Grouning problem with Lepai Tripath amp, please help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-20-2013, 01:28 PM - Thread Starter
pascal210's Avatar
I really like my new Lepai Tripath Class-T amp (http://********/W9fPmF) but it produces a high pitched whine that really ruins it. When I touch the outside box it somewhat decreases. This makes me think it needs to be grounded. It takes a 12V adapter. Is there one that will ground it? I know a little about electronics, how could I ground it myself?
pascal210 is offline
post #2 of 8 Old 01-20-2013, 02:38 PM
xianthax's Avatar
What is the power supply your using?
If it has a ground prong on it, try it without the prong, e.g. use a 3 prong to 2 prong adaptor
xianthax is offline
post #3 of 8 Old 01-20-2013, 02:40 PM - Thread Starter
pascal210's Avatar
It doesn't have a 3rd prong, only two. Should I get one with three?
post #4 of 8 Old 01-20-2013, 03:02 PM
xianthax's Avatar
If you have one laying around, its worth a shot.
You've basically got some sort of ground loop going on. The strange thing is, if there is no ground at the AC/DC transformer (wall wart), then it should be floating.
I'm guessing the metal case of that amp is connected to its ground. Is it touching anything metal? Specifically anything metal that is also touching some of your other equipment?
xianthax is offline
post #5 of 8 Old 01-20-2013, 03:16 PM - Thread Starter
pascal210's Avatar
It's on a wood shelf, but next to two bookshelf speakers and a keyboard. I could get a photo if that would help.
Is there some way that I could add a ground wire, maybe soldered to some component in the board and then running somewhere else?
post #6 of 8 Old 01-20-2013, 04:30 PM
xianthax's Avatar
The safest thing to do is try a grounded 12v supply first. It may or may or fix the problem so it could be a complete waste of money, but should be ~$10 or something like that.
You can try grounding the chassis to see if that fixes it, but finding an earth ground to connect to can be potentially dangerous to you and the amplifier if your not familiar with what your doing.
Side question: What is plugged into it? Is there something plugged into both the RCA and 3.5 inputs?
xianthax is offline
post #7 of 8 Old 01-20-2013, 07:08 PM - Thread Starter
pascal210's Avatar
I have an iPod Classic plugged in through the RCA port. As a side note, I have my speakers bi-wired, and my 12V adapter is coming from a really nice power strip which is plugged into an outlet with the ground lifted (I live in an old house). The power strip says that "my equipment is protected" because a little LED with that title is on, but the other led in the actual power switch is flickering. Power isn't flickering though.
Anything look wrong here?
post #8 of 8 Old 01-20-2013, 07:35 PM
xianthax's Avatar
Well, both the amp and the ipod have virtual grounds, I don't actually see what could be causing the ground loop, if it is a ground loop.
My only guess is to try a grounded 12V supply.
xianthax is offline
