Recommendations for Surround Sound Setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-27-2013, 08:04 AM - Thread Starter
Franco20's Avatar
I'm hoping I can get some help setting up surround sound in my new home. Below is a picture of the area in question. I have a 47" TV that will be mounted right above the fireplace. The builders recommended installing the speaker wires in the ceiling, but after reading around it seems that would not be the best setup for surround sound. I was just hoping I could get some recommendations from some of you to determine where I should have my front 3 speakers. I plan on mounting the back 2 speakers on the ceiling. Thank you for any help/suggestions.
Franco20 is offline
post #2 of 6 Old 01-27-2013, 09:29 AM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 569
If that is to be a functioning fireplace, do not put your TV above it.
The screen will get damaged by smoke and the extra heat will void the warranty when the tech smells smoke on it.
It will also be too high for proper viewing.
commsysman is offline
post #3 of 6 Old 01-27-2013, 10:46 AM - Thread Starter
Franco20's Avatar
The fireplace will maybe be used 1 - 2 times a year. It has a blower that will blow the heat directly to the front. Another thing worth mentioning is that the ceiling fan in the picture will not be there. What I had in mind for the speakers was to mount the TV a little above the fireplace, and then mount the front left and right speakers a but above the TV and to the left and right next to the windows.
Franco20 is offline
post #4 of 6 Old 01-27-2013, 11:51 AM
Ethan Winer's Avatar
Quoted: 267 Post(s)
Liked: 363
I'd put the speakers just below the TV, with the left, center, and right all at the same height. Then place the surrounds also at ear height as explained in this short article:
How to set up a room
--Ethan
Ethan Winer is offline
post #5 of 6 Old 01-28-2013, 12:40 AM
mogorf's Avatar
Quoted: 1119 Post(s)
Liked: 714
mogorf is online now
post #6 of 6 Old 01-29-2013, 11:37 AM
Mister Bean's Avatar
I'll echo the others. I've watched movies in setups similar to what you're describing, and it's generally not a pleasant experience. It's uncomfortable looking up at a television for that much time. And sound seems strange when it's coming from the ceiling, or close to it.
Can you orient the room differently? From a design perspective I don't like to have conflicting focal points like a fireplace on one wall, and television on another. But the downsides of putting the television on that wall might outweigh that.
Mister Bean is offline
