice's Avatar
Quoted: 185 Post(s)
Liked: 174
I understand you say these are all "lossless" however they do differ in a way Max. Bitrate on the Blu Ray disk. I do not know if this is a limitation of the disk itself or the format but they are as followed.
LPCM = 27.648 Mbit/s
Dolby TrueHD = 18.64 Mbit/s
DTS-HD MA = 24.5 Mbit/s
This shouldn’t effect sound quality as nothing as of yet tops the scale but there are differences.
PlayNice is offline
post #5 of 87 Old 01-18-2013, 03:12 PM
sdurani's Avatar
Liked: 3605
Since this doesn't affect sound quality, on what do you want people to base their answer to your question: "When you purchase a new Blu-Ray and look on the back what are you hoping to see?"
Your original post is the eqivalent of you getting 3 identical documents and then saying that you have a "soft spot" for the one that arrived in a medium sized envelope. Since the documents (soundtracks) are 100% exactly the same, are you asking people to decide based on what size envelope (compression codec) it came in?
Sanjay
sdurani is offline
post #6 of 87 Old 01-18-2013, 03:49 PM - Thread Starter
PlayNice's Avatar
Quoted: 185 Post(s)
Liked: 174
They a give lossless sound yes but they are compressed differently. I asked which do you prefer. I myself prefer DTS HD MA as the movies with this track sound more clear and crisp to myself. Now this is just personal preference just as I mentioned this is for fun no need to get into a war here.
I would be very interested to find a movie that was encoded with both tracks. Could be the same disk or two disk but then we could see is they are identical you know.
So stop being a bore and what do you prefer?
PlayNice is offline
post #7 of 87 Old 01-18-2013, 03:57 PM
William's Avatar
Quoted: 29 Post(s)
Liked: 50
They a give lossless sound yes but they are compressed differently. I asked which do you prefer. I myself prefer DTS HD MA as the movies with this track sound more clear and crisp to myself....
Oxymoron, three things that are the same can't ALSO be different (except in quantum mechanics). You have a vivid/subjective imagination but that is the only difference.biggrin.gif
Also riddle me this extreme contradiction: How can the DTS-Master track "sound more clear and crisp" than the original master (copy) LPCM track?eek.gif
William is offline
post #8 of 87 Old 01-18-2013, 05:12 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 191
PlayNice, perhaps you do not understand that the method of compression is irrelevant. What matters is the PCM produced by decompression. Lossless means the output is identical to the input. TrueHD and dts-MA are simply two different ways to achieve the exact same result. Take the same soundtrack and feed it into the Dolby and DTS encoders and the PCM outputs will be identical.
BIslander is offline
post #9 of 87 Old 01-18-2013, 05:44 PM
sdurani's Avatar
Liked: 3605
As I said in my first post, I'm not arguing with you, just plain having fun.
The lossless one of course.
Sanjay
sdurani is offline
post #10 of 87 Old 01-20-2013, 11:52 AM - Thread Starter
PlayNice's Avatar
Quoted: 185 Post(s)
Liked: 174
After placing in my disk of Close Encounters of the Third Kind I would say DTS-HDMA sounds more, how do I say it? Punchier than Dolbly TrueHD. That's just my thoughts. One of the few disk with both soundtracks, forgot I had it!
PlayNice is offline
post #11 of 87 Old 01-20-2013, 12:27 PM
William's Avatar
Quoted: 29 Post(s)
Liked: 50
You are being fooled by the old attenuation trick that louder = punchier. The TrueHD track's DN metadata is set at -31dB and HD Master is set at -27dB. Simply turn up the volume +4dB on TrueHD (or -4dB on DTS Master)and they will be 100% identical "Punchier".
EDIT: Read here for an understanding of Dialogue Normalization (poor nomenclature, but I didn't name it)
William is offline
post #12 of 87 Old 01-20-2013, 01:53 PM - Thread Starter
PlayNice's Avatar
Quoted: 185 Post(s)
Liked: 174
Thanks for clarify that for me, I started this thread just for fun to see what people prefer, know myself liked DTS more but that explains it I set reference using DTS so that us playing at reference and Dolby is 4dB under.
So I guess depending in how you set your system up would be how you get your sound.
PlayNice is offline
post #13 of 87 Old 01-20-2013, 02:25 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 191
For the sake of accuracy, the numbers are backwards in William's post. The default Dolby dialnorm value is -27, which tells the decoder to attenuate the overall volume by 4dB. The default DTS encoder DN value is 0 (-31), which means no attenuation.
The standard being employed says dialog should be played back at -31dBFS (below full scale). The decoder looks at the DN value in the metadata. The -27 value that Dolby uses by default tells the decoder that dialog is 4dB too high and the software lowers the overall output level. The 0 value that DTS uses by default tells the decoder that dialog is at the correct -31dBFS level and the software does no attenuation.
DN has never worked as intended. It is supposed to level out loudness differences between programs so that the volume doesn't jump up on commercials, for example. But, the person doing the encoding needs to determine the average dialog level of the program and enter that value in the metadata, which rarely happens. The people doing the encoding usually just accept the Dolby and DTS defaults, regardless of the actual dialog level. So, if the same soundtrack is encoded both ways, the DTS version will playback 4dB louder than the Dolby one.
post #14 of 87 Old 01-20-2013, 02:56 PM
pokekevin's Avatar
Quoted: 18 Post(s)
Liked: 102
I thought it was the other way around? -31 for DTS and -27 for Dolby (most of the times).
