Audio Feedback Problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-28-2013, 01:21 PM - Thread Starter
CyberKwyjibo's Avatar
Equipment
Receiver: Yamaha Natural Sound AV Receiver RX-V567
Satellite Box: DirecTV HD-DVR
Computer: Dell Optiplex 790
Issue
I am experiencing audio feedback through my speakers when I am using my Dell Optiplex computer through my receiver. It is connected to the receiver via a RCA-to-3.5mm cable. Also connected to the receiver is my DirecTV HD-DVR satellite box. It is connected to the receiver via HDMI.
It is the connection between the DirecTV box and the receiver via HDM that is causing the feedback problem when I am using my computer. When the input is selected on the computer, the audio feedback is instantly heard. As soon as I unplug the HDMI cable from the receiver, the feedback goes away. As soon as the HDMI cable gets plugged back in, the feedback returns. I have tried other ports for the connections, but the feedback continues. I've also switched out the HDMI cable, and I still get the feedback.
Does anyone know why when the computer input is selected that it would get feedback because of the connection of another device? I don't get any feedback when the DirecTV is selected as the input, only when computer is selected.
CyberKwyjibo is offline
post #2 of 6 Old 01-28-2013, 01:27 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Originally Posted by CyberKwyjibo View Post
Equipment
Issue
Is there a microphone or webcam attached to the computer?
arnyk is offline
post #3 of 6 Old 01-28-2013, 01:40 PM
SAM64's Avatar
Liked: 78
Probably a ground loop, and he's referring to hum as 'feedback'.
SAM64 is offline
post #4 of 6 Old 01-28-2013, 02:18 PM - Thread Starter
There is no microphone. The computer is also connected to a Sony Bravia HDTV and a Creative webcam, which does have a built-in microphone.
post #5 of 6 Old 01-28-2013, 02:19 PM - Thread Starter
I'm not sure if it's feedback, that was just my best guess. There is a humming noise, but again, I don't know if that's classified as feedback.
post #6 of 6 Old 01-28-2013, 02:36 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Humming noises are called hum or humming noises.
Whoda thunk? ;-)
Definitely not feedback!
You no doubt have a ground loop. Easiest fix is a Ground Loop Isolator - less than $20 at Radio Shack or any number of places on the web.
arnyk is offline
