What soundproofing products 'contain' the bass? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-19-2013, 12:15 PM - Thread Starter
Stealth3si's Avatar
Quoted: 32 Post(s)
What soundproofing products have the ability to contain the bass inside an untreated room so that a noticeable amount of bass that is escaping out of the room be significantly attenuated from the bass heard in an adjacent room?
I'm interested to know if there are soundproofing products to solve this acoustic problem and where I can buy them.
5.1 small-room size: 800 ft³+ 54 ft³ corner door space
AVR: Denon 1712
Fronts: Pioneer SP-BS41-LR /Center: Pioneer SP-C21 / Rear: Pioneer SP-BS21-LR
Subwoofer: SVS PC12-NSD
Screen: Samsung UN46EH6070 46" 1080p 3D LED 240 CMR TV
Viewing distance: 7.33 ft
Stealth3si is offline
post #2 of 8 Old 01-19-2013, 12:49 PM
Ethan Winer's Avatar
Quoted: 264 Post(s)
Liked: 359
Ethan Winer is offline
post #3 of 8 Old 01-19-2013, 06:57 PM
someoledude's Avatar
Quoted: 14 Post(s)
I purchased items from soundisolationstore.com and they have a lot of info on isolation techniques in general. I got an AVS discount, too, though I don't know if that is still offered.
someoledude is offline
post #4 of 8 Old 01-19-2013, 07:34 PM
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 689
Sealed doors, sealed room, hvac with multiple bends and lined, room in a room construction techniques,
mtbdudex is offline
post #5 of 8 Old 01-20-2013, 05:20 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
+1
One of the more stealthy room-in-room construction techniques is the wall with a separate set of studs for the inside wall and the outside wall. The floating floor is another one. I've seen ceilings floated by supporting the joists with nylon cords.
arnyk is offline
post #6 of 8 Old 01-21-2013, 02:08 PM
Nyal Mellor's Avatar
Quoted: 435 Post(s)
Liked: 312
EEK, really!? Did that pass building inspections?
Want to learn about home theater design and acoustics? Read our blog.
Company: Acoustic Frontiers - design and creation of high performance home theaters for discerning audio/video enthusiasts.
Certifications: HAA Level I & II, THX Video Level I & II, CEDIA EST I & II.
AVS Projects: Too many to show in my signature - see here for the master list.
Nyal Mellor is online now
post #7 of 8 Old 01-21-2013, 02:45 PM
William's Avatar
Quoted: 29 Post(s)
Liked: 50
Originally Posted by Ethan Winer View Post
Your best bet is probably Green Glue, available here:
http://www.soundproofingcompany.com/
--Ethan
I used room in room, multi layer drywall with Green Glue between and it works VERY well. Strong bass needs 2 things to significantly reduce it. Mass (drywall) and energy transformation. Green Glue turns acoustic energy to heat.
William is offline
post #8 of 8 Old 01-21-2013, 02:58 PM
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 689
$10 this same question will come up in 3-4 months.....like it has every 3-4 months.
And cables make a sound diff
And amps make sound diff
I'm just being sarcastic today - got caught in snow squall traffic jam going to Detroit auto show this morning, but a simple search would show up similar results.
mtbdudex is offline