Also I thought they got rid of dialnorm when it came to bluray?
As for which one I prefer? I prefer DTS HD MA because I'm a DTS fanboy. Naw back in the days when I could only output audio with SPDIF with my HTPC, hd ma was the easier one to use with my ISO rips because it would revert to using the core DTS track. If it was Dolby, than I'd have to select the AC3 track manually thru my htpc. Not an issue anymore though.
pokekevin is offline
post #15 of 87 Old 01-20-2013, 03:02 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 191
No. DTS actually added dialnorm to its HD encoder. It is not part of the DTS Surround encoder. The usage hasn't changed much though.
post #16 of 87 Old 01-20-2013, 03:04 PM
pokekevin's Avatar
Quoted: 18 Post(s)
Liked: 102
Oh dts lol
So are all Dolby Tracks (TrueHD + AC3) set to -27? From what I can recall I thought the Dolby encoder (if thats what it is called) automatically sets the DN value to -27
post #17 of 87 Old 01-20-2013, 03:21 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 191
DN is a field in the metadata with allowable value from 31 to 1. The person doing the encoding enters a value. Or not. Dolby encoders default to 27. DTS encoders default to 31. Most of the time, encoding engineers simply accept the default values.
post #18 of 87 Old 01-20-2013, 03:22 PM
sdurani's Avatar
Liked: 3605
A good example of DialNorm being used on DTS tracks is the BD of 'Transformers 2: Revenge of the Fallen', where the Walmart exclusive Big Screen edition plays back 4dB quieter than the regular edition, despite the those two DTS-HD MA soundtracks being identical.
Sanjay
sdurani is offline
post #19 of 87 Old 01-20-2013, 03:23 PM
pokekevin's Avatar
Quoted: 18 Post(s)
Liked: 102
So even though Dolby encoders default at -27, would an AVR still show it as having an offset of -4?
post #20 of 87 Old 01-20-2013, 03:24 PM
pokekevin's Avatar
Quoted: 18 Post(s)
Liked: 102
I remember that causing a big stir on the Bluray forums lol.
post #21 of 87 Old 01-20-2013, 03:31 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 191
4 = 31-27, the amount that the decoder attenuates the level so that average dialog plays at the correct -31dBFS.
post #22 of 87 Old 01-20-2013, 03:40 PM
pokekevin's Avatar
Quoted: 18 Post(s)
Liked: 102
4 = 31-27, the amount that the decoder attenuates the level so that average plays at the correct -31dBFS.
The player automatically does it or do I need to raise the MV by 4?
post #23 of 87 Old 01-20-2013, 03:46 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 191
The decoder lowers the volume by the amount of the offset. You can counter the attenuation by raising the master volume the same amount.
post #24 of 87 Old 01-20-2013, 03:55 PM
pokekevin's Avatar
Quoted: 18 Post(s)
Liked: 102
I understand where the 4 comes from but what I meant was since -27 is the stock setting on the dolby encoder, would the avr still see an offset of -4? or does a setting of -23 show an offset of -4? Appreciate the help! biggrin.gif
post #25 of 87 Old 01-20-2013, 04:29 PM
sdurani's Avatar
Liked: 3605
If the player automatically did it, folks wouldn't be hearing DTS encodes 4dB louder than Dolby encoded tracks. So you have to raise the MV by 4dB on your receiver.
I have to admit that I'm never aware of which tracks have DialNorm and which don't, since I always set the MV to a comfortable level rather than going by a number on the front panel display.
Sanjay
sdurani is offline
post #26 of 87 Old 01-20-2013, 05:50 PM
pokekevin's Avatar
Quoted: 18 Post(s)
Liked: 102
I love looking at that front panel... lol!
btw when is the next GTG? I have a bunch more questions regarding my build!
post #27 of 87 Old 01-20-2013, 06:52 PM
sdurani's Avatar
Liked: 3605
We all have our hobbies.
Is a get together necessary for you to ask questions? Did you misplace your phone?
Sanjay
sdurani is offline
post #28 of 87 Old 01-20-2013, 06:54 PM
pokekevin's Avatar
Quoted: 18 Post(s)
Liked: 102
post #29 of 87 Old 01-21-2013, 01:59 AM
derrickdj1's Avatar
Quoted: 992 Post(s)
Liked: 731
They all will give you the same quality movie experience, the only difference is what is displayed on the avr/preamp.
derrickdj1 is offline
post #30 of 87 Old 02-01-2013, 12:34 PM
jungleland26's Avatar
I'm with you. I feel the discussion itself is very interesting. Sure, lossless is lossless. However the methods used to maintain such, while using different containers begs questions.
Before I render any opinions, I should note that I'm a deeply seasoned audiophile that's had everything from pioneer, denon, onkyo, marantz etc. Current setup is all mark levinson with wilson audio watt puppies and wilson audio center with one watchdog sub. Moving on..
I've done side by side comparisons with FLAC vs et al... My findings have been simple. FLAC performs in the audio space, just as it does on your storage space. It puts a lot into a small container. And that can be heard, at least by me (or perhaps it's the drugs talking). The soundstage sounds closer together and has noticeably less accuracy in reproduction...more distorted perhaps?
jungleland26 is offline
