HELP: Use Soundbar for Center Channel Speaker? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-21-2013, 02:53 PM - Thread Starter
KCCOO's Avatar
I'd like to use a Soundbar for my Center Channel Speaker. How would I go about hooking it into my receiver without creating issues? My soundbar is a Magnavox - 2.1-Channel Soundbar System with Subwoofer (MSB5305), and my receiver is an Onkyo TX-NR414. The Center channel input on the receiver is a +/-, but the soundbar has it's own amp and has a L/R audio input. Can I make this work?
KCCOO is offline
post #2 of 3 Old 01-22-2013, 01:02 PM
fbov's Avatar
Quoted: 262 Post(s)
Liked: 150
Not likely...
The soundbar is far too sophisticated, given it contains amps, crossovers and some degree of signal processing. The only way to connect to your NR414 is as a center channel speaker, which involves modifications to the soundbar
- disconnect internal speakers from internal components
- connect speaker terminals directly to your amp's CC output.
Note this bypasses all the soundbar internals, including the sub, making it a passive speaker.
What would work even better is if your AVR had a pre-amp output for the CC that would go right to the soundbar.
The right way is to get a center channel speaker...
Have fun,
Frank
fbov is offline
post #3 of 3 Old 01-22-2013, 02:31 PM - Thread Starter
KCCOO's Avatar
Thank you--after much research--I finally found this info online--but you just put it to bed for me.
KCCOO is offline
