Connecting Mac Book Pro To Yamaha RX-657 - AVS Forum | Home Theater Discussions And Reviews
Old 01-19-2013, 12:26 PM - Thread Starter
mav52's Avatar
I gave my daughter a Yamaha RX-657 receiver ( no hdmi or USB) and she wants to connect her Mac Book Pro to the receiver to play music flies stored from iTunes. The receiver has 3 optical inputs and 2 coaxial inputs. The Mac has a USB, analog out and headphone that we assume we could use for a connection... Would taking the mac's analog out via toslink to the receivers optical input be the correct hook up method for the best sound. Will I also have to change anything in the mac books preferences to allow this to happen
mav52 is offline
Old 01-19-2013, 12:56 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
If by "analog out" you mean "audio out," then that should work. (Really old Macs did have analog-only out, but I'm pretty sure by the time the Macbook Pro came along they were using a combined digital/analog audio port.) You'll need a mini-Toslink-to-Toslink cable.
The Mac should detect whether you're using a digital or analog cable, and output accordingly. (I'm assuming you haven't previously set sound to output to USB.)
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
Old 01-19-2013, 01:01 PM - Thread Starter
mav52's Avatar
whoops, it is audio out... Thanks. She's heading down to radio shack/ best buy for a mini-toslink to toslink cable
mav52 is offline
