In-wall cable used in conduit outdoors? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-27-2013, 03:39 PM - Thread Starter
Vaison's Avatar
I'm preparing to have a very large paver patio build and I am running 8 speakers on it, 4 more to follow later when the pool is built. I am seeking feedback about running 12awg monoprice in-wall cable through conduit and underground vs. using direct burial cable (I would still put this in conduit). Pricing for the direct burial cable is more than double from what I can find and monoprice does not sell direct burial. Any suggestions or thoughts on just using the in-wall cable through conduct?
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10239&cs_id=1023901&p_id=2818&seq=1&format=2
Vaison is offline
post #2 of 6 Old 01-27-2013, 07:46 PM
Glimmie's Avatar
Quoted: 732 Post(s)
Liked: 596
Yes, it's perfectly OK to use indoor wire with conduit outside.
Glimmie is offline
post #3 of 6 Old 01-28-2013, 12:18 PM
DonH50's Avatar
Quoted: 1797 Post(s)
Liked: 1333
Not in our county... Has to be UV-tolerant if above ground, rated for burial if below, even in conduit.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
post #4 of 6 Old 01-28-2013, 12:22 PM
Glimmie's Avatar
Quoted: 732 Post(s)
Liked: 596
That may be for class 1 wiring (line voltage) but it's not an issue for speaker wire. But still ask your local inspector if in doubt. I assume a construction project as described is being inspected so you want to make sure before you install the wire. The conduit is certainly within code.
Glimmie is offline
post #5 of 6 Old 01-28-2013, 07:47 PM - Thread Starter
Vaison's Avatar
Thanks for your responses. I couldn't cancel my purchase of the direct burial cable, so I am stuck with it now. But, I am a bit baffled on the setup of my system and just posted for assistance in the receivers section (if you guys read that part of the site). After looking at Glimmie's setup, I bet my question would be very simple to answer. That is one sick setup you have there. It looks like a tv station!
Vaison is offline
post #6 of 6 Old 01-28-2013, 08:19 PM
DonH50's Avatar
Liked: 1333
Oops, you are right, I was thinking of AC power cable. Speaker cable is treated as low-voltage wiring and code is a little looser. For me I'd probably use the UWG or whatever anyway just to be safe.
